root/radiance/ray/src/px/pfilt.c
Revision: 2.29
Committed: Sun Mar 28 20:33:14 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 2.28: +46 -21 lines
2 static const char RCSid[] = "$Id: pfilt.c,v 2.28 2004/01/02 12:47:01 schorsch Exp $";
5 * pfilt.c - program to post-process picture file.
6 *
7 * 9/26/85
8 * 6/23/93 Added additional buffers for value spreading
9 */
10
11 #include "copyright.h"
12
13 #include <signal.h>
14 #include <string.h>
15
16 #include "platform.h"
17 #include "standard.h"
18 #include "rtio.h"
19 #include "color.h"
20 #include "view.h"
21 #include "paths.h"
22 #include "pfilt.h"
23
24
25 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
26
27 double CHECKRAD = 2.0; /* radius to check for filtering */
28
29 #define THRESHRAD 5.0 /* maximum sample spread in output */
30
31 COLOR exposure = WHTCOLOR; /* exposure for the frame */
32
33 double rad = 0.0; /* output pixel radius for filtering */
34
35 double thresh = 0.0; /* maximum contribution for subpixel */
36
37 int nrows = 0; /* number of rows for output */
38 int ncols = 0; /* number of columns for output */
39
40 double x_c = 1.0; /* ratio of output x size to input */
41 double y_r = 1.0; /* ratio of output y size to input */
42
43 int singlepass = 0; /* true means skip first pass */
44
45 int avghot = 0; /* true means average in bright spots */
46
47 double hotlvl = 100.0; /* level considered "hot" */
48
49 int npts = 0; /* (half) number of points for stars */
50
51 double spread = 1e-4; /* spread for star points */
52
53 char *tfname = NULL;
54
55 char template[] = TEMPLATE;
56
57 char *lampdat = "lamp.tab"; /* lamp data file */
58
59 int order; /* scanline ordering of input */
60 int xres, yres; /* resolution of input */
61 double inpaspect = 1.0; /* pixel aspect ratio of input */
62 int correctaspect = 0; /* aspect ratio correction? */
63
64 int wrongformat = 0;
65
66 VIEW ourview = STDVIEW;
67 int gotview = 0;
68 int wrapfilt = 0; /* wrap filter horizontally? */
69
70 int estatus = 0; /* exit status (for non-fatal errors) */
71
72 int xrad; /* x search radius */
73 int yrad; /* y search radius */
74 int xbrad; /* x box size */
75 int ybrad; /* y box size */
76
77 int barsize; /* size of input scan bar */
78 COLOR **scanin; /* input scan bar */
79 COLOR *scanout; /* output scan line */
80 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
81 float **greybar; /* grey-averaged input values */
82 int obarsize = 0; /* size of output scan bar */
83 int orad = 0; /* output window radius */
84
85 char *progname;
86
87 static gethfunc headline;
88 static double rgb_bright(COLOR clr);
89 static double xyz_bright(COLOR clr);
90 static void copyfile(FILE *in, FILE *out);
91 static void pass1(FILE *in);
92 static void pass2(FILE *in);
93 static void scan2init(void);
94 static void scan2sync(int r);
95 static void scan2flush(void);
96
97
98 int
99 main(
100 int argc,
101 char **argv
102 )
103 {
104 FILE *fin;
105 float *lampcolor;
106 char *lamptype = NULL;
107 long fpos;
108 double outaspect = 0.0;
109 double d;
110 int i, j;
111 SET_DEFAULT_BINARY();
112 SET_FILE_BINARY(stdin);
113 SET_FILE_BINARY(stdout);
114 if (signal(SIGINT, quit) == SIG_IGN)
115 signal(SIGINT, SIG_IGN);
116 #ifdef SIGHUP
117 if (signal(SIGHUP, quit) == SIG_IGN)
118 signal(SIGHUP, SIG_IGN);
119 #endif
120 signal(SIGTERM, quit);
121 #ifdef SIGPIPE
122 signal(SIGPIPE, quit);
123 #endif
124 #ifdef SIGXCPU
125 signal(SIGXCPU, quit);
126 signal(SIGXFSZ, quit);
127 #endif
128
129 progname = argv[0] = fixargv0(argv[0]);
130
131 for (i = 1; i < argc; i++)
