1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* pf3.c - routines for gaussian and box filtering |
6 |
7 |
* 8/13/86 |
8 |
9 |
10 |
#include "standard.h" |
11 |
12 |
#include "color.h" |
13 |
14 |
#define RSCA 1.13 /* square-radius multiplier: sqrt(4/PI) */ |
15 |
#define TEPS 0.2 /* threshold proximity goal */ |
16 |
#define REPS 0.1 /* radius proximity goal */ |
17 |
18 |
extern double CHECKRAD; /* radius over which gaussian is summed */ |
19 |
20 |
extern double rad; /* output pixel radius for filtering */ |
21 |
22 |
extern double thresh; /* maximum contribution for subpixel */ |
23 |
24 |
extern int nrows; /* number of rows for output */ |
25 |
extern int ncols; /* number of columns for output */ |
26 |
27 |
extern int xres, yres; /* resolution of input */ |
28 |
29 |
extern double x_c, y_r; /* conversion factors */ |
30 |
31 |
extern int xrad; /* x search radius */ |
32 |
extern int yrad; /* y search radius */ |
33 |
extern int xbrad; /* x box size */ |
34 |
extern int ybrad; /* y box size */ |
35 |
36 |
extern int barsize; /* size of input scan bar */ |
37 |
extern COLOR **scanin; /* input scan bar */ |
38 |
extern COLOR *scanout; /* output scan line */ |
39 |
extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */ |
40 |
extern float **greybar; /* grey-averaged input values */ |
41 |
extern int obarsize; /* size of output scan bar */ |
42 |
extern int orad; /* output window radius */ |
43 |
44 |
extern int wrapfilt; /* wrap filter horizontally? */ |
45 |
46 |
extern char *progname; |
47 |
48 |
float *gausstable; /* gauss lookup table */ |
49 |
50 |
float *ringsum; /* sum of ring values */ |
51 |
short *ringwt; /* weight (count) of ring values */ |
52 |
short *ringndx; /* ring index table */ |
53 |
float *warr; /* array of pixel weights */ |
54 |
55 |
extern double (*ourbright)(); /* brightness computation function */ |
56 |
57 |
double pickfilt(); |
58 |
59 |
#define lookgauss(x) gausstable[(int)(10.*(x)+.5)] |
60 |
61 |
62 |
initmask() /* initialize gaussian lookup table */ |
63 |
64 |
int gtabsiz; |
65 |
double gaussN; |
66 |
double d; |
67 |
register int x; |
68 |
69 |
gtabsiz = 111*CHECKRAD*CHECKRAD; |
70 |
gausstable = (float *)malloc(gtabsiz*sizeof(float)); |
71 |
if (gausstable == NULL) |
72 |
goto memerr; |
73 |
d = x_c*y_r*0.25/(rad*rad); |
74 |
gausstable[0] = exp(-d); |
75 |
for (x = 1; x < gtabsiz; x++) |
76 |
if (x*0.1 <= d) |
77 |
gausstable[x] = gausstable[0]; |
78 |
else |
79 |
gausstable[x] = exp(-x*0.1); |
80 |
if (obarsize == 0) |
81 |
return; |
82 |
/* compute integral of filter */ |
83 |
gaussN = PI*d*exp(-d); /* plateau */ |
84 |
for (d = sqrt(d)+0.05; d <= RSCA*CHECKRAD; d += 0.1) |
85 |
gaussN += 0.1*2.0*PI*d*exp(-d*d); |
86 |
/* normalize filter */ |
87 |
gaussN = x_c*y_r/(rad*rad*gaussN); |
88 |
for (x = 0; x < gtabsiz; x++) |
89 |
gausstable[x] *= gaussN; |
90 |
/* create ring averages table */ |
91 |
ringndx = (short *)malloc((2*orad*orad+1)*sizeof(short)); |
92 |
if (ringndx == NULL) |
93 |
goto memerr; |
94 |
for (x = 2*orad*orad+1; --x > orad*orad; ) |
95 |
ringndx[x] = -1; |
96 |
do |
97 |
ringndx[x] = sqrt((double)x); |
98 |
while (x--); |
99 |
ringsum = (float *)malloc((orad+1)*sizeof(float)); |
100 |
ringwt = (short *)malloc((orad+1)*sizeof(short)); |
