root/radiance/ray/src/px/pfilt.c
Revision: 2.2
Committed: Thu Dec 19 14:51:52 1991 UTC (33 years, 6 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 */
12
13 #include <stdio.h>
14
15 #include <signal.h>
16
17 #include "color.h"
18
19 #include "resolu.h"
20
21 extern char *malloc();
22 extern float *matchlamp();
23
24 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
25
26 #define CHECKRAD 1.5 /* radius to check for filtering */
27
28 COLOR exposure = WHTCOLOR; /* exposure for the frame */
29
30 double rad = 0.0; /* output pixel radius for filtering */
31
32 int nrows = 0; /* number of rows for output */
33 int ncols = 0; /* number of columns for output */
34
35 double x_c = 1.0; /* ratio of output x size to input */
36 double y_r = 1.0; /* ratio of output y size to input */
37
38 int singlepass = 0; /* true means skip first pass */
39
40 int avghot = 0; /* true means average in bright spots */
41
42 double hotlvl = 1000.0; /* level considered "hot" */
43
44 int npts = 0; /* (half) number of points for stars */
45
46 double spread = 1e-4; /* spread for star points */
47
48 #define TEMPLATE "/usr/tmp/pfXXXXXX"
49
50 char *tfname = NULL;
51
52 char *lampdat = "lamp.tab"; /* lamp data file */
53
54 int order; /* scanline ordering of input */
55 int xres, yres; /* resolution of input */
56 double inpaspect = 1.0; /* pixel aspect ratio of input */
57 int correctaspect = 0; /* aspect ratio correction? */
58
59 int wrongformat = 0;
60
61 int xrad; /* x window size */
62 int yrad; /* y window size */
63
64 int barsize; /* size of input scan bar */
65 COLOR **scanin; /* input scan bar */
66 COLOR *scanout; /* output scan line */
67
68 char *progname;
69
70
71 main(argc, argv)
72 int argc;
73 char **argv;
74 {
75 extern char *mktemp();
76 extern double pow();
77 extern long ftell();
78 extern int quit(), headline();
79 FILE *fin;
80 float *lampcolor;
81 char *lamptype = NULL;
82 long fpos;
83 double outaspect = 0.0;
84 double d;
85 int i, j;
86
87 if (signal(SIGINT, quit) == SIG_IGN)
88 signal(SIGINT, SIG_IGN);
89 if (signal(SIGHUP, quit) == SIG_IGN)
90 signal(SIGINT, SIG_IGN);
91 signal(SIGTERM, quit);
92 signal(SIGPIPE, quit);
93 #ifdef SIGXCPU
94 signal(SIGXCPU, quit);
95 signal(SIGXFSZ, quit);
96 #endif
97
98 progname = argv[0];
99
100 for (i = 1; i < argc; i++)
101 if (argv[i][0] == '-')
102 switch (argv[i][1]) {
103 case 'x':
104 i++;
105 if (argv[i][0] == '/') {
106 x_c = 1.0/atof(argv[i]+1);
107 ncols = 0;
108 } else
109 ncols = atoi(argv[i]);
110 break;
111 case 'y':
112 i++;
113 if (argv[i][0] == '/') {
114 y_r = 1.0/atof(argv[i]+1);
115 nrows = 0;
116 } else
117 nrows = atoi(argv[i]);
118 break;
119 case 'c':
120 correctaspect = !correctaspect;
121 break;
122 case 'p':
123 i++;
124 outaspect = atof(argv[i]);
125 break;
126 case 'e':
127 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
128 d = pow(2.0, atof(argv[i+1]));
129 else
130 d = atof(argv[i+1]);
131 if (d < 1e-20 || d > 1e20) {
132 fprintf(stderr,
133 "%s: exposure out of range\n",
134 argv[0]);
135 exit(1);
136 }
137 switch (argv[i][2]) {
138 case '\0':
139 scalecolor(exposure, d);
140 break;
141 case 'r':
142 colval(exposure,RED) *= d;
143 break;
144 case 'g':
145 colval(exposure,GRN) *= d;
146 break;
147 case 'b':
148 colval(exposure,BLU) *= d;
149 break;
150 default:
151 goto badopt;
152 }
153 i++;
154 break;
155 case 'f':
