root/radiance/ray/src/px/pfilt.c
Revision: 1.1
Committed: Thu Feb 2 10:49:26 1989 UTC (36 years, 3 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 */
12
13 #include <stdio.h>
14
15 #include <signal.h>
16
17 #include "color.h"
18
19
20 extern char *malloc();
21
22 #define CHECKRAD 1.5 /* radius to check for filtering */
23
24 COLOR exposure = WHTCOLOR; /* exposure for the frame */
25
26 double rad = 0.0; /* output pixel radius for filtering */
27
28 int nrows = 0; /* number of rows for output */
29 int ncols = 0; /* number of columns for output */
30
31 int singlepass = 0; /* true means skip first pass */
32
33 int avghot = 0; /* true means average in bright spots */
34
35 double hotlvl = 1000.0; /* level considered "hot" */
36
37 int npts = 0; /* (half) number of points for stars */
38
39 double spread = 1e-4; /* spread for star points */
40
41 #define TEMPLATE "/usr/tmp/pfXXXXXX"
42
43 char *tfname = NULL;
44
45 int xres, yres; /* resolution of input */
46
47 double x_c, y_r; /* conversion factors */
48
49 int xrad; /* x window size */
50 int yrad; /* y window size */
51
52 int barsize; /* size of input scan bar */
53 COLOR **scanin; /* input scan bar */
54 COLOR *scanout; /* output scan line */
55
56 char *progname;
57
58
59 main(argc, argv)
60 int argc;
61 char **argv;
62 {
63 extern char *mktemp();
64 extern double atof(), pow();
65 extern long ftell();
66 extern int quit();
67 FILE *fin;
68 long fpos;
69 double d;
70 int i;
71
72 if (signal(SIGINT, quit) == SIG_IGN)
73 signal(SIGINT, SIG_IGN);
74 if (signal(SIGHUP, quit) == SIG_IGN)
75 signal(SIGINT, SIG_IGN);
76 signal(SIGTERM, quit);
77 signal(SIGPIPE, quit);
78 #ifdef SIGXCPU
79 signal(SIGXCPU, quit);
80 signal(SIGXFSZ, quit);
81 #endif
82
83 progname = argv[0];
84
85 for (i = 1; i < argc; i++)
86 if (argv[i][0] == '-')
87 switch (argv[i][1]) {
88 case 'x':
89 ncols = atoi(argv[++i]);
90 break;
91 case 'y':
92 nrows = atoi(argv[++i]);
93 break;
94 case 'e':
95 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
96 d = pow(2.0, atof(argv[i+1]));
97 else
98 d = atof(argv[i+1]);
99 switch (argv[i][2]) {
100 case '\0':
101 scalecolor(exposure, d);
102 break;
103 case 'r':
104 colval(exposure,RED) *= d;
105 break;
106 case 'g':
107 colval(exposure,GRN) *= d;
108 break;
109 case 'b':
110 colval(exposure,BLU) *= d;
111 break;
112 default:
113 goto badopt;
114 }
115 i++;
116 break;
117 case '1':
118 singlepass = 1;
119 break;
120 case 'p':
121 npts = atoi(argv[++i]) / 2;
122 break;
123 case 's':
124 spread = atof(argv[++i]);
125 break;
126 case 'a':
127 avghot = !avghot;
128 break;
129 case 'h':
130 hotlvl = atof(argv[++i]);
131 break;
132 case 'r':
133 rad = atof(argv[++i]);
134 break;
135 case 'b':
136 rad = 0.0;
137 break;
138 default:;
139 badopt:
140 fprintf(stderr, "%s: unknown option: %s\n",
141 progname, argv[i]);
142 quit(1);
143 break;
144 }
145 else
146 break;
147
148 if (i == argc) {
149 if (singlepass)
150 fin = stdin;
151 else {
152 tfname = mktemp(TEMPLATE);
153 if ((fin = fopen(tfname, "w+")) == NULL) {
154 fprintf(stderr, "%s: can't create ", progname);
155 fprintf(stderr, "temp file \"%s\"\n", tfname);
156 quit(1);
157 }
158 copyfile(stdin, fin);
159 if (fseek(fin, 0L, 0) == -1) {
160 fprintf(stderr, "%s: seek fail\n", progname);
161 quit(1);
162 }
163 }
164 } else if (i == argc-1) {
165 if ((fin = fopen(argv[i], "r")) == NULL) {
166 fprintf(stderr, "%s: can't open file \"%s\"\n",
167 progname, argv[i]);
168 quit(1);
169 }
170 } else {
171 fprintf(stderr, "%s: bad # file arguments\n", progname);
172 quit(1);
173 }
174 /* copy header */
175 copyheader(fin, stdout);
176 /* add new header info. */
