root/radiance/ray/src/px/pf3.c
Revision: 2.17
Committed: Sun Jul 27 22:12:03 2003 UTC (22 years ago) by schorsch
2 static const char RCSid[] = "$Id: pf3.c,v 2.16 2003/06/30 14:59:12 schorsch Exp $";
5 * pf3.c - routines for gaussian and box filtering
6 *
7 * 8/13/86
8 */
9
10 #include "standard.h"
11
12 #include <string.h>
13
14 #include "color.h"
15
16 #define RSCA 1.13 /* square-radius multiplier: sqrt(4/PI) */
17 #define TEPS 0.2 /* threshold proximity goal */
18 #define REPS 0.1 /* radius proximity goal */
19
20 extern double CHECKRAD; /* radius over which gaussian is summed */
21
22 extern double rad; /* output pixel radius for filtering */
23
24 extern double thresh; /* maximum contribution for subpixel */
25
26 extern int nrows; /* number of rows for output */
27 extern int ncols; /* number of columns for output */
28
29 extern int xres, yres; /* resolution of input */
30
31 extern double x_c, y_r; /* conversion factors */
32
33 extern int xrad; /* x search radius */
34 extern int yrad; /* y search radius */
35 extern int xbrad; /* x box size */
36 extern int ybrad; /* y box size */
37
38 extern int barsize; /* size of input scan bar */
39 extern COLOR **scanin; /* input scan bar */
40 extern COLOR *scanout; /* output scan line */
41 extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */
42 extern float **greybar; /* grey-averaged input values */
43 extern int obarsize; /* size of output scan bar */
44 extern int orad; /* output window radius */
45
46 extern int wrapfilt; /* wrap filter horizontally? */
47
48 extern char *progname;
49
50 float *gausstable; /* gauss lookup table */
51
52 float *ringsum; /* sum of ring values */
53 short *ringwt; /* weight (count) of ring values */
54 short *ringndx; /* ring index table */
55 float *warr; /* array of pixel weights */
56
57 extern double (*ourbright)(); /* brightness computation function */
58
59 double pickfilt();
60
61 #define lookgauss(x) gausstable[(int)(10.*(x)+.5)]
62
63
64 initmask() /* initialize gaussian lookup table */
65 {
66 int gtabsiz;
67 double gaussN;
68 double d;
69 register int x;
70
71 gtabsiz = 111*CHECKRAD*CHECKRAD;
72 gausstable = (float *)malloc(gtabsiz*sizeof(float));
73 if (gausstable == NULL)
74 goto memerr;
75 d = x_c*y_r*0.25/(rad*rad);
76 gausstable[0] = exp(-d);
77 for (x = 1; x < gtabsiz; x++)
78 if (x*0.1 <= d)
79 gausstable[x] = gausstable[0];
80 else
81 gausstable[x] = exp(-x*0.1);
82 if (obarsize == 0)
83 return;
84 /* compute integral of filter */
85 gaussN = PI*d*exp(-d); /* plateau */
86 for (d = sqrt(d)+0.05; d <= RSCA*CHECKRAD; d += 0.1)
87 gaussN += 0.1*2.0*PI*d*exp(-d*d);
88 /* normalize filter */
89 gaussN = x_c*y_r/(rad*rad*gaussN);
90 for (x = 0; x < gtabsiz; x++)
91 gausstable[x] *= gaussN;
92 /* create ring averages table */
93 ringndx = (short *)malloc((2*orad*orad+1)*sizeof(short));
94 if (ringndx == NULL)
95 goto memerr;
96 for (x = 2*orad*orad+1; --x > orad*orad; )
97 ringndx[x] = -1;
98 do
99 ringndx[x] = sqrt((double)x);
100 while (x--);
101 ringsum = (float *)malloc((orad+1)*sizeof(float));
102 ringwt = (short *)malloc((orad+1)*sizeof(short));
103 warr = (float *)malloc(obarsize*obarsize*sizeof(float));
104 if ((ringsum == NULL) | (ringwt == 0) | (warr == NULL))
