root/radiance/ray/src/px/pfilt.c
Revision: 2.30
Committed: Mon Mar 29 00:34:23 2004 UTC (21 years, 4 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9
Changes since 2.29: +6 -5 lines
Continued ANSIfication. Added headerfiles pfilt.h and clrtab.h.
2 static const char RCSid[] = "$Id: pfilt.c,v 2.29 2004/03/28 20:33:14 schorsch Exp $";
5 * pfilt.c - program to post-process picture file.
6 *
7 * 9/26/85
8 * 6/23/93 Added additional buffers for value spreading
9 */
10
11 #include "copyright.h"
12
13 #include <signal.h>
14 #include <string.h>
15
16 #include "platform.h"
17 #include "standard.h"
18 #include "rtio.h"
19 #include "color.h"
20 #include "view.h"
21 #include "paths.h"
22 #include "pfilt.h"
23
24
25 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
26
27 double CHECKRAD = 2.0; /* radius to check for filtering */
28
29 #define THRESHRAD 5.0 /* maximum sample spread in output */
30
31 COLOR exposure = WHTCOLOR; /* exposure for the frame */
32
33 double rad = 0.0; /* output pixel radius for filtering */
34
35 double thresh = 0.0; /* maximum contribution for subpixel */
36
37 int nrows = 0; /* number of rows for output */
38 int ncols = 0; /* number of columns for output */
39
40 double x_c = 1.0; /* ratio of output x size to input */
41 double y_r = 1.0; /* ratio of output y size to input */
42
43 int singlepass = 0; /* true means skip first pass */
44
45 int avghot = 0; /* true means average in bright spots */
46
47 double hotlvl = 100.0; /* level considered "hot" */
48
49 int npts = 0; /* (half) number of points for stars */
50
51 double spread = 1e-4; /* spread for star points */
52
53 char *tfname = NULL;
54
55 char template[] = TEMPLATE;
56
57 char *lampdat = "lamp.tab"; /* lamp data file */
58
59 int order; /* scanline ordering of input */
60 int xres, yres; /* resolution of input */
61 double inpaspect = 1.0; /* pixel aspect ratio of input */
62 int correctaspect = 0; /* aspect ratio correction? */
63
64 int wrongformat = 0;
65
66 VIEW ourview = STDVIEW;
67 int gotview = 0;
68 int wrapfilt = 0; /* wrap filter horizontally? */
69
70 int estatus = 0; /* exit status (for non-fatal errors) */
71
72 int xrad; /* x search radius */
73 int yrad; /* y search radius */
74 int xbrad; /* x box size */
75 int ybrad; /* y box size */
76
77 int barsize; /* size of input scan bar */
78 COLOR **scanin; /* input scan bar */
79 COLOR *scanout; /* output scan line */
80 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
81 float **greybar; /* grey-averaged input values */
82 int obarsize = 0; /* size of output scan bar */
83 int orad = 0; /* output window radius */
84
85 char *progname;
86
87 static gethfunc headline;
88 static brightfunc_t rgb_bright;
89 static brightfunc_t xyz_bright;
90 //static double rgb_bright(COLOR clr);
91 //static double xyz_bright(COLOR clr);
92 static void copyfile(FILE *in, FILE *out);
93 static void pass1(FILE *in);
94 static void pass2(FILE *in);
95 static void scan2init(void);
96 static void scan2sync(int r);
97 static void scan2flush(void);
98
99
100 int
101 main(
102 int argc,
103 char **argv
104 )
105 {
106 FILE *fin;
107 float *lampcolor;
108 char *lamptype = NULL;
109 long fpos;
110 double outaspect = 0.0;
111 double d;
112 int i, j;
113 SET_DEFAULT_BINARY();
114 SET_FILE_BINARY(stdin);
115 SET_FILE_BINARY(stdout);
116 if (signal(SIGINT, quit) == SIG_IGN)
117 signal(SIGINT, SIG_IGN);
118 #ifdef SIGHUP
119 if (signal(SIGHUP, quit) == SIG_IGN)
120 signal(SIGHUP, SIG_IGN);
121 #endif
122 signal(SIGTERM, quit);
123 #ifdef SIGPIPE
124 signal(SIGPIPE, quit);
125 #endif
126 #ifdef SIGXCPU
127 signal(SIGXCPU, quit);
