refactor(pfilt): minor code fixes and reorg
fix(pfilt): Not sure if binary mode is working under Windows
fix(pfilt): Need to set primary channels for pbright() to work properly
feat(pfilt): Added support for hyperspectral image filtering
refactor: Cleaned up and simplified #include's
Fixed issue with pfilt -m option and non-integer size divisors
Removed '//' comments that don't fit with standard C
Continued ANSIfication. Added headerfiles pfilt.h and clrtab.h.
Fixed pre-release upsampling bug in new filtering kernel
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
made output pixel positioning more precise
added exit status change for truncated input files
fixed bug in indexing and size of buffers for -m option
added compatibility with Radiance XYZE picture format
improved error message for truncated input
fixed bug in lamp data routine
minor compiler warning fixes
minor bug fixes
minor optimization
added -m option for sample smoothing
changed default setting of hotlvl and made it absolute
bug fix for 16-bit integers (DOS)
Changes for PC port
added insurance for lampcolor[i] == 0.0
improved gaussian filtering
added use of COLORCORR header i/o
moved loading of lamp data before opening of input file
added option to override output of aspect ratio change
recomputed y_r after picture adjustment (bug fix)
fixed pass2() so it reads all its input regardless
added code to maintain pixel aspect ratio
changed EXPOSURE information interface
Added -2 option for two-pass
resolution ratio supercedes previous specification
consolidated resolution ratio variables
changed syntax for resolution ratios
added scaling options for x and y resolution