156 lampdat = argv[++i];
157 break;
158 case 't':
159 lamptype = argv[++i];
160 break;
161 case '1':
162 singlepass = 1;
163 break;
164 case '2':
165 singlepass = 0;
166 break;
167 case 'n':
168 npts = atoi(argv[++i]) / 2;
169 break;
170 case 's':
171 spread = atof(argv[++i]);
172 break;
173 case 'a':
174 avghot = !avghot;
175 break;
176 case 'h':
177 hotlvl = atof(argv[++i]);
178 break;
179 case 'r':
180 rad = atof(argv[++i]);
181 break;
182 case 'b':
183 rad = 0.0;
184 break;
185 default:;
186 badopt:
187 fprintf(stderr, "%s: unknown option: %s\n",
188 progname, argv[i]);
189 quit(1);
190 break;
191 }
192 else
193 break;
194 /* get lamp data (if necessary) */
195 if (lamptype != NULL) {
196 if (loadlamps(lampdat) < 0)
197 quit(1);
198 if ((lampcolor = matchlamp(lamptype)) == NULL) {
199 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
200 quit(1);
201 }
202 for (i = 0; i < 3; i++)
203 if (lampcolor[i] > 1e-4)
204 colval(exposure,i) /= lampcolor[i];
205 freelamps();
206 }
207 /* open input file */
208 if (i == argc) {
209 if (singlepass)
210 fin = stdin;
211 else {
212 tfname = mktemp(TEMPLATE);
213 if ((fin = fopen(tfname, "w+")) == NULL) {
214 fprintf(stderr, "%s: can't create ", progname);
215 fprintf(stderr, "temp file \"%s\"\n", tfname);
216 quit(1);
217 }
218 copyfile(stdin, fin);
219 if (fseek(fin, 0L, 0) == -1) {
220 fprintf(stderr, "%s: seek fail\n", progname);
221 quit(1);
222 }
223 }
224 } else if (i == argc-1) {
225 if ((fin = fopen(argv[i], "r")) == NULL) {
226 fprintf(stderr, "%s: can't open file \"%s\"\n",
227 progname, argv[i]);
228 quit(1);
229 }
230 } else {
231 fprintf(stderr, "%s: bad # file arguments\n", progname);
232 quit(1);
233 }
234 /* get header */
235 getheader(fin, headline, NULL);
236 if (wrongformat) {
237 fprintf(stderr, "%s: input must be a Radiance picture\n",
238 progname);
239 quit(1);
240 }
241 /* add new header info. */
242 printargs(i, argv, stdout);
243 /* get picture size */
244 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
245 fprintf(stderr, "%s: bad picture size\n", progname);
246 quit(1);
247 }
248 if (!(order & YMAJOR))
249 inpaspect = 1.0/inpaspect;
250 /* compute output resolution */
251 if (ncols <= 0)
252 ncols = x_c*xres + .5;
253 if (nrows <= 0)
254 nrows = y_r*yres + .5;
255 if (outaspect > .01) {
256 d = inpaspect * yres/xres / outaspect;
257 if (d * ncols > nrows)
258 ncols = nrows / d;
259 else
260 nrows = ncols * d;
261 }
262 x_c = (double)ncols/xres;
263 y_r = (double)nrows/yres;
264
265 if (singlepass) { /* skip exposure, etc. */
266 pass1default();
267 pass2(fin);
268 quit(0);
269 }
270
271 fpos = ftell(fin); /* save input file position */
272
273 pass1(fin);
274
275 if (fseek(fin, fpos, 0) == -1) {
276 fprintf(stderr, "%s: seek fail\n", progname);
277 quit(1);
278 }
279 pass2(fin);
280
281 quit(0);
282 }
283
284
285 headline(s) /* process line from header */
286 char *s;
287 {
288 char fmt[32];
289
290 fputs(s, stdout); /* copy to output */
291 if (isaspect(s)) /* get aspect ratio */
292 inpaspect *= aspectval(s);
293 else if (isformat(s)) {
294 formatval(fmt, s);
295 wrongformat = strcmp(fmt, COLRFMT);
296 }
297 }
298
299
300 copyfile(in, out) /* copy a file */
301 register FILE *in, *out;
302 {
303 register int c;
304
305 while ((c = getc(in)) != EOF)
306 putc(c, out);
307
308 if (ferror(out)) {