128 signal(SIGXFSZ, quit);
129 #endif
130
131 progname = argv[0] = fixargv0(argv[0]);
132
133 for (i = 1; i < argc; i++)
134 if (argv[i][0] == '-')
135 switch (argv[i][1]) {
136 case 'x':
137 i++;
138 if (argv[i][0] == '/') {
139 x_c = 1.0/atof(argv[i]+1);
140 ncols = 0;
141 } else
142 ncols = atoi(argv[i]);
143 break;
144 case 'y':
145 i++;
146 if (argv[i][0] == '/') {
147 y_r = 1.0/atof(argv[i]+1);
148 nrows = 0;
149 } else
150 nrows = atoi(argv[i]);
151 break;
152 case 'c':
153 correctaspect = !correctaspect;
154 break;
155 case 'p':
156 i++;
157 outaspect = atof(argv[i]);
158 break;
159 case 'e':
160 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
161 d = pow(2.0, atof(argv[i+1]));
162 else
163 d = atof(argv[i+1]);
164 if (d < 1e-20 || d > 1e20) {
165 fprintf(stderr,
166 "%s: exposure out of range\n",
167 argv[0]);
168 quit(1);
169 }
170 switch (argv[i][2]) {
171 case '\0':
172 scalecolor(exposure, d);
173 break;
174 case 'r':
175 colval(exposure,RED) *= d;
176 break;
177 case 'g':
178 colval(exposure,GRN) *= d;
179 break;
180 case 'b':
181 colval(exposure,BLU) *= d;
182 break;
183 default:
184 goto badopt;
185 }
186 i++;
187 break;
188 case 'f':
189 lampdat = argv[++i];
190 break;
191 case 't':
192 lamptype = argv[++i];
193 break;
194 case '1':
195 singlepass = 1;
196 break;
197 case '2':
198 singlepass = 0;
199 break;
200 case 'n':
201 npts = atoi(argv[++i]) / 2;
202 break;
203 case 's':
204 spread = atof(argv[++i]);
205 break;
206 case 'a':
207 avghot = !avghot;
208 break;
209 case 'h':
210 hotlvl = atof(argv[++i]);
211 break;
212 case 'r':
213 rad = atof(argv[++i]);
214 break;
215 case 'm':
216 thresh = atof(argv[++i]);
217 if (rad <= FTINY)
218 rad = 0.6;
219 break;
220 case 'b':
221 rad = thresh = 0.0;
222 break;
223 default:;
224 badopt:
225 fprintf(stderr, "%s: unknown option: %s\n",
226 progname, argv[i]);
227 quit(1);
228 break;
229 }
230 else
231 break;
232 /* get lamp data (if necessary) */
233 if (lamptype != NULL) {
234 if (loadlamps(lampdat) < 0)
235 quit(1);
236 if ((lampcolor = matchlamp(lamptype)) == NULL) {
237 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
238 quit(1);
239 }
240 for (j = 0; j < 3; j++)
241 if (lampcolor[j] > 1e-4)
242 colval(exposure,j) /= lampcolor[j];
243 freelamps();
244 }
245 /* open input file */
246 if (i == argc) {
247 if (singlepass)
248 fin = stdin;
249 else {
250 tfname = mktemp(template);
251 if ((fin = fopen(tfname, "w+")) == NULL) {
252 fprintf(stderr, "%s: can't create ", progname);
253 fprintf(stderr, "temp file \"%s\"\n", tfname);
254 quit(1);
255 }
256 copyfile(stdin, fin);
257 if (fseek(fin, 0L, 0) == -1) {
258 fprintf(stderr, "%s: seek fail\n", progname);
259 quit(1);
260 }
261 }
262 } else if (i == argc-1) {
263 if ((fin = fopen(argv[i], "r")) == NULL) {
264 fprintf(stderr, "%s: can't open file \"%s\"\n",
265 progname, argv[i]);
266 quit(1);
267 }
268 } else {
269 fprintf(stderr, "%s: bad # file arguments\n", progname);
270 quit(1);
271 }
272 /* get header */
273 getheader(fin, headline, NULL);
274 if (wrongformat) {
275 fprintf(stderr, "%s: input must be a Radiance picture\n",
276 progname);
277 quit(1);
278 }
279 /* add new header info. */
280 printargs(i, argv, stdout);
281 /* get picture size */
282 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
283 fprintf(stderr, "%s: bad picture size\n", progname);
284 quit(1);
285 }
286 if (!(order & YMAJOR))
287 inpaspect = 1.0/inpaspect;
288 /* wrap around for cylindrical view? */
289 wrapfilt = gotview && ourview.type == VT_CYL &&
290 ourview.horiz >= 360.-FTINY && order & YMAJOR;
291 /* compute output resolution */