101 |
warr = (float *)malloc(obarsize*obarsize*sizeof(float)); |
102 |
if (ringsum == NULL | ringwt == 0 | warr == NULL) |
103 |
goto memerr; |
104 |
return; |
105 |
memerr: |
106 |
fprintf(stderr, "%s: out of memory in initmask\n", progname); |
107 |
quit(1); |
108 |
109 |
110 |
111 |
dobox(csum, xcent, ycent, c, r) /* simple box filter */ |
112 |
COLOR csum; |
113 |
int xcent, ycent; |
114 |
int c, r; |
115 |
116 |
int wsum; |
117 |
double d; |
118 |
int y; |
119 |
register int x, offs; |
120 |
register COLOR *scan; |
121 |
122 |
wsum = 0; |
123 |
setcolor(csum, 0.0, 0.0, 0.0); |
124 |
for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) { |
125 |
if (y < 0) continue; |
126 |
if (y >= yres) break; |
127 |
d = y_r < 1.0 ? y_r*y - (r+.5) : (double)(y - ycent); |
128 |
if (d < -0.5) continue; |
129 |
if (d >= 0.5) break; |
130 |
scan = scanin[y%barsize]; |
131 |
for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) { |
132 |
offs = x < 0 ? xres : x >= xres ? -xres : 0; |
133 |
if (offs && !wrapfilt) |
134 |
continue; |
135 |
d = x_c < 1.0 ? x_c*x - (c+.5) : (double)(x - xcent); |
136 |
137 |
138 |
wsum++; |
139 |
addcolor(csum, scan[x+offs]); |
140 |
141 |
142 |
if (wsum > 1) { |
143 |
d = 1.0/wsum; |
144 |
scalecolor(csum, d); |
145 |
146 |
147 |
148 |
149 |
dogauss(csum, xcent, ycent, c, r) /* gaussian filter */ |
150 |
COLOR csum; |
151 |
int xcent, ycent; |
152 |
int c, r; |
153 |
154 |
double dy, dx, weight, wsum; |
155 |
COLOR ctmp; |
156 |
int y; |
157 |
158 |
159 |
160 |
wsum = FTINY; |
161 |
162 |
for (y = ycent-yrad; y <= ycent+yrad; y++) { |
163 |
164 |
165 |
dy = (y_r*(y+.5) - (r+.5))/rad; |
166 |
167 |
for (x = xcent-xrad; x <= xcent+xrad; x++) { |
168 |
169 |
170 |
continue; |
171 |
dx = (x_c*(x+.5) - (c+.5))/rad; |
172 |
weight = lookgauss(dx*dx + dy*dy); |
173 |
wsum += weight; |
174 |
copycolor(ctmp, scan[x+offs]); |
175 |
scalecolor(ctmp, weight); |
176 |
addcolor(csum, ctmp); |
177 |
178 |
179 |
weight = 1.0/wsum; |
180 |
scalecolor(csum, weight); |
181 |
182 |
183 |
184 |
dothresh(xcent, ycent, ccent, rcent) /* gaussian threshold filter */ |
185 |
int xcent, ycent; |
186 |
int ccent, rcent; |
187 |
188 |
double d; |
189 |
int r, y, offs; |
190 |
register int c, x; |
191 |
register float *gscan; |
192 |
/* compute ring sums */ |
193 |
bzero((char *)ringsum, (orad+1)*sizeof(float)); |
194 |
bzero((char *)ringwt, (orad+1)*sizeof(short)); |
195 |
for (r = -orad; r <= orad; r++) { |
196 |
if (rcent+r < 0) continue; |
197 |
if (rcent+r >= nrows) break; |
198 |
gscan = greybar[(rcent+r)%obarsize]; |
199 |
for (c = -orad; c <= orad; c++) { |
200 |
offs = ccent+c < 0 ? ncols : |
201 |
ccent+c >= ncols ? -ncols : 0; |
202 |
203 |
continue; |
204 |
x = ringndx[c*c + r*r]; |
205 |
if (x < 0) continue; |
206 |
ringsum[x] += gscan[ccent+c+offs]; |
207 |
ringwt[x]++; |
208 |
209 |
210 |
/* filter each subpixel */ |
211 |
212 |
213 |
214 |
d = y_r < 1.0 ? y_r*y - (rcent+.5) : (double)(y - ycent); |
215 |
216 |
217 |
218 |
219 |
220 |
continue; |
221 |
d = x_c < 1.0 ? x_c*x - (ccent+.5) : (double)(x - xcent); |
222 |
223 |
224 |
sumans(x, y, rcent, ccent, |
225 |
pickfilt((*ourbright)(scanin[y%barsize][x+offs]))); |
226 |
227 |
228 |
229 |
230 |
231 |
double |
