--- ray/src/px/pfilt.c 1990/12/08 13:23:47 1.14 +++ ray/src/px/pfilt.c 2003/10/22 02:06:35 2.27 @@ -1,62 +1,85 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pfilt.c,v 2.27 2003/10/22 02:06:35 greg Exp $"; #endif - /* * pfilt.c - program to post-process picture file. * * 9/26/85 + * 6/23/93 Added additional buffers for value spreading */ -#include +#include "copyright.h" #include +#include +#include "platform.h" +#include "standard.h" #include "color.h" +#include "view.h" +#include "paths.h" -extern char *malloc(); extern float *matchlamp(); -#define CHECKRAD 1.5 /* radius to check for filtering */ +#define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b)) +double CHECKRAD = 2.0; /* radius to check for filtering */ + +#define THRESHRAD 5.0 /* maximum sample spread in output */ + COLOR exposure = WHTCOLOR; /* exposure for the frame */ -double rad = 0.0; /* output pixel radius for filtering */ +double rad = 0.0; /* output pixel radius for filtering */ +double thresh = 0.0; /* maximum contribution for subpixel */ + int nrows = 0; /* number of rows for output */ int ncols = 0; /* number of columns for output */ -double x_c = 1.0; /* ratio of output x size to input */ -double y_r = 1.0; /* ratio of output y size to input */ +double x_c = 1.0; /* ratio of output x size to input */ +double y_r = 1.0; /* ratio of output y size to input */ int singlepass = 0; /* true means skip first pass */ int avghot = 0; /* true means average in bright spots */ -double hotlvl = 1000.0; /* level considered "hot" */ +double hotlvl = 100.0; /* level considered "hot" */ int npts = 0; /* (half) number of points for stars */ -double spread = 1e-4; /* spread for star points */ +double spread = 1e-4; /* spread for star points */ -#define TEMPLATE "/usr/tmp/pfXXXXXX" - char *tfname = NULL; +char template[] = TEMPLATE; + char *lampdat = "lamp.tab"; /* lamp data file */ +int order; /* scanline ordering of input */ int xres, yres; /* resolution of input */ -double inpaspect = 1.0; /* pixel aspect ratio of input */ +double inpaspect = 1.0; /* pixel aspect ratio of input */ int correctaspect = 0; /* aspect ratio correction? */ -int xrad; /* x window size */ -int yrad; /* y window size */ +int wrongformat = 0; +VIEW ourview = STDVIEW; +int gotview = 0; +int wrapfilt = 0; /* wrap filter horizontally? */ + +int estatus = 0; /* exit status (for non-fatal errors) */ + +int xrad; /* x search radius */ +int yrad; /* y search radius */ +int xbrad; /* x box size */ +int ybrad; /* y box size */ + int barsize; /* size of input scan bar */ COLOR **scanin; /* input scan bar */ COLOR *scanout; /* output scan line */ +COLOR **scoutbar; /* output scan bar (if thresh > 0) */ +float **greybar; /* grey-averaged input values */ +int obarsize = 0; /* size of output scan bar */ +int orad = 0; /* output window radius */ char *progname; @@ -65,30 +88,33 @@ main(argc, argv) int argc; char **argv; { - extern char *mktemp(); - extern double atof(), pow(); - extern long ftell(); - extern int quit(), headline(); + extern int headline(); FILE *fin; float *lampcolor; char *lamptype = NULL; long fpos; - double outaspect = 0.0; - double d; - int i; - + double outaspect = 0.0; + double d; + int i, j; + SET_DEFAULT_BINARY(); + SET_FILE_BINARY(stdin); + SET_FILE_BINARY(stdout); if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN); +#ifdef SIGHUP if (signal(SIGHUP, quit) == SIG_IGN) - signal(SIGINT, SIG_IGN); + signal(SIGHUP, SIG_IGN); +#endif signal(SIGTERM, quit); +#ifdef SIGPIPE signal(SIGPIPE, quit); -#ifdef SIGXCPU +#endif +#ifdef SIGXCPU signal(SIGXCPU, quit); signal(SIGXFSZ, quit); #endif - progname = argv[0]; + progname = argv[0] = fixargv0(argv[0]); for (i = 1; i < argc; i++) if (argv[i][0] == '-') @@ -121,6 +147,12 @@ char **argv; d = pow(2.0, atof(argv[i+1])); else d = atof(argv[i+1]); + if (d < 1e-20 || d > 1e20) { + fprintf(stderr, + "%s: exposure out