root/radiance/ray/src/px/pf3.c
Thu Jul 26 23:50:40 2018 UTC (6 years, 8 months ago) by greg
CVS Tags: rad5R2, rad5R3, rad5R4
Changes since 2.18: +20 -20 lines
Diff to previous 2.18
Fixed issue with pfilt -m option and non-integer size divisors
Sun Mar 28 20:33:14 2004 UTC (21 years ago) by schorsch
Changes since 2.17: +42 -54 lines
Diff to previous 2.17
Sun Jul 27 22:12:03 2003 UTC (21 years, 8 months ago) by schorsch
Diff to previous 2.16
Mon Jun 30 14:59:12 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.15: +5 -3 lines
Diff to previous 2.15
Tue Feb 25 00:26:05 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 2.14
Fixed pre-release upsampling bug in new filtering kernel
Sat Feb 22 02:07:27 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.13: +22 -18 lines
Diff to previous 2.13
Thu Dec 12 14:24:00 1996 UTC (28 years, 3 months ago) by greg
Diff to previous 2.12
made output pixel positioning more precise
Thu Apr 4 13:01:35 1996 UTC (28 years, 11 months ago) by greg
Changes since 2.11: +40 -26 lines
added wraparound filtering for cylindrical views
Fri Jul 16 11:32:06 1993 UTC (31 years, 8 months ago) by greg
Changes since 2.10: +7 -4 lines
improved handling of zero exclusive average in pickfilt()
Thu Jul 15 18:32:06 1993 UTC (31 years, 8 months ago) by greg
Changes since 2.9: +32 -14 lines
corrected test criteria using exclusive average and
improved convergence of algorithm in pickfilt()
Fri Jul 9 10:27:52 1993 UTC (31 years, 8 months ago) by greg
minor optimization in pickfilt()
Fri Jun 25 17:08:40 1993 UTC (31 years, 9 months ago) by greg
bug fix in dothresh()
Fri Jun 25 15:01:20 1993 UTC (31 years, 9 months ago) by greg
Changes since 2.6: +202 -23 lines
added -m option for sample smoothing
Wed Jun 23 12:17:09 1993 UTC (31 years, 9 months ago) by greg
Changes since 2.5: +8 -8 lines
minor changes for readability
Fri Jun 18 13:36:20 1993 UTC (31 years, 9 months ago) by greg
Changes since 2.4: +11 -7 lines
fixed long-standing bug in normalization of Gaussian filter
Thu Nov 12 11:35:55 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.3: +10 -10 lines
minor optimizations
Fri Oct 2 16:23:41 1992 UTC (32 years, 6 months ago) by greg
Mon Sep 21 12:14:12 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.1: +5 -5 lines
Changes for PC port
Tue Nov 12 16:05:26 1991 UTC (33 years, 4 months ago) by greg
Diff to previous 1.2
Wed Jun 5 12:15:34 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.1: +4 -4 lines
Diff to previous 1.1
improved gaussian filtering
Thu Feb 2 10:49:26 1989 UTC (36 years, 2 months ago) by greg
