root/radiance/ray/src/px/pf2.c
Fri Dec 8 17:56:26 2023 UTC (5 months, 2 weeks ago) by greg
Changes since 2.10: +13 -13 lines
feat(pfilt): Added support for hyperspectral image filtering
Thu Dec 7 21:15:54 2023 UTC (5 months, 3 weeks ago) by greg
Changes since 2.9: +2 -11 lines
refactor: Cleaned up and simplified #include's
Thu Apr 21 03:11:55 2022 UTC (2 years, 1 month ago) by greg
perf: Replaced random()%modulus with irandom(modulus) where appropriate
Thu Jul 26 23:50:40 2018 UTC (5 years, 10 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 2.7: +13 -13 lines
Fixed issue with pfilt -m option and non-integer size divisors
Changes since 2.6: +28 -36 lines
Changes since 2.5: +3 -5 lines
Tue Apr 2 10:32:29 1996 UTC (28 years, 2 months ago) by greg
changed bright() to (*ourbright)() for CIE scanlines
Wed Nov 9 15:04:52 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.3: +15 -10 lines
made pfilt more intelligent about averaging out zero pixels
Fri Oct 2 16:23:20 1992 UTC (31 years, 8 months ago) by greg
Mon Sep 21 12:14:08 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.1: +15 -15 lines
Changes for PC port
Tue Nov 12 16:05:24 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1
Thu Feb 2 10:49:24 1989 UTC (35 years, 4 months ago) by greg
