root/radiance/ray/src/px/pf3.c
Revision: 2.13
Committed: Thu Dec 12 14:24:00 1996 UTC (28 years, 8 months ago) by greg
made output pixel positioning more precise
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pf3.c - routines for gaussian and box filtering
9 *
10 * 8/13/86
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #define TEPS 0.2 /* threshold proximity goal */
18 #define REPS 0.1 /* radius proximity goal */
19
20 extern double CHECKRAD; /* radius over which gaussian is summed */
21
22 extern double rad; /* output pixel radius for filtering */
23
24 extern double thresh; /* maximum contribution for subpixel */
25
26 extern int nrows; /* number of rows for output */
27 extern int ncols; /* number of columns for output */
28
29 extern int xres, yres; /* resolution of input */
30
31 extern double x_c, y_r; /* conversion factors */
32
33 extern int xrad; /* x search radius */
34 extern int yrad; /* y search radius */
35 extern int xbrad; /* x box size */
36 extern int ybrad; /* y box size */
37
38 extern int barsize; /* size of input scan bar */
39 extern COLOR **scanin; /* input scan bar */
40 extern COLOR *scanout; /* output scan line */
41 extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */
42 extern float **greybar; /* grey-averaged input values */
43 extern int obarsize; /* size of output scan bar */
44 extern int orad; /* output window radius */
45
46 extern int wrapfilt; /* wrap filter horizontally? */
47
48 extern char *progname;
49
50 float *gausstable; /* gauss lookup table */
51
52 float *ringsum; /* sum of ring values */
53 short *ringwt; /* weight (count) of ring values */
54 short *ringndx; /* ring index table */
55 float *warr; /* array of pixel weights */
56
57 extern double (*ourbright)(); /* brightness computation function */
58
59 double pickfilt();
60
61 #define lookgauss(x) gausstable[(int)(10.*(x)+.5)]
62
63
64 initmask() /* initialize gaussian lookup table */
65 {
66 int gtabsiz;
67 double gaussN;
68 double d;
69 register int x;
70
71 gtabsiz = 150*CHECKRAD;
72 gausstable = (float *)malloc(gtabsiz*sizeof(float));
73 if (gausstable == NULL)
74 goto memerr;
75 d = x_c*y_r*0.25/(rad*rad);
76 gausstable[0] = exp(-d)/sqrt(d);
77 for (x = 1; x < gtabsiz; x++)
78 if ((gausstable[x] = exp(-x*0.1)/sqrt(x*0.1)) > gausstable[0])
79 gausstable[x] = gausstable[0];
80 if (obarsize == 0)
81 return;
82 /* compute integral of filter */
83 gaussN = PI*sqrt(d)*exp(-d); /* plateau */
84 for (d = sqrt(d)+0.05; d <= 1.25*CHECKRAD; d += 0.1)
85 gaussN += 0.1*2.0*PI*exp(-d*d);
86 /* normalize filter */
87 gaussN = x_c*y_r/(rad*rad*gaussN);
88 for (x = 0; x < gtabsiz; x++)
89 gausstable[x] *= gaussN;
90 /* create ring averages table */
91 ringndx = (short *)malloc((2*orad*orad+1)*sizeof(short));
92 if (ringndx == NULL)
93 goto memerr;
94 for (x = 2*orad*orad+1; --x > orad*orad; )
95 ringndx[x] = -1;
96 do
97 ringndx[x] = sqrt((double)x);
98 while (x--);
99 ringsum = (float *)malloc((orad+1)*sizeof(float));
100 ringwt = (short *)malloc((orad+1)*sizeof(short));
101 warr = (float *)malloc(obarsize*obarsize*sizeof(float));
102 if (ringsum == NULL | ringwt == 0 | warr == NULL)
103 goto memerr;
