--- ray/src/px/pf3.c 2003/07/27 22:12:03 2.17 +++ ray/src/px/pf3.c 2004/03/28 20:33:14 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pf3.c,v 2.17 2003/07/27 22:12:03 schorsch Exp $"; +static const char RCSid[] = "$Id: pf3.c,v 2.18 2004/03/28 20:33:14 schorsch Exp $"; #endif /* * pf3.c - routines for gaussian and box filtering @@ -12,41 +12,12 @@ static const char RCSid[] = "$Id: pf3.c,v 2.17 2003/07 #include #include "color.h" +#include "pfilt.h" #define RSCA 1.13 /* square-radius multiplier: sqrt(4/PI) */ #define TEPS 0.2 /* threshold proximity goal */ #define REPS 0.1 /* radius proximity goal */ -extern double CHECKRAD; /* radius over which gaussian is summed */ - -extern double rad; /* output pixel radius for filtering */ - -extern double thresh; /* maximum contribution for subpixel */ - -extern int nrows; /* number of rows for output */ -extern int ncols; /* number of columns for output */ - -extern int xres, yres; /* resolution of input */ - -extern double x_c, y_r; /* conversion factors */ - -extern int xrad; /* x search radius */ -extern int yrad; /* y search radius */ -extern int xbrad; /* x box size */ -extern int ybrad; /* y box size */ - -extern int barsize; /* size of input scan bar */ -extern COLOR **scanin; /* input scan bar */ -extern COLOR *scanout; /* output scan line */ -extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */ -extern float **greybar; /* grey-averaged input values */ -extern int obarsize; /* size of output scan bar */ -extern int orad; /* output window radius */ - -extern int wrapfilt; /* wrap filter horizontally? */ - -extern char *progname; - float *gausstable; /* gauss lookup table */ float *ringsum; /* sum of ring values */ @@ -54,14 +25,14 @@ short *ringwt; /* weight (count) of ring values */ short *ringndx; /* ring index table */ float *warr; /* array of pixel weights */ -extern double (*ourbright)(); /* brightness computation function */ - -double pickfilt(); - #define lookgauss(x) gausstable[(int)(10.*(x)+.5)] +static double pickfilt(double p0); +static void sumans(int px, int py, int rcent, int ccent, double m); -initmask() /* initialize gaussian lookup table */ + +extern void +initmask(void) /* initialize gaussian lookup table */ { int gtabsiz; double gaussN; @@ -110,10 +81,14 @@ memerr: } -dobox(csum, xcent, ycent, c, r) /* simple box filter */ -COLOR csum; -int xcent, ycent; -int c, r; +extern void +dobox( /* simple box filter */ + COLOR csum, + int xcent, + int ycent, + int c, + int r +) { int wsum; double d; @@ -148,10 +123,14 @@ int c, r; } -dogauss(csum, xcent, ycent, c, r) /* gaussian filter */ -COLOR csum; -int xcent, ycent; -int c, r; +extern void +dogauss( /* gaussian filter */ + COLOR csum, + int xcent, + int ycent, + int c, + int r +) { double dy, dx, weight, wsum; COLOR ctmp; @@ -183,9 +162,13 @@ int c, r; } -dothresh(xcent, ycent, ccent, rcent) /* gaussian threshold filter */ -int xcent, ycent; -int ccent, rcent; +extern void +dothresh( /* gaussian threshold filter */ + int xcent, + int ycent, + int ccent, + int rcent +) { double d; int r, y, offs; @@ -230,9 +213,10 @@ int ccent, rcent; } -double -pickfilt(p0) /* find filter multiplier for p0 */ -double p0; +static double +pickfilt( /* find filter multiplier for p0 */ + double p0 +) { double m = 1.0; double t, num, denom, avg, wsum; @@ -290,10 +274,14 @@ double p0; } -sumans(px, py, rcent, ccent, m) /* sum input pixel to output */ -int px, py; -int rcent, ccent; -double m; +static void +sumans( /* sum input pixel to output */ + int px, + int py, + int rcent, + int ccent, + double m +) { double dy2, dx; COLOR pval, ctmp;
