root/radiance/ray/src/px/pf3.c
Revision: 2.15
Committed: Tue Feb 25 00:26:05 2003 UTC (21 years, 3 months ago) by greg
Fixed pre-release upsampling bug in new filtering kernel
5 * pf3.c - routines for gaussian and box filtering
6 *
7 * 8/13/86
8 */
9
10 #include "standard.h"
11
12 #include "color.h"
13
14 #define RSCA 1.13 /* square-radius multiplier: sqrt(4/PI) */
15 #define TEPS 0.2 /* threshold proximity goal */
16 #define REPS 0.1 /* radius proximity goal */
17
18 extern double CHECKRAD; /* radius over which gaussian is summed */
19
20 extern double rad; /* output pixel radius for filtering */
21
22 extern double thresh; /* maximum contribution for subpixel */
23
24 extern int nrows; /* number of rows for output */
25 extern int ncols; /* number of columns for output */
26
27 extern int xres, yres; /* resolution of input */
28
29 extern double x_c, y_r; /* conversion factors */
30
31 extern int xrad; /* x search radius */
32 extern int yrad; /* y search radius */
33 extern int xbrad; /* x box size */
34 extern int ybrad; /* y box size */
35
36 extern int barsize; /* size of input scan bar */
37 extern COLOR **scanin; /* input scan bar */
38 extern COLOR *scanout; /* output scan line */
39 extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */
40 extern float **greybar; /* grey-averaged input values */
41 extern int obarsize; /* size of output scan bar */
42 extern int orad; /* output window radius */
43
44 extern int wrapfilt; /* wrap filter horizontally? */
45
46 extern char *progname;
47
48 float *gausstable; /* gauss lookup table */
49
50 float *ringsum; /* sum of ring values */
51 short *ringwt; /* weight (count) of ring values */
52 short *ringndx; /* ring index table */
53 float *warr; /* array of pixel weights */
54
55 extern double (*ourbright)(); /* brightness computation function */
56
57 double pickfilt();
58
59 #define lookgauss(x) gausstable[(int)(10.*(x)+.5)]
60
61
62 initmask() /* initialize gaussian lookup table */
63 {
64 int gtabsiz;
65 double gaussN;
66 double d;
67 register int x;
68
69 gtabsiz = 111*CHECKRAD*CHECKRAD;
70 gausstable = (float *)malloc(gtabsiz*sizeof(float));
71 if (gausstable == NULL)
72 goto memerr;
73 d = x_c*y_r*0.25/(rad*rad);
74 gausstable[0] = exp(-d);
75 for (x = 1; x < gtabsiz; x++)
76 if (x*0.1 <= d)
77 gausstable[x] = gausstable[0];
78 else
79 gausstable[x] = exp(-x*0.1);
80 if (obarsize == 0)
81 return;
82 /* compute integral of filter */
83 gaussN = PI*d*exp(-d); /* plateau */
84 for (d = sqrt(d)+0.05; d <= RSCA*CHECKRAD; d += 0.1)
85 gaussN += 0.1*2.0*PI*d*exp(-d*d);
86 /* normalize filter */
87 gaussN = x_c*y_r/(rad*rad*gaussN);
88 for (x = 0; x < gtabsiz; x++)
89 gausstable[x] *= gaussN;
90 /* create ring averages table */
91 ringndx = (short *)malloc((2*orad*orad+1)*sizeof(short));
92 if (ringndx == NULL)
93 goto memerr;
94 for (x = 2*orad*orad+1; --x > orad*orad; )
95 ringndx[x] = -1;
96 do
97 ringndx[x] = sqrt((double)x);
98 while (x--);
99 ringsum = (float *)malloc((orad+1)*sizeof(float));
100 ringwt = (short *)malloc((orad+1)*sizeof(short));
101 warr = (float *)malloc(obarsize*obarsize*sizeof(float));
102 if (ringsum == NULL | ringwt == 0 | warr == NULL)
