root/radiance/ray/src/px/pfilt.c
Revision: 2.32
Committed: Thu Jul 26 23:50:40 2018 UTC (6 years, 11 months ago) by greg
Changes since 2.31: +7 -7 lines
Fixed issue with pfilt -m option and non-integer size divisors
2 static const char RCSid[] = "$Id: pfilt.c,v 2.31 2010/09/03 21:18:15 greg Exp $";
5 * pfilt.c - program to post-process picture file.
6 *
7 * 9/26/85
8 * 6/23/93 Added additional buffers for value spreading
9 */
10
11 #include "copyright.h"
12
13 #include <signal.h>
14 #include <string.h>
15
16 #include "platform.h"
17 #include "standard.h"
18 #include "rtio.h"
19 #include "color.h"
20 #include "view.h"
21 #include "paths.h"
22 #include "pfilt.h"
23
24
25 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
26
27 double CHECKRAD = 2.0; /* radius to check for filtering */
28
29 #define THRESHRAD 5.0 /* maximum sample spread in output */
30
31 COLOR exposure = WHTCOLOR; /* exposure for the frame */
32
33 double rad = 0.0; /* output pixel radius for filtering */
34
35 double thresh = 0.0; /* maximum contribution for subpixel */
36
37 int nrows = 0; /* number of rows for output */
38 int ncols = 0; /* number of columns for output */
39
40 double x_c = 1.0; /* ratio of output x size to input */
41 double y_r = 1.0; /* ratio of output y size to input */
42
43 int singlepass = 0; /* true means skip first pass */
44
45 int avghot = 0; /* true means average in bright spots */
46
47 double hotlvl = 100.0; /* level considered "hot" */
48
49 int npts = 0; /* (half) number of points for stars */
50
51 double spread = 1e-4; /* spread for star points */
52
53 char *tfname = NULL;
54
55 char template[] = TEMPLATE;
56
57 char *lampdat = "lamp.tab"; /* lamp data file */
58
59 int order; /* scanline ordering of input */
60 int xres, yres; /* resolution of input */
61 double inpaspect = 1.0; /* pixel aspect ratio of input */
62 int correctaspect = 0; /* aspect ratio correction? */
63
64 int wrongformat = 0;
65
66 VIEW ourview = STDVIEW;
67 int gotview = 0;
68 int wrapfilt = 0; /* wrap filter horizontally? */
69
70 int estatus = 0; /* exit status (for non-fatal errors) */
71
72 int xrad; /* x search radius */
73 int yrad; /* y search radius */
74 int xbrad; /* x box size */
75 int ybrad; /* y box size */
76
77 int barsize; /* size of input scan bar */
78 COLOR **scanin; /* input scan bar */
79 COLOR *scanout; /* output scan line */
80 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
81 float **greybar; /* grey-averaged input values */
82 int obarsize = 0; /* size of output scan bar */
83 int orad = 0; /* output window radius */
84
85 char *progname;
86
87 static gethfunc headline;
88 static brightfunc_t rgb_bright;
89 static brightfunc_t xyz_bright;
90 static void copyfile(FILE *in, FILE *out);
91 static void pass1(FILE *in);
92 static void pass2(FILE *in);
93 static void scan2init(void);
94 static void scan2sync(int r);
95 static void scan2flush(void);
96
97
98 int
99 main(
100 int argc,
101 char **argv
102 )
103 {
104 FILE *fin;
105 float *lampcolor;
106 char *lamptype = NULL;
107 long fpos;
108 double outaspect = 0.0;
109 double d;
110 int i, j;
111 SET_DEFAULT_BINARY();
112 SET_FILE_BINARY(stdin);
113 SET_FILE_BINARY(stdout);
114 if (signal(SIGINT, quit) == SIG_IGN)
115 signal(SIGINT, SIG_IGN);
116 #ifdef SIGHUP
117 if (signal(SIGHUP, quit) == SIG_IGN)
118 signal(SIGHUP, SIG_IGN);
119 #endif
120 signal(SIGTERM, quit);
121 #ifdef SIGPIPE
122 signal(SIGPIPE, quit);
123 #endif
124 #ifdef SIGXCPU
125 signal(SIGXCPU, quit);
126 signal(SIGXFSZ, quit);
127 #endif
128
129 progname = argv[0] = fixargv0(argv[0]);