of range\n", + argv[0]); + quit(1); + } switch (argv[i][2]) { case '\0': scalecolor(exposure, d); @@ -166,8 +198,13 @@ char **argv; case 'r': rad = atof(argv[++i]); break; + case 'm': + thresh = atof(argv[++i]); + if (rad <= FTINY) + rad = 0.6; + break; case 'b': - rad = 0.0; + rad = thresh = 0.0; break; default:; badopt: @@ -186,9 +223,9 @@ char **argv; fprintf(stderr, "%s: unknown lamp type\n", lamptype); quit(1); } - colval(exposure,RED) /= lampcolor[0]; - colval(exposure,GRN) /= lampcolor[1]; - colval(exposure,BLU) /= lampcolor[2]; + for (j = 0; j < 3; j++) + if (lampcolor[j] > 1e-4) + colval(exposure,j) /= lampcolor[j]; freelamps(); } /* open input file */ @@ -196,7 +233,7 @@ char **argv; if (singlepass) fin = stdin; else { - tfname = mktemp(TEMPLATE); + tfname = mktemp(template); if ((fin = fopen(tfname, "w+")) == NULL) { fprintf(stderr, "%s: can't create ", progname); fprintf(stderr, "temp file \"%s\"\n", tfname); @@ -219,14 +256,24 @@ char **argv; quit(1); } /* get header */ - getheader(fin, headline); + getheader(fin, headline, NULL); + if (wrongformat) { + fprintf(stderr, "%s: input must be a Radiance picture\n", + progname); + quit(1); + } /* add new header info. */ printargs(i, argv, stdout); /* get picture size */ - if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) { + if ((order = fgetresolu(&xres, &yres, fin)) < 0) { fprintf(stderr, "%s: bad picture size\n", progname); quit(1); } + if (!(order & YMAJOR)) + inpaspect = 1.0/inpaspect; + /* wrap around for cylindrical view? */ + wrapfilt = gotview && ourview.type == VT_CYL && + ourview.horiz >= 360.-FTINY && order & YMAJOR; /* compute output resolution */ if (ncols <= 0) ncols = x_c*xres + .5; @@ -258,16 +305,51 @@ char **argv; } pass2(fin); - quit(0); + quit(estatus); } +double +rgb_bright(clr) +COLOR clr; +{ + return(bright(clr)); +} + + +double +xyz_bright(clr) +COLOR clr; +{ + return(clr[CIEY]); +} + + +double (*ourbright)() = rgb_bright; + + +int headline(s) /* process line from header */ char *s; { + char fmt[32]; + fputs(s, stdout); /* copy to output */ if (isaspect(s)) /* get aspect ratio */ inpaspect *= aspectval(s); + else if (isexpos(s)) /* get exposure */ + hotlvl *= exposval(s); + else if (formatval(fmt, s)) { /* get format */ + wrongformat = 0; + if (!strcmp(COLRFMT, fmt)) + ourbright = rgb_bright; + else if (!strcmp(CIEFMT, fmt)) + ourbright = xyz_bright; + else + wrongformat = !globmatch(PICFMT, fmt); + } else if (isview(s) && sscanview(&ourview, s) > 0) + gotview++; + return(0); } @@ -301,20 +383,21 @@ FILE *in; } for (i = 0; i < yres; i++) { if (freadscan(scan, xres, in) < 0) { - nrows = nrows * i / yres; /* adjust frame */ + nrows = (long)nrows * i / yres; /* adjust frame */ if (nrows <= 0) { fprintf(stderr, "%s: empty frame\n", progname); quit(1); } fprintf(stderr, "%s: warning - partial frame (%d%%)\n", - progname, 100*i/yres); + progname, (int)(100L*i/yres)); yres = i; y_r = (double)nrows/yres; + estatus++; break; } pass1scan(scan, i); } - free((char *)scan); + free((void *)scan); } @@ -324,18 +407,18 @@ FILE *in; int yread; int ycent, xcent; int r, c; - + pass2init(); scan2init(); yread = 0; for (r = 0; r < nrows; r++) { - ycent = (long)r*yres/nrows; + ycent = (r+.5)*yres/nrows; while (yread <= ycent+yrad) { if (yread < yres) { if (freadscan(scanin[yread%barsize], xres, in) < 0) { fprintf(stderr, - "%s: bad read (y=%d)\n", + "%s: truncated input (y=%d)\n", progname, yres-1-yread); quit(1); } @@ -343,72 +426,150 @@ FILE *in; } yread++; } + if (obarsize > 0) + scan2sync(r); for (c = 0; c < ncols; c++) { - xcent = (long)c*xres/ncols; - if (rad <= 0.0) - dobox(scanout[c], xcent, ycent, c, r); - else + xcent = (c+.5)*xres/ncols; + if (thresh > FTINY) + dothresh(xcent, ycent, c, r); + else if (rad > FTINY) dogauss(scanout[c], xcent, ycent, c, r); + else + dobox(scanout[c], xcent, ycent, c, r); } - if (fwritescan(scanout, ncols, stdout) < 