root/radiance/ray/src/px/pfilt.c
Revision: 2.22
Committed: Tue Feb 25 00:26:05 2003 UTC (21 years, 3 months ago) by greg
Fixed pre-release upsampling bug in new filtering kernel
5 * pfilt.c - program to post-process picture file.
6 *
7 * 9/26/85
8 * 6/23/93 Added additional buffers for value spreading
9 */
10
11 #include "standard.h"
12
13 #include <signal.h>
14
15 #include "color.h"
16
17 #include "view.h"
18
19 #include "paths.h"
20
21 extern float *matchlamp();
22
23 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
24
25 double CHECKRAD = 2.0; /* radius to check for filtering */
26
27 #define THRESHRAD 5.0 /* maximum sample spread in output */
28
29 COLOR exposure = WHTCOLOR; /* exposure for the frame */
30
31 double rad = 0.0; /* output pixel radius for filtering */
32
33 double thresh = 0.0; /* maximum contribution for subpixel */
34
35 int nrows = 0; /* number of rows for output */
36 int ncols = 0; /* number of columns for output */
37
38 double x_c = 1.0; /* ratio of output x size to input */
39 double y_r = 1.0; /* ratio of output y size to input */
40
41 int singlepass = 0; /* true means skip first pass */
42
43 int avghot = 0; /* true means average in bright spots */
44
45 double hotlvl = 100.0; /* level considered "hot" */
46
47 int npts = 0; /* (half) number of points for stars */
48
49 double spread = 1e-4; /* spread for star points */
50
51 char *tfname = NULL;
52
53 char template[] = TEMPLATE;
54
55 char *lampdat = "lamp.tab"; /* lamp data file */
56
57 int order; /* scanline ordering of input */
58 int xres, yres; /* resolution of input */
59 double inpaspect = 1.0; /* pixel aspect ratio of input */
60 int correctaspect = 0; /* aspect ratio correction? */
61
62 int wrongformat = 0;
63
64 VIEW ourview = STDVIEW;
65 int gotview = 0;
66 int wrapfilt = 0; /* wrap filter horizontally? */
67
68 int estatus = 0; /* exit status (for non-fatal errors) */
69
70 int xrad; /* x search radius */
71 int yrad; /* y search radius */
72 int xbrad; /* x box size */
73 int ybrad; /* y box size */
74
75 int barsize; /* size of input scan bar */
76 COLOR **scanin; /* input scan bar */
77 COLOR *scanout; /* output scan line */
78 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
79 float **greybar; /* grey-averaged input values */
80 int obarsize = 0; /* size of output scan bar */
81 int orad = 0; /* output window radius */
82
83 char *progname;
84
85
86 main(argc, argv)
87 int argc;
88 char **argv;
89 {
90 extern int headline();
91 FILE *fin;
92 float *lampcolor;
93 char *lamptype = NULL;
94 long fpos;
95 double outaspect = 0.0;
96 double d;
97 int i, j;
98 #ifdef MSDOS
99 extern int _fmode;
100 _fmode = O_BINARY;
101 setmode(fileno(stdin), O_BINARY);
102 setmode(fileno(stdout), O_BINARY);
103 #endif
104 if (signal(SIGINT, quit) == SIG_IGN)
105 signal(SIGINT, SIG_IGN);
106 if (signal(SIGHUP, quit) == SIG_IGN)
107 signal(SIGHUP, SIG_IGN);
108 signal(SIGTERM, quit);
109 signal(SIGPIPE, quit);
110 #ifdef SIGXCPU
111 signal(SIGXCPU, quit);
112 signal(SIGXFSZ, quit);
113 #endif
114
115 progname = argv[0] = fixargv0(argv[0]);
116
117 for (i = 1; i < argc; i++)
118 if (argv[i][0] == '-')
119 switch (argv[i][1]) {
120 case 'x':
121 i++;
122 if (argv[i][0] == '/') {
123 x_c = 1.0/atof(argv[i]+1);
124 ncols = 0;
125 } else
126 ncols = atoi(argv[i]);
127 break;
128 case 'y':
129 i++;
130 if (argv[i][0] == '/') {
131 y_r = 1.0/atof(argv[i]+1);