130
131 for (i = 1; i < argc; i++)
132 if (argv[i][0] == '-')
133 switch (argv[i][1]) {
134 case 'x':
135 i++;
136 if (argv[i][0] == '/') {
137 x_c = 1.0/atof(argv[i]+1);
138 ncols = 0;
139 } else
140 ncols = atoi(argv[i]);
141 break;
142 case 'y':
143 i++;
144 if (argv[i][0] == '/') {
145 y_r = 1.0/atof(argv[i]+1);
146 nrows = 0;
147 } else
148 nrows = atoi(argv[i]);
149 break;
150 case 'c':
151 correctaspect = !correctaspect;
152 break;
153 case 'p':
154 i++;
155 outaspect = atof(argv[i]);
156 break;
157 case 'e':
158 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
159 d = pow(2.0, atof(argv[i+1]));
160 else
161 d = atof(argv[i+1]);
162 if (d < 1e-20 || d > 1e20) {
163 fprintf(stderr,
164 "%s: exposure out of range\n",
165 argv[0]);
166 quit(1);
167 }
168 switch (argv[i][2]) {
169 case '\0':
170 scalecolor(exposure, d);
171 break;
172 case 'r':
173 colval(exposure,RED) *= d;
174 break;
175 case 'g':
176 colval(exposure,GRN) *= d;
177 break;
178 case 'b':
179 colval(exposure,BLU) *= d;
180 break;
181 default:
182 goto badopt;
183 }
184 i++;
185 break;
186 case 'f':
187 lampdat = argv[++i];
188 break;
189 case 't':
190 lamptype = argv[++i];
191 break;
192 case '1':
193 singlepass = 1;
194 break;
195 case '2':
196 singlepass = 0;
197 break;
198 case 'n':
199 npts = atoi(argv[++i]) / 2;
200 break;
201 case 's':
202 spread = atof(argv[++i]);
203 break;
204 case 'a':
205 avghot = !avghot;
206 break;
207 case 'h':
208 hotlvl = atof(argv[++i]);
209 break;
210 case 'r':
211 rad = atof(argv[++i]);
212 break;
213 case 'm':
214 thresh = atof(argv[++i]);
215 if (rad <= FTINY)
216 rad = 0.6;
217 break;
218 case 'b':
219 rad = thresh = 0.0;
220 break;
221 default:;
222 badopt:
223 fprintf(stderr, "%s: unknown option: %s\n",
224 progname, argv[i]);
225 quit(1);
226 break;
227 }
228 else
229 break;
230 /* get lamp data (if necessary) */
231 if (lamptype != NULL) {
232 if (loadlamps(lampdat) < 0)
233 quit(1);
234 if ((lampcolor = matchlamp(lamptype)) == NULL) {
235 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
236 quit(1);
237 }
238 for (j = 0; j < 3; j++)
239 if (lampcolor[j] > 1e-4)
240 colval(exposure,j) /= lampcolor[j];
241 freelamps();
242 }
243 /* open input file */
244 if (i == argc) {
245 if (singlepass)
246 fin = stdin;
247 else {
248 tfname = mktemp(template);
249 if ((fin = fopen(tfname, "w+")) == NULL) {
250 fprintf(stderr, "%s: can't create ", progname);
251 fprintf(stderr, "temp file \"%s\"\n", tfname);
252 quit(1);
253 }
254 copyfile(stdin, fin);
255 if (fseek(fin, 0L, 0) == -1) {
256 fprintf(stderr, "%s: seek fail\n", progname);
257 quit(1);
258 }
259 }
260 } else if (i == argc-1) {
261 if ((fin = fopen(argv[i], "r")) == NULL) {
262 fprintf(stderr, "%s: can't open file \"%s\"\n",
263 progname, argv[i]);
264 quit(1);
265 }
266 } else {
267 fprintf(stderr, "%s: bad # file arguments\n", progname);
268 quit(1);
269 }
270 /* get header */
271 getheader(fin, headline, NULL);
272 if (wrongformat) {
273 fprintf(stderr, "%s: input must be a Radiance picture\n",
274 progname);
275 quit(1);
276 }
277 /* add new header info. */
278 printargs(i, argv, stdout);
279 /* get picture size */
280 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
281 fprintf(stderr, "%s: bad picture size\n", progname);
282 quit(1);
283 }
284 if (!(order & YMAJOR))
285 inpaspect = 1.0/inpaspect;
286 /* wrap around for cylindrical view? */
287 wrapfilt = gotview && ourview.type == VT_CYL &&
288 ourview.horiz >= 360.-FTINY && order & YMAJOR;
289 /* compute output resolution */
290 if (ncols <= 0)
