root/radiance/ray/src/px/pextrem.c
Fri Sep 20 17:39:12 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.15: +50 -33 lines
Diff to previous 2.15 , to selected 2.14
feat(pextrem): Added handling of hyperspectral pictures
Fri Feb 4 20:11:49 2022 UTC (3 years, 4 months ago) by greg
Changes since 2.14: +11 -10 lines
Diff to previous 2.14
feat(pvalue,pextrem): Added -O option to report watts/sr/meter^2 always
Fri Jul 19 17:37:56 2019 UTC (5 years, 10 months ago) by greg
Changes since 2.13: +2 -3 lines
Diff to previous 2.13
Thu Aug 2 18:33:44 2018 UTC (6 years, 10 months ago) by greg
Thu May 4 00:42:40 2017 UTC (8 years, 1 month ago) by greg
Reduced number of reported significant figures to something more sensible
Thu Jun 2 18:13:47 2005 UTC (20 years ago) by greg
CVS Tags: rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Fixed maximum reporting for images that are everywhere zero
Sun Mar 28 20:33:14 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.9: +6 -4 lines
Fri Jan 2 12:47:01 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 2.8: +9 -3 lines
Thu Jul 3 22:41:44 2003 UTC (21 years, 11 months ago) by schorsch
Sun Jun 8 12:03:10 2003 UTC (22 years ago) by schorsch
Thu Jun 5 19:29:34 2003 UTC (22 years ago) by schorsch
Changes since 2.5: +5 -9 lines
Sat Feb 22 02:07:27 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.4: +3 -8 lines
Tue Oct 27 09:08:26 1998 UTC (26 years, 7 months ago) by gwlarson
Tue Oct 19 17:23:31 1993 UTC (31 years, 7 months ago) by greg
added math.h include
Mon Sep 21 12:14:03 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.1: +10 -1 lines
Changes for PC port
Fri Aug 21 13:48:48 1992 UTC (32 years, 9 months ago) by greg
Diff to selected 2.14
