root/radiance/ray/src/px/pf3.c
Revision: 2.9
Committed: Fri Jul 9 10:27:52 1993 UTC (31 years, 10 months ago) by greg
minor optimization in pickfilt()
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pf3.c - routines for gaussian and box filtering
9 *
10 * 8/13/86
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #define TEPS 0.2 /* threshold proximity goal */
18
19 extern double CHECKRAD; /* radius over which gaussian is summed */
20
21 extern double rad; /* output pixel radius for filtering */
22
23 extern double thresh; /* maximum contribution for subpixel */
24
25 extern int nrows; /* number of rows for output */
26 extern int ncols; /* number of columns for output */
27
28 extern int xres, yres; /* resolution of input */
29
30 extern double x_c, y_r; /* conversion factors */
31
32 extern int xrad; /* x search radius */
33 extern int yrad; /* y search radius */
34 extern int xbrad; /* x box size */
35 extern int ybrad; /* y box size */
36
37 extern int barsize; /* size of input scan bar */
38 extern COLOR **scanin; /* input scan bar */
39 extern COLOR *scanout; /* output scan line */
40 extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */
41 extern float **greybar; /* grey-averaged input values */
42 extern int obarsize; /* size of output scan bar */
43 extern int orad; /* output window radius */
44
45 extern char *progname;
46
47 float *gausstable; /* gauss lookup table */
48
49 float *ringsum; /* sum of ring values */
50 short *ringwt; /* weight (count) of ring values */
51 short *ringndx; /* ring index table */
52 float *warr; /* array of pixel weights */
53
54 double pickfilt();
55
56 #define lookgauss(x) gausstable[(int)(10.*(x)+.5)]
57
58
59 initmask() /* initialize gaussian lookup table */
60 {
61 int gtabsiz;
62 double gaussN;
63 double d;
64 register int x;
65
66 gtabsiz = 150*CHECKRAD;
67 gausstable = (float *)malloc(gtabsiz*sizeof(float));
68 if (gausstable == NULL)
69 goto memerr;
70 d = x_c*y_r*0.25/(rad*rad);
71 gausstable[0] = exp(-d)/sqrt(d);
72 for (x = 1; x < gtabsiz; x++)
73 if ((gausstable[x] = exp(-x*0.1)/sqrt(x*0.1)) > gausstable[0])
74 gausstable[x] = gausstable[0];
75 if (obarsize == 0)
76 return;
77 /* compute integral of filter */
78 gaussN = PI*sqrt(d)*exp(-d); /* plateau */
79 for (d = sqrt(d)+0.05; d <= 1.25*CHECKRAD; d += 0.1)
80 gaussN += 0.1*2.0*PI*exp(-d*d);
81 /* normalize filter */
82 gaussN = x_c*y_r/(rad*rad*gaussN);
83 for (x = 0; x < gtabsiz; x++)
84 gausstable[x] *= gaussN;
85 /* create ring averages table */
86 ringndx = (short *)malloc((2*orad*orad+1)*sizeof(short));
87 if (ringndx == NULL)
88 goto memerr;
89 for (x = 2*orad*orad+1; --x > orad*orad; )
90 ringndx[x] = -1;
91 do
92 ringndx[x] = sqrt((double)x);
93 while (x--);
94 ringsum = (float *)malloc((orad+1)*sizeof(float));
95 ringwt = (short *)malloc((orad+1)*sizeof(short));
96 warr = (float *)malloc(obarsize*obarsize*sizeof(float));
97 if (ringsum == NULL | ringwt == 0 | warr == NULL)
98 goto memerr;
99 return;
100 memerr:
101 fprintf(stderr, "%s: out of memory in initmask\n", progname);
102 quit(1);
103 }
104
105
106 dobox(csum, xcent, ycent, c, r) /* simple box filter */
107 COLOR csum;
108 int xcent, ycent;
109 int c, r;
110 {
111 int wsum;
112 double d;
113 int y;
114 register int x;
115 register COLOR *scan;
116
117 wsum = 0;
118 setcolor(csum, 0.0, 0.0, 0.0);
119 for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
120 if (y < 0) continue;
121 if (y >= yres) break;
122 d = y_r < 1.0 ? y_r*y - r : (double)(y - ycent);
123 if (d < -0.5) continue;
124 if (d >= 0.5) break;
125 scan = scanin[y%barsize];
126 for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
127 if (x < 0) continue;
128 if (x >= xres) break;
129 d = x_c < 1.0 ? x_c*x - c : (double)(x - xcent);
130 if (d < -0.5) continue;
131 if (d >= 0.5) break;
132 wsum++;
133 addcolor(csum, scan[x]);
134 }
135 }
136 if (wsum > 1)
137 scalecolor(csum, 1.0/wsum);
138 }
139
140
141 dogauss(csum, xcent, ycent, c, r) /* gaussian filter */
142 COLOR csum;
143 int xcent, ycent;
144 int c, r;
145 {
146 double dy, dx, weight, wsum;
147 COLOR ctmp;
148 int y;
149 register int x;
150 register COLOR *scan;
151
