root/radiance/ray/src/px/pfilt.c
Revision: 2.28
Committed: Fri Jan 2 12:47:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.27: +8 -5 lines
2 static const char RCSid[] = "$Id: pfilt.c,v 2.27 2003/10/22 02:06:35 greg Exp $";
5 * pfilt.c - program to post-process picture file.
6 *
7 * 9/26/85
8 * 6/23/93 Added additional buffers for value spreading
9 */
10
11 #include "copyright.h"
12
13 #include <signal.h>
14 #include <string.h>
15
16 #include "platform.h"
17 #include "standard.h"
18 #include "color.h"
19 #include "view.h"
20 #include "paths.h"
21
22 extern float *matchlamp();
23
24 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
25
26 double CHECKRAD = 2.0; /* radius to check for filtering */
27
28 #define THRESHRAD 5.0 /* maximum sample spread in output */
29
30 COLOR exposure = WHTCOLOR; /* exposure for the frame */
31
32 double rad = 0.0; /* output pixel radius for filtering */
33
34 double thresh = 0.0; /* maximum contribution for subpixel */
35
36 int nrows = 0; /* number of rows for output */
37 int ncols = 0; /* number of columns for output */
38
39 double x_c = 1.0; /* ratio of output x size to input */
40 double y_r = 1.0; /* ratio of output y size to input */
41
42 int singlepass = 0; /* true means skip first pass */
43
44 int avghot = 0; /* true means average in bright spots */
45
46 double hotlvl = 100.0; /* level considered "hot" */
47
48 int npts = 0; /* (half) number of points for stars */
49
50 double spread = 1e-4; /* spread for star points */
51
52 char *tfname = NULL;
53
54 char template[] = TEMPLATE;
55
56 char *lampdat = "lamp.tab"; /* lamp data file */
57
58 int order; /* scanline ordering of input */
59 int xres, yres; /* resolution of input */
60 double inpaspect = 1.0; /* pixel aspect ratio of input */
61 int correctaspect = 0; /* aspect ratio correction? */
62
63 int wrongformat = 0;
64
65 VIEW ourview = STDVIEW;
66 int gotview = 0;
67 int wrapfilt = 0; /* wrap filter horizontally? */
68
69 int estatus = 0; /* exit status (for non-fatal errors) */
70
71 int xrad; /* x search radius */
72 int yrad; /* y search radius */
73 int xbrad; /* x box size */
74 int ybrad; /* y box size */
75
76 int barsize; /* size of input scan bar */
77 COLOR **scanin; /* input scan bar */
78 COLOR *scanout; /* output scan line */
79 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
80 float **greybar; /* grey-averaged input values */
81 int obarsize = 0; /* size of output scan bar */
82 int orad = 0; /* output window radius */
83
84 char *progname;
85
86 static gethfunc headline;
87
88
89 main(argc, argv)
90 int argc;
91 char **argv;
92 {
93 FILE *fin;
94 float *lampcolor;
95 char *lamptype = NULL;
96 long fpos;
97 double outaspect = 0.0;
98 double d;
99 int i, j;
100 SET_DEFAULT_BINARY();
101 SET_FILE_BINARY(stdin);
102 SET_FILE_BINARY(stdout);
103 if (signal(SIGINT, quit) == SIG_IGN)
104 signal(SIGINT, SIG_IGN);
105 #ifdef SIGHUP
106 if (signal(SIGHUP, quit) == SIG_IGN)
107 signal(SIGHUP, SIG_IGN);
108 #endif
109 signal(SIGTERM, quit);
110 #ifdef SIGPIPE
111 signal(SIGPIPE, quit);
112 #endif
113 #ifdef SIGXCPU
114 signal(SIGXCPU, quit);
115 signal(SIGXFSZ, quit);
116 #endif
117
118 progname = argv[0] = fixargv0(argv[0]);
119
120 for (i = 1; i < argc; i++)
121 if (argv[i][0] == '-')
122 switch (argv[i][1]) {
123 case 'x':
124 i++;
125 if (argv[i][0] == '/') {
126 x_c = 1.0/atof(argv[i]+1);
127 ncols = 0;
128 } else
129 ncols = atoi(argv[i]);
130 break;