132 if (argv[i][0] == '-')
133 switch (argv[i][1]) {
134 case 'x':
135 i++;
136 if (argv[i][0] == '/') {
137 x_c = 1.0/atof(argv[i]+1);
138 ncols = 0;
139 } else
140 ncols = atoi(argv[i]);
141 break;
142 case 'y':
143 i++;
144 if (argv[i][0] == '/') {
145 y_r = 1.0/atof(argv[i]+1);
146 nrows = 0;
147 } else
148 nrows = atoi(argv[i]);
149 break;
150 case 'c':
151 correctaspect = !correctaspect;
152 break;
153 case 'p':
154 i++;
155 outaspect = atof(argv[i]);
156 break;
157 case 'e':
158 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
159 d = pow(2.0, atof(argv[i+1]));
160 else
161 d = atof(argv[i+1]);
162 if (d < 1e-20 || d > 1e20) {
163 fprintf(stderr,
164 "%s: exposure out of range\n",
165 argv[0]);
166 quit(1);
167 }
168 switch (argv[i][2]) {
169 case '\0':
170 scalecolor(exposure, d);
171 break;
172 case 'r':
173 colval(exposure,RED) *= d;
174 break;
175 case 'g':
176 colval(exposure,GRN) *= d;
177 break;
178 case 'b':
179 colval(exposure,BLU) *= d;
180 break;
181 default:
182 goto badopt;
183 }
184 i++;
185 break;
186 case 'f':
187 lampdat = argv[++i];
188 break;
189 case 't':
190 lamptype = argv[++i];
191 break;
192 case '1':
193 singlepass = 1;
194 break;
195 case '2':
196 singlepass = 0;
197 break;
198 case 'n':
199 npts = atoi(argv[++i]) / 2;
200 break;
201 case 's':
202 spread = atof(argv[++i]);
203 break;
204 case 'a':
205 avghot = !avghot;
206 break;
207 case 'h':
208 hotlvl = atof(argv[++i]);
209 break;
210 case 'r':
211 rad = atof(argv[++i]);
212 break;
213 case 'm':
214 thresh = atof(argv[++i]);
215 if (rad <= FTINY)
216 rad = 0.6;
217 break;
218 case 'b':
219 rad = thresh = 0.0;
220 break;
221 default:;
222 badopt:
223 fprintf(stderr, "%s: unknown option: %s\n",
224 progname, argv[i]);
225 quit(1);
226 break;
227 }
228 else
229 break;
230 /* get lamp data (if necessary) */
231 if (lamptype != NULL) {
232 if (loadlamps(lampdat) < 0)
233 quit(1);
234 if ((lampcolor = matchlamp(lamptype)) == NULL) {
235 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
236 quit(1);
237 }
238 for (j = 0; j < 3; j++)
239 if (lampcolor[j] > 1e-4)
240 colval(exposure,j) /= lampcolor[j];
241 freelamps();
242 }
243 /* open input file */
244 if (i == argc) {
245 if (singlepass)
246 fin = stdin;
247 else {
248 tfname = mktemp(template);
249 if ((fin = fopen(tfname, "w+")) == NULL) {
250 fprintf(stderr, "%s: can't create ", progname);
251 fprintf(stderr, "temp file \"%s\"\n", tfname);
252 quit(1);
253 }
254 copyfile(stdin, fin);
255 if (fseek(fin, 0L, 0) == -1) {
256 fprintf(stderr, "%s: seek fail\n", progname);
257 quit(1);
258 }
259 }
260 } else if (i == argc-1) {
261 if ((fin = fopen(argv[i], "r")) == NULL) {
262 fprintf(stderr, "%s: can't open file \"%s\"\n",
263 progname, argv[i]);
264 quit(1);
265 }
266 } else {
267 fprintf(stderr, "%s: bad # file arguments\n", progname);
268 quit(1);
269 }
270 /* get header */
271 getheader(fin, headline, NULL);
272 if (wrongformat) {
273 fprintf(stderr, "%s: input must be a Radiance picture\n",
274 progname);
275 quit(1);
276 }
277 /* add new header info. */
278 printargs(i, argv, stdout);
279 /* get picture size */
280 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
281 fprintf(stderr, "%s: bad picture size\n", progname);
282 quit(1);
283 }
284 if (!(order & YMAJOR))
285 inpaspect = 1.0/inpaspect;
286 /* wrap around for cylindrical view? */
287 wrapfilt = gotview && ourview.type == VT_CYL &&
288 ourview.horiz >= 360.-FTINY && order & YMAJOR;
289 /* compute output resolution */
290 if (ncols <= 0)
291 ncols = x_c*xres + .5;
292 if (nrows <= 0)