132 nrows = 0;
133 } else
134 nrows = atoi(argv[i]);
135 break;
136 case 'c':
137 correctaspect = !correctaspect;
138 break;
139 case 'p':
140 i++;
141 outaspect = atof(argv[i]);
142 break;
143 case 'e':
144 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
145 d = pow(2.0, atof(argv[i+1]));
146 else
147 d = atof(argv[i+1]);
148 if (d < 1e-20 || d > 1e20) {
149 fprintf(stderr,
150 "%s: exposure out of range\n",
151 argv[0]);
152 quit(1);
153 }
154 switch (argv[i][2]) {
155 case '\0':
156 scalecolor(exposure, d);
157 break;
158 case 'r':
159 colval(exposure,RED) *= d;
160 break;
161 case 'g':
162 colval(exposure,GRN) *= d;
163 break;
164 case 'b':
165 colval(exposure,BLU) *= d;
166 break;
167 default:
168 goto badopt;
169 }
170 i++;
171 break;
172 case 'f':
173 lampdat = argv[++i];
174 break;
175 case 't':
176 lamptype = argv[++i];
177 break;
178 case '1':
179 singlepass = 1;
180 break;
181 case '2':
182 singlepass = 0;
183 break;
184 case 'n':
185 npts = atoi(argv[++i]) / 2;
186 break;
187 case 's':
188 spread = atof(argv[++i]);
189 break;
190 case 'a':
191 avghot = !avghot;
192 break;
193 case 'h':
194 hotlvl = atof(argv[++i]);
195 break;
196 case 'r':
197 rad = atof(argv[++i]);
198 break;
199 case 'm':
200 thresh = atof(argv[++i]);
201 if (rad <= FTINY)
202 rad = 0.6;
203 break;
204 case 'b':
205 rad = thresh = 0.0;
206 break;
207 default:;
208 badopt:
209 fprintf(stderr, "%s: unknown option: %s\n",
210 progname, argv[i]);
211 quit(1);
212 break;
213 }
214 else
215 break;
216 /* get lamp data (if necessary) */
217 if (lamptype != NULL) {
218 if (loadlamps(lampdat) < 0)
219 quit(1);
220 if ((lampcolor = matchlamp(lamptype)) == NULL) {
221 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
222 quit(1);
223 }
224 for (j = 0; j < 3; j++)
225 if (lampcolor[j] > 1e-4)
226 colval(exposure,j) /= lampcolor[j];
227 freelamps();
228 }
229 /* open input file */
230 if (i == argc) {
231 if (singlepass)
232 fin = stdin;
233 else {
234 tfname = mktemp(template);
235 if ((fin = fopen(tfname, "w+")) == NULL) {
236 fprintf(stderr, "%s: can't create ", progname);
237 fprintf(stderr, "temp file \"%s\"\n", tfname);
238 quit(1);
239 }
240 copyfile(stdin, fin);
241 if (fseek(fin, 0L, 0) == -1) {
242 fprintf(stderr, "%s: seek fail\n", progname);
243 quit(1);
244 }
245 }
246 } else if (i == argc-1) {
247 if ((fin = fopen(argv[i], "r")) == NULL) {
248 fprintf(stderr, "%s: can't open file \"%s\"\n",
249 progname, argv[i]);
250 quit(1);
251 }
252 } else {
253 fprintf(stderr, "%s: bad # file arguments\n", progname);
254 quit(1);
255 }
256 /* get header */
257 getheader(fin, headline, NULL);
258 if (wrongformat) {
259 fprintf(stderr, "%s: input must be a Radiance picture\n",
260 progname);
261 quit(1);
262 }
263 /* add new header info. */
264 printargs(i, argv, stdout);
265 /* get picture size */
266 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
267 fprintf(stderr, "%s: bad picture size\n", progname);
268 quit(1);
269 }
270 if (!(order & YMAJOR))
271 inpaspect = 1.0/inpaspect;
272 /* wrap around for cylindrical view? */
273 wrapfilt = gotview && ourview.type == VT_CYL &&
274 ourview.horiz >= 360.-FTINY && order & YMAJOR;
275 /* compute output resolution */
276 if (ncols <= 0)
277 ncols = x_c*xres + .5;
278 if (nrows <= 0)
279 nrows = y_r*yres + .5;
280 if (outaspect > .01) {
281 d = inpaspect * yres/xres / outaspect;
282 if (d * ncols > nrows)
