--- ray/src/px/pf3.c 1992/09/21 12:14:12 2.2 +++ ray/src/px/pf3.c 1993/06/25 15:01:20 2.7 @@ -10,50 +10,96 @@ static char SCCSid[] = "$SunId$ LBL"; * 8/13/86 */ -#include +#include "standard.h" #include "color.h" -#define FTINY 1e-7 +#define TEPS 0.25 /* threshold proximity goal */ +extern double CHECKRAD; /* radius over which gaussian is summed */ + extern double rad; /* output pixel radius for filtering */ +extern double thresh; /* maximum contribution for subpixel */ + extern int nrows; /* number of rows for output */ extern int ncols; /* number of columns for output */ -extern int boxfilt; /* do box filtering? */ - extern int xres, yres; /* resolution of input */ extern double x_c, y_r; /* conversion factors */ -extern int xrad; /* x window size */ -extern int yrad; /* y window size */ +extern int xrad; /* x search radius */ +extern int yrad; /* y search radius */ +extern int xbrad; /* x box size */ +extern int ybrad; /* y box size */ extern int barsize; /* size of input scan bar */ extern COLOR **scanin; /* input scan bar */ extern COLOR *scanout; /* output scan line */ +extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */ +extern float **greybar; /* grey-averaged input values */ +extern int obarsize; /* size of output scan bar */ +extern int orad; /* output window radius */ extern char *progname; -float *exptable; /* exponent table */ +float *gausstable; /* gauss lookup table */ -#define lookexp(x) exptable[(int)(-10.*(x)+.5)] +float *ringsum; /* sum of ring values */ +short *ringwt; /* weight (count) of ring values */ +short *ringndx; /* ring index table */ +float *warr; /* array of pixel weights */ +double pickfilt(); +#define lookgauss(x) gausstable[(int)(10.*(x)+.5)] + + initmask() /* initialize gaussian lookup table */ { - extern char *malloc(); - extern double exp(); + int gtabsiz; + double gaussN; + double d; register int x; - exptable = (float *)malloc(100*sizeof(float)); - if (exptable == NULL) { - fprintf(stderr, "%s: out of memory in initmask\n", progname); - quit(1); - } - for (x = 0; x < 100; x++) - exptable[x] = exp(-x*0.1); + gtabsiz = 150*CHECKRAD; + gausstable = (float *)malloc(gtabsiz*sizeof(float)); + if (gausstable == NULL) + goto memerr; + d = x_c*y_r*0.25/(rad*rad); + gausstable[0] = exp(-d)/sqrt(d); + for (x = 1; x < gtabsiz; x++) + if ((gausstable[x] = exp(-x*0.1)/sqrt(x*0.1)) > gausstable[0]) + gausstable[x] = gausstable[0]; + if (obarsize == 0) + return; + /* compute integral of filter */ + gaussN = PI*sqrt(d)*exp(-d); /* plateau */ + for (d = sqrt(d)+0.05; d <= 1.25*CHECKRAD; d += 0.1) + gaussN += 0.1*2.0*PI*exp(-d*d); + /* normalize filter */ + gaussN = x_c*y_r/(rad*rad*gaussN); + for (x = 0; x < gtabsiz; x++) + gausstable[x] *= gaussN; + /* create ring averages table */ + ringndx = (short *)malloc((2*orad*orad+1)*sizeof(short)); + if (ringndx == NULL) + goto memerr; + for (x = 2*orad*orad+1; --x > orad*orad; ) + ringndx[x] = -1; + do + ringndx[x] = sqrt((double)x) + 0.5; + while (x--); + ringsum = (float *)malloc((orad+1)*sizeof(float)); + ringwt = (short *)malloc((orad+1)*sizeof(short)); + warr = (float *)malloc(obarsize*obarsize*sizeof(float)); + if (ringsum == NULL | ringwt == 0 | warr == NULL) + goto memerr; + return; +memerr: + fprintf(stderr, "%s: out of memory in initmask\n", progname); + quit(1); } @@ -62,27 +108,27 @@ COLOR csum; int xcent, ycent; int c, r; { - static int wsum; - static double d; - static int y; + int wsum; + double d; + int y; register int x; register COLOR *scan; - + wsum = 0; setcolor(csum, 0.0, 0.0, 0.0); - for (y = ycent+1-yrad; y <= ycent+yrad; y++) { - if (y < 0 || y >= yres) - continue; - d = y_r < 1.0 ? y_r*y - r : y - ycent; - if (d > 0.5+FTINY || d < -0.5-FTINY) - continue; + for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) { + if (y < 0) continue; + if (y >= yres) break; + d = y_r < 1.0 ? y_r*y - r : (double)(y - ycent); + if (d < -0.5) continue; + if (d >= 0.5) break; scan = scanin[y%barsize]; - for (x = xcent+1-xrad; x <= xcent+xrad; x++) { - if (x < 0 || x >= xres) - continue; - d = x_c < 1.0 ? x_c*x - c : x - xcent; - if (d > 0.5+FTINY || d < -0.5-FTINY) - continue; + for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) { + if (x < 0) continue; + if (x >= xres) break; + d = x_c < 1.0 ? x_c*x - c : (double)(x - xcent); + if (d < -0.5) continue; + if (d >= 0.5) break; wsum++; addcolor(csum, scan[x]); } @@ -97,24 +143,24 @@ COLOR csum; int xcent, ycent; int c, r; { - static double dy, dx, weight, wsum; - static COLOR ctmp; - static int y; + double dy, dx, weight, wsum; + COLOR ctmp; + int y; register int x; register COLOR *scan; wsum = FTINY; setcolor(csum, 0.0, 0.0, 0.0); for (y = ycent-yrad; y <= ycent+yrad; y++) { - if (y < 0 || y >= yres) - continue; + if (y < 0) continue; + if (y >= yres) break; dy = (y_r*(y+.5) - (r+.5))/rad; scan = scanin[y%barsize]; for (x = xcent-xrad; x <= xcent+xrad; x++) { - if (x < 0 || x >= xres) - continue; + if (x < 0) continue; + if (x >= xres) break; dx = (x_c*(x+.5) - (c+.5))/rad; - weight = lookexp(-(dx*dx + dy*dy)); + weight = lookgauss(dx*dx + dy*dy); wsum += weight; copycolor(ctmp, scan[x]); scalecolor(ctmp, weight); @@ -122,4 +168,142 @@ int c, r; } } scalecolor(csum, 1.0/wsum); +} + + +dothresh(xcent, ycent, ccent, rcent) /* gaussian threshold filter */ +int xcent, ycent; +int ccent, rcent; +{ + double d; + int r, y; + register int c, x; + register float *gscan; +#define pval gscan + /* compute ring sums */ + bzero((char *)ringsum, (orad+1)*sizeof(float)); + bzero((char *)ringwt, (orad+1)*sizeof(short)); + for (r = -orad; r <= orad; r++) { + if (rcent+r < 0) continue; + if (rcent+r >= ncols) break; + gscan = greybar[(rcent+r)%obarsize]; + for (c = -orad; c <= orad; c++) { + if (ccent+c < 0) continue; + if (ccent+c >= ncols) break; + x = ringndx[c*c + r*r]; + if (x < 0) continue; + ringsum[x] += gscan[ccent+c]; + ringwt[x]++; + } + } + /* filter each subpixel */ + for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) { + if (y < 0) continue; + if (y >= yres) break; + d = y_r < 1.0 ? y_r*y - rcent : (double)(y - ycent); + if (d < -0.5) continue; + if (d >= 0.5) break; + for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) { + if (x < 0) continue; + if (x >= xres) break; + d = x_c < 1.0 ? x_c*x - ccent : (double)(x - xcent); + if (d < -0.5) continue; + if (d >= 0.5) break; + pval = scanin[y%barsize][x]; + sumans(x, y, rcent, ccent, pickfilt(bright(pval))); + } + } +#undef pval +} + + +double +pickfilt(p0) /* find filter multiplier for p0 */ +double p0; +{ + double m = 1.0; + double t, avg, wsum; + int ilimit = 5/TEPS; + register int i; + /* iterative search for m */ + do { + /* compute grey weighted average */ + i = 1.25*CHECKRAD*rad*m + .5; + if (i > orad) i = orad+1; + avg = wsum = 0.0; + while (i--) { + t = i/(m*rad); + t = lookgauss(t*t); + avg += t*ringsum[i]; + wsum += t*ringwt[i]; + } + avg /= wsum; + /* check threshold */ + t = p0 - avg; + if (t < 0.0) t = -t; + t *= gausstable[0]/(m*m*avg); + if (t <= thresh && (m <= 1.0+FTINY || + (thresh-t)/thresh <= TEPS)) + break; + if (t > thresh && (m*CHECKRAD*rad >= orad-FTINY || + (t-thresh)/thresh <= TEPS)) + break; + /* next guesstimate */ + m *= sqrt(t/thresh); + if (m < 1.0) m = 1.0; + else if (m*CHECKRAD*rad > orad) m = orad/rad/CHECKRAD; + } while (--ilimit > 0); + return(m); +} + + +sumans(px, py, rcent, ccent, m) /* sum input pixel to output */ +int px, py; +int rcent, ccent; +double m; +{ + double dy, dx; + COLOR pval, ctmp; + int ksiz, r; + double pc, pr, norm; + register int i, c; + register COLOR *scan; + + copycolor(pval, scanin[py%barsize][px]); + pc = x_c*(px+.5); + pr = y_r*(py+.5); + ksiz = CHECKRAD*m*rad + 1; + if (ksiz > orad) ksiz = orad; + /* compute normalization */ + norm = 0.0; + i = 0; + for (r = rcent-ksiz; r <= rcent+ksiz; r++) { + if (r < 0) continue; + if (r >= nrows) break; + dy = (pr - (r+.5))/(m*rad); + for (c = ccent-ksiz; c <= ccent+ksiz; c++) { + if (c < 0) continue; + if (c >= ncols) break; + dx = (pc - (c+.5))/(m*rad); + norm += warr[i++] = lookgauss(dx*dx + dy*dy); + } + } + norm = 1.0/norm; + if (x_c < 1.0) norm *= x_c; + if (y_r < 1.0) norm *= y_r; + /* sum pixels */ + i = 0; + for (r = rcent-ksiz; r <= rcent+ksiz; r++) { + if (r < 0) continue; + if (r >= nrows) break; + scan = scoutbar[r%obarsize]; + for (c = ccent-ksiz; c <= ccent+ksiz; c++) { + if (c < 0) continue; + if (c >= ncols) break; + copycolor(ctmp, pval); + dx = norm*warr[i++]; + scalecolor(ctmp, dx); + addcolor(scan[c], ctmp); + } + } }
