root/Development/ray/src/px/pfilt.c
Revision: 2.42
Committed: Wed Jul 2 16:54:44 2025 UTC (3 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.41: +2 -2 lines
perf: Made +/-0.5% threshold for caring about pixel aspect ratio consistent
2 static const char RCSid[] = "$Id: pfilt.c,v 2.41 2025/06/07 05:09:46 greg Exp $";
5 * pfilt.c - program to post-process picture file.
6 *
7 * 9/26/85
8 * 6/23/93 Added additional buffers for value spreading
9 */
10
11 #include "copyright.h"
12
13 #include <signal.h>
14 #include "pfilt.h"
15 #include "platform.h"
16 #include "view.h"
17
18 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
19
20 double CHECKRAD = 2.0; /* radius to check for filtering */
21
22 #define THRESHRAD 5.0 /* maximum sample spread in output */
23
24 COLOR exposure = WHTCOLOR; /* exposure for the frame */
25
26 double rad = 0.0; /* output pixel radius for filtering */
27
28 double thresh = 0.0; /* maximum contribution for subpixel */
29
30 int nrows = 0; /* number of rows for output */
31 int ncols = 0; /* number of columns for output */
32
33 double x_c = 1.0; /* ratio of output x size to input */
34 double y_r = 1.0; /* ratio of output y size to input */
35
36 int singlepass = 0; /* true means skip first pass */
37
38 int avghot = 0; /* true means average in bright spots */
39
40 double hotlvl = 100.0; /* level considered "hot" */
41
42 int npts = 0; /* (half) number of points for stars */
43
44 double spread = 1e-4; /* spread for star points */
45
46 char *tfname = NULL;
47
48 char template[] = TEMPLATE;
49
50 char *lampdat = "lamp.tab"; /* lamp data file */
51
52 int order; /* scanline ordering of input */
53 int xres, yres; /* resolution of input */
54 double inpaspect = 1.0; /* pixel aspect ratio of input */
55 int correctaspect = 0; /* aspect ratio correction? */
56
57 int wrongformat = 0;
58
59 VIEW ourview = STDVIEW;
60 int gotview = 0;
61 int wrapfilt = 0; /* wrap filter horizontally? */
62
63 int estatus = 0; /* exit status (for non-fatal errors) */
64
65 int xrad; /* x search radius */
66 int yrad; /* y search radius */
67 int xbrad; /* x box size */
68 int ybrad; /* y box size */
69
70 int barsize; /* size of input scan bar */
71 COLORV **scanin; /* input scan bar */
72 COLORV *scanout; /* output scan line */
73 COLORV **scoutbar; /* output scan bar (if thresh > 0) */
74 float **greybar; /* grey-averaged input values */
75 int obarsize = 0; /* size of output scan bar */
76 int orad = 0; /* output window radius */
77
78 static void copyfile(FILE *infp, FILE *out);
79 static void pass1(FILE *infp);
80 static void pass2(FILE *infp);
81 static void scan2init(void);
82 static void scan2sync(int r);
83 static void scan2flush(void);
84
85
86 static double
87 rgb_bright(
88 SCOLOR clr
89 )
90 {
91 return(bright(clr));
92 }
93
94
95 static double
96 xyz_bright(
97 SCOLOR clr
98 )
99 {
100 return(colval(clr,CIEY));
101 }
102
103
104 static double
105 spec_bright(
106 SCOLOR clr
107 )
108 {
109 return(pbright(clr));
110 }
111
112
113 brightfunc_t *ourbright = rgb_bright;
114
115
116 static int
117 headline( /* process line from header */
118 char *s,
119 void *p
120 )
121 {
122 char fmt[MAXFMTLEN];
123
124 fputs(s, stdout); /* copy to output */
125 if (isaspect(s)) /* get aspect ratio */
126 inpaspect *= aspectval(s);
127 else if (isexpos(s)) /* get exposure */
128 hotlvl *= exposval(s);
129 else if (isncomp(s)) /* get #components (spectral) */
130 NCSAMP = ncompval(s);
131 else if (iswlsplit(s)) /* get wavelength partitions */
132 wlsplitval(WLPART, s);
133 else if (formatval(fmt, s)) { /* get format */
134 wrongformat = 0;
135 if (!strcmp(COLRFMT, fmt))
136 ourbright = rgb_bright;
