root/radiance/ray/src/px/pfilt.c
Revision: 2.25
Committed: Mon Jun 30 14:59:12 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.24: +5 -2 lines
2 static const char RCSid[] = "$Id: pfilt.c,v 2.24 2003/06/08 12:03:10 schorsch Exp $";
5 * pfilt.c - program to post-process picture file.
6 *
7 * 9/26/85
8 * 6/23/93 Added additional buffers for value spreading
9 */
10
11 #include "copyright.h"
12
13 #include <signal.h>
14 #include <string.h>
15
16 #include "standard.h"
17 #include "platform.h"
18 #include "color.h"
19 #include "view.h"
20 #include "paths.h"
21
22 extern float *matchlamp();
23
24 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
25
26 double CHECKRAD = 2.0; /* radius to check for filtering */
27
28 #define THRESHRAD 5.0 /* maximum sample spread in output */
29
30 COLOR exposure = WHTCOLOR; /* exposure for the frame */
31
32 double rad = 0.0; /* output pixel radius for filtering */
33
34 double thresh = 0.0; /* maximum contribution for subpixel */
35
36 int nrows = 0; /* number of rows for output */
37 int ncols = 0; /* number of columns for output */
38
39 double x_c = 1.0; /* ratio of output x size to input */
40 double y_r = 1.0; /* ratio of output y size to input */
41
42 int singlepass = 0; /* true means skip first pass */
43
44 int avghot = 0; /* true means average in bright spots */
45
46 double hotlvl = 100.0; /* level considered "hot" */
47
48 int npts = 0; /* (half) number of points for stars */
49
50 double spread = 1e-4; /* spread for star points */
51
52 char *tfname = NULL;
53
54 char template[] = TEMPLATE;
55
56 char *lampdat = "lamp.tab"; /* lamp data file */
57
58 int order; /* scanline ordering of input */
59 int xres, yres; /* resolution of input */
60 double inpaspect = 1.0; /* pixel aspect ratio of input */
61 int correctaspect = 0; /* aspect ratio correction? */
62
63 int wrongformat = 0;
64
65 VIEW ourview = STDVIEW;
66 int gotview = 0;
67 int wrapfilt = 0; /* wrap filter horizontally? */
68
69 int estatus = 0; /* exit status (for non-fatal errors) */
70
71 int xrad; /* x search radius */
72 int yrad; /* y search radius */
73 int xbrad; /* x box size */
74 int ybrad; /* y box size */
75
76 int barsize; /* size of input scan bar */
77 COLOR **scanin; /* input scan bar */
78 COLOR *scanout; /* output scan line */
79 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
80 float **greybar; /* grey-averaged input values */
81 int obarsize = 0; /* size of output scan bar */
82 int orad = 0; /* output window radius */
83
84 char *progname;
85
86
87 main(argc, argv)
88 int argc;
89 char **argv;
90 {
91 extern int headline();
92 FILE *fin;
93 float *lampcolor;
94 char *lamptype = NULL;
95 long fpos;
96 double outaspect = 0.0;
97 double d;
98 int i, j;
99 SET_DEFAULT_BINARY();
100 SET_FILE_BINARY(stdin);
101 SET_FILE_BINARY(stdout);
102 if (signal(SIGINT, quit) == SIG_IGN)
103 signal(SIGINT, SIG_IGN);
104 #ifdef SIGHUP
105 if (signal(SIGHUP, quit) == SIG_IGN)
106 signal(SIGHUP, SIG_IGN);
107 #endif
108 signal(SIGTERM, quit);
109 #ifdef SIGPIPE
110 signal(SIGPIPE, quit);
111 #endif
112 #ifdef SIGXCPU
113 signal(SIGXCPU, quit);
114 signal(SIGXFSZ, quit);
115 #endif
116
117 progname = argv[0] = fixargv0(argv[0]);
118
119 for (i = 1; i < argc; i++)
120 if (argv[i][0] == '-')
121 switch (argv[i][1]) {
122 case 'x':
123 i++;
124 if (argv[i][0] == '/') {
125 x_c = 1.0/atof(argv[i]+1);
126 ncols = 0;
127 } else
128 ncols = atoi(argv[i]);
