root/radiance/ray/src/px/pfilt.c
Revision: 2.3
Committed: Tue Sep 8 15:33:08 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.2: +2 -3 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 */
12
13 #include <stdio.h>
14
15 #include <signal.h>
16
17 #include "color.h"
18
19 #include "resolu.h"
20
21 #include "paths.h"
22
23 extern char *malloc();
24 extern float *matchlamp();
25
26 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
27
28 #define CHECKRAD 1.5 /* radius to check for filtering */
29
30 COLOR exposure = WHTCOLOR; /* exposure for the frame */
31
32 double rad = 0.0; /* output pixel radius for filtering */
33
34 int nrows = 0; /* number of rows for output */
35 int ncols = 0; /* number of columns for output */
36
37 double x_c = 1.0; /* ratio of output x size to input */
38 double y_r = 1.0; /* ratio of output y size to input */
39
40 int singlepass = 0; /* true means skip first pass */
41
42 int avghot = 0; /* true means average in bright spots */
43
44 double hotlvl = 1000.0; /* level considered "hot" */
45
46 int npts = 0; /* (half) number of points for stars */
47
48 double spread = 1e-4; /* spread for star points */
49
50 char *tfname = NULL;
51
52 char *lampdat = "lamp.tab"; /* lamp data file */
53
54 int order; /* scanline ordering of input */
55 int xres, yres; /* resolution of input */
56 double inpaspect = 1.0; /* pixel aspect ratio of input */
57 int correctaspect = 0; /* aspect ratio correction? */
58
59 int wrongformat = 0;
60
61 int xrad; /* x window size */
62 int yrad; /* y window size */
63
64 int barsize; /* size of input scan bar */
65 COLOR **scanin; /* input scan bar */
66 COLOR *scanout; /* output scan line */
67
68 char *progname;
69
70
71 main(argc, argv)
72 int argc;
73 char **argv;
74 {
75 extern double pow();
76 extern long ftell();
77 extern int quit(), headline();
78 FILE *fin;
79 float *lampcolor;
80 char *lamptype = NULL;
81 long fpos;
82 double outaspect = 0.0;
83 double d;
84 int i, j;
85
86 if (signal(SIGINT, quit) == SIG_IGN)
87 signal(SIGINT, SIG_IGN);
88 if (signal(SIGHUP, quit) == SIG_IGN)
89 signal(SIGINT, SIG_IGN);
90 signal(SIGTERM, quit);
91 signal(SIGPIPE, quit);
92 #ifdef SIGXCPU
93 signal(SIGXCPU, quit);
94 signal(SIGXFSZ, quit);
95 #endif
96
97 progname = argv[0];
98
99 for (i = 1; i < argc; i++)
100 if (argv[i][0] == '-')
101 switch (argv[i][1]) {
102 case 'x':
103 i++;
104 if (argv[i][0] == '/') {
105 x_c = 1.0/atof(argv[i]+1);
106 ncols = 0;
107 } else
108 ncols = atoi(argv[i]);
109 break;
110 case 'y':
111 i++;
112 if (argv[i][0] == '/') {
113 y_r = 1.0/atof(argv[i]+1);
114 nrows = 0;
115 } else
116 nrows = atoi(argv[i]);
117 break;
118 case 'c':
119 correctaspect = !correctaspect;
120 break;
121 case 'p':
122 i++;
123 outaspect = atof(argv[i]);
124 break;
125 case 'e':
126 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
127 d = pow(2.0, atof(argv[i+1]));
128 else
129 d = atof(argv[i+1]);
130 if (d < 1e-20 || d > 1e20) {
131 fprintf(stderr,
132 "%s: exposure out of range\n",
133 argv[0]);
134 exit(1);
135 }
136 switch (argv[i][2]) {
137 case '\0':
138 scalecolor(exposure, d);
139 break;
140 case 'r':
141 colval(exposure,RED) *= d;
142 break;
143 case 'g':
144 colval(exposure,GRN) *= d;
145 break;
146 case 'b':
147 colval(exposure,BLU) *= d;
148 break;
149 default:
150 goto badopt;
151 }
152 i++;
153 break;
154 case 'f':
