root/radiance/ray/src/px/pf3.c
Revision: 2.18
Committed: Sun Mar 28 20:33:14 2004 UTC (20 years, 2 months ago) by schorsch
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
Changes since 2.17: +42 -54 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.18 static const char RCSid[] = "$Id: pf3.c,v 2.17 2003/07/27 22:12:03 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * pf3.c - routines for gaussian and box filtering
6     *
7     * 8/13/86
8     */
9
10 greg 2.7 #include "standard.h"
11 greg 1.1
12 schorsch 2.16 #include <string.h>
13
14 greg 1.1 #include "color.h"
15 schorsch 2.18 #include "pfilt.h"
16 greg 1.1
17 greg 2.14 #define RSCA 1.13 /* square-radius multiplier: sqrt(4/PI) */
18 greg 2.9 #define TEPS 0.2 /* threshold proximity goal */
19 greg 2.10 #define REPS 0.1 /* radius proximity goal */
20 greg 1.1
21 greg 2.5 float *gausstable; /* gauss lookup table */
22 greg 1.1
23 greg 2.7 float *ringsum; /* sum of ring values */
24     short *ringwt; /* weight (count) of ring values */
25     short *ringndx; /* ring index table */
26     float *warr; /* array of pixel weights */
27
28 schorsch 2.18 #define lookgauss(x) gausstable[(int)(10.*(x)+.5)]
29 greg 2.7
30 schorsch 2.18 static double pickfilt(double p0);
31     static void sumans(int px, int py, int rcent, int ccent, double m);
32 greg 1.1
33
34 schorsch 2.18 extern void
35     initmask(void) /* initialize gaussian lookup table */
36 greg 1.1 {
37 greg 2.7 int gtabsiz;
38     double gaussN;
39 greg 2.5 double d;
40 greg 1.1 register int x;
41
42 greg 2.15 gtabsiz = 111*CHECKRAD*CHECKRAD;
43 greg 2.7 gausstable = (float *)malloc(gtabsiz*sizeof(float));
44     if (gausstable == NULL)
45     goto memerr;
46     d = x_c*y_r*0.25/(rad*rad);
47 greg 2.14 gausstable[0] = exp(-d);
48 greg 2.7 for (x = 1; x < gtabsiz; x++)
49 greg 2.14 if (x*0.1 <= d)
50 greg 2.5 gausstable[x] = gausstable[0];
51 greg 2.14 else
52     gausstable[x] = exp(-x*0.1);
53 greg 2.7 if (obarsize == 0)
54     return;
55     /* compute integral of filter */
56 greg 2.14 gaussN = PI*d*exp(-d); /* plateau */
57     for (d = sqrt(d)+0.05; d <= RSCA*CHECKRAD; d += 0.1)
58     gaussN += 0.1*2.0*PI*d*exp(-d*d);
59 greg 2.7 /* normalize filter */
60     gaussN = x_c*y_r/(rad*rad*gaussN);
61     for (x = 0; x < gtabsiz; x++)
62     gausstable[x] *= gaussN;
63     /* create ring averages table */
64     ringndx = (short *)malloc((2*orad*orad+1)*sizeof(short));
65     if (ringndx == NULL)
66     goto memerr;
67     for (x = 2*orad*orad+1; --x > orad*orad; )
68     ringndx[x] = -1;
69     do
70 greg 2.8 ringndx[x] = sqrt((double)x);
71 greg 2.7 while (x--);
72     ringsum = (float *)malloc((orad+1)*sizeof(float));
73     ringwt = (short *)malloc((orad+1)*sizeof(short));
74     warr = (float *)malloc(obarsize*obarsize*sizeof(float));
75 schorsch 2.17 if ((ringsum == NULL) | (ringwt == 0) | (warr == NULL))
76 greg 2.7 goto memerr;
77     return;
78     memerr:
79     fprintf(stderr, "%s: out of memory in initmask\n", progname);
80     quit(1);
81 greg 1.1 }
82
83
84 schorsch 2.18 extern void
85     dobox( /* simple box filter */
86     COLOR csum,
87     int xcent,
88     int ycent,
89     int c,
90     int r
91     )
92 greg 1.1 {
93 greg 2.6 int wsum;
94     double d;
95     int y;
96 greg 2.12 register int x, offs;
97 greg 2.2 register COLOR *scan;
98 greg 2.7
99 greg 1.1 wsum = 0;
100     setcolor(csum, 0.0, 0.0, 0.0);
101 greg 2.7 for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
102 greg 2.4 if (y < 0) continue;
103     if (y >= yres) break;
104 greg 2.13 d = y_r < 1.0 ? y_r*y - (r+.5) : (double)(y - ycent);
105 greg 2.7 if (d < -0.5) continue;