104 return;
105 memerr:
106 fprintf(stderr, "%s: out of memory in initmask\n", progname);
107 quit(1);
108 }
109
110
111 dobox(csum, xcent, ycent, c, r) /* simple box filter */
112 COLOR csum;
113 int xcent, ycent;
114 int c, r;
115 {
116 int wsum;
117 double d;
118 int y;
119 register int x, offs;
120 register COLOR *scan;
121
122 wsum = 0;
123 setcolor(csum, 0.0, 0.0, 0.0);
124 for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
125 if (y < 0) continue;
126 if (y >= yres) break;
127 d = y_r < 1.0 ? y_r*y - (r+.5) : (double)(y - ycent);
128 if (d < -0.5) continue;
129 if (d >= 0.5) break;
130 scan = scanin[y%barsize];
131 for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
132 offs = x < 0 ? xres : x >= xres ? -xres : 0;
133 if (offs && !wrapfilt)
134 continue;
135 d = x_c < 1.0 ? x_c*x - (c+.5) : (double)(x - xcent);
136 if (d < -0.5) continue;
137 if (d >= 0.5) break;
138 wsum++;
139 addcolor(csum, scan[x+offs]);
140 }
141 }
142 if (wsum > 1)
143 scalecolor(csum, 1.0/wsum);
144 }
145
146
147 dogauss(csum, xcent, ycent, c, r) /* gaussian filter */
148 COLOR csum;
149 int xcent, ycent;
150 int c, r;
151 {
152 double dy, dx, weight, wsum;
153 COLOR ctmp;
154 int y;
155 register int x, offs;
156 register COLOR *scan;
157
158 wsum = FTINY;
159 setcolor(csum, 0.0, 0.0, 0.0);
160 for (y = ycent-yrad; y <= ycent+yrad; y++) {
161 if (y < 0) continue;
162 if (y >= yres) break;
163 dy = (y_r*(y+.5) - (r+.5))/rad;
164 scan = scanin[y%barsize];
165 for (x = xcent-xrad; x <= xcent+xrad; x++) {
166 offs = x < 0 ? xres : x >= xres ? -xres : 0;
167 if (offs && !wrapfilt)
168 continue;
169 dx = (x_c*(x+.5) - (c+.5))/rad;
170 weight = lookgauss(dx*dx + dy*dy);
171 wsum += weight;
172 copycolor(ctmp, scan[x+offs]);
173 scalecolor(ctmp, weight);
174 addcolor(csum, ctmp);
175 }
176 }
177 scalecolor(csum, 1.0/wsum);
178 }
179
180
181 dothresh(xcent, ycent, ccent, rcent) /* gaussian threshold filter */
182 int xcent, ycent;
183 int ccent, rcent;
184 {
185 double d;
186 int r, y, offs;
187 register int c, x;
188 register float *gscan;
189 /* compute ring sums */
190 bzero((char *)ringsum, (orad+1)*sizeof(float));
191 bzero((char *)ringwt, (orad+1)*sizeof(short));
192 for (r = -orad; r <= orad; r++) {
193 if (rcent+r < 0) continue;
194 if (rcent+r >= nrows) break;
195 gscan = greybar[(rcent+r)%obarsize];
196 for (c = -orad; c <= orad; c++) {
197 offs = ccent+c < 0 ? ncols :
198 ccent+c >= ncols ? -ncols : 0;
199 if (offs && !wrapfilt)
200 continue;
201 x = ringndx[c*c + r*r];
202 if (x < 0) continue;
203 ringsum[x] += gscan[ccent+c+offs];
204 ringwt[x]++;
205 }
206 }
207 /* filter each subpixel */
208 for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
209 if (y < 0) continue;
210 if (y >= yres) break;
211 d = y_r < 1.0 ? y_r*y - (rcent+.5) : (double)(y - ycent);
212 if (d < -0.5) continue;
213 if (d >= 0.5) break;
214 for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
215 offs = x < 0 ? xres : x >= xres ? -xres : 0;
216 if (offs && !wrapfilt)
217 continue;
218 d = x_c < 1.0 ? x_c*x - (ccent+.5) : (double)(x - xcent);
219 if (d < -0.5) continue;
220 if (d >= 0.5) break;
221 sumans(x, y, rcent, ccent,