0) { + if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) { fprintf(stderr, "%s: write error in pass2\n", progname); quit(1); } } - /* skip leftovers */ + /* skip leftover input */ while (yread < yres) { if (freadscan(scanin[0], xres, in) < 0) break; yread++; } + scan2flush(); /* flush output */ } scan2init() /* prepare scanline arrays */ { - double d; + COLOR ctmp; + double d; register int i; - if (rad <= 0.0) { - xrad = xres/ncols/2 + 1; - yrad = yres/nrows/2 + 1; - } else { + xbrad = xres/ncols/2 + 1; + ybrad = yres/nrows/2 + 1; + if (rad > FTINY) { if (nrows >= yres && ncols >= xres) rad *= (y_r + x_c)/2.0; - xrad = CHECKRAD*rad/x_c + 1; - yrad = CHECKRAD*rad/y_r + 1; - + if (thresh > FTINY) { + orad = CHECKRAD*THRESHRAD*rad + 1; + xrad = orad/x_c + xbrad; + yrad = orad/y_r + ybrad; + obarsize = 2*orad + 1; + } else { + xrad = CHECKRAD*rad/x_c + 1; + yrad = CHECKRAD*rad/y_r + 1; + } initmask(); /* initialize filter table */ + } else { + xrad = xbrad; + yrad = ybrad; } - barsize = 2 * yrad; + barsize = 2*yrad + 1; scanin = (COLOR **)malloc(barsize*sizeof(COLOR *)); + if (scanin == NULL) + goto memerr; for (i = 0; i < barsize; i++) { scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR)); - if (scanin[i] == NULL) { - fprintf(stderr, "%s: out of memory\n", progname); - quit(1); + if (scanin[i] == NULL) + goto memerr; + } + if (obarsize > 0) { + scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *)); + greybar = (float **)malloc(obarsize*sizeof(float *)); + if ((scoutbar == NULL) | (greybar == NULL)) + goto memerr; + for (i = 0; i < obarsize; i++) { + scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR)); + greybar[i] = (float *)malloc(ncols*sizeof(float)); + if ((scoutbar[i] == NULL) | (greybar[i] == NULL)) + goto memerr; } + } else { + scanout = (COLOR *)malloc(ncols*sizeof(COLOR)); + if (scanout == NULL) + goto memerr; } - scanout = (COLOR *)malloc(ncols*sizeof(COLOR)); - if (scanout == NULL) { - fprintf(stderr, "%s: out of memory\n", progname); - quit(1); - } - /* record pixel aspect and exposure */ + /* record pixel aspect ratio */ if (!correctaspect) { - d = x_c / y_r; - if (d < .99 || d > 1.01) + d = order & YMAJOR ? x_c/y_r : y_r/x_c ; + if (!FEQ(d,1.0)) fputaspect(d, stdout); } - d = bright(exposure); - if (d < .995 || d > 1.005) + /* record exposure */ + d = (*ourbright)(exposure); + if (!FEQ(d,1.0)) fputexpos(d, stdout); + /* record color correction */ + copycolor(ctmp, exposure); + scalecolor(ctmp, 1.0/d); + if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) || + !FEQ(colval(ctmp,GRN),colval(ctmp,BLU))) + fputcolcor(ctmp, stdout); printf("\n"); - fputresolu(YMAJOR|YDECR, ncols, nrows, stdout); /* resolution */ + /* write out resolution */ + fputresolu(order, ncols, nrows, stdout); + return; +memerr: + fprintf(stderr, "%s: out of memory\n", progname); + quit(1); } +scan2sync(r) /* synchronize grey averages and output scan */ +int r; +{ + static int nextrow = 0; + COLOR ctmp; + int ybot; + register int c; + /* average input scanlines */ + while (nextrow <= r+orad && nextrow < nrows) { + ybot = (nextrow+.5)*yres/nrows; + for (c = 0; c < ncols; c++) { + dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow); + greybar[nextrow%obarsize][c] = (*ourbright)(ctmp); + } + /* and zero output scanline */ + memset((char *)scoutbar[nextrow%obarsize], '\0', ncols*sizeof(COLOR)); + nextrow++; + } + /* point to top scanline for output */ + if (r-orad >= 0) + scanout = scoutbar[(r-orad)%obarsize]; + else + scanout = NULL; +} + + +scan2flush() /* flush output buffer */ +{ + register int r; + + for (r = nrows-orad; r < nrows; r++) + if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0) + break; + if (fflush(stdout) < 0) { + fprintf(stderr, "%s: write error at end of pass2\n", progname); + quit(1); + } +} + + +void quit(code) /* remove temporary file and exit */ int code; {