292 if (ncols <= 0)
293 ncols = x_c*xres + .5;
294 if (nrows <= 0)
295 nrows = y_r*yres + .5;
296 if (outaspect > .01) {
297 d = inpaspect * yres/xres / outaspect;
298 if (d * ncols > nrows)
299 ncols = nrows / d;
300 else
301 nrows = ncols * d;
302 }
303 x_c = (double)ncols/xres;
304 y_r = (double)nrows/yres;
305
306 if (singlepass) { /* skip exposure, etc. */
307 pass1default();
308 pass2(fin);
309 quit(0);
310 }
311
312 fpos = ftell(fin); /* save input file position */
313
314 pass1(fin);
315
316 if (fseek(fin, fpos, 0) == -1) {
317 fprintf(stderr, "%s: seek fail\n", progname);
318 quit(1);
319 }
320 pass2(fin);
321
322 quit(estatus);
323 return estatus; /* pro forma return */
324 }
325
326
327 static double
328 rgb_bright(
329 COLOR clr
330 )
331 {
332 return(bright(clr));
333 }
334
335
336 static double
337 xyz_bright(
338 COLOR clr
339 )
340 {
341 return(clr[CIEY]);
342 }
343
344
345 brightfunc_t *ourbright = rgb_bright;
346
347 static int
348 headline( /* process line from header */
349 char *s,
350 void *p
351 )
352 {
353 char fmt[32];
354
355 fputs(s, stdout); /* copy to output */
356 if (isaspect(s)) /* get aspect ratio */
357 inpaspect *= aspectval(s);
358 else if (isexpos(s)) /* get exposure */
359 hotlvl *= exposval(s);
360 else if (formatval(fmt, s)) { /* get format */
361 wrongformat = 0;
362 if (!strcmp(COLRFMT, fmt))
363 ourbright = rgb_bright;
364 else if (!strcmp(CIEFMT, fmt))
365 ourbright = xyz_bright;
366 else
367 wrongformat = !globmatch(PICFMT, fmt);
368 } else if (isview(s) && sscanview(&ourview, s) > 0)
369 gotview++;
370 return(0);
371 }
372
373
374 static void
375 copyfile( /* copy a file */
376 register FILE *in,
377 register FILE *out
378 )
379 {
380 register int c;
381
382 while ((c = getc(in)) != EOF)
383 putc(c, out);
384
385 if (ferror(out)) {
386 fprintf(stderr, "%s: write error in copyfile\n", progname);
387 quit(1);
388 }
389 }
390
391
392 static void
393 pass1( /* first pass of picture file */
394 FILE *in
395 )
396 {
397 int i;
398 COLOR *scan;
399
400 pass1init();
401
402 scan = (COLOR *)malloc(xres*sizeof(COLOR));
403 if (scan == NULL) {
404 fprintf(stderr, "%s: out of memory\n", progname);
405 quit(1);
406 }
407 for (i = 0; i < yres; i++) {
408 if (freadscan(scan, xres, in) < 0) {
409 nrows = (long)nrows * i / yres; /* adjust frame */
410 if (nrows <= 0) {
411 fprintf(stderr, "%s: empty frame\n", progname);
412 quit(1);
413 }
414 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
415 progname, (int)(100L*i/yres));
416 yres = i;
417 y_r = (double)nrows/yres;
418 estatus++;
419 break;
420 }
421 pass1scan(scan, i);
422 }
423 free((void *)scan);
424 }
425
426
427 static void
428 pass2( /* last pass on file, write to stdout */
429 FILE *in
430 )
431 {
432 int yread;
433 int ycent, xcent;
434 int r, c;
435
436 pass2init();
437 scan2init();
438 yread = 0;
439 for (r = 0; r < nrows; r++) {
440 ycent = (r+.5)*yres/nrows;
441 while (yread <= ycent+yrad) {
442 if (yread < yres) {
443 if (freadscan(scanin[yread%barsize],
444 xres, in) < 0) {
445 fprintf(stderr,
446 "%s: truncated input (y=%d)\n",
447 progname, yres-1-yread);
448 quit(1);
449 }
450 pass2scan(scanin[yread%barsize], yread);
451 }
452 yread++;
453 }
454 if (obarsize > 0)
455 scan2sync(r);
456 for (c = 0; c < ncols; c++) {
457 xcent = (c+.5)*xres/ncols;
458 if (thresh > FTINY)
459 dothresh(xcent, ycent, c, r);
460 else if (rad > FTINY)
461 dogauss(scanout[c], xcent, ycent, c, r);
462 else
463 dobox(scanout[c], xcent, ycent, c, r);
464 }
465 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
466 fprintf(stderr, "%s: write error in pass2\n", progname);