152 wsum = FTINY;
153 setcolor(csum, 0.0, 0.0, 0.0);
154 for (y = ycent-yrad; y <= ycent+yrad; y++) {
155 if (y < 0) continue;
156 if (y >= yres) break;
157 dy = (y_r*(y+.5) - (r+.5))/rad;
158 scan = scanin[y%barsize];
159 for (x = xcent-xrad; x <= xcent+xrad; x++) {
160 if (x < 0) continue;
161 if (x >= xres) break;
162 dx = (x_c*(x+.5) - (c+.5))/rad;
163 weight = lookgauss(dx*dx + dy*dy);
164 wsum += weight;
165 copycolor(ctmp, scan[x]);
166 scalecolor(ctmp, weight);
167 addcolor(csum, ctmp);
168 }
169 }
170 scalecolor(csum, 1.0/wsum);
171 }
172
173
174 dothresh(xcent, ycent, ccent, rcent) /* gaussian threshold filter */
175 int xcent, ycent;
176 int ccent, rcent;
177 {
178 double d;
179 int r, y;
180 register int c, x;
181 register float *gscan;
182 #define pval gscan
183 /* compute ring sums */
184 bzero((char *)ringsum, (orad+1)*sizeof(float));
185 bzero((char *)ringwt, (orad+1)*sizeof(short));
186 for (r = -orad; r <= orad; r++) {
187 if (rcent+r < 0) continue;
188 if (rcent+r >= nrows) break;
189 gscan = greybar[(rcent+r)%obarsize];
190 for (c = -orad; c <= orad; c++) {
191 if (ccent+c < 0) continue;
192 if (ccent+c >= ncols) break;
193 x = ringndx[c*c + r*r];
194 if (x < 0) continue;
195 ringsum[x] += gscan[ccent+c];
196 ringwt[x]++;
197 }
198 }
199 /* filter each subpixel */
200 for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
201 if (y < 0) continue;
202 if (y >= yres) break;
203 d = y_r < 1.0 ? y_r*y - rcent : (double)(y - ycent);
204 if (d < -0.5) continue;
205 if (d >= 0.5) break;
206 for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
207 if (x < 0) continue;
208 if (x >= xres) break;
209 d = x_c < 1.0 ? x_c*x - ccent : (double)(x - xcent);
210 if (d < -0.5) continue;
211 if (d >= 0.5) break;
212 pval = scanin[y%barsize][x];
213 sumans(x, y, rcent, ccent, pickfilt(bright(pval)));
214 }
215 }
216 #undef pval
217 }
218
219
220 double
221 pickfilt(p0) /* find filter multiplier for p0 */
222 double p0;
223 {
224 double m = 1.0;
225 double t, avg, wsum;
226 int ilimit = 4/TEPS;
227 register int i;
228 /* iterative search for m */
229 do {
230 /* compute grey weighted average */
231 i = 1.25*CHECKRAD*rad*m + .5;
232 if (i > orad) i = orad;
233 avg = wsum = 0.0;
234 while (i--) {
235 t = (i+.5)/(m*rad);
236 t = lookgauss(t*t);
237 avg += t*ringsum[i];
238 wsum += t*ringwt[i];
239 }
240 avg /= wsum;
241 /* check threshold */
242 t = p0 - avg;
243 if (t < 0.0) t = -t;
244 t *= gausstable[0]/(m*m*avg);
245 if (t <= thresh && (m <= 1.0+FTINY ||
246 (thresh-t)/thresh <= TEPS))
247 break;
248 if (t > thresh && (m*CHECKRAD*rad >= orad-FTINY ||
249 (t-thresh)/thresh <= TEPS))
250 break;
251 /* next guesstimate */
252 m *= sqrt(t/thresh);
253 if (m < 1.0) m = 1.0;
254 else if (m*CHECKRAD*rad > orad) m = orad/rad/CHECKRAD;
255 } while (--ilimit > 0);
256 return(m);
257 }
258
259
260 sumans(px, py, rcent, ccent, m) /* sum input pixel to output */
261 int px, py;
262 int rcent, ccent;
263 double m;
264 {
265 double dy, dx;
266 COLOR pval, ctmp;
267 int ksiz, r;
268 double pc, pr, norm;
269 register int i, c;
270 register COLOR *scan;
271
272 copycolor(pval, scanin[py%barsize][px]);
273 pc = x_c*(px+.5);
274 pr = y_r*(py+.5);
275 ksiz = CHECKRAD*m*rad + 1;
276 if (ksiz > orad) ksiz = orad;
277 /* compute normalization */
278 norm = 0.0;
279 i = 0;
280 for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
281 if (r < 0) continue;
282 if (r >= nrows) break;
283 dy = (pr - (r+.5))/(m*rad);
284 for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
285 if (c < 0) continue;
286 if (c >= ncols) break;
287 dx = (pc - (c+.5))/(m*rad);
288 norm += warr[i++] = lookgauss(dx*dx + dy*dy);
289 }
290 }
291 norm = 1.0/norm;
292 if (x_c < 1.0) norm *= x_c;
293 if (y_r < 1.0) norm *= y_r;
294 /* sum pixels */
295 i = 0;
296 for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
297 if (r < 0) continue;
298 if (r >= nrows) break;
299 scan = scoutbar[r%obarsize];
300 for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
301 if (c < 0) continue;
302 if (c >= ncols) break;
303 copycolor(ctmp, pval);
304 dx = norm*warr[i++];
305 scalecolor(ctmp, dx);
306 addcolor(scan[c], ctmp);
307 }
308 }
309 }