129 break;
130 case 'y':
131 i++;
132 if (argv[i][0] == '/') {
133 y_r = 1.0/atof(argv[i]+1);
134 nrows = 0;
135 } else
136 nrows = atoi(argv[i]);
137 break;
138 case 'c':
139 correctaspect = !correctaspect;
140 break;
141 case 'p':
142 i++;
143 outaspect = atof(argv[i]);
144 break;
145 case 'e':
146 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
147 d = pow(2.0, atof(argv[i+1]));
148 else
149 d = atof(argv[i+1]);
150 if (d < 1e-20 || d > 1e20) {
151 fprintf(stderr,
152 "%s: exposure out of range\n",
153 argv[0]);
154 quit(1);
155 }
156 switch (argv[i][2]) {
157 case '\0':
158 scalecolor(exposure, d);
159 break;
160 case 'r':
161 colval(exposure,RED) *= d;
162 break;
163 case 'g':
164 colval(exposure,GRN) *= d;
165 break;
166 case 'b':
167 colval(exposure,BLU) *= d;
168 break;
169 default:
170 goto badopt;
171 }
172 i++;
173 break;
174 case 'f':
175 lampdat = argv[++i];
176 break;
177 case 't':
178 lamptype = argv[++i];
179 break;
180 case '1':
181 singlepass = 1;
182 break;
183 case '2':
184 singlepass = 0;
185 break;
186 case 'n':
187 npts = atoi(argv[++i]) / 2;
188 break;
189 case 's':
190 spread = atof(argv[++i]);
191 break;
192 case 'a':
193 avghot = !avghot;
194 break;
195 case 'h':
196 hotlvl = atof(argv[++i]);
197 break;
198 case 'r':
199 rad = atof(argv[++i]);
200 break;
201 case 'm':
202 thresh = atof(argv[++i]);
203 if (rad <= FTINY)
204 rad = 0.6;
205 break;
206 case 'b':
207 rad = thresh = 0.0;
208 break;
209 default:;
210 badopt:
211 fprintf(stderr, "%s: unknown option: %s\n",
212 progname, argv[i]);
213 quit(1);
214 break;
215 }
216 else
217 break;
218 /* get lamp data (if necessary) */
219 if (lamptype != NULL) {
220 if (loadlamps(lampdat) < 0)
221 quit(1);
222 if ((lampcolor = matchlamp(lamptype)) == NULL) {
223 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
224 quit(1);
225 }
226 for (j = 0; j < 3; j++)
227 if (lampcolor[j] > 1e-4)
228 colval(exposure,j) /= lampcolor[j];
229 freelamps();
230 }
231 /* open input file */
232 if (i == argc) {
233 if (singlepass)
234 fin = stdin;
235 else {
236 tfname = mktemp(template);
237 if ((fin = fopen(tfname, "w+")) == NULL) {
238 fprintf(stderr, "%s: can't create ", progname);
239 fprintf(stderr, "temp file \"%s\"\n", tfname);
240 quit(1);
241 }
242 copyfile(stdin, fin);
243 if (fseek(fin, 0L, 0) == -1) {
244 fprintf(stderr, "%s: seek fail\n", progname);
245 quit(1);
246 }
247 }
248 } else if (i == argc-1) {
249 if ((fin = fopen(argv[i], "r")) == NULL) {
250 fprintf(stderr, "%s: can't open file \"%s\"\n",
251 progname, argv[i]);
252 quit(1);
253 }
254 } else {
255 fprintf(stderr, "%s: bad # file arguments\n", progname);
256 quit(1);
257 }
258 /* get header */
259 getheader(fin, headline, NULL);
260 if (wrongformat) {
261 fprintf(stderr, "%s: input must be a Radiance picture\n",
262 progname);
263 quit(1);
264 }
265 /* add new header info. */
266 printargs(i, argv, stdout);
267 /* get picture size */
268 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
269 fprintf(stderr, "%s: bad picture size\n", progname);
270 quit(1);
271 }
272 if (!(order & YMAJOR))
273 inpaspect = 1.0/inpaspect;
274 /* wrap around for cylindrical view? */
275 wrapfilt = gotview && ourview.type == VT_CYL &&
276 ourview.horiz >= 360.-FTINY && order & YMAJOR;
277 /* compute output resolution */
278 if (ncols <= 0)
279 ncols = x_c*xres + .5;
280 if (nrows <= 0)
281 nrows = y_r*yres + .5;
282 if (outaspect > .01) {
