root/radiance/ray/src/px/pextrem.c
Fri Jul 19 17:37:56 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.13: +2 -3 lines
Thu Aug 2 18:33:44 2018 UTC (5 years, 10 months ago) by greg
Thu May 4 00:42:40 2017 UTC (7 years, 1 month ago) by greg
Reduced number of reported significant figures to something more sensible
Thu Jun 2 18:13:47 2005 UTC (19 years ago) by greg
CVS Tags: rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Fixed maximum reporting for images that are everywhere zero
Changes since 2.9: +6 -4 lines
Fri Jan 2 12:47:01 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 2.8: +9 -3 lines
Thu Jul 3 22:41:44 2003 UTC (20 years, 11 months ago) by schorsch
Sun Jun 8 12:03:10 2003 UTC (21 years ago) by schorsch
Changes since 2.5: +5 -9 lines
Changes since 2.4: +3 -8 lines
Tue Oct 27 09:08:26 1998 UTC (25 years, 7 months ago) by gwlarson
Tue Oct 19 17:23:31 1993 UTC (30 years, 8 months ago) by greg
added math.h include
Mon Sep 21 12:14:03 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.1: +10 -1 lines
Changes for PC port
Fri Aug 21 13:48:48 1992 UTC (31 years, 10 months ago) by greg
Diff to selected 2.6