309 fprintf(stderr, "%s: write error in copyfile\n", progname);
310 quit(1);
311 }
312 }
313
314
315 pass1(in) /* first pass of picture file */
316 FILE *in;
317 {
318 int i;
319 COLOR *scan;
320
321 pass1init();
322
323 scan = (COLOR *)malloc(xres*sizeof(COLOR));
324 if (scan == NULL) {
325 fprintf(stderr, "%s: out of memory\n", progname);
326 quit(1);
327 }
328 for (i = 0; i < yres; i++) {
329 if (freadscan(scan, xres, in) < 0) {
330 nrows = nrows * i / yres; /* adjust frame */
331 if (nrows <= 0) {
332 fprintf(stderr, "%s: empty frame\n", progname);
333 quit(1);
334 }
335 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
336 progname, 100*i/yres);
337 yres = i;
338 y_r = (double)nrows/yres;
339 break;
340 }
341 pass1scan(scan, i);
342 }
343 free((char *)scan);
344 }
345
346
347 pass2(in) /* last pass on file, write to stdout */
348 FILE *in;
349 {
350 int yread;
351 int ycent, xcent;
352 int r, c;
353
354 pass2init();
355 scan2init();
356 yread = 0;
357 for (r = 0; r < nrows; r++) {
358 ycent = (long)r*yres/nrows;
359 while (yread <= ycent+yrad) {
360 if (yread < yres) {
361 if (freadscan(scanin[yread%barsize],
362 xres, in) < 0) {
363 fprintf(stderr,
364 "%s: bad read (y=%d)\n",
365 progname, yres-1-yread);
366 quit(1);
367 }
368 pass2scan(scanin[yread%barsize], yread);
369 }
370 yread++;
371 }
372 for (c = 0; c < ncols; c++) {
373 xcent = (long)c*xres/ncols;
374 if (rad <= 0.0)
375 dobox(scanout[c], xcent, ycent, c, r);
376 else
377 dogauss(scanout[c], xcent, ycent, c, r);
378 }
379 if (fwritescan(scanout, ncols, stdout) < 0) {
380 fprintf(stderr, "%s: write error in pass2\n", progname);
381 quit(1);
382 }
383 }
384 /* skip leftovers */
385 while (yread < yres) {
386 if (freadscan(scanin[0], xres, in) < 0)
387 break;
388 yread++;
389 }
390 }
391
392
393 scan2init() /* prepare scanline arrays */
394 {
395 COLOR ctmp;
396 double d;
397 register int i;
398
399 if (rad <= 0.0) {
400 xrad = xres/ncols/2 + 1;
401 yrad = yres/nrows/2 + 1;
402 } else {
403 if (nrows >= yres && ncols >= xres)
404 rad *= (y_r + x_c)/2.0;
405
406 xrad = CHECKRAD*rad/x_c + 1;
407 yrad = CHECKRAD*rad/y_r + 1;
408
409 initmask(); /* initialize filter table */
410 }
411 barsize = 2*yrad + 1;
412 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
413 for (i = 0; i < barsize; i++) {
414 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
415 if (scanin[i] == NULL) {
416 fprintf(stderr, "%s: out of memory\n", progname);
417 quit(1);
418 }
419 }
420 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
421 if (scanout == NULL) {
422 fprintf(stderr, "%s: out of memory\n", progname);
423 quit(1);
424 }
425 /* record pixel aspect ratio */
426 if (!correctaspect) {
427 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
428 if (!FEQ(d,1.0))
429 fputaspect(d, stdout);
430 }
431 /* record exposure */
432 d = bright(exposure);
433 if (!FEQ(d,1.0))
434 fputexpos(d, stdout);
435 /* record color correction */
436 copycolor(ctmp, exposure);
437 scalecolor(ctmp, 1.0/d);
438 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
439 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
440 fputcolcor(ctmp, stdout);
441 printf("\n");
442 /* write out resolution */
443 fputresolu(order, ncols, nrows, stdout);
444 }
445
446
447 quit(code) /* remove temporary file and exit */
448 int code;
449 {
450 if (tfname != NULL)
451 unlink(tfname);
452 exit(code);
453 }