105 goto memerr;
106 return;
107 memerr:
108 fprintf(stderr, "%s: out of memory in initmask\n", progname);
109 quit(1);
110 }
111
112
113 dobox(csum, xcent, ycent, c, r) /* simple box filter */
114 COLOR csum;
115 int xcent, ycent;
116 int c, r;
117 {
118 int wsum;
119 double d;
120 int y;
121 register int x, offs;
122 register COLOR *scan;
123
124 wsum = 0;
125 setcolor(csum, 0.0, 0.0, 0.0);
126 for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
127 if (y < 0) continue;
128 if (y >= yres) break;
129 d = y_r < 1.0 ? y_r*y - (r+.5) : (double)(y - ycent);
130 if (d < -0.5) continue;
131 if (d >= 0.5) break;
132 scan = scanin[y%barsize];
133 for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
134 offs = x < 0 ? xres : x >= xres ? -xres : 0;
135 if (offs && !wrapfilt)
136 continue;
137 d = x_c < 1.0 ? x_c*x - (c+.5) : (double)(x - xcent);
138 if (d < -0.5) continue;
139 if (d >= 0.5) break;
140 wsum++;
141 addcolor(csum, scan[x+offs]);
142 }
143 }
144 if (wsum > 1) {
145 d = 1.0/wsum;
146 scalecolor(csum, d);
147 }
148 }
149
150
151 dogauss(csum, xcent, ycent, c, r) /* gaussian filter */
152 COLOR csum;
153 int xcent, ycent;
154 int c, r;
155 {
156 double dy, dx, weight, wsum;
157 COLOR ctmp;
158 int y;
159 register int x, offs;
160 register COLOR *scan;
161
162 wsum = FTINY;
163 setcolor(csum, 0.0, 0.0, 0.0);
164 for (y = ycent-yrad; y <= ycent+yrad; y++) {
165 if (y < 0) continue;
166 if (y >= yres) break;
167 dy = (y_r*(y+.5) - (r+.5))/rad;
168 scan = scanin[y%barsize];
169 for (x = xcent-xrad; x <= xcent+xrad; x++) {
170 offs = x < 0 ? xres : x >= xres ? -xres : 0;
171 if (offs && !wrapfilt)
172 continue;
173 dx = (x_c*(x+.5) - (c+.5))/rad;
174 weight = lookgauss(dx*dx + dy*dy);
175 wsum += weight;
176 copycolor(ctmp, scan[x+offs]);
177 scalecolor(ctmp, weight);
178 addcolor(csum, ctmp);
179 }
180 }
181 weight = 1.0/wsum;
182 scalecolor(csum, weight);
183 }
184
185
186 dothresh(xcent, ycent, ccent, rcent) /* gaussian threshold filter */
187 int xcent, ycent;
188 int ccent, rcent;
189 {
190 double d;
191 int r, y, offs;
192 register int c, x;
193 register float *gscan;
194 /* compute ring sums */
195 memset((char *)ringsum, '\0', (orad+1)*sizeof(float));
196 memset((char *)ringwt, '\0', (orad+1)*sizeof(short));
197 for (r = -orad; r <= orad; r++) {
198 if (rcent+r < 0) continue;
199 if (rcent+r >= nrows) break;
200 gscan = greybar[(rcent+r)%obarsize];
201 for (c = -orad; c <= orad; c++) {
202 offs = ccent+c < 0 ? ncols :
203 ccent+c >= ncols ? -ncols : 0;
204 if (offs && !wrapfilt)
205 continue;
206 x = ringndx[c*c + r*r];
207 if (x < 0) continue;
208 ringsum[x] += gscan[ccent+c+offs];
209 ringwt[x]++;
210 }
211 }
212 /* filter each subpixel */
213 for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
214 if (y < 0) continue;
215 if (y >= yres) break;
216 d = y_r < 1.0 ? y_r*y - (rcent+.5) : (double)(y - ycent);
217 if (d < -0.5) continue;
218 if (d >= 0.5) break;
219 for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
220 offs = x < 0 ? xres : x >= xres ? -xres : 0;
221 if (offs && !wrapfilt)
222 continue;
223 d = x_c < 1.0 ? x_c*x - (ccent+.5) : (double)(x - xcent);
224 if (d < -0.5) continue;
225 if (d >= 0.5) break;
