--- ray/src/px/pf3.c 1991/06/05 12:15:34 1.2 +++ ray/src/px/pf3.c 2003/02/25 00:26:05 2.15 @@ -1,59 +1,110 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pf3.c,v 2.15 2003/02/25 00:26:05 greg Exp $"; #endif - /* * pf3.c - routines for gaussian and box filtering * * 8/13/86 */ -#include +#include "standard.h" #include "color.h" -#define FTINY 1e-7 +#define RSCA 1.13 /* square-radius multiplier: sqrt(4/PI) */ +#define TEPS 0.2 /* threshold proximity goal */ +#define REPS 0.1 /* radius proximity goal */ +extern double CHECKRAD; /* radius over which gaussian is summed */ + extern double rad; /* output pixel radius for filtering */ +extern double thresh; /* maximum contribution for subpixel */ + extern int nrows; /* number of rows for output */ extern int ncols; /* number of columns for output */ -extern int boxfilt; /* do box filtering? */ - extern int xres, yres; /* resolution of input */ extern double x_c, y_r; /* conversion factors */ -extern int xrad; /* x window size */ -extern int yrad; /* y window size */ +extern int xrad; /* x search radius */ +extern int yrad; /* y search radius */ +extern int xbrad; /* x box size */ +extern int ybrad; /* y box size */ extern int barsize; /* size of input scan bar */ extern COLOR **scanin; /* input scan bar */ extern COLOR *scanout; /* output scan line */ +extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */ +extern float **greybar; /* grey-averaged input values */ +extern int obarsize; /* size of output scan bar */ +extern int orad; /* output window radius */ +extern int wrapfilt; /* wrap filter horizontally? */ + extern char *progname; -float *exptable; /* exponent table */ +float *gausstable; /* gauss lookup table */ -#define lookexp(x) exptable[(int)(-10.*(x)+.5)] +float *ringsum; /* sum of ring values */ +short *ringwt; /* weight (count) of ring values */ +short *ringndx; /* ring index table */ +float *warr; /* array of pixel weights */ +extern double (*ourbright)(); /* brightness computation function */ +double pickfilt(); + +#define lookgauss(x) gausstable[(int)(10.*(x)+.5)] + + initmask() /* initialize gaussian lookup table */ { - extern char *malloc(); - extern double exp(); + int gtabsiz; + double gaussN; + double d; register int x; - exptable = (float *)malloc(100*sizeof(float)); - if (exptable == NULL) { - fprintf(stderr, "%s: out of memory in initmask\n", progname); - quit(1); - } - for (x = 0; x < 100; x++) - exptable[x] = exp(-x*0.1); + gtabsiz = 111*CHECKRAD*CHECKRAD; + gausstable = (float *)malloc(gtabsiz*sizeof(float)); + if (gausstable == NULL) + goto memerr; + d = x_c*y_r*0.25/(rad*rad); + gausstable[0] = exp(-d); + for (x = 1; x < gtabsiz; x++) + if (x*0.1 <= d) + gausstable[x] = gausstable[0]; + else + gausstable[x] = exp(-x*0.1); + if (obarsize == 0) + return; + /* compute integral of filter */ + gaussN = PI*d*exp(-d); /* plateau */ + for (d = sqrt(d)+0.05; d <= RSCA*CHECKRAD; d += 0.1) + gaussN += 0.1*2.0*PI*d*exp(-d*d); + /* normalize filter */ + gaussN = x_c*y_r/(rad*rad*gaussN); + for (x = 0; x < gtabsiz; x++) + gausstable[x] *= gaussN; + /* create ring averages table */ + ringndx = (short *)malloc((2*orad*orad+1)*sizeof(short)); + if (ringndx == NULL) + goto memerr; + for (x = 2*orad*orad+1; --x > orad*orad; ) + ringndx[x] = -1; + do + ringndx[x] = sqrt((double)x); + while (x--); + ringsum = (float *)malloc((orad+1)*sizeof(float)); + ringwt = (short *)malloc((orad+1)*sizeof(short)); + warr = (float *)malloc(obarsize*obarsize*sizeof(float)); + if (ringsum == NULL | ringwt == 0 | warr == NULL) + goto memerr; + return; +memerr: + fprintf(stderr, "%s: out of memory in initmask\n", progname); + quit(1); } @@ -62,33 +113,36 @@ COLOR csum; int xcent, ycent; int c, r; { - static int wsum; - static double d; - static int y; - register int x; - register COLOR *scan; - + int wsum; + double d; + int y; + register int x, offs; + register COLOR *scan; + wsum = 0; setcolor(csum, 0.0, 0.0, 0.0); - for (y = ycent+1-yrad; y <= ycent+yrad; y++) { - if (y < 0 || y >= yres) - continue; - d = y_r < 1.0 ? y_r*y - r : y - ycent; - if (d > 0.5+FTINY || d < -0.5-FTINY) - continue; + for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) { + if (y < 0) continue; + if (y >= yres) break; + d = y_r < 1.0 ? y_r*y - (r+.5) : (double)(y - ycent); + if (d < -0.5) continue; + if (d >= 0.5) break; scan = scanin[y%barsize]; - for (x = xcent+1-xrad; x <= xcent+xrad; x++) { - if (x < 0 || x >= xres) + for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) { + offs = x < 0 ? xres : x >= xres ? -xres : 0; + if (offs && !wrapfilt) continue; - d = x_c < 1.0 ? x_c*x - c : x - xcent; - if (d > 0.5+FTINY || d < -0.5-FTINY) - continue; + d = x_c < 1.0 ? x_c*x - (c+.5) : (double)(x - xcent); + if (d < -0.5) continue; + if (d >= 0.5) break; wsum++; - addcolor(csum, scan[x]); + addcolor(csum, scan[x+offs]); } } - if (wsum > 1) - scalecolor(csum, 1.0/wsum); + if (wsum > 1) { + d = 1.0/wsum; + scalecolor(csum, d); + } } @@ -97,29 +151,198 @@ COLOR csum; int xcent, ycent; int c, r; { - static double dy, dx, weight, wsum; - static COLOR ctmp; - static int y; - register int x; - register COLOR *scan; + double dy, dx, weight, wsum; + COLOR ctmp; + int y; + register int x, offs; + register COLOR *scan; wsum = FTINY; setcolor(csum, 0.0, 0.0, 0.0); for (y = ycent-yrad; y <= ycent+yrad; y++) { - if (y < 0 || y >= yres) - continue; + if (y < 0) continue; + if (y >= yres) break; dy = (y_r*(y+.5) - (r+.5))/rad; scan = scanin[y%barsize]; for (x = xcent-xrad; x <= xcent+xrad; x++) { - if (x < 0 || x >= xres) + offs = x < 0 ? xres : x >= xres ? -xres : 0; + if (offs && !wrapfilt) continue; dx = (x_c*(x+.5) - (c+.5))/rad; - weight = lookexp(-(dx*dx + dy*dy)); + weight = lookgauss(dx*dx + dy*dy); wsum += weight; - copycolor(ctmp, scan[x]); + copycolor(ctmp, scan[x+offs]); scalecolor(ctmp, weight); addcolor(csum, ctmp); } } - scalecolor(csum, 1.0/wsum); + weight = 1.0/wsum; + scalecolor(csum, weight); +} + + +dothresh(xcent, ycent, ccent, rcent) /* gaussian threshold filter */ +int xcent, ycent; +int ccent, rcent; +{ + double d; + int r, y, offs; + register int c, x; + register float *gscan; + /* compute ring sums */ + bzero((char *)ringsum, (orad+1)*sizeof(float)); + bzero((char *)ringwt, (orad+1)*sizeof(short)); + for (r = -orad; r <= orad; r++) { + if (rcent+r < 0) continue; + if (rcent+r >= nrows) break; + gscan = greybar[(rcent+r)%obarsize]; + for (c = -orad; c <= orad; c++) { + offs = ccent+c < 0 ? ncols : + ccent+c >= ncols ? -ncols : 0; + if (offs && !wrapfilt) + continue; + x = ringndx[c*c + r*r]; + if (x < 0) continue; + ringsum[x] += gscan[ccent+c+offs]; + ringwt[x]++; + } + } + /* filter each subpixel */ + for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) { + if (y < 0) continue; + if (y >= yres) break; + d = y_r < 1.0 ? y_r*y - (rcent+.5) : (double)(y - ycent); + if (d < -0.5) continue; + if (d >= 0.5) break; + for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) { + offs = x < 0 ? xres : x >= xres ? -xres : 0; + if (offs && !wrapfilt) + continue; + d = x_c < 1.0 ? x_c*x - (ccent+.5) : (double)(x - xcent); + if (d < -0.5) continue; + if (d >= 0.5) break; + sumans(x, y, rcent, ccent, + pickfilt((*ourbright)(scanin[y%barsize][x+offs]))); + } + } +} + + +double +pickfilt(p0) /* find filter multiplier for p0 */ +double p0; +{ + double m = 1.0; + double t, num, denom, avg, wsum; + double mlimit[2]; + int ilimit = 4.0/TEPS; + register int i; + /* iterative search for m */ + mlimit[0] = 1.0; mlimit[1] = orad/rad/CHECKRAD; + do { + /* compute grey weighted average */ + i = RSCA*CHECKRAD*rad*m + .5; + if (i > orad) i = orad; + avg = wsum = 0.0; + while (i--) { + t = (i+.5)/(m*rad); + t = lookgauss(t*t); + avg += t*ringsum[i]; + wsum += t*ringwt[i]; + } + if (avg < 1e-20) /* zero inclusive average */ + return(1.0); + avg /= wsum; + /* check threshold */ + denom = m*m/gausstable[0] - p0/avg; + if (denom <= FTINY) { /* zero exclusive average */ + if (m >= mlimit[1]-REPS) + break; + m = mlimit[1]; + continue; + } + num = p0/avg - 1.0; + if (num < 0.0) num = -num; + t = num/denom; + if (t <= thresh) { + if (m <= mlimit[0]+REPS || (thresh-t)/thresh <= TEPS) + break; + } else { + if (m >= mlimit[1]-REPS || (t-thresh)/thresh <= TEPS) + break; + } + t = m; /* remember current m */ + /* next guesstimate */ + m = sqrt(gausstable[0]*(num/thresh + p0/avg)); + if (m < t) { /* bound it */ + if (m <= mlimit[0]+FTINY) + m = 0.5*(mlimit[0] + t); + mlimit[1] = t; + } else { + if (m >= mlimit[1]-FTINY) + m = 0.5*(mlimit[1] + t); + mlimit[0] = t; + } + } while (--ilimit > 0); + return(m); +} + + +sumans(px, py, rcent, ccent, m) /* sum input pixel to output */ +int px, py; +int rcent, ccent; +double m; +{ + double dy2, dx; + COLOR pval, ctmp; + int ksiz, r, offs; + double pc, pr, norm; + register int i, c; + register COLOR *scan; + /* + * This normalization method fails at the picture borders because + * a different number of input pixels contribute there. + */ + scan = scanin[py%barsize] + (px < 0 ? xres : px >= xres ? -xres : 0); + copycolor(pval, scan[px]); + pc = x_c*(px+.5); + pr = y_r*(py+.5); + ksiz = CHECKRAD*m*rad + 1; + if (ksiz > orad) ksiz = orad; + /* compute normalization */ + norm = 0.0; + i = 0; + for (r = rcent-ksiz; r <= rcent+ksiz; r++) { + if (r < 0) continue; + if (r >= nrows) break; + dy2 = (pr - (r+.5))/(m*rad); + dy2 *= dy2; + for (c = ccent-ksiz; c <= ccent+ksiz; c++) { + if (!wrapfilt) { + if (c < 0) continue; + if (c >= ncols) break; + } + dx = (pc - (c+.5))/(m*rad); + norm += warr[i++] = lookgauss(dx*dx + dy2); + } + } + norm = 1.0/norm; + if (x_c < 1.0) norm *= x_c; + if (y_r < 1.0) norm *= y_r; + /* sum pixels */ + i = 0; + for (r = rcent-ksiz; r <= rcent+ksiz; r++) { + if (r < 0) continue; + if (r >= nrows) break; + scan = scoutbar[r%obarsize]; + for (c = ccent-ksiz; c <= ccent+ksiz; c++) { + offs = c < 0 ? ncols : c >= ncols ? -ncols : 0; + if (offs && !wrapfilt) + continue; + copycolor(ctmp, pval); + dx = norm*warr[i++]; + scalecolor(ctmp, dx); + addcolor(scan[c+offs], ctmp); + } + } }