137 else if (!strcmp(CIEFMT, fmt))
138 ourbright = xyz_bright;
139 else if (!strcmp(SPECFMT, fmt))
140 ourbright = spec_bright;
141 else
142 wrongformat = !globmatch(PICFMT, fmt);
143 } else if (isview(s) && sscanview(&ourview, s) > 0)
144 gotview++;
145 return(0);
146 }
147
148
149 int
150 main(
151 int argc,
152 char **argv
153 )
154 {
155 FILE *fin;
156 float *lampcolor;
157 char *lamptype = NULL;
158 long fpos;
159 double outaspect = 0.0;
160 double d;
161 int i, j;
162
163 fixargv0(argv[0]); /* sets global progname */
164 SET_DEFAULT_BINARY();
165 SET_FILE_BINARY(stdin);
166 SET_FILE_BINARY(stdout);
167 if (signal(SIGINT, quit) == SIG_IGN)
168 signal(SIGINT, SIG_IGN);
169 #ifdef SIGHUP
170 if (signal(SIGHUP, quit) == SIG_IGN)
171 signal(SIGHUP, SIG_IGN);
172 #endif
173 signal(SIGTERM, quit);
174 #ifdef SIGPIPE
175 signal(SIGPIPE, quit);
176 #endif
177 #ifdef SIGXCPU
178 signal(SIGXCPU, quit);
179 signal(SIGXFSZ, quit);
180 #endif
181 for (i = 1; i < argc; i++)
182 if (argv[i][0] == '-')
183 switch (argv[i][1]) {
184 case 'x':
185 i++;
186 if (argv[i][0] == '/') {
187 x_c = 1.0/atof(argv[i]+1);
188 ncols = 0;
189 } else
190 ncols = atoi(argv[i]);
191 break;
192 case 'y':
193 i++;
194 if (argv[i][0] == '/') {
195 y_r = 1.0/atof(argv[i]+1);
196 nrows = 0;
197 } else
198 nrows = atoi(argv[i]);
199 break;
200 case 'c':
201 correctaspect = !correctaspect;
202 break;
203 case 'p':
204 i++;
205 outaspect = atof(argv[i]);
206 break;
207 case 'e':
208 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
209 d = pow(2.0, atof(argv[i+1]));
210 else
211 d = atof(argv[i+1]);
212 if (d < 1e-20 || d > 1e20) {
213 fprintf(stderr,
214 "%s: exposure out of range\n",
215 progname);
216 quit(1);
217 }
218 switch (argv[i][2]) {
219 case '\0':
220 scalecolor(exposure, d);
221 break;
222 case 'r':
223 colval(exposure,RED) *= d;
224 break;
225 case 'g':
226 colval(exposure,GRN) *= d;
227 break;
228 case 'b':
229 colval(exposure,BLU) *= d;
230 break;
231 default:
232 goto badopt;
233 }
234 i++;
235 break;
236 case 'f':
237 lampdat = argv[++i];
238 break;
239 case 't':
240 lamptype = argv[++i];
241 break;
242 case '1':
243 singlepass = 1;
244 break;
245 case '2':
246 singlepass = 0;
247 break;
248 case 'n':
249 npts = atoi(argv[++i]) / 2;
250 break;
251 case 's':
252 spread = atof(argv[++i]);
253 break;
254 case 'a':
255 avghot = !avghot;
256 break;
257 case 'h':
258 hotlvl = atof(argv[++i]);
259 break;
260 case 'r':
261 rad = atof(argv[++i]);
262 break;
263 case 'm':
264 thresh = atof(argv[++i]);
265 if (rad <= FTINY)
266 rad = 0.6;
267 break;
268 case 'b':
269 rad = thresh = 0.0;
270 break;
271 default:;
272 badopt:
273 fprintf(stderr, "%s: unknown option: %s\n",
274 progname, argv[i]);
275 quit(1);
276 break;
277 }
278 else
279 break;
280 /* get lamp data (if necessary) */
281 if (lamptype != NULL) {
282 if (loadlamps(lampdat) < 0)
283 quit(1);
284 if ((lampcolor = matchlamp(lamptype)) == NULL) {
285 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
286 quit(1);
287 }
288 for (j = 0; j < 3; j++)
289 if (lampcolor[j] > 1e-4)
290 colval(exposure,j) /= lampcolor[j];
291 freelamps();
292 }
293 /* open input file */
294 if (i == argc) {
295 if (singlepass)
296 fin = stdin;
297 else {
298 tfname = mktemp(template);
299 if ((fin = fopen(tfname, "w+b")) == NULL) {
300 fprintf(stderr, "%s: can't create ", progname);
301 fprintf(stderr, "temp file \"%s\"\n", tfname);
302 quit(1);
303 }
304 copyfile(stdin, fin);
305 if (fseek(fin, 0L, 0) == -1) {
306 fprintf(stderr, "%s: seek fail\n", progname);
307 quit(1);
308 }
309 }
310 } else if (i == argc-1) {
311 if ((fin = fopen(argv[i], "rb")) == NULL) {
312 fprintf(stderr, "%s: can't open file \"%s\"\n",