293 nrows = y_r*yres + .5;
294 if (outaspect > .01) {
295 d = inpaspect * yres/xres / outaspect;
296 if (d * ncols > nrows)
297 ncols = nrows / d;
298 else
299 nrows = ncols * d;
300 }
301 x_c = (double)ncols/xres;
302 y_r = (double)nrows/yres;
303
304 if (singlepass) { /* skip exposure, etc. */
305 pass1default();
306 pass2(fin);
307 quit(0);
308 }
309
310 fpos = ftell(fin); /* save input file position */
311
312 pass1(fin);
313
314 if (fseek(fin, fpos, 0) == -1) {
315 fprintf(stderr, "%s: seek fail\n", progname);
316 quit(1);
317 }
318 pass2(fin);
319
320 quit(estatus);
321 return estatus; /* pro forma return */
322 }
323
324
325 static double
326 rgb_bright(
327 COLOR clr
328 )
329 {
330 return(bright(clr));
331 }
332
333
334 static double
335 xyz_bright(
336 COLOR clr
337 )
338 {
339 return(clr[CIEY]);
340 }
341
342
343 double (*ourbright)() = rgb_bright;
344
345
346 static int
347 headline( /* process line from header */
348 char *s,
349 void *p
350 )
351 {
352 char fmt[32];
353
354 fputs(s, stdout); /* copy to output */
355 if (isaspect(s)) /* get aspect ratio */
356 inpaspect *= aspectval(s);
357 else if (isexpos(s)) /* get exposure */
358 hotlvl *= exposval(s);
359 else if (formatval(fmt, s)) { /* get format */
360 wrongformat = 0;
361 if (!strcmp(COLRFMT, fmt))
362 ourbright = rgb_bright;
363 else if (!strcmp(CIEFMT, fmt))
364 ourbright = xyz_bright;
365 else
366 wrongformat = !globmatch(PICFMT, fmt);
367 } else if (isview(s) && sscanview(&ourview, s) > 0)
368 gotview++;
369 return(0);
370 }
371
372
373 static void
374 copyfile( /* copy a file */
375 register FILE *in,
376 register FILE *out
377 )
378 {
379 register int c;
380
381 while ((c = getc(in)) != EOF)
382 putc(c, out);
383
384 if (ferror(out)) {
385 fprintf(stderr, "%s: write error in copyfile\n", progname);
386 quit(1);
387 }
388 }
389
390
391 static void
392 pass1( /* first pass of picture file */
393 FILE *in
394 )
395 {
396 int i;
397 COLOR *scan;
398
399 pass1init();
400
401 scan = (COLOR *)malloc(xres*sizeof(COLOR));
402 if (scan == NULL) {
403 fprintf(stderr, "%s: out of memory\n", progname);
404 quit(1);
405 }
406 for (i = 0; i < yres; i++) {
407 if (freadscan(scan, xres, in) < 0) {
408 nrows = (long)nrows * i / yres; /* adjust frame */
409 if (nrows <= 0) {
410 fprintf(stderr, "%s: empty frame\n", progname);
411 quit(1);
412 }
413 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
414 progname, (int)(100L*i/yres));
415 yres = i;
416 y_r = (double)nrows/yres;
417 estatus++;
418 break;
419 }
420 pass1scan(scan, i);
421 }
422 free((void *)scan);
423 }
424
425
426 static void
427 pass2( /* last pass on file, write to stdout */
428 FILE *in
429 )
430 {
431 int yread;
432 int ycent, xcent;
433 int r, c;
434
435 pass2init();
436 scan2init();
437 yread = 0;
438 for (r = 0; r < nrows; r++) {
439 ycent = (r+.5)*yres/nrows;
440 while (yread <= ycent+yrad) {
441 if (yread < yres) {
442 if (freadscan(scanin[yread%barsize],
443 xres, in) < 0) {
444 fprintf(stderr,
445 "%s: truncated input (y=%d)\n",
446 progname, yres-1-yread);
447 quit(1);
448 }
449 pass2scan(scanin[yread%barsize], yread);
450 }
451 yread++;
452 }
453 if (obarsize > 0)
454 scan2sync(r);
455 for (c = 0; c < ncols; c++) {
456 xcent = (c+.5)*xres/ncols;
457 if (thresh > FTINY)
458 dothresh(xcent, ycent, c, r);
459 else if (rad > FTINY)
460 dogauss(scanout[c], xcent, ycent, c, r);
461 else
462 dobox(scanout[c], xcent, ycent, c, r);
463 }
464 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
465 fprintf(stderr, "%s: write error in pass2\n", progname);
466 quit(1);
467 }