131 case 'y':
132 i++;
133 if (argv[i][0] == '/') {
134 y_r = 1.0/atof(argv[i]+1);
135 nrows = 0;
136 } else
137 nrows = atoi(argv[i]);
138 break;
139 case 'c':
140 correctaspect = !correctaspect;
141 break;
142 case 'p':
143 i++;
144 outaspect = atof(argv[i]);
145 break;
146 case 'e':
147 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
148 d = pow(2.0, atof(argv[i+1]));
149 else
150 d = atof(argv[i+1]);
151 if (d < 1e-20 || d > 1e20) {
152 fprintf(stderr,
153 "%s: exposure out of range\n",
154 argv[0]);
155 quit(1);
156 }
157 switch (argv[i][2]) {
158 case '\0':
159 scalecolor(exposure, d);
160 break;
161 case 'r':
162 colval(exposure,RED) *= d;
163 break;
164 case 'g':
165 colval(exposure,GRN) *= d;
166 break;
167 case 'b':
168 colval(exposure,BLU) *= d;
169 break;
170 default:
171 goto badopt;
172 }
173 i++;
174 break;
175 case 'f':
176 lampdat = argv[++i];
177 break;
178 case 't':
179 lamptype = argv[++i];
180 break;
181 case '1':
182 singlepass = 1;
183 break;
184 case '2':
185 singlepass = 0;
186 break;
187 case 'n':
188 npts = atoi(argv[++i]) / 2;
189 break;
190 case 's':
191 spread = atof(argv[++i]);
192 break;
193 case 'a':
194 avghot = !avghot;
195 break;
196 case 'h':
197 hotlvl = atof(argv[++i]);
198 break;
199 case 'r':
200 rad = atof(argv[++i]);
201 break;
202 case 'm':
203 thresh = atof(argv[++i]);
204 if (rad <= FTINY)
205 rad = 0.6;
206 break;
207 case 'b':
208 rad = thresh = 0.0;
209 break;
210 default:;
211 badopt:
212 fprintf(stderr, "%s: unknown option: %s\n",
213 progname, argv[i]);
214 quit(1);
215 break;
216 }
217 else
218 break;
219 /* get lamp data (if necessary) */
220 if (lamptype != NULL) {
221 if (loadlamps(lampdat) < 0)
222 quit(1);
223 if ((lampcolor = matchlamp(lamptype)) == NULL) {
224 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
225 quit(1);
226 }
227 for (j = 0; j < 3; j++)
228 if (lampcolor[j] > 1e-4)
229 colval(exposure,j) /= lampcolor[j];
230 freelamps();
231 }
232 /* open input file */
233 if (i == argc) {
234 if (singlepass)
235 fin = stdin;
236 else {
237 tfname = mktemp(template);
238 if ((fin = fopen(tfname, "w+")) == NULL) {
239 fprintf(stderr, "%s: can't create ", progname);
240 fprintf(stderr, "temp file \"%s\"\n", tfname);
241 quit(1);
242 }
243 copyfile(stdin, fin);
244 if (fseek(fin, 0L, 0) == -1) {
245 fprintf(stderr, "%s: seek fail\n", progname);
246 quit(1);
247 }
248 }
249 } else if (i == argc-1) {
250 if ((fin = fopen(argv[i], "r")) == NULL) {
251 fprintf(stderr, "%s: can't open file \"%s\"\n",
252 progname, argv[i]);
253 quit(1);
254 }
255 } else {
256 fprintf(stderr, "%s: bad # file arguments\n", progname);
257 quit(1);
258 }
259 /* get header */
260 getheader(fin, headline, NULL);
261 if (wrongformat) {
262 fprintf(stderr, "%s: input must be a Radiance picture\n",
263 progname);
264 quit(1);
265 }
266 /* add new header info. */
267 printargs(i, argv, stdout);
268 /* get picture size */
269 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
270 fprintf(stderr, "%s: bad picture size\n", progname);
271 quit(1);
272 }
273 if (!(order & YMAJOR))
274 inpaspect = 1.0/inpaspect;
275 /* wrap around for cylindrical view? */
276 wrapfilt = gotview && ourview.type == VT_CYL &&
277 ourview.horiz >= 360.-FTINY && order & YMAJOR;
278 /* compute output resolution */
279 if (ncols <= 0)
280 ncols = x_c*xres + .5;
281 if (nrows <= 0)
282 nrows = y_r*yres + .5;
283 if (outaspect > .01) {
284 d = inpaspect * yres/xres / outaspect;