313 progname, argv[i]);
314 quit(1);
315 }
316 } else {
317 fprintf(stderr, "%s: bad # file arguments\n", progname);
318 quit(1);
319 }
320 /* get header */
321 getheader(fin, headline, NULL);
322 if (wrongformat) {
323 fprintf(stderr, "%s: input must be a Radiance picture\n",
324 progname);
325 quit(1);
326 }
327 if ((ourbright == spec_bright) ^ (NCSAMP > 3) ||
328 setspectrsamp(CNDX, WLPART) < 0) {
329 fprintf(stderr, "%s: bad number of components\n", progname);
330 quit(1);
331 }
332 /* add new header info. */
333 printargs(i, argv, stdout);
334 /* get picture size */
335 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
336 fprintf(stderr, "%s: bad picture size\n", progname);
337 quit(1);
338 }
339 if (!(order & YMAJOR))
340 inpaspect = 1.0/inpaspect;
341 /* wrap around for cylindrical view? */
342 wrapfilt = gotview && ourview.type == VT_CYL &&
343 ourview.horiz >= 360.-FTINY && order & YMAJOR;
344 /* compute output resolution */
345 if (ncols <= 0)
346 ncols = x_c*xres + .5;
347 if (nrows <= 0)
348 nrows = y_r*yres + .5;
349 if (outaspect > .01) {
350 d = inpaspect * yres/xres / outaspect;
351 if (d * ncols > nrows)
352 ncols = nrows / d;
353 else
354 nrows = ncols * d;
355 }
356 x_c = (double)ncols/xres;
357 y_r = (double)nrows/yres;
358
359 if (singlepass) { /* skip exposure, etc. */
360 pass1default();
361 pass2(fin);
362 quit(0);
363 }
364
365 fpos = ftell(fin); /* save input file position */
366
367 pass1(fin);
368
369 if (fseek(fin, fpos, 0) == -1) {
370 fprintf(stderr, "%s: seek fail\n", progname);
371 quit(1);
372 }
373 pass2(fin);
374
375 quit(estatus);
376 return estatus; /* pro forma return */
377 }
378
379
380 static void
381 copyfile( /* copy a file */
382 FILE *infp,
383 FILE *out
384 )
385 {
386 int c;
387
388 while ((c = getc(infp)) != EOF)
389 putc(c, out);
390
391 if (ferror(out)) {
392 fprintf(stderr, "%s: write error in copyfile\n", progname);
393 quit(1);
394 }
395 }
396
397
398 static void
399 pass1( /* first pass of picture file */
400 FILE *infp
401 )
402 {
403 int i;
404 COLORV *scan;
405
406 pass1init();
407
408 scan = (COLORV *)malloc(xres*NCSAMP*sizeof(COLORV));
409 if (scan == NULL) {
410 fprintf(stderr, "%s: out of memory\n", progname);
411 quit(1);
412 }
413 for (i = 0; i < yres; i++) {
414 if (freadsscan(scan, NCSAMP, xres, infp) < 0) {
415 nrows = (long)nrows * i / yres; /* adjust frame */
416 if (nrows <= 0) {
417 fprintf(stderr, "%s: empty frame\n", progname);
418 quit(1);
419 }
420 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
421 progname, (int)(100L*i/yres));
422 yres = i;
423 y_r = (double)nrows/yres;
424 estatus++;
425 break;
426 }
427 pass1scan(scan, i);
428 }
429 free(scan);
430 }
431
432
433 static void
434 pass2( /* last pass on file, write to stdout */
435 FILE *infp
436 )
437 {
438 int yread;
439 int ycent, xcent;
440 int r, c;
441
442 pass2init();
443 scan2init();
444 yread = 0;
445 for (r = 0; r < nrows; r++) {
446 ycent = (r+.5)*yres/nrows;
447 while (yread <= ycent+yrad) {
448 if (yread < yres) {
449 if (freadsscan(scanin[yread%barsize],
450 NCSAMP, xres, infp) < 0) {
451 fprintf(stderr,
452 "%s: truncated input (y=%d)\n",
453 progname, yres-1-yread);
454 quit(1);
455 }
456 pass2scan(scanin[yread%barsize], yread);
457 }
458 yread++;
459 }
460 if (obarsize > 0) /* => thresh > FTINY */
461 scan2sync(r);
462 for (c = 0; c < ncols; c++) {
463 xcent = (c+.5)*xres/ncols;
464 if (thresh > FTINY)
465 dothresh(xcent, ycent, c, r);
466 else if (rad > FTINY)
467 dogauss(scanout+c*NCSAMP, xcent, ycent, c, r);
468 else
469 dobox(scanout+c*NCSAMP, xcent, ycent, c, r);
470 }
471 if (scanout != NULL && fwritesscan(scanout, NCSAMP, ncols, stdout) < 0) {