468 }
469 /* skip leftover input */
470 while (yread < yres) {
471 if (freadscan(scanin[0], xres, in) < 0)
472 break;
473 yread++;
474 }
475 scan2flush(); /* flush output */
476 }
477
478
479 static void
480 scan2init(void) /* prepare scanline arrays */
481 {
482 COLOR ctmp;
483 double d;
484 register int i;
485
486 xbrad = xres/ncols/2 + 1;
487 ybrad = yres/nrows/2 + 1;
488 if (rad > FTINY) {
489 if (nrows >= yres && ncols >= xres)
490 rad *= (y_r + x_c)/2.0;
491
492 if (thresh > FTINY) {
493 orad = CHECKRAD*THRESHRAD*rad + 1;
494 xrad = orad/x_c + xbrad;
495 yrad = orad/y_r + ybrad;
496 obarsize = 2*orad + 1;
497 } else {
498 xrad = CHECKRAD*rad/x_c + 1;
499 yrad = CHECKRAD*rad/y_r + 1;
500 }
501 initmask(); /* initialize filter table */
502 } else {
503 xrad = xbrad;
504 yrad = ybrad;
505 }
506 barsize = 2*yrad + 1;
507 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
508 if (scanin == NULL)
509 goto memerr;
510 for (i = 0; i < barsize; i++) {
511 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
512 if (scanin[i] == NULL)
513 goto memerr;
514 }
515 if (obarsize > 0) {
516 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
517 greybar = (float **)malloc(obarsize*sizeof(float *));
518 if ((scoutbar == NULL) | (greybar == NULL))
519 goto memerr;
520 for (i = 0; i < obarsize; i++) {
521 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
522 greybar[i] = (float *)malloc(ncols*sizeof(float));
523 if ((scoutbar[i] == NULL) | (greybar[i] == NULL))
524 goto memerr;
525 }
526 } else {
527 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
528 if (scanout == NULL)
529 goto memerr;
530 }
531 /* record pixel aspect ratio */
532 if (!correctaspect) {
533 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
534 if (!FEQ(d,1.0))
535 fputaspect(d, stdout);
536 }
537 /* record exposure */
538 d = (*ourbright)(exposure);
539 if (!FEQ(d,1.0))
540 fputexpos(d, stdout);
541 /* record color correction */
542 copycolor(ctmp, exposure);
543 scalecolor(ctmp, 1.0/d);
544 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
545 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
546 fputcolcor(ctmp, stdout);
547 printf("\n");
548 /* write out resolution */
549 fputresolu(order, ncols, nrows, stdout);
550 return;
551 memerr:
552 fprintf(stderr, "%s: out of memory\n", progname);
553 quit(1);
554 }
555
556
557 static void
558 scan2sync( /* synchronize grey averages and output scan */
559 int r
560 )
561 {
562 static int nextrow = 0;
563 COLOR ctmp;
564 int ybot;
565 register int c;
566 /* average input scanlines */
567 while (nextrow <= r+orad && nextrow < nrows) {
568 ybot = (nextrow+.5)*yres/nrows;
569 for (c = 0; c < ncols; c++) {
570 dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
571 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
572 }
573 /* and zero output scanline */
574 memset((char *)scoutbar[nextrow%obarsize], '\0', ncols*sizeof(COLOR));
575 nextrow++;
576 }
577 /* point to top scanline for output */
578 if (r-orad >= 0)
579 scanout = scoutbar[(r-orad)%obarsize];
580 else
581 scanout = NULL;
582 }
583
584
585 static void
586 scan2flush(void) /* flush output buffer */
587 {
588 register int r;
589
590 for (r = nrows-orad; r < nrows; r++)
591 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
592 break;
593 if (fflush(stdout) < 0) {
594 fprintf(stderr, "%s: write error at end of pass2\n", progname);
595 quit(1);
596 }
597 }
598
599
600 void
601 quit(code) /* remove temporary file and exit */
602 int code;
603 {
604 if (tfname != NULL)
605 unlink(tfname);
606 exit(code);
607 }