291 ncols = x_c*xres + .5;
292 if (nrows <= 0)
293 nrows = y_r*yres + .5;
294 if (outaspect > .01) {
295 d = inpaspect * yres/xres / outaspect;
296 if (d * ncols > nrows)
297 ncols = nrows / d;
298 else
299 nrows = ncols * d;
300 }
301 x_c = (double)ncols/xres;
302 y_r = (double)nrows/yres;
303
304 if (singlepass) { /* skip exposure, etc. */
305 pass1default();
306 pass2(fin);
307 quit(0);
308 }
309
310 fpos = ftell(fin); /* save input file position */
311
312 pass1(fin);
313
314 if (fseek(fin, fpos, 0) == -1) {
315 fprintf(stderr, "%s: seek fail\n", progname);
316 quit(1);
317 }
318 pass2(fin);
319
320 quit(estatus);
321 return estatus; /* pro forma return */
322 }
323
324
325 static double
326 rgb_bright(
327 COLOR clr
328 )
329 {
330 return(bright(clr));
331 }
332
333
334 static double
335 xyz_bright(
336 COLOR clr
337 )
338 {
339 return(clr[CIEY]);
340 }
341
342
343 brightfunc_t *ourbright = rgb_bright;
344
345 static int
346 headline( /* process line from header */
347 char *s,
348 void *p
349 )
350 {
351 char fmt[32];
352
353 fputs(s, stdout); /* copy to output */
354 if (isaspect(s)) /* get aspect ratio */
355 inpaspect *= aspectval(s);
356 else if (isexpos(s)) /* get exposure */
357 hotlvl *= exposval(s);
358 else if (formatval(fmt, s)) { /* get format */
359 wrongformat = 0;
360 if (!strcmp(COLRFMT, fmt))
361 ourbright = rgb_bright;
362 else if (!strcmp(CIEFMT, fmt))
363 ourbright = xyz_bright;
364 else
365 wrongformat = !globmatch(PICFMT, fmt);
366 } else if (isview(s) && sscanview(&ourview, s) > 0)
367 gotview++;
368 return(0);
369 }
370
371
372 static void
373 copyfile( /* copy a file */
374 FILE *in,
375 FILE *out
376 )
377 {
378 int c;
379
380 while ((c = getc(in)) != EOF)
381 putc(c, out);
382
383 if (ferror(out)) {
384 fprintf(stderr, "%s: write error in copyfile\n", progname);
385 quit(1);
386 }
387 }
388
389
390 static void
391 pass1( /* first pass of picture file */
392 FILE *in
393 )
394 {
395 int i;
396 COLOR *scan;
397
398 pass1init();
399
400 scan = (COLOR *)malloc(xres*sizeof(COLOR));
401 if (scan == NULL) {
402 fprintf(stderr, "%s: out of memory\n", progname);
403 quit(1);
404 }
405 for (i = 0; i < yres; i++) {
406 if (freadscan(scan, xres, in) < 0) {
407 nrows = (long)nrows * i / yres; /* adjust frame */
408 if (nrows <= 0) {
409 fprintf(stderr, "%s: empty frame\n", progname);
410 quit(1);
411 }
412 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
413 progname, (int)(100L*i/yres));
414 yres = i;
415 y_r = (double)nrows/yres;
416 estatus++;
417 break;
418 }
419 pass1scan(scan, i);
420 }
421 free((void *)scan);
422 }
423
424
425 static void
426 pass2( /* last pass on file, write to stdout */
427 FILE *in
428 )
429 {
430 int yread;
431 int ycent, xcent;
432 int r, c;
433
434 pass2init();
435 scan2init();
436 yread = 0;
437 for (r = 0; r < nrows; r++) {
438 ycent = (r+.5)*yres/nrows;
439 while (yread <= ycent+yrad) {
440 if (yread < yres) {
441 if (freadscan(scanin[yread%barsize],
442 xres, in) < 0) {
443 fprintf(stderr,
444 "%s: truncated input (y=%d)\n",
445 progname, yres-1-yread);
446 quit(1);
447 }
448 pass2scan(scanin[yread%barsize], yread);
449 }
450 yread++;
451 }
452 if (obarsize > 0)
453 scan2sync(r);
454 for (c = 0; c < ncols; c++) {
455 xcent = (c+.5)*xres/ncols;
456 if (thresh > FTINY)
457 dothresh(xcent, ycent, c, r);
458 else if (rad > FTINY)
459 dogauss(scanout[c], xcent, ycent, c, r);
460 else
461 dobox(scanout[c], xcent, ycent, c, r);
462 }
463 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
464 fprintf(stderr, "%s: write error in pass2\n", progname);