283 d = inpaspect * yres/xres / outaspect;
284 if (d * ncols > nrows)
285 ncols = nrows / d;
286 else
287 nrows = ncols * d;
288 }
289 x_c = (double)ncols/xres;
290 y_r = (double)nrows/yres;
291
292 if (singlepass) { /* skip exposure, etc. */
293 pass1default();
294 pass2(fin);
295 quit(0);
296 }
297
298 fpos = ftell(fin); /* save input file position */
299
300 pass1(fin);
301
302 if (fseek(fin, fpos, 0) == -1) {
303 fprintf(stderr, "%s: seek fail\n", progname);
304 quit(1);
305 }
306 pass2(fin);
307
308 quit(estatus);
309 }
310
311
312 double
313 rgb_bright(clr)
314 COLOR clr;
315 {
316 return(bright(clr));
317 }
318
319
320 double
321 xyz_bright(clr)
322 COLOR clr;
323 {
324 return(clr[CIEY]);
325 }
326
327
328 double (*ourbright)() = rgb_bright;
329
330
331 int
332 headline(s) /* process line from header */
333 char *s;
334 {
335 char fmt[32];
336
337 fputs(s, stdout); /* copy to output */
338 if (isaspect(s)) /* get aspect ratio */
339 inpaspect *= aspectval(s);
340 else if (isexpos(s)) /* get exposure */
341 hotlvl *= exposval(s);
342 else if (formatval(fmt, s)) { /* get format */
343 wrongformat = 0;
344 if (!strcmp(COLRFMT, fmt))
345 ourbright = rgb_bright;
346 else if (!strcmp(CIEFMT, fmt))
347 ourbright = xyz_bright;
348 else
349 wrongformat = !globmatch(PICFMT, fmt);
350 } else if (isview(s) && sscanview(&ourview, s) > 0)
351 gotview++;
352 return(0);
353 }
354
355
356 copyfile(in, out) /* copy a file */
357 register FILE *in, *out;
358 {
359 register int c;
360
361 while ((c = getc(in)) != EOF)
362 putc(c, out);
363
364 if (ferror(out)) {
365 fprintf(stderr, "%s: write error in copyfile\n", progname);
366 quit(1);
367 }
368 }
369
370
371 pass1(in) /* first pass of picture file */
372 FILE *in;
373 {
374 int i;
375 COLOR *scan;
376
377 pass1init();
378
379 scan = (COLOR *)malloc(xres*sizeof(COLOR));
380 if (scan == NULL) {
381 fprintf(stderr, "%s: out of memory\n", progname);
382 quit(1);
383 }
384 for (i = 0; i < yres; i++) {
385 if (freadscan(scan, xres, in) < 0) {
386 nrows = (long)nrows * i / yres; /* adjust frame */
387 if (nrows <= 0) {
388 fprintf(stderr, "%s: empty frame\n", progname);
389 quit(1);
390 }
391 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
392 progname, (int)(100L*i/yres));
393 yres = i;
394 y_r = (double)nrows/yres;
395 estatus++;
396 break;
397 }
398 pass1scan(scan, i);
399 }
400 free((void *)scan);
401 }
402
403
404 pass2(in) /* last pass on file, write to stdout */
405 FILE *in;
406 {
407 int yread;
408 int ycent, xcent;
409 int r, c;
410
411 pass2init();
412 scan2init();
413 yread = 0;
414 for (r = 0; r < nrows; r++) {
415 ycent = (r+.5)*yres/nrows;
416 while (yread <= ycent+yrad) {
417 if (yread < yres) {
418 if (freadscan(scanin[yread%barsize],
419 xres, in) < 0) {
420 fprintf(stderr,
421 "%s: truncated input (y=%d)\n",
422 progname, yres-1-yread);
423 quit(1);
424 }
425 pass2scan(scanin[yread%barsize], yread);
426 }
427 yread++;
428 }
429 if (obarsize > 0)
430 scan2sync(r);
431 for (c = 0; c < ncols; c++) {
432 xcent = (c+.5)*xres/ncols;
433 if (thresh > FTINY)
434 dothresh(xcent, ycent, c, r);
435 else if (rad > FTINY)
436 dogauss(scanout[c], xcent, ycent, c, r);
437 else
438 dobox(scanout[c], xcent, ycent, c, r);
439 }
440 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
441 fprintf(stderr, "%s: write error in pass2\n", progname);
442 quit(1);
443 }
444 }
445 /* skip leftover input */
446 while (yread < yres) {