285 if (d * ncols > nrows)
286 ncols = nrows / d;
287 else
288 nrows = ncols * d;
289 }
290 x_c = (double)ncols/xres;
291 y_r = (double)nrows/yres;
292
293 if (singlepass) { /* skip exposure, etc. */
294 pass1default();
295 pass2(fin);
296 quit(0);
297 }
298
299 fpos = ftell(fin); /* save input file position */
300
301 pass1(fin);
302
303 if (fseek(fin, fpos, 0) == -1) {
304 fprintf(stderr, "%s: seek fail\n", progname);
305 quit(1);
306 }
307 pass2(fin);
308
309 quit(estatus);
310 }
311
312
313 double
314 rgb_bright(clr)
315 COLOR clr;
316 {
317 return(bright(clr));
318 }
319
320
321 double
322 xyz_bright(clr)
323 COLOR clr;
324 {
325 return(clr[CIEY]);
326 }
327
328
329 double (*ourbright)() = rgb_bright;
330
331
332 static int
333 headline( /* process line from header */
334 char *s,
335 void *p
336 )
337 {
338 char fmt[32];
339
340 fputs(s, stdout); /* copy to output */
341 if (isaspect(s)) /* get aspect ratio */
342 inpaspect *= aspectval(s);
343 else if (isexpos(s)) /* get exposure */
344 hotlvl *= exposval(s);
345 else if (formatval(fmt, s)) { /* get format */
346 wrongformat = 0;
347 if (!strcmp(COLRFMT, fmt))
348 ourbright = rgb_bright;
349 else if (!strcmp(CIEFMT, fmt))
350 ourbright = xyz_bright;
351 else
352 wrongformat = !globmatch(PICFMT, fmt);
353 } else if (isview(s) && sscanview(&ourview, s) > 0)
354 gotview++;
355 return(0);
356 }
357
358
359 copyfile(in, out) /* copy a file */
360 register FILE *in, *out;
361 {
362 register int c;
363
364 while ((c = getc(in)) != EOF)
365 putc(c, out);
366
367 if (ferror(out)) {
368 fprintf(stderr, "%s: write error in copyfile\n", progname);
369 quit(1);
370 }
371 }
372
373
374 pass1(in) /* first pass of picture file */
375 FILE *in;
376 {
377 int i;
378 COLOR *scan;
379
380 pass1init();
381
382 scan = (COLOR *)malloc(xres*sizeof(COLOR));
383 if (scan == NULL) {
384 fprintf(stderr, "%s: out of memory\n", progname);
385 quit(1);
386 }
387 for (i = 0; i < yres; i++) {
388 if (freadscan(scan, xres, in) < 0) {
389 nrows = (long)nrows * i / yres; /* adjust frame */
390 if (nrows <= 0) {
391 fprintf(stderr, "%s: empty frame\n", progname);
392 quit(1);
393 }
394 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
395 progname, (int)(100L*i/yres));
396 yres = i;
397 y_r = (double)nrows/yres;
398 estatus++;
399 break;
400 }
401 pass1scan(scan, i);
402 }
403 free((void *)scan);
404 }
405
406
407 pass2(in) /* last pass on file, write to stdout */
408 FILE *in;
409 {
410 int yread;
411 int ycent, xcent;
412 int r, c;
413
414 pass2init();
415 scan2init();
416 yread = 0;
417 for (r = 0; r < nrows; r++) {
418 ycent = (r+.5)*yres/nrows;
419 while (yread <= ycent+yrad) {
420 if (yread < yres) {
421 if (freadscan(scanin[yread%barsize],
422 xres, in) < 0) {
423 fprintf(stderr,
424 "%s: truncated input (y=%d)\n",
425 progname, yres-1-yread);
426 quit(1);
427 }
428 pass2scan(scanin[yread%barsize], yread);
429 }
430 yread++;
431 }
432 if (obarsize > 0)
433 scan2sync(r);
434 for (c = 0; c < ncols; c++) {
435 xcent = (c+.5)*xres/ncols;
436 if (thresh > FTINY)
437 dothresh(xcent, ycent, c, r);
438 else if (rad > FTINY)
439 dogauss(scanout[c], xcent, ycent, c, r);
440 else
441 dobox(scanout[c], xcent, ycent, c, r);
442 }
443 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
444 fprintf(stderr, "%s: write error in pass2\n", progname);
445 quit(1);
446 }
447 }
448 /* skip leftover input */
449 while (yread < yres) {