465 quit(1);
466 }
467 }
468 /* skip leftover input */
469 while (yread < yres) {
470 if (freadscan(scanin[0], xres, in) < 0)
471 break;
472 yread++;
473 }
474 scan2flush(); /* flush output */
475 }
476
477
478 static void
479 scan2init(void) /* prepare scanline arrays */
480 {
481 COLOR ctmp;
482 double d;
483 int i;
484
485 xbrad = xres/ncols/2 + 1;
486 ybrad = yres/nrows/2 + 1;
487 if (rad > FTINY) {
488 if (nrows >= yres && ncols >= xres)
489 rad *= (y_r + x_c)/2.0;
490
491 if (thresh > FTINY) {
492 orad = CHECKRAD*THRESHRAD*rad + 1;
493 xrad = orad/x_c + xbrad;
494 yrad = orad/y_r + ybrad;
495 obarsize = 2*orad + 1;
496 } else {
497 xrad = CHECKRAD*rad/x_c + 1;
498 yrad = CHECKRAD*rad/y_r + 1;
499 }
500 initmask(); /* initialize filter table */
501 } else {
502 xrad = xbrad;
503 yrad = ybrad;
504 }
505 barsize = 2*yrad + 1;
506 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
507 if (scanin == NULL)
508 goto memerr;
509 for (i = 0; i < barsize; i++) {
510 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
511 if (scanin[i] == NULL)
512 goto memerr;
513 }
514 if (obarsize > 0) {
515 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
516 greybar = (float **)malloc(obarsize*sizeof(float *));
517 if ((scoutbar == NULL) | (greybar == NULL))
518 goto memerr;
519 for (i = 0; i < obarsize; i++) {
520 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
521 greybar[i] = (float *)malloc(ncols*sizeof(float));
522 if ((scoutbar[i] == NULL) | (greybar[i] == NULL))
523 goto memerr;
524 }
525 } else {
526 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
527 if (scanout == NULL)
528 goto memerr;
529 }
530 /* record pixel aspect ratio */
531 if (!correctaspect) {
532 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
533 if (!FEQ(d,1.0))
534 fputaspect(d, stdout);
535 }
536 /* record exposure */
537 d = (*ourbright)(exposure);
538 if (!FEQ(d,1.0))
539 fputexpos(d, stdout);
540 /* record color correction */
541 copycolor(ctmp, exposure);
542 scalecolor(ctmp, 1.0/d);
543 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
544 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
545 fputcolcor(ctmp, stdout);
546 printf("\n");
547 /* write out resolution */
548 fputresolu(order, ncols, nrows, stdout);
549 return;
550 memerr:
551 fprintf(stderr, "%s: out of memory\n", progname);
552 quit(1);
553 }
554
555
556 static void
557 scan2sync( /* synchronize grey averages and output scan */
558 int r
559 )
560 {
561 static int nextrow = 0;
562 COLOR ctmp;
563 int ybot;
564 int c;
565 /* average input scanlines */
566 while (nextrow <= r+orad && nextrow < nrows) {
567 ybot = (nextrow+.5)*yres/nrows;
568 for (c = 0; c < ncols; c++) {
569 dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
570 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
571 }
572 /* and zero output scanline */
573 memset((char *)scoutbar[nextrow%obarsize], '\0', ncols*sizeof(COLOR));
574 nextrow++;
575 }
576 /* point to top scanline for output */
577 if (r-orad >= 0)
578 scanout = scoutbar[(r-orad)%obarsize];
579 else
580 scanout = NULL;
581 }
582
583
584 static void
585 scan2flush(void) /* flush output buffer */
586 {
587 int r;
588
589 for (r = nrows-orad; r < nrows; r++)
590 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
591 break;
592 if (fflush(stdout) < 0) {
593 fprintf(stderr, "%s: write error at end of pass2\n", progname);
594 quit(1);
595 }
596 }
597
598
599 void
600 quit(code) /* remove temporary file and exit */
601 int code;
602 {
603 if (tfname != NULL)
604 unlink(tfname);
605 exit(code);
606 }