106     if (d >= 0.5) break;
107 greg 1.1 scan = scanin[y%barsize];
108 greg 2.7 for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
109 greg 2.12 offs = x < 0 ? xres : x >= xres ? -xres : 0;
110     if (offs && !wrapfilt)
111     continue;
112 greg 2.13 d = x_c < 1.0 ? x_c*x - (c+.5) : (double)(x - xcent);
113 greg 2.7 if (d < -0.5) continue;
114     if (d >= 0.5) break;
115 greg 1.1 wsum++;
116 greg 2.12 addcolor(csum, scan[x+offs]);
117 greg 1.1 }
118     }
119 greg 2.14 if (wsum > 1) {
120     d = 1.0/wsum;
121     scalecolor(csum, d);
122     }
123 greg 1.1 }
124
125
126 schorsch 2.18 extern void
127     dogauss( /* gaussian filter */
128     COLOR csum,
129     int xcent,
130     int ycent,
131     int c,
132     int r
133     )
134 greg 1.1 {
135 greg 2.6 double dy, dx, weight, wsum;
136     COLOR ctmp;
137     int y;
138 greg 2.12 register int x, offs;
139 greg 2.2 register COLOR *scan;
140 greg 1.1
141     wsum = FTINY;
142     setcolor(csum, 0.0, 0.0, 0.0);
143 greg 1.2 for (y = ycent-yrad; y <= ycent+yrad; y++) {
144 greg 2.4 if (y < 0) continue;
145     if (y >= yres) break;
146 greg 1.2 dy = (y_r*(y+.5) - (r+.5))/rad;
147 greg 1.1 scan = scanin[y%barsize];
148 greg 1.2 for (x = xcent-xrad; x <= xcent+xrad; x++) {
149 greg 2.12 offs = x < 0 ? xres : x >= xres ? -xres : 0;
150     if (offs && !wrapfilt)
151     continue;
152 greg 1.2 dx = (x_c*(x+.5) - (c+.5))/rad;
153 greg 2.6 weight = lookgauss(dx*dx + dy*dy);
154 greg 1.1 wsum += weight;
155 greg 2.12 copycolor(ctmp, scan[x+offs]);
156 greg 1.1 scalecolor(ctmp, weight);
157     addcolor(csum, ctmp);
158     }
159     }
160 greg 2.14 weight = 1.0/wsum;
161     scalecolor(csum, weight);
162 greg 2.7 }
163
164
165 schorsch 2.18 extern void
166     dothresh( /* gaussian threshold filter */
167     int xcent,
168     int ycent,
169     int ccent,
170     int rcent
171     )
172 greg 2.7 {
173     double d;
174 greg 2.12 int r, y, offs;
175 greg 2.7 register int c, x;
176     register float *gscan;
177     /* compute ring sums */
178 schorsch 2.16 memset((char *)ringsum, '\0', (orad+1)*sizeof(float));
179     memset((char *)ringwt, '\0', (orad+1)*sizeof(short));
180 greg 2.7 for (r = -orad; r <= orad; r++) {
181     if (rcent+r < 0) continue;
182 greg 2.8 if (rcent+r >= nrows) break;
183 greg 2.7 gscan = greybar[(rcent+r)%obarsize];
184     for (c = -orad; c <= orad; c++) {
185 greg 2.12 offs = ccent+c < 0 ? ncols :
186     ccent+c >= ncols ? -ncols : 0;
187     if (offs && !wrapfilt)
188     continue;
189 greg 2.7 x = ringndx[c*c + r*r];
190     if (x < 0) continue;
191 greg 2.12 ringsum[x] += gscan[ccent+c+offs];
192 greg 2.7 ringwt[x]++;
193     }
194     }
195     /* filter each subpixel */
196     for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
197     if (y < 0) continue;
198     if (y >= yres) break;
199 greg 2.13 d = y_r < 1.0 ? y_r*y - (rcent+.5) : (double)(y - ycent);
200 greg 2.7 if (d < -0.5) continue;
201     if (d >= 0.5) break;
202     for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
203 greg 2.12 offs = x < 0 ? xres : x >= xres ? -xres : 0;
204     if (offs && !wrapfilt)
205     continue;
206 greg 2.13 d = x_c < 1.0 ? x_c*x - (ccent+.5) : (double)(x - xcent);
207 greg 2.7 if (d < -0.5) continue;
208     if (d >= 0.5) break;
209 greg 2.12 sumans(x, y, rcent, ccent,
210     pickfilt((*ourbright)(scanin[y%barsize][x+offs])));
211 greg 2.7 }
212     }
213     }
214
215
216 schorsch 2.18 static double
217     pickfilt( /* find filter multiplier for p0 */
218     double p0
219     )
220 greg 2.7 {
221     double m = 1.0;
222 greg 2.10 double t, num, denom, avg, wsum;