232 |
pickfilt(p0) /* find filter multiplier for p0 */ |
233 |
double p0; |
234 |
235 |
double m = 1.0; |
236 |
double t, num, denom, avg, wsum; |
237 |
double mlimit[2]; |
238 |
int ilimit = 4.0/TEPS; |
239 |
register int i; |
240 |
/* iterative search for m */ |
241 |
mlimit[0] = 1.0; mlimit[1] = orad/rad/CHECKRAD; |
242 |
do { |
243 |
/* compute grey weighted average */ |
244 |
i = RSCA*CHECKRAD*rad*m + .5; |
245 |
if (i > orad) i = orad; |
246 |
avg = wsum = 0.0; |
247 |
while (i--) { |
248 |
t = (i+.5)/(m*rad); |
249 |
t = lookgauss(t*t); |
250 |
avg += t*ringsum[i]; |
251 |
wsum += t*ringwt[i]; |
252 |
253 |
if (avg < 1e-20) /* zero inclusive average */ |
254 |
return(1.0); |
255 |
avg /= wsum; |
256 |
/* check threshold */ |
257 |
denom = m*m/gausstable[0] - p0/avg; |
258 |
if (denom <= FTINY) { /* zero exclusive average */ |
259 |
if (m >= mlimit[1]-REPS) |
260 |
break; |
261 |
m = mlimit[1]; |
262 |
continue; |
263 |
264 |
num = p0/avg - 1.0; |
265 |
if (num < 0.0) num = -num; |
266 |
t = num/denom; |
267 |
if (t <= thresh) { |
268 |
if (m <= mlimit[0]+REPS || (thresh-t)/thresh <= TEPS) |
269 |
break; |
270 |
} else { |
271 |
if (m >= mlimit[1]-REPS || (t-thresh)/thresh <= TEPS) |
272 |
break; |
273 |
274 |
t = m; /* remember current m */ |
275 |
/* next guesstimate */ |
276 |
m = sqrt(gausstable[0]*(num/thresh + p0/avg)); |
277 |
if (m < t) { /* bound it */ |
278 |
if (m <= mlimit[0]+FTINY) |
279 |
m = 0.5*(mlimit[0] + t); |
280 |
mlimit[1] = t; |
281 |
} else { |
282 |
if (m >= mlimit[1]-FTINY) |
283 |
m = 0.5*(mlimit[1] + t); |
284 |
mlimit[0] = t; |
285 |
286 |
} while (--ilimit > 0); |
287 |
return(m); |
288 |
289 |
290 |
291 |
sumans(px, py, rcent, ccent, m) /* sum input pixel to output */ |
292 |
int px, py; |
293 |
int rcent, ccent; |
294 |
double m; |
295 |
296 |
double dy2, dx; |
297 |
COLOR pval, ctmp; |
298 |
int ksiz, r, offs; |
299 |
double pc, pr, norm; |
300 |
register int i, c; |
301 |
302 |
303 |
* This normalization method fails at the picture borders because |
304 |
* a different number of input pixels contribute there. |
305 |
306 |
scan = scanin[py%barsize] + (px < 0 ? xres : px >= xres ? -xres : 0); |
307 |
copycolor(pval, scan[px]); |
308 |
pc = x_c*(px+.5); |
309 |
pr = y_r*(py+.5); |
310 |
ksiz = CHECKRAD*m*rad + 1; |
311 |
if (ksiz > orad) ksiz = orad; |
312 |
/* compute normalization */ |
313 |
norm = 0.0; |
314 |
i = 0; |
315 |
for (r = rcent-ksiz; r <= rcent+ksiz; r++) { |
316 |
if (r < 0) continue; |
317 |
if (r >= nrows) break; |
318 |
dy2 = (pr - (r+.5))/(m*rad); |
319 |
dy2 *= dy2; |
320 |
for (c = ccent-ksiz; c <= ccent+ksiz; c++) { |
321 |
if (!wrapfilt) { |
322 |
if (c < 0) continue; |
323 |
if (c >= ncols) break; |
324 |
325 |
dx = (pc - (c+.5))/(m*rad); |
326 |
norm += warr[i++] = lookgauss(dx*dx + dy2); |
327 |
328 |
329 |
norm = 1.0/norm; |
330 |
if (x_c < 1.0) norm *= x_c; |
331 |
if (y_r < 1.0) norm *= y_r; |
332 |
/* sum pixels */ |
333 |
i = 0; |
334 |
335 |
336 |
337 |
scan = scoutbar[r%obarsize]; |
338 |
339 |
offs = c < 0 ? ncols : c >= ncols ? -ncols : 0; |
340 |
341 |
continue; |
342 |
copycolor(ctmp, pval); |
343 |
dx = norm*warr[i++]; |
344 |
scalecolor(ctmp, dx); |
345 |
addcolor(scan[c+offs], ctmp); |
346 |
347 |
348 |