472 fprintf(stderr, "%s: write error in pass2\n", progname);
473 quit(1);
474 }
475 }
476 /* skip leftover input */
477 while (yread < yres) {
478 if (freadscolrs((uby8 *)tempbuffer(xres*(NCSAMP+1)),
479 NCSAMP, xres, infp) < 0)
480 break;
481 yread++;
482 }
483 scan2flush(); /* flush output */
484 }
485
486
487 static void
488 scan2init(void) /* prepare scanline arrays */
489 {
490 COLOR ctmp;
491 double d;
492 int i;
493
494 xbrad = xres/ncols/2 + 1;
495 ybrad = yres/nrows/2 + 1;
496 if (rad > FTINY) {
497 if (nrows >= yres && ncols >= xres)
498 rad *= (y_r + x_c)/2.0;
499
500 if (thresh > FTINY) {
501 orad = CHECKRAD*THRESHRAD*rad + 1;
502 xrad = orad/x_c + xbrad;
503 yrad = orad/y_r + ybrad;
504 obarsize = 2*orad + 1;
505 } else {
506 xrad = CHECKRAD*rad/x_c + 1;
507 yrad = CHECKRAD*rad/y_r + 1;
508 }
509 initmask(); /* initialize filter table */
510 } else {
511 xrad = xbrad;
512 yrad = ybrad;
513 }
514 barsize = 2*yrad + 1;
515 scanin = (COLORV **)malloc(barsize*sizeof(COLORV *));
516 if (scanin == NULL)
517 goto memerr;
518 for (i = 0; i < barsize; i++) {
519 scanin[i] = (COLORV *)malloc(xres*NCSAMP*sizeof(COLORV));
520 if (scanin[i] == NULL)
521 goto memerr;
522 }
523 if (obarsize > 0) {
524 scoutbar = (COLORV **)malloc(obarsize*sizeof(COLORV *));
525 greybar = (float **)malloc(obarsize*sizeof(float *));
526 if ((scoutbar == NULL) | (greybar == NULL))
527 goto memerr;
528 for (i = 0; i < obarsize; i++) {
529 scoutbar[i] = (COLORV *)malloc(ncols*NCSAMP*sizeof(COLORV));
530 greybar[i] = (float *)malloc(ncols*sizeof(float));
531 if ((scoutbar[i] == NULL) | (greybar[i] == NULL))
532 goto memerr;
533 }
534 } else {
535 scanout = (COLORV *)malloc(ncols*NCSAMP*sizeof(COLORV));
536 if (scanout == NULL)
537 goto memerr;
538 }
539 /* record pixel aspect ratio */
540 if (!correctaspect) {
541 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
542 if ((d < 0.995) | (d > 1.005))
543 fputaspect(d, stdout);
544 }
545 /* record exposure */
546 d = bright(exposure);
547 if (!FEQ(d,1.0))
548 fputexpos(d, stdout);
549 /* record color correction */
550 copycolor(ctmp, exposure);
551 scalecolor(ctmp, 1.0/d);
552 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
553 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
554 fputcolcor(ctmp, stdout);
555 printf("\n");
556 /* write out resolution */
557 fputresolu(order, ncols, nrows, stdout);
558 return;
559 memerr:
560 fprintf(stderr, "%s: out of memory\n", progname);
561 quit(1);
562 }
563
564
565 static void
566 scan2sync( /* synchronize grey averages and output scan */
567 int r
568 )
569 {
570 static int nextrow = 0;
571 SCOLOR ctmp;
572 int ybot;
573 int c;
574 /* average input scanlines */
575 while (nextrow <= r+orad && nextrow < nrows) {
576 ybot = (nextrow+.5)*yres/nrows;
577 for (c = 0; c < ncols; c++) {
578 dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
579 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
580 }
581 /* and zero output scanline */
582 memset(scoutbar[nextrow%obarsize], 0, ncols*NCSAMP*sizeof(COLORV));
583 nextrow++;
584 }
585 /* point to top scanline for output */
586 if (r-orad >= 0)
587 scanout = scoutbar[(r-orad)%obarsize];
588 else
589 scanout = NULL;
590 }
591
592
593 static void
594 scan2flush(void) /* flush output buffer */
595 {
596 int r;
597
598 for (r = nrows-orad; r < nrows; r++)
599 if (fwritesscan(scoutbar[r%obarsize], NCSAMP, ncols, stdout) < 0)
600 break;
601 if (fflush(stdout) < 0) {
602 fprintf(stderr, "%s: write error at end of pass2\n", progname);
603 quit(1);
604 }
605 }
606
607
608 void
609 quit(code) /* remove temporary file and exit */
610 int code;
611 {
612 if (tfname != NULL)
613 unlink(tfname);
614 exit(code);
615 }