223     double mlimit[2];
224 greg 2.14 int ilimit = 4.0/TEPS;
225 greg 2.7 register int i;
226     /* iterative search for m */
227 greg 2.11 mlimit[0] = 1.0; mlimit[1] = orad/rad/CHECKRAD;
228 greg 2.7 do {
229     /* compute grey weighted average */
230 greg 2.14 i = RSCA*CHECKRAD*rad*m + .5;
231 greg 2.8 if (i > orad) i = orad;
232 greg 2.7 avg = wsum = 0.0;
233     while (i--) {
234 greg 2.8 t = (i+.5)/(m*rad);
235 greg 2.7 t = lookgauss(t*t);
236     avg += t*ringsum[i];
237     wsum += t*ringwt[i];
238     }
239 greg 2.10 if (avg < 1e-20) /* zero inclusive average */
240     return(1.0);
241 greg 2.7 avg /= wsum;
242     /* check threshold */
243 greg 2.10 denom = m*m/gausstable[0] - p0/avg;
244 greg 2.11 if (denom <= FTINY) { /* zero exclusive average */
245     if (m >= mlimit[1]-REPS)
246     break;
247     m = mlimit[1];
248     continue;
249     }
250 greg 2.10 num = p0/avg - 1.0;
251     if (num < 0.0) num = -num;
252     t = num/denom;
253     if (t <= thresh) {
254     if (m <= mlimit[0]+REPS || (thresh-t)/thresh <= TEPS)
255     break;
256     } else {
257     if (m >= mlimit[1]-REPS || (t-thresh)/thresh <= TEPS)
258     break;
259     }
260     t = m; /* remember current m */
261 greg 2.7 /* next guesstimate */
262 greg 2.10 m = sqrt(gausstable[0]*(num/thresh + p0/avg));
263     if (m < t) { /* bound it */
264     if (m <= mlimit[0]+FTINY)
265     m = 0.5*(mlimit[0] + t);
266     mlimit[1] = t;
267     } else {
268     if (m >= mlimit[1]-FTINY)
269     m = 0.5*(mlimit[1] + t);
270     mlimit[0] = t;
271     }
272 greg 2.7 } while (--ilimit > 0);
273     return(m);
274     }
275
276
277 schorsch 2.18 static void
278     sumans( /* sum input pixel to output */
279     int px,
280     int py,
281     int rcent,
282     int ccent,
283     double m
284     )
285 greg 2.7 {
286 greg 2.14 double dy2, dx;
287 greg 2.7 COLOR pval, ctmp;
288 greg 2.12 int ksiz, r, offs;
289 greg 2.7 double pc, pr, norm;
290     register int i, c;
291     register COLOR *scan;
292 greg 2.12 /*
293     * This normalization method fails at the picture borders because
294     * a different number of input pixels contribute there.
295     */
296     scan = scanin[py%barsize] + (px < 0 ? xres : px >= xres ? -xres : 0);
297     copycolor(pval, scan[px]);
298 greg 2.7 pc = x_c*(px+.5);
299     pr = y_r*(py+.5);
300     ksiz = CHECKRAD*m*rad + 1;
301     if (ksiz > orad) ksiz = orad;
302     /* compute normalization */
303     norm = 0.0;
304     i = 0;
305     for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
306     if (r < 0) continue;
307     if (r >= nrows) break;
308 greg 2.14 dy2 = (pr - (r+.5))/(m*rad);
309     dy2 *= dy2;
310 greg 2.7 for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
311 greg 2.12 if (!wrapfilt) {
312     if (c < 0) continue;
313     if (c >= ncols) break;
314     }
315 greg 2.7 dx = (pc - (c+.5))/(m*rad);
316 greg 2.14 norm += warr[i++] = lookgauss(dx*dx + dy2);
317 greg 2.7 }
318     }
319     norm = 1.0/norm;
320     if (x_c < 1.0) norm *= x_c;
321     if (y_r < 1.0) norm *= y_r;
322     /* sum pixels */
323     i = 0;
324     for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
325     if (r < 0) continue;
326     if (r >= nrows) break;
327     scan = scoutbar[r%obarsize];
328     for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
329 greg 2.12 offs = c < 0 ? ncols : c >= ncols ? -ncols : 0;
330     if (offs && !wrapfilt)
331     continue;
332 greg 2.7 copycolor(ctmp, pval);
333     dx = norm*warr[i++];
334     scalecolor(ctmp, dx);
335 greg 2.12 addcolor(scan[c+offs], ctmp);
336 greg 2.7 }
337     }
338 greg 1.1 }