155 lampdat = argv[++i];
156 break;
157 case 't':
158 lamptype = argv[++i];
159 break;
160 case '1':
161 singlepass = 1;
162 break;
163 case '2':
164 singlepass = 0;
165 break;
166 case 'n':
167 npts = atoi(argv[++i]) / 2;
168 break;
169 case 's':
170 spread = atof(argv[++i]);
171 break;
172 case 'a':
173 avghot = !avghot;
174 break;
175 case 'h':
176 hotlvl = atof(argv[++i]);
177 break;
178 case 'r':
179 rad = atof(argv[++i]);
180 break;
181 case 'b':
182 rad = 0.0;
183 break;
184 default:;
185 badopt:
186 fprintf(stderr, "%s: unknown option: %s\n",
187 progname, argv[i]);
188 quit(1);
189 break;
190 }
191 else
192 break;
193 /* get lamp data (if necessary) */
194 if (lamptype != NULL) {
195 if (loadlamps(lampdat) < 0)
196 quit(1);
197 if ((lampcolor = matchlamp(lamptype)) == NULL) {
198 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
199 quit(1);
200 }
201 for (i = 0; i < 3; i++)
202 if (lampcolor[i] > 1e-4)
203 colval(exposure,i) /= lampcolor[i];
204 freelamps();
205 }
206 /* open input file */
207 if (i == argc) {
208 if (singlepass)
209 fin = stdin;
210 else {
211 tfname = mktemp(TEMPLATE);
212 if ((fin = fopen(tfname, "w+")) == NULL) {
213 fprintf(stderr, "%s: can't create ", progname);
214 fprintf(stderr, "temp file \"%s\"\n", tfname);
215 quit(1);
216 }
217 copyfile(stdin, fin);
218 if (fseek(fin, 0L, 0) == -1) {
219 fprintf(stderr, "%s: seek fail\n", progname);
220 quit(1);
221 }
222 }
223 } else if (i == argc-1) {
224 if ((fin = fopen(argv[i], "r")) == NULL) {
225 fprintf(stderr, "%s: can't open file \"%s\"\n",
226 progname, argv[i]);
227 quit(1);
228 }
229 } else {
230 fprintf(stderr, "%s: bad # file arguments\n", progname);
231 quit(1);
232 }
233 /* get header */
234 getheader(fin, headline, NULL);
235 if (wrongformat) {
236 fprintf(stderr, "%s: input must be a Radiance picture\n",
237 progname);
238 quit(1);
239 }
240 /* add new header info. */
241 printargs(i, argv, stdout);
242 /* get picture size */
243 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
244 fprintf(stderr, "%s: bad picture size\n", progname);
245 quit(1);
246 }
247 if (!(order & YMAJOR))
248 inpaspect = 1.0/inpaspect;
249 /* compute output resolution */
250 if (ncols <= 0)
251 ncols = x_c*xres + .5;
252 if (nrows <= 0)
253 nrows = y_r*yres + .5;
254 if (outaspect > .01) {
255 d = inpaspect * yres/xres / outaspect;
256 if (d * ncols > nrows)
257 ncols = nrows / d;
258 else
259 nrows = ncols * d;
260 }
261 x_c = (double)ncols/xres;
262 y_r = (double)nrows/yres;
263
264 if (singlepass) { /* skip exposure, etc. */
265 pass1default();
266 pass2(fin);
267 quit(0);
268 }
269
270 fpos = ftell(fin); /* save input file position */
271
272 pass1(fin);
273
274 if (fseek(fin, fpos, 0) == -1) {
275 fprintf(stderr, "%s: seek fail\n", progname);
276 quit(1);
277 }
278 pass2(fin);
279
280 quit(0);
281 }
282
283
284 headline(s) /* process line from header */
285 char *s;
286 {
287 char fmt[32];
288
289 fputs(s, stdout); /* copy to output */
290 if (isaspect(s)) /* get aspect ratio */
291 inpaspect *= aspectval(s);
292 else if (isformat(s)) {
293 formatval(fmt, s);
294 wrongformat = strcmp(fmt, COLRFMT);
295 }
296 }
297
298
299 copyfile(in, out) /* copy a file */
300 register FILE *in, *out;
301 {
302 register int c;
303
304 while ((c = getc(in)) != EOF)
305 putc(c, out);
306
307 if (ferror(out)) {