222 pickfilt((*ourbright)(scanin[y%barsize][x+offs])));
223 }
224 }
225 }
226
227
228 double
229 pickfilt(p0) /* find filter multiplier for p0 */
230 double p0;
231 {
232 double m = 1.0;
233 double t, num, denom, avg, wsum;
234 double mlimit[2];
235 int ilimit = 4/TEPS;
236 register int i;
237 /* iterative search for m */
238 mlimit[0] = 1.0; mlimit[1] = orad/rad/CHECKRAD;
239 do {
240 /* compute grey weighted average */
241 i = 1.25*CHECKRAD*rad*m + .5;
242 if (i > orad) i = orad;
243 avg = wsum = 0.0;
244 while (i--) {
245 t = (i+.5)/(m*rad);
246 t = lookgauss(t*t);
247 avg += t*ringsum[i];
248 wsum += t*ringwt[i];
249 }
250 if (avg < 1e-20) /* zero inclusive average */
251 return(1.0);
252 avg /= wsum;
253 /* check threshold */
254 denom = m*m/gausstable[0] - p0/avg;
255 if (denom <= FTINY) { /* zero exclusive average */
256 if (m >= mlimit[1]-REPS)
257 break;
258 m = mlimit[1];
259 continue;
260 }
261 num = p0/avg - 1.0;
262 if (num < 0.0) num = -num;
263 t = num/denom;
264 if (t <= thresh) {
265 if (m <= mlimit[0]+REPS || (thresh-t)/thresh <= TEPS)
266 break;
267 } else {
268 if (m >= mlimit[1]-REPS || (t-thresh)/thresh <= TEPS)
269 break;
270 }
271 t = m; /* remember current m */
272 /* next guesstimate */
273 m = sqrt(gausstable[0]*(num/thresh + p0/avg));
274 if (m < t) { /* bound it */
275 if (m <= mlimit[0]+FTINY)
276 m = 0.5*(mlimit[0] + t);
277 mlimit[1] = t;
278 } else {
279 if (m >= mlimit[1]-FTINY)
280 m = 0.5*(mlimit[1] + t);
281 mlimit[0] = t;
282 }
283 } while (--ilimit > 0);
284 return(m);
285 }
286
287
288 sumans(px, py, rcent, ccent, m) /* sum input pixel to output */
289 int px, py;
290 int rcent, ccent;
291 double m;
292 {
293 double dy, dx;
294 COLOR pval, ctmp;
295 int ksiz, r, offs;
296 double pc, pr, norm;
297 register int i, c;
298 register COLOR *scan;
299 /*
300 * This normalization method fails at the picture borders because
301 * a different number of input pixels contribute there.
302 */
303 scan = scanin[py%barsize] + (px < 0 ? xres : px >= xres ? -xres : 0);
304 copycolor(pval, scan[px]);
305 pc = x_c*(px+.5);
306 pr = y_r*(py+.5);
307 ksiz = CHECKRAD*m*rad + 1;
308 if (ksiz > orad) ksiz = orad;
309 /* compute normalization */
310 norm = 0.0;
311 i = 0;
312 for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
313 if (r < 0) continue;
314 if (r >= nrows) break;
315 dy = (pr - (r+.5))/(m*rad);
316 for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
317 if (!wrapfilt) {
318 if (c < 0) continue;
319 if (c >= ncols) break;
320 }
321 dx = (pc - (c+.5))/(m*rad);
322 norm += warr[i++] = lookgauss(dx*dx + dy*dy);
323 }
324 }
325 norm = 1.0/norm;
326 if (x_c < 1.0) norm *= x_c;
327 if (y_r < 1.0) norm *= y_r;
328 /* sum pixels */
329 i = 0;
330 for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
331 if (r < 0) continue;
332 if (r >= nrows) break;
333 scan = scoutbar[r%obarsize];
334 for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
335 offs = c < 0 ? ncols : c >= ncols ? -ncols : 0;
336 if (offs && !wrapfilt)
337 continue;
338 copycolor(ctmp, pval);
339 dx = norm*warr[i++];
340 scalecolor(ctmp, dx);
341 addcolor(scan[c+offs], ctmp);
342 }
343 }
344 }