450 if (freadscan(scanin[0], xres, in) < 0)
451 break;
452 yread++;
453 }
454 scan2flush(); /* flush output */
455 }
456
457
458 scan2init() /* prepare scanline arrays */
459 {
460 COLOR ctmp;
461 double d;
462 register int i;
463
464 xbrad = xres/ncols/2 + 1;
465 ybrad = yres/nrows/2 + 1;
466 if (rad > FTINY) {
467 if (nrows >= yres && ncols >= xres)
468 rad *= (y_r + x_c)/2.0;
469
470 if (thresh > FTINY) {
471 orad = CHECKRAD*THRESHRAD*rad + 1;
472 xrad = orad/x_c + xbrad;
473 yrad = orad/y_r + ybrad;
474 obarsize = 2*orad + 1;
475 } else {
476 xrad = CHECKRAD*rad/x_c + 1;
477 yrad = CHECKRAD*rad/y_r + 1;
478 }
479 initmask(); /* initialize filter table */
480 } else {
481 xrad = xbrad;
482 yrad = ybrad;
483 }
484 barsize = 2*yrad + 1;
485 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
486 if (scanin == NULL)
487 goto memerr;
488 for (i = 0; i < barsize; i++) {
489 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
490 if (scanin[i] == NULL)
491 goto memerr;
492 }
493 if (obarsize > 0) {
494 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
495 greybar = (float **)malloc(obarsize*sizeof(float *));
496 if ((scoutbar == NULL) | (greybar == NULL))
497 goto memerr;
498 for (i = 0; i < obarsize; i++) {
499 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
500 greybar[i] = (float *)malloc(ncols*sizeof(float));
501 if ((scoutbar[i] == NULL) | (greybar[i] == NULL))
502 goto memerr;
503 }
504 } else {
505 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
506 if (scanout == NULL)
507 goto memerr;
508 }
509 /* record pixel aspect ratio */
510 if (!correctaspect) {
511 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
512 if (!FEQ(d,1.0))
513 fputaspect(d, stdout);
514 }
515 /* record exposure */
516 d = (*ourbright)(exposure);
517 if (!FEQ(d,1.0))
518 fputexpos(d, stdout);
519 /* record color correction */
520 copycolor(ctmp, exposure);
521 scalecolor(ctmp, 1.0/d);
522 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
523 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
524 fputcolcor(ctmp, stdout);
525 printf("\n");
526 /* write out resolution */
527 fputresolu(order, ncols, nrows, stdout);
528 return;
529 memerr:
530 fprintf(stderr, "%s: out of memory\n", progname);
531 quit(1);
532 }
533
534
535 scan2sync(r) /* synchronize grey averages and output scan */
536 int r;
537 {
538 static int nextrow = 0;
539 COLOR ctmp;
540 int ybot;
541 register int c;
542 /* average input scanlines */
543 while (nextrow <= r+orad && nextrow < nrows) {
544 ybot = (nextrow+.5)*yres/nrows;
545 for (c = 0; c < ncols; c++) {
546 dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
547 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
548 }
549 /* and zero output scanline */
550 memset((char *)scoutbar[nextrow%obarsize], '\0', ncols*sizeof(COLOR));
551 nextrow++;
552 }
553 /* point to top scanline for output */
554 if (r-orad >= 0)
555 scanout = scoutbar[(r-orad)%obarsize];
556 else
557 scanout = NULL;
558 }
559
560
561 scan2flush() /* flush output buffer */
562 {
563 register int r;
564
565 for (r = nrows-orad; r < nrows; r++)
566 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
567 break;
568 if (fflush(stdout) < 0) {
569 fprintf(stderr, "%s: write error at end of pass2\n", progname);
570 quit(1);
571 }
572 }
573
574
575 void
576 quit(code) /* remove temporary file and exit */
577 int code;
578 {
579 if (tfname != NULL)
580 unlink(tfname);
581 exit(code);
582 }