103 goto memerr;
104 return;
105 memerr:
106 fprintf(stderr, "%s: out of memory in initmask\n", progname);
107 quit(1);
108 }
109
110
111 dobox(csum, xcent, ycent, c, r) /* simple box filter */
112 COLOR csum;
113 int xcent, ycent;
114 int c, r;
115 {
116 int wsum;
117 double d;
118 int y;
119 register int x, offs;
120 register COLOR *scan;
121
122 wsum = 0;
123 setcolor(csum, 0.0, 0.0, 0.0);
124 for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
125 if (y < 0) continue;
126 if (y >= yres) break;
127 d = y_r < 1.0 ? y_r*y - (r+.5) : (double)(y - ycent);
128 if (d < -0.5) continue;
129 if (d >= 0.5) break;
130 scan = scanin[y%barsize];
131 for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
132 offs = x < 0 ? xres : x >= xres ? -xres : 0;
133 if (offs && !wrapfilt)
134 continue;
135 d = x_c < 1.0 ? x_c*x - (c+.5) : (double)(x - xcent);
136 if (d < -0.5) continue;
137 if (d >= 0.5) break;
138 wsum++;
139 addcolor(csum, scan[x+offs]);
140 }
141 }
142 if (wsum > 1) {
143 d = 1.0/wsum;
144 scalecolor(csum, d);
145 }
146 }
147
148
149 dogauss(csum, xcent, ycent, c, r) /* gaussian filter */
150 COLOR csum;
151 int xcent, ycent;
152 int c, r;
153 {
154 double dy, dx, weight, wsum;
155 COLOR ctmp;
156 int y;
157 register int x, offs;
158 register COLOR *scan;
159
160 wsum = FTINY;
161 setcolor(csum, 0.0, 0.0, 0.0);
162 for (y = ycent-yrad; y <= ycent+yrad; y++) {
163 if (y < 0) continue;
164 if (y >= yres) break;
165 dy = (y_r*(y+.5) - (r+.5))/rad;
166 scan = scanin[y%barsize];
167 for (x = xcent-xrad; x <= xcent+xrad; x++) {
168 offs = x < 0 ? xres : x >= xres ? -xres : 0;
169 if (offs && !wrapfilt)
170 continue;
171 dx = (x_c*(x+.5) - (c+.5))/rad;
172 weight = lookgauss(dx*dx + dy*dy);
173 wsum += weight;
174 copycolor(ctmp, scan[x+offs]);
175 scalecolor(ctmp, weight);
176 addcolor(csum, ctmp);
177 }
178 }
179 weight = 1.0/wsum;
180 scalecolor(csum, weight);
181 }
182
183
184 dothresh(xcent, ycent, ccent, rcent) /* gaussian threshold filter */
185 int xcent, ycent;
186 int ccent, rcent;
187 {
188 double d;
189 int r, y, offs;
190 register int c, x;
191 register float *gscan;
192 /* compute ring sums */
193 bzero((char *)ringsum, (orad+1)*sizeof(float));
194 bzero((char *)ringwt, (orad+1)*sizeof(short));
195 for (r = -orad; r <= orad; r++) {
196 if (rcent+r < 0) continue;
197 if (rcent+r >= nrows) break;
198 gscan = greybar[(rcent+r)%obarsize];
199 for (c = -orad; c <= orad; c++) {
200 offs = ccent+c < 0 ? ncols :
201 ccent+c >= ncols ? -ncols : 0;
202 if (offs && !wrapfilt)
203 continue;
204 x = ringndx[c*c + r*r];
205 if (x < 0) continue;
206 ringsum[x] += gscan[ccent+c+offs];
207 ringwt[x]++;
208 }
209 }
210 /* filter each subpixel */
211 for (y = ycent+1-ybrad; y <= ycent+ybrad; y++) {
212 if (y < 0) continue;
213 if (y >= yres) break;
214 d = y_r < 1.0 ? y_r*y - (rcent+.5) : (double)(y - ycent);
215 if (d < -0.5) continue;
216 if (d >= 0.5) break;
217 for (x = xcent+1-xbrad; x <= xcent+xbrad; x++) {
218 offs = x < 0 ? xres : x >= xres ? -xres : 0;
219 if (offs && !wrapfilt)
220 continue;
221 d = x_c < 1.0 ? x_c*x - (ccent+.5) : (double)(x - xcent);
222 if (d < -0.5) continue;
223 if (d >= 0.5) break;