226 sumans(x, y, rcent, ccent,
227 pickfilt((*ourbright)(scanin[y%barsize][x+offs])));
228 }
229 }
230 }
231
232
233 double
234 pickfilt(p0) /* find filter multiplier for p0 */
235 double p0;
236 {
237 double m = 1.0;
238 double t, num, denom, avg, wsum;
239 double mlimit[2];
240 int ilimit = 4.0/TEPS;
241 register int i;
242 /* iterative search for m */
243 mlimit[0] = 1.0; mlimit[1] = orad/rad/CHECKRAD;
244 do {
245 /* compute grey weighted average */
246 i = RSCA*CHECKRAD*rad*m + .5;
247 if (i > orad) i = orad;
248 avg = wsum = 0.0;
249 while (i--) {
250 t = (i+.5)/(m*rad);
251 t = lookgauss(t*t);
252 avg += t*ringsum[i];
253 wsum += t*ringwt[i];
254 }
255 if (avg < 1e-20) /* zero inclusive average */
256 return(1.0);
257 avg /= wsum;
258 /* check threshold */
259 denom = m*m/gausstable[0] - p0/avg;
260 if (denom <= FTINY) { /* zero exclusive average */
261 if (m >= mlimit[1]-REPS)
262 break;
263 m = mlimit[1];
264 continue;
265 }
266 num = p0/avg - 1.0;
267 if (num < 0.0) num = -num;
268 t = num/denom;
269 if (t <= thresh) {
270 if (m <= mlimit[0]+REPS || (thresh-t)/thresh <= TEPS)
271 break;
272 } else {
273 if (m >= mlimit[1]-REPS || (t-thresh)/thresh <= TEPS)
274 break;
275 }
276 t = m; /* remember current m */
277 /* next guesstimate */
278 m = sqrt(gausstable[0]*(num/thresh + p0/avg));
279 if (m < t) { /* bound it */
280 if (m <= mlimit[0]+FTINY)
281 m = 0.5*(mlimit[0] + t);
282 mlimit[1] = t;
283 } else {
284 if (m >= mlimit[1]-FTINY)
285 m = 0.5*(mlimit[1] + t);
286 mlimit[0] = t;
287 }
288 } while (--ilimit > 0);
289 return(m);
290 }
291
292
293 sumans(px, py, rcent, ccent, m) /* sum input pixel to output */
294 int px, py;
295 int rcent, ccent;
296 double m;
297 {
298 double dy2, dx;
299 COLOR pval, ctmp;
300 int ksiz, r, offs;
301 double pc, pr, norm;
302 register int i, c;
303 register COLOR *scan;
304 /*
305 * This normalization method fails at the picture borders because
306 * a different number of input pixels contribute there.
307 */
308 scan = scanin[py%barsize] + (px < 0 ? xres : px >= xres ? -xres : 0);
309 copycolor(pval, scan[px]);
310 pc = x_c*(px+.5);
311 pr = y_r*(py+.5);
312 ksiz = CHECKRAD*m*rad + 1;
313 if (ksiz > orad) ksiz = orad;
314 /* compute normalization */
315 norm = 0.0;
316 i = 0;
317 for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
318 if (r < 0) continue;
319 if (r >= nrows) break;
320 dy2 = (pr - (r+.5))/(m*rad);
321 dy2 *= dy2;
322 for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
323 if (!wrapfilt) {
324 if (c < 0) continue;
325 if (c >= ncols) break;
326 }
327 dx = (pc - (c+.5))/(m*rad);
328 norm += warr[i++] = lookgauss(dx*dx + dy2);
329 }
330 }
331 norm = 1.0/norm;
332 if (x_c < 1.0) norm *= x_c;
333 if (y_r < 1.0) norm *= y_r;
334 /* sum pixels */
335 i = 0;
336 for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
337 if (r < 0) continue;
338 if (r >= nrows) break;
339 scan = scoutbar[r%obarsize];
340 for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
341 offs = c < 0 ? ncols : c >= ncols ? -ncols : 0;
342 if (offs && !wrapfilt)
343 continue;
344 copycolor(ctmp, pval);
345 dx = norm*warr[i++];
346 scalecolor(ctmp, dx);
347 addcolor(scan[c+offs], ctmp);
348 }
349 }
350 }
