--- ray/src/px/pfilt.c 1995/05/31 08:50:27 2.14 +++ ray/src/px/pfilt.c 2003/06/05 19:29:34 2.23 @@ -1,9 +1,6 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pfilt.c,v 2.23 2003/06/05 19:29:34 schorsch Exp $"; #endif - /* * pfilt.c - program to post-process picture file. * @@ -11,21 +8,18 @@ static char SCCSid[] = "$SunId$ LBL"; * 6/23/93 Added additional buffers for value spreading */ -#include "standard.h" - #include +#include "standard.h" #include "color.h" - -#include "resolu.h" - +#include "view.h" #include "paths.h" extern float *matchlamp(); #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b)) -double CHECKRAD = 1.5; /* radius to check for filtering */ +double CHECKRAD = 2.0; /* radius to check for filtering */ #define THRESHRAD 5.0 /* maximum sample spread in output */ @@ -64,6 +58,12 @@ int correctaspect = 0; /* aspect ratio correction? * int wrongformat = 0; +VIEW ourview = STDVIEW; +int gotview = 0; +int wrapfilt = 0; /* wrap filter horizontally? */ + +int estatus = 0; /* exit status (for non-fatal errors) */ + int xrad; /* x search radius */ int yrad; /* y search radius */ int xbrad; /* x box size */ @@ -84,8 +84,7 @@ main(argc, argv) int argc; char **argv; { - extern long ftell(); - extern int quit(), headline(); + extern int headline(); FILE *fin; float *lampcolor; char *lamptype = NULL; @@ -93,12 +92,9 @@ char **argv; double outaspect = 0.0; double d; int i, j; -#ifdef MSDOS - extern int _fmode; - _fmode = O_BINARY; - setmode(fileno(stdin), O_BINARY); - setmode(fileno(stdout), O_BINARY); -#endif + SET_DEFAULT_BINARY(); + SET_FILE_BINARY(stdin); + SET_FILE_BINARY(stdout); if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN); if (signal(SIGHUP, quit) == SIG_IGN) @@ -147,7 +143,7 @@ char **argv; fprintf(stderr, "%s: exposure out of range\n", argv[0]); - exit(1); + quit(1); } switch (argv[i][2]) { case '\0': @@ -197,7 +193,7 @@ char **argv; case 'm': thresh = atof(argv[++i]); if (rad <= FTINY) - rad = 1.0; + rad = 0.6; break; case 'b': rad = thresh = 0.0; @@ -267,6 +263,9 @@ char **argv; } if (!(order & YMAJOR)) inpaspect = 1.0/inpaspect; + /* wrap around for cylindrical view? */ + wrapfilt = gotview && ourview.type == VT_CYL && + ourview.horiz >= 360.-FTINY && order & YMAJOR; /* compute output resolution */ if (ncols <= 0) ncols = x_c*xres + .5; @@ -298,10 +297,30 @@ char **argv; } pass2(fin); - quit(0); + quit(estatus); } +double +rgb_bright(clr) +COLOR clr; +{ + return(bright(clr)); +} + + +double +xyz_bright(clr) +COLOR clr; +{ + return(clr[CIEY]); +} + + +double (*ourbright)() = rgb_bright; + + +int headline(s) /* process line from header */ char *s; { @@ -310,12 +329,19 @@ char *s; fputs(s, stdout); /* copy to output */ if (isaspect(s)) /* get aspect ratio */ inpaspect *= aspectval(s); - else if (isexpos(s)) + else if (isexpos(s)) /* get exposure */ hotlvl *= exposval(s); - else if (isformat(s)) { - formatval(fmt, s); - wrongformat = strcmp(fmt, COLRFMT); - } + else if (formatval(fmt, s)) { /* get format */ + wrongformat = 0; + if (!strcmp(COLRFMT, fmt)) + ourbright = rgb_bright; + else if (!strcmp(CIEFMT, fmt)) + ourbright = xyz_bright; + else + wrongformat = !globmatch(PICFMT, fmt); + } else if (isview(s) && sscanview(&ourview, s) > 0) + gotview++; + return(0); } @@ -358,11 +384,12 @@ FILE *in; progname, (int)(100L*i/yres)); yres = i; y_r = (double)nrows/yres; + estatus++; break; } pass1scan(scan, i); } - free((char *)scan); + free((void *)scan); } @@ -377,7 +404,7 @@ FILE *in; scan2init(); yread = 0; for (r = 0; r < nrows; r++) { - ycent = (long)r*yres/nrows; + ycent = (r+.5)*yres/nrows; while (yread <= ycent+yrad) { if (yread < yres) { if (freadscan(scanin[yread%barsize], @@ -394,7 +421,7 @@ FILE *in; if (obarsize > 0) scan2sync(r); for (c = 0; c < ncols; c++) { - xcent = (long)c*xres/ncols; + xcent = (c+.5)*xres/ncols; if (thresh > FTINY) dothresh(xcent, ycent, c, r); else if (rad > FTINY) @@ -430,9 +457,9 @@ scan2init() /* prepare scanline arrays */ rad *= (y_r + x_c)/2.0; if (thresh > FTINY) { - xrad = CHECKRAD*THRESHRAD*rad/x_c + xbrad; - yrad = CHECKRAD*THRESHRAD*rad/y_r + ybrad; orad = CHECKRAD*THRESHRAD*rad + 1; + xrad = orad/x_c + xbrad; + yrad = orad/y_r + ybrad; obarsize = 2*orad + 1; } else { xrad = CHECKRAD*rad/x_c + 1; @@ -475,7 +502,7 @@ scan2init() /* prepare scanline arrays */ fputaspect(d, stdout); } /* record exposure */ - d = bright(exposure); + d = (*ourbright)(exposure); if (!FEQ(d,1.0)) fputexpos(d, stdout); /* record color correction */ @@ -502,11 +529,11 @@ int r; int ybot; register int c; /* average input scanlines */ - while (nextrow < r+orad && nextrow < nrows) { - ybot = (long)nextrow*yres/nrows; + while (nextrow <= r+orad && nextrow < nrows) { + ybot = (nextrow+.5)*yres/nrows; for (c = 0; c < ncols; c++) { - dobox(ctmp, (int)((long)c*xres/ncols),ybot, c,nextrow); - greybar[nextrow%obarsize][c] = bright(ctmp); + dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow); + greybar[nextrow%obarsize][c] = (*ourbright)(ctmp); } /* and zero output scanline */ bzero((char *)scoutbar[nextrow%obarsize], ncols*sizeof(COLOR)); @@ -529,11 +556,12 @@ scan2flush() /* flush output buffer */ break; if (fflush(stdout) < 0) { fprintf(stderr, "%s: write error at end of pass2\n", progname); - exit(1); + quit(1); } } +void quit(code) /* remove temporary file and exit */ int code; {