224 sumans(x, y, rcent, ccent,
225 pickfilt((*ourbright)(scanin[y%barsize][x+offs])));
226 }
227 }
228 }
229
230
231 double
232 pickfilt(p0) /* find filter multiplier for p0 */
233 double p0;
234 {
235 double m = 1.0;
236 double t, num, denom, avg, wsum;
237 double mlimit[2];
238 int ilimit = 4.0/TEPS;
239 register int i;
240 /* iterative search for m */
241 mlimit[0] = 1.0; mlimit[1] = orad/rad/CHECKRAD;
242 do {
243 /* compute grey weighted average */
244 i = RSCA*CHECKRAD*rad*m + .5;
245 if (i > orad) i = orad;
246 avg = wsum = 0.0;
247 while (i--) {
248 t = (i+.5)/(m*rad);
249 t = lookgauss(t*t);
250 avg += t*ringsum[i];
251 wsum += t*ringwt[i];
252 }
253 if (avg < 1e-20) /* zero inclusive average */
254 return(1.0);
255 avg /= wsum;
256 /* check threshold */
257 denom = m*m/gausstable[0] - p0/avg;
258 if (denom <= FTINY) { /* zero exclusive average */
259 if (m >= mlimit[1]-REPS)
260 break;
261 m = mlimit[1];
262 continue;
263 }
264 num = p0/avg - 1.0;
265 if (num < 0.0) num = -num;
266 t = num/denom;
267 if (t <= thresh) {
268 if (m <= mlimit[0]+REPS || (thresh-t)/thresh <= TEPS)
269 break;
270 } else {
271 if (m >= mlimit[1]-REPS || (t-thresh)/thresh <= TEPS)
272 break;
273 }
274 t = m; /* remember current m */
275 /* next guesstimate */
276 m = sqrt(gausstable[0]*(num/thresh + p0/avg));
277 if (m < t) { /* bound it */
278 if (m <= mlimit[0]+FTINY)
279 m = 0.5*(mlimit[0] + t);
280 mlimit[1] = t;
281 } else {
282 if (m >= mlimit[1]-FTINY)
283 m = 0.5*(mlimit[1] + t);
284 mlimit[0] = t;
285 }
286 } while (--ilimit > 0);
287 return(m);
288 }
289
290
291 sumans(px, py, rcent, ccent, m) /* sum input pixel to output */
292 int px, py;
293 int rcent, ccent;
294 double m;
295 {
296 double dy2, dx;
297 COLOR pval, ctmp;
298 int ksiz, r, offs;
299 double pc, pr, norm;
300 register int i, c;
301 register COLOR *scan;
302 /*
303 * This normalization method fails at the picture borders because
304 * a different number of input pixels contribute there.
305 */
306 scan = scanin[py%barsize] + (px < 0 ? xres : px >= xres ? -xres : 0);
307 copycolor(pval, scan[px]);
308 pc = x_c*(px+.5);
309 pr = y_r*(py+.5);
310 ksiz = CHECKRAD*m*rad + 1;
311 if (ksiz > orad) ksiz = orad;
312 /* compute normalization */
313 norm = 0.0;
314 i = 0;
315 for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
316 if (r < 0) continue;
317 if (r >= nrows) break;
318 dy2 = (pr - (r+.5))/(m*rad);
319 dy2 *= dy2;
320 for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
321 if (!wrapfilt) {
322 if (c < 0) continue;
323 if (c >= ncols) break;
324 }
325 dx = (pc - (c+.5))/(m*rad);
326 norm += warr[i++] = lookgauss(dx*dx + dy2);
327 }
328 }
329 norm = 1.0/norm;
330 if (x_c < 1.0) norm *= x_c;
331 if (y_r < 1.0) norm *= y_r;
332 /* sum pixels */
333 i = 0;
334 for (r = rcent-ksiz; r <= rcent+ksiz; r++) {
335 if (r < 0) continue;
336 if (r >= nrows) break;
337 scan = scoutbar[r%obarsize];
338 for (c = ccent-ksiz; c <= ccent+ksiz; c++) {
339 offs = c < 0 ? ncols : c >= ncols ? -ncols : 0;
340 if (offs && !wrapfilt)
341 continue;
342 copycolor(ctmp, pval);
343 dx = norm*warr[i++];
344 scalecolor(ctmp, dx);
345 addcolor(scan[c+offs], ctmp);
346 }
347 }
348 }
