root/radiance/ray/src/px/pfilt.c
Fri Sep 3 21:18:15 2010 UTC (14 years, 9 months ago) by greg
Changes since 2.30: +1 -3 lines
Diff to previous 2.30
Removed '//' comments that don't fit with standard C
Mon Mar 29 00:34:23 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.29: +6 -5 lines
Diff to previous 2.29
Continued ANSIfication. Added headerfiles pfilt.h and clrtab.h.
Sun Mar 28 20:33:14 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.28: +46 -21 lines
Diff to previous 2.28
Fri Jan 2 12:47:01 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 2.27: +8 -5 lines
Diff to previous 2.27
Wed Oct 22 02:06:35 2003 UTC (21 years, 7 months ago) by greg
Diff to previous 2.26
Diff to previous 2.25
Mon Jun 30 14:59:12 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.24: +5 -2 lines
Diff to previous 2.24
Sun Jun 8 12:03:10 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.23: +6 -1 lines
Diff to previous 2.23
Thu Jun 5 19:29:34 2003 UTC (22 years ago) by schorsch
Changes since 2.22: +5 -11 lines
Diff to previous 2.22
Tue Feb 25 00:26:05 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 2.21
Fixed pre-release upsampling bug in new filtering kernel
Sat Feb 22 02:07:27 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.20: +5 -10 lines
Diff to previous 2.20
Tue Oct 27 09:08:26 1998 UTC (26 years, 7 months ago) by gwlarson
Changes since 2.19: +2 -0 lines
Diff to previous 2.19
Wed Oct 2 16:56:16 1996 UTC (28 years, 8 months ago) by greg
Changes since 2.18: +4 -4 lines
Diff to previous 2.18
made output pixel positioning more precise
Wed May 22 10:42:08 1996 UTC (29 years ago) by greg
Changes since 2.17: +6 -3 lines
Diff to previous 2.17
added exit status change for truncated input files
Mon Apr 1 17:24:44 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.16: +11 -1 lines
Diff to previous 2.16
Wed Feb 14 20:19:52 1996 UTC (29 years, 3 months ago) by greg
Diff to previous 2.15
fixed bug in indexing and size of buffers for -m option
Mon Oct 16 12:04:36 1995 UTC (29 years, 7 months ago) by greg
Changes since 2.14: +30 -6 lines
Diff to previous 2.14
added compatibility with Radiance XYZE picture format
Wed May 31 08:50:27 1995 UTC (30 years ago) by greg
Diff to previous 2.13
improved error message for truncated input
Mon Feb 7 16:27:50 1994 UTC (31 years, 4 months ago) by greg
Diff to previous 2.12
fixed bug in lamp data routine
Thu Nov 18 09:56:17 1993 UTC (31 years, 6 months ago) by greg
minor compiler warning fixes
Tue Sep 21 10:55:54 1993 UTC (31 years, 8 months ago) by greg
minor bug fixes
Fri Jun 25 17:07:03 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.9: +14 -13 lines
minor optimization
Fri Jun 25 15:01:17 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.8: +103 -20 lines
added -m option for sample smoothing
Fri Jun 18 16:20:16 1993 UTC (31 years, 11 months ago) by greg
changed default setting of hotlvl and made it absolute
Thu Nov 12 09:05:17 1992 UTC (32 years, 6 months ago) by greg
bug fix for 16-bit integers (DOS)
Tue Nov 3 16:52:20 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.5: +2 -9 lines
Fri Oct 2 16:24:06 1992 UTC (32 years, 8 months ago) by greg
Mon Sep 21 12:14:17 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.3: +24 -15 lines
Changes for PC port
Tue Sep 8 15:33:08 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.2: +2 -3 lines
Thu Dec 19 14:51:52 1991 UTC (33 years, 5 months ago) by greg
Tue Nov 12 16:04:27 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.19
Mon Nov 11 14:01:15 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.18: +8 -3 lines
Diff to previous 1.18
Mon Oct 28 08:10:18 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.17: +5 -5 lines
Diff to previous 1.17
added insurance for lampcolor[i] == 0.0
Wed Jun 5 12:15:30 1991 UTC (34 years ago) by greg
Diff to previous 1.16
improved gaussian filtering
Thu Apr 18 14:35:21 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.15: +14 -1 lines
Diff to previous 1.15
Fri Dec 14 16:33:16 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.14: +21 -4 lines
Diff to previous 1.14
added use of COLORCORR header i/o
Sat Dec 8 13:23:47 1990 UTC (34 years, 6 months ago) by greg
Changes since 1.13: +14 -14 lines
Diff to previous 1.13
moved loading of lamp data before opening of input file
Sat Dec 8 10:14:33 1990 UTC (34 years, 6 months ago) by greg
Changes since 1.12: +24 -0 lines
Diff to previous 1.12
Wed Nov 28 11:13:23 1990 UTC (34 years, 6 months ago) by greg
Changes since 1.11: +9 -3 lines
Diff to previous 1.11
added option to override output of aspect ratio change
Tue Oct 16 13:52:44 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.10: +1 -0 lines
Diff to previous 1.10
recomputed y_r after picture adjustment (bug fix)
Thu Sep 13 09:46:00 1990 UTC (34 years, 8 months ago) by greg
Diff to previous 1.9
fixed pass2() so it reads all its input regardless
Tue Jan 9 17:58:35 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.8: +40 -17 lines
Diff to previous 1.8
added code to maintain pixel aspect ratio
Fri Jan 5 17:52:52 1990 UTC (35 years, 5 months ago) by greg
Diff to previous 1.7
changed EXPOSURE information interface
Wed Sep 13 17:16:37 1989 UTC (35 years, 8 months ago) by greg
Diff to previous 1.6
Sat Apr 29 09:22:54 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.5: +3 -0 lines
Diff to previous 1.5
Added -2 option for two-pass
Thu Apr 13 07:52:50 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.4: +6 -4 lines
Diff to previous 1.4
resolution ratio supercedes previous specification
Tue Apr 11 21:50:05 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.3: +8 -13 lines
Diff to previous 1.3
consolidated resolution ratio variables
Tue Apr 11 21:39:00 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.2: +8 -6 lines
Diff to previous 1.2
changed syntax for resolution ratios
Tue Apr 11 17:22:05 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.1: +19 -6 lines
added scaling options for x and y resolution
Thu Feb 2 10:49:26 1989 UTC (36 years, 4 months ago) by greg