177 printargs(i, argv, stdout);
178 /* get picture size */
179 if (fscanf(fin, "-Y %d +X %d\n", &yres, &xres) != 2) {
180 fprintf(stderr, "%s: bad picture size\n", progname);
181 quit(1);
182 }
183 if (ncols <= 0)
184 ncols = xres;
185 if (nrows <= 0)
186 nrows = yres;
187
188 if (singlepass) {
189 /* skip exposure, etc. */
190 pass1default();
191 pass2(fin);
192 quit(0);
193 }
194
195 fpos = ftell(fin); /* save input file position */
196
197 pass1(fin);
198
199 if (fseek(fin, fpos, 0) == -1) {
200 fprintf(stderr, "%s: seek fail\n", progname);
201 quit(1);
202 }
203 pass2(fin);
204
205 quit(0);
206 }
207
208
209 copyfile(in, out) /* copy a file */
210 register FILE *in, *out;
211 {
212 register int c;
213
214 while ((c = getc(in)) != EOF)
215 putc(c, out);
216
217 if (ferror(out)) {
218 fprintf(stderr, "%s: write error in copyfile\n", progname);
219 quit(1);
220 }
221 }
222
223
224 pass1(in) /* first pass of picture file */
225 FILE *in;
226 {
227 int i;
228 COLOR *scan;
229
230 pass1init();
231
232 scan = (COLOR *)malloc(xres*sizeof(COLOR));
233 if (scan == NULL) {
234 fprintf(stderr, "%s: out of memory\n", progname);
235 quit(1);
236 }
237 for (i = 0; i < yres; i++) {
238 if (freadscan(scan, xres, in) < 0) {
239 nrows = nrows * i / yres; /* adjust frame */
240 if (nrows <= 0) {
241 fprintf(stderr, "%s: empty frame\n", progname);
242 quit(1);
243 }
244 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
245 progname, 100*i/yres);
246 yres = i;
247 break;
248 }
249 pass1scan(scan, i);
250 }
251 free((char *)scan);
252 }
253
254
255 pass2(in) /* last pass on file, write to stdout */
256 FILE *in;
257 {
258 int yread;
259 int ycent, xcent;
260 int r, c;
261
262 pass2init();
263 scan2init();
264 yread = 0;
265 for (r = 0; r < nrows; r++) {
266 ycent = (long)r*yres/nrows;
267 while (yread <= ycent+yrad) {
268 if (yread < yres) {
269 if (freadscan(scanin[yread%barsize],
270 xres, in) < 0) {
271 fprintf(stderr,
272 "%s: bad read (y=%d)\n",
273 progname, yres-1-yread);
274 quit(1);
275 }
276 pass2scan(scanin[yread%barsize], yread);
277 }
278 yread++;
279 }
280 for (c = 0; c < ncols; c++) {
281 xcent = (long)c*xres/ncols;
282 if (rad <= 0.0)
283 dobox(scanout[c], xcent, ycent, c, r);
284 else
285 dogauss(scanout[c], xcent, ycent, c, r);
286 }
287 if (fwritescan(scanout, ncols, stdout) < 0) {
288 fprintf(stderr, "%s: write error in pass2\n", progname);
289 quit(1);
290 }
291 }
292 }
293
294
295 scan2init() /* prepare scanline arrays */
296 {
297 double e;
298 register int i;
299
300 x_c = (double)ncols/xres;
301 y_r = (double)nrows/yres;
302
303 if (rad <= 0.0) {
304 xrad = xres/ncols/2 + 1;
305 yrad = yres/nrows/2 + 1;
306 } else {
307 if (nrows >= yres && ncols >= xres)
308 rad *= (y_r + x_c)/2.0;
309
310 xrad = CHECKRAD*rad/x_c + 1;
311 yrad = CHECKRAD*rad/y_r + 1;
312
313 initmask(); /* initialize filter table */
314 }
315 barsize = 2 * yrad;
316 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
317 for (i = 0; i < barsize; i++) {
318 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
319 if (scanin[i] == NULL) {
320 fprintf(stderr, "%s: out of memory\n", progname);
321 quit(1);
322 }
323 }
324 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
325 if (scanout == NULL) {
326 fprintf(stderr, "%s: out of memory\n", progname);
327 quit(1);
328 }
329 e = bright(exposure);
330 if (e < 1-1e-7 || e > 1+1e-7) /* record exposure */
331 printf("EXPOSURE=%e\n", e);
332 printf("\n");
333 printf("-Y %d +X %d\n", nrows, ncols); /* write picture size */
334 }
335
336
337 quit(code) /* remove temporary file and exit */
338 int code;
339 {
340 if (tfname != NULL)
341 unlink(tfname);
342 exit(code);
343 }