447 if (freadscan(scanin[0], xres, in) < 0)
448 break;
449 yread++;
450 }
451 scan2flush(); /* flush output */
452 }
453
454
455 scan2init() /* prepare scanline arrays */
456 {
457 COLOR ctmp;
458 double d;
459 register int i;
460
461 xbrad = xres/ncols/2 + 1;
462 ybrad = yres/nrows/2 + 1;
463 if (rad > FTINY) {
464 if (nrows >= yres && ncols >= xres)
465 rad *= (y_r + x_c)/2.0;
466
467 if (thresh > FTINY) {
468 orad = CHECKRAD*THRESHRAD*rad + 1;
469 xrad = orad/x_c + xbrad;
470 yrad = orad/y_r + ybrad;
471 obarsize = 2*orad + 1;
472 } else {
473 xrad = CHECKRAD*rad/x_c + 1;
474 yrad = CHECKRAD*rad/y_r + 1;
475 }
476 initmask(); /* initialize filter table */
477 } else {
478 xrad = xbrad;
479 yrad = ybrad;
480 }
481 barsize = 2*yrad + 1;
482 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
483 if (scanin == NULL)
484 goto memerr;
485 for (i = 0; i < barsize; i++) {
486 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
487 if (scanin[i] == NULL)
488 goto memerr;
489 }
490 if (obarsize > 0) {
491 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
492 greybar = (float **)malloc(obarsize*sizeof(float *));
493 if (scoutbar == NULL | greybar == NULL)
494 goto memerr;
495 for (i = 0; i < obarsize; i++) {
496 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
497 greybar[i] = (float *)malloc(ncols*sizeof(float));
498 if (scoutbar[i] == NULL | greybar[i] == NULL)
499 goto memerr;
500 }
501 } else {
502 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
503 if (scanout == NULL)
504 goto memerr;
505 }
506 /* record pixel aspect ratio */
507 if (!correctaspect) {
508 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
509 if (!FEQ(d,1.0))
510 fputaspect(d, stdout);
511 }
512 /* record exposure */
513 d = (*ourbright)(exposure);
514 if (!FEQ(d,1.0))
515 fputexpos(d, stdout);
516 /* record color correction */
517 copycolor(ctmp, exposure);
518 scalecolor(ctmp, 1.0/d);
519 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
520 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
521 fputcolcor(ctmp, stdout);
522 printf("\n");
523 /* write out resolution */
524 fputresolu(order, ncols, nrows, stdout);
525 return;
526 memerr:
527 fprintf(stderr, "%s: out of memory\n", progname);
528 quit(1);
529 }
530
531
532 scan2sync(r) /* synchronize grey averages and output scan */
533 int r;
534 {
535 static int nextrow = 0;
536 COLOR ctmp;
537 int ybot;
538 register int c;
539 /* average input scanlines */
540 while (nextrow <= r+orad && nextrow < nrows) {
541 ybot = (nextrow+.5)*yres/nrows;
542 for (c = 0; c < ncols; c++) {
543 dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
544 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
545 }
546 /* and zero output scanline */
547 memset((char *)scoutbar[nextrow%obarsize], '\0', ncols*sizeof(COLOR));
548 nextrow++;
549 }
550 /* point to top scanline for output */
551 if (r-orad >= 0)
552 scanout = scoutbar[(r-orad)%obarsize];
553 else
554 scanout = NULL;
555 }
556
557
558 scan2flush() /* flush output buffer */
559 {
560 register int r;
561
562 for (r = nrows-orad; r < nrows; r++)
563 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
564 break;
565 if (fflush(stdout) < 0) {
566 fprintf(stderr, "%s: write error at end of pass2\n", progname);
567 quit(1);
568 }
569 }
570
571
572 void
573 quit(code) /* remove temporary file and exit */
574 int code;
575 {
576 if (tfname != NULL)
577 unlink(tfname);
578 exit(code);
579 }