308 fprintf(stderr, "%s: write error in copyfile\n", progname);
309 quit(1);
310 }
311 }
312
313
314 pass1(in) /* first pass of picture file */
315 FILE *in;
316 {
317 int i;
318 COLOR *scan;
319
320 pass1init();
321
322 scan = (COLOR *)malloc(xres*sizeof(COLOR));
323 if (scan == NULL) {
324 fprintf(stderr, "%s: out of memory\n", progname);
325 quit(1);
326 }
327 for (i = 0; i < yres; i++) {
328 if (freadscan(scan, xres, in) < 0) {
329 nrows = nrows * i / yres; /* adjust frame */
330 if (nrows <= 0) {
331 fprintf(stderr, "%s: empty frame\n", progname);
332 quit(1);
333 }
334 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
335 progname, 100*i/yres);
336 yres = i;
337 y_r = (double)nrows/yres;
338 break;
339 }
340 pass1scan(scan, i);
341 }
342 free((char *)scan);
343 }
344
345
346 pass2(in) /* last pass on file, write to stdout */
347 FILE *in;
348 {
349 int yread;
350 int ycent, xcent;
351 int r, c;
352
353 pass2init();
354 scan2init();
355 yread = 0;
356 for (r = 0; r < nrows; r++) {
357 ycent = (long)r*yres/nrows;
358 while (yread <= ycent+yrad) {
359 if (yread < yres) {
360 if (freadscan(scanin[yread%barsize],
361 xres, in) < 0) {
362 fprintf(stderr,
363 "%s: bad read (y=%d)\n",
364 progname, yres-1-yread);
365 quit(1);
366 }
367 pass2scan(scanin[yread%barsize], yread);
368 }
369 yread++;
370 }
371 for (c = 0; c < ncols; c++) {
372 xcent = (long)c*xres/ncols;
373 if (rad <= 0.0)
374 dobox(scanout[c], xcent, ycent, c, r);
375 else
376 dogauss(scanout[c], xcent, ycent, c, r);
377 }
378 if (fwritescan(scanout, ncols, stdout) < 0) {
379 fprintf(stderr, "%s: write error in pass2\n", progname);
380 quit(1);
381 }
382 }
383 /* skip leftovers */
384 while (yread < yres) {
385 if (freadscan(scanin[0], xres, in) < 0)
386 break;
387 yread++;
388 }
389 }
390
391
392 scan2init() /* prepare scanline arrays */
393 {
394 COLOR ctmp;
395 double d;
396 register int i;
397
398 if (rad <= 0.0) {
399 xrad = xres/ncols/2 + 1;
400 yrad = yres/nrows/2 + 1;
401 } else {
402 if (nrows >= yres && ncols >= xres)
403 rad *= (y_r + x_c)/2.0;
404
405 xrad = CHECKRAD*rad/x_c + 1;
406 yrad = CHECKRAD*rad/y_r + 1;
407
408 initmask(); /* initialize filter table */
409 }
410 barsize = 2*yrad + 1;
411 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
412 for (i = 0; i < barsize; i++) {
413 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
414 if (scanin[i] == NULL) {
415 fprintf(stderr, "%s: out of memory\n", progname);
416 quit(1);
417 }
418 }
419 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
420 if (scanout == NULL) {
421 fprintf(stderr, "%s: out of memory\n", progname);
422 quit(1);
423 }
424 /* record pixel aspect ratio */
425 if (!correctaspect) {
426 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
427 if (!FEQ(d,1.0))
428 fputaspect(d, stdout);
429 }
430 /* record exposure */
431 d = bright(exposure);
432 if (!FEQ(d,1.0))
433 fputexpos(d, stdout);
434 /* record color correction */
435 copycolor(ctmp, exposure);
436 scalecolor(ctmp, 1.0/d);
437 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
438 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
439 fputcolcor(ctmp, stdout);
440 printf("\n");
441 /* write out resolution */
442 fputresolu(order, ncols, nrows, stdout);
443 }
444
445
446 quit(code) /* remove temporary file and exit */
447 int code;
448 {
449 if (tfname != NULL)
450 unlink(tfname);
451 exit(code);
452 }