283 ncols = nrows / d;
284 else
285 nrows = ncols * d;
286 }
287 x_c = (double)ncols/xres;
288 y_r = (double)nrows/yres;
289
290 if (singlepass) { /* skip exposure, etc. */
291 pass1default();
292 pass2(fin);
293 quit(0);
294 }
295
296 fpos = ftell(fin); /* save input file position */
297
298 pass1(fin);
299
300 if (fseek(fin, fpos, 0) == -1) {
301 fprintf(stderr, "%s: seek fail\n", progname);
302 quit(1);
303 }
304 pass2(fin);
305
306 quit(estatus);
307 }
308
309
310 double
311 rgb_bright(clr)
312 COLOR clr;
313 {
314 return(bright(clr));
315 }
316
317
318 double
319 xyz_bright(clr)
320 COLOR clr;
321 {
322 return(clr[CIEY]);
323 }
324
325
326 double (*ourbright)() = rgb_bright;
327
328
329 int
330 headline(s) /* process line from header */
331 char *s;
332 {
333 char fmt[32];
334
335 fputs(s, stdout); /* copy to output */
336 if (isaspect(s)) /* get aspect ratio */
337 inpaspect *= aspectval(s);
338 else if (isexpos(s)) /* get exposure */
339 hotlvl *= exposval(s);
340 else if (formatval(fmt, s)) { /* get format */
341 wrongformat = 0;
342 if (!strcmp(COLRFMT, fmt))
343 ourbright = rgb_bright;
344 else if (!strcmp(CIEFMT, fmt))
345 ourbright = xyz_bright;
346 else
347 wrongformat = !globmatch(PICFMT, fmt);
348 } else if (isview(s) && sscanview(&ourview, s) > 0)
349 gotview++;
350 return(0);
351 }
352
353
354 copyfile(in, out) /* copy a file */
355 register FILE *in, *out;
356 {
357 register int c;
358
359 while ((c = getc(in)) != EOF)
360 putc(c, out);
361
362 if (ferror(out)) {
363 fprintf(stderr, "%s: write error in copyfile\n", progname);
364 quit(1);
365 }
366 }
367
368
369 pass1(in) /* first pass of picture file */
370 FILE *in;
371 {
372 int i;
373 COLOR *scan;
374
375 pass1init();
376
377 scan = (COLOR *)malloc(xres*sizeof(COLOR));
378 if (scan == NULL) {
379 fprintf(stderr, "%s: out of memory\n", progname);
380 quit(1);
381 }
382 for (i = 0; i < yres; i++) {
383 if (freadscan(scan, xres, in) < 0) {
384 nrows = (long)nrows * i / yres; /* adjust frame */
385 if (nrows <= 0) {
386 fprintf(stderr, "%s: empty frame\n", progname);
387 quit(1);
388 }
389 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
390 progname, (int)(100L*i/yres));
391 yres = i;
392 y_r = (double)nrows/yres;
393 estatus++;
394 break;
395 }
396 pass1scan(scan, i);
397 }
398 free((void *)scan);
399 }
400
401
402 pass2(in) /* last pass on file, write to stdout */
403 FILE *in;
404 {
405 int yread;
406 int ycent, xcent;
407 int r, c;
408
409 pass2init();
410 scan2init();
411 yread = 0;
412 for (r = 0; r < nrows; r++) {
413 ycent = (r+.5)*yres/nrows;
414 while (yread <= ycent+yrad) {
415 if (yread < yres) {
416 if (freadscan(scanin[yread%barsize],
417 xres, in) < 0) {
418 fprintf(stderr,
419 "%s: truncated input (y=%d)\n",
420 progname, yres-1-yread);
421 quit(1);
422 }
423 pass2scan(scanin[yread%barsize], yread);
424 }
425 yread++;
426 }
427 if (obarsize > 0)
428 scan2sync(r);
429 for (c = 0; c < ncols; c++) {
430 xcent = (c+.5)*xres/ncols;
431 if (thresh > FTINY)
432 dothresh(xcent, ycent, c, r);
433 else if (rad > FTINY)
434 dogauss(scanout[c], xcent, ycent, c, r);
435 else
436 dobox(scanout[c], xcent, ycent, c, r);
437 }
438 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
439 fprintf(stderr, "%s: write error in pass2\n", progname);
440 quit(1);
441 }
442 }
443 /* skip leftover input */
444 while (yread < yres) {
445 if (freadscan(scanin[0], xres, in) < 0)