467 quit(1);
468 }
469 }
470 /* skip leftover input */
471 while (yread < yres) {
472 if (freadscan(scanin[0], xres, in) < 0)
473 break;
474 yread++;
475 }
476 scan2flush(); /* flush output */
477 }
478
479
480 static void
481 scan2init(void) /* prepare scanline arrays */
482 {
483 COLOR ctmp;
484 double d;
485 register int i;
486
487 xbrad = xres/ncols/2 + 1;
488 ybrad = yres/nrows/2 + 1;
489 if (rad > FTINY) {
490 if (nrows >= yres && ncols >= xres)
491 rad *= (y_r + x_c)/2.0;
492
493 if (thresh > FTINY) {
494 orad = CHECKRAD*THRESHRAD*rad + 1;
495 xrad = orad/x_c + xbrad;
496 yrad = orad/y_r + ybrad;
497 obarsize = 2*orad + 1;
498 } else {
499 xrad = CHECKRAD*rad/x_c + 1;
500 yrad = CHECKRAD*rad/y_r + 1;
501 }
502 initmask(); /* initialize filter table */
503 } else {
504 xrad = xbrad;
505 yrad = ybrad;
506 }
507 barsize = 2*yrad + 1;
508 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
509 if (scanin == NULL)
510 goto memerr;
511 for (i = 0; i < barsize; i++) {
512 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
513 if (scanin[i] == NULL)
514 goto memerr;
515 }
516 if (obarsize > 0) {
517 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
518 greybar = (float **)malloc(obarsize*sizeof(float *));
519 if ((scoutbar == NULL) | (greybar == NULL))
520 goto memerr;
521 for (i = 0; i < obarsize; i++) {
522 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
523 greybar[i] = (float *)malloc(ncols*sizeof(float));
524 if ((scoutbar[i] == NULL) | (greybar[i] == NULL))
525 goto memerr;
526 }
527 } else {
528 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
529 if (scanout == NULL)
530 goto memerr;
531 }
532 /* record pixel aspect ratio */
533 if (!correctaspect) {
534 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
535 if (!FEQ(d,1.0))
536 fputaspect(d, stdout);
537 }
538 /* record exposure */
539 d = (*ourbright)(exposure);
540 if (!FEQ(d,1.0))
541 fputexpos(d, stdout);
542 /* record color correction */
543 copycolor(ctmp, exposure);
544 scalecolor(ctmp, 1.0/d);
545 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
546 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
547 fputcolcor(ctmp, stdout);
548 printf("\n");
549 /* write out resolution */
550 fputresolu(order, ncols, nrows, stdout);
551 return;
552 memerr:
553 fprintf(stderr, "%s: out of memory\n", progname);
554 quit(1);
555 }
556
557
558 static void
559 scan2sync( /* synchronize grey averages and output scan */
560 int r
561 )
562 {
563 static int nextrow = 0;
564 COLOR ctmp;
565 int ybot;
566 register int c;
567 /* average input scanlines */
568 while (nextrow <= r+orad && nextrow < nrows) {
569 ybot = (nextrow+.5)*yres/nrows;
570 for (c = 0; c < ncols; c++) {
571 dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
572 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
573 }
574 /* and zero output scanline */
575 memset((char *)scoutbar[nextrow%obarsize], '\0', ncols*sizeof(COLOR));
576 nextrow++;
577 }
578 /* point to top scanline for output */
579 if (r-orad >= 0)
580 scanout = scoutbar[(r-orad)%obarsize];
581 else
582 scanout = NULL;
583 }
584
585
586 static void
587 scan2flush(void) /* flush output buffer */
588 {
589 register int r;
590
591 for (r = nrows-orad; r < nrows; r++)
592 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
593 break;
594 if (fflush(stdout) < 0) {
595 fprintf(stderr, "%s: write error at end of pass2\n", progname);
596 quit(1);
597 }
598 }
599
600
601 void
602 quit(code) /* remove temporary file and exit */
603 int code;
604 {
605 if (tfname != NULL)
606 unlink(tfname);
607 exit(code);
608 }