446 break;
447 yread++;
448 }
449 scan2flush(); /* flush output */
450 }
451
452
453 scan2init() /* prepare scanline arrays */
454 {
455 COLOR ctmp;
456 double d;
457 register int i;
458
459 xbrad = xres/ncols/2 + 1;
460 ybrad = yres/nrows/2 + 1;
461 if (rad > FTINY) {
462 if (nrows >= yres && ncols >= xres)
463 rad *= (y_r + x_c)/2.0;
464
465 if (thresh > FTINY) {
466 orad = CHECKRAD*THRESHRAD*rad + 1;
467 xrad = orad/x_c + xbrad;
468 yrad = orad/y_r + ybrad;
469 obarsize = 2*orad + 1;
470 } else {
471 xrad = CHECKRAD*rad/x_c + 1;
472 yrad = CHECKRAD*rad/y_r + 1;
473 }
474 initmask(); /* initialize filter table */
475 } else {
476 xrad = xbrad;
477 yrad = ybrad;
478 }
479 barsize = 2*yrad + 1;
480 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
481 if (scanin == NULL)
482 goto memerr;
483 for (i = 0; i < barsize; i++) {
484 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
485 if (scanin[i] == NULL)
486 goto memerr;
487 }
488 if (obarsize > 0) {
489 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
490 greybar = (float **)malloc(obarsize*sizeof(float *));
491 if (scoutbar == NULL | greybar == NULL)
492 goto memerr;
493 for (i = 0; i < obarsize; i++) {
494 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
495 greybar[i] = (float *)malloc(ncols*sizeof(float));
496 if (scoutbar[i] == NULL | greybar[i] == NULL)
497 goto memerr;
498 }
499 } else {
500 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
501 if (scanout == NULL)
502 goto memerr;
503 }
504 /* record pixel aspect ratio */
505 if (!correctaspect) {
506 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
507 if (!FEQ(d,1.0))
508 fputaspect(d, stdout);
509 }
510 /* record exposure */
511 d = (*ourbright)(exposure);
512 if (!FEQ(d,1.0))
513 fputexpos(d, stdout);
514 /* record color correction */
515 copycolor(ctmp, exposure);
516 scalecolor(ctmp, 1.0/d);
517 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
518 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
519 fputcolcor(ctmp, stdout);
520 printf("\n");
521 /* write out resolution */
522 fputresolu(order, ncols, nrows, stdout);
523 return;
524 memerr:
525 fprintf(stderr, "%s: out of memory\n", progname);
526 quit(1);
527 }
528
529
530 scan2sync(r) /* synchronize grey averages and output scan */
531 int r;
532 {
533 static int nextrow = 0;
534 COLOR ctmp;
535 int ybot;
536 register int c;
537 /* average input scanlines */
538 while (nextrow <= r+orad && nextrow < nrows) {
539 ybot = (nextrow+.5)*yres/nrows;
540 for (c = 0; c < ncols; c++) {
541 dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
542 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
543 }
544 /* and zero output scanline */
545 bzero((char *)scoutbar[nextrow%obarsize], ncols*sizeof(COLOR));
546 nextrow++;
547 }
548 /* point to top scanline for output */
549 if (r-orad >= 0)
550 scanout = scoutbar[(r-orad)%obarsize];
551 else
552 scanout = NULL;
553 }
554
555
556 scan2flush() /* flush output buffer */
557 {
558 register int r;
559
560 for (r = nrows-orad; r < nrows; r++)
561 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
562 break;
563 if (fflush(stdout) < 0) {
564 fprintf(stderr, "%s: write error at end of pass2\n", progname);
565 quit(1);
566 }
567 }
568
569
570 void
571 quit(code) /* remove temporary file and exit */
572 int code;
573 {
574 if (tfname != NULL)
575 unlink(tfname);
576 exit(code);
577 }
