root/radiance/ray/src/px/pcwarp.c
Revision: 3.5
Committed: Mon Nov 10 19:08:19 2008 UTC (16 years, 4 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1
Changes since 3.4: +2 -2 lines
2 static const char RCSid[] = "$Id: pcwarp.c,v 3.4 2004/03/28 20:33:14 schorsch Exp $";
5 * Warp colors in Radiance picture to correct for input/output changes.
6 */
7
8 #include <stdio.h>
9
10 #include "resolu.h"
11 #include "color.h"
12 #include "warp3d.h"
13
14 char *progname; /* global argv[0] */
15
16 FILE *infp = NULL; /* input stream */
17 int xres, yres; /* input picture resolution */
18
19 WARP3D *cwarp; /* our warp map */
20 int iclip = CGAMUT_UPPER; /* input value gamut clipping */
21 int oclip = CGAMUT_LOWER; /* output value gamut clipping */
22
23 static void syserror(char *s);
24 static void picwarp(void);
25
26
27 int
28 main(
29 int argc,
30 char *argv[]
31 )
32 {
33 static char picfmt[LPICFMT+1] = PICFMT;
34 int cwflags = 0;
35 int rval;
36 int i;
37
38 progname = argv[0];
39 infp = stdin;
40 /* get options */
41 for (i = 1; i < argc && argv[i][0] == '-'; i++)
42 switch (argv[i][1]) {
43 case 'e':
44 cwflags = W3EXACT;
45 break;
46 case 'f':
47 cwflags = W3FAST;
48 break;
49 case 'i':
50 iclip = 0;
51 break;
52 case 'o':
53 oclip = CGAMUT;
54 break;
55 default:
56 goto userr;
57 }
58 /* load warp map */
59 if (i >= argc)
60 goto userr;
61 if ((cwarp = load3dw(argv[i++], NULL)) == NULL)
62 syserror("load3dw");
63 set3dwfl(cwarp, cwflags);
64 /* open input and output pictures */
65 if (i < argc && (infp = fopen(argv[i], "r")) == NULL)
66 syserror(argv[i]);
67 if (i < argc-1 && freopen(argv[i+1], "w", stdout) == NULL)
68 syserror(argv[i+1]);
69 /* transfer header */
70 if ((rval = checkheader(infp, picfmt, stdout)) < 0) {
71 fprintf(stderr, "%s: input not a Radiance picture\n",
72 progname);
73 exit(1);
74 }
75 if (rval)
76 fputformat(picfmt, stdout);
77 /* add new header info. */
78 printargs(i, argv, stdout);
79 putchar('\n');
80 /* get picture size */
81 if ((rval = fgetresolu(&xres, &yres, infp)) < 0) {
82 fprintf(stderr, "%s: bad picture size\n", progname);
83 exit(1);
84 }
85 /* new picture size the same */
86 fputresolu(rval, xres, yres, stdout);
87 /* warp those colors! */
88 picwarp();
89 exit(0);
90 userr:
91 fprintf(stderr,
92 "Usage: %s [-i][-o][-e|-f] map.cwp [input.hdr [output.hdr]]\n",
93 progname);
94 exit(1);
95 }
96
97
98 static void
99 syserror( /* print system error and exit */
100 char *s
101 )
102 {
103 fprintf(stderr, "%s: ", progname);
104 perror(s);
105 exit(2);
106 }
107
108
109 static void
110 picwarp(void) /* warp our picture scanlines */
111 {
112 register COLOR *scan;
113 long ngamut = 0;
114 int rval;
115 int y;
116 register int x;
117
118 scan = (COLOR *)malloc(xres*sizeof(COLOR));
119 if (scan == NULL)
120 syserror("picwarp");
121 for (y = 0; y < yres; y++) {
122 if (freadscan(scan, xres, infp) < 0) {
123 fprintf(stderr, "%s: error reading input picture\n",
124 progname);
125 exit(1);
126 }
127 for (x = 0; x < xres; x++) {
128 if (iclip)
129 clipgamut(scan[x], bright(scan[x]), iclip,
130 cblack, cwhite);
131 rval = warp3d(scan[x], scan[x], cwarp);
132 if (rval & W3ERROR)
133 syserror("warp3d");
134 if (rval & W3BADMAP) {
135 fprintf(stderr, "%s: singular color mapping\n",
136 progname);
137 exit(1);
138 }
139 if (rval & W3GAMUT)
140 ngamut++;
141 if (oclip)
142 clipgamut(scan[x], bright(scan[x]), oclip,
143 cblack, cwhite);
144 }
145 if (fwritescan(scan, xres, stdout) < 0) {
146 fprintf(stderr, "%s: error writing output picture\n",
147 progname);
148 exit(1);
149 }
150 }
151 if (ngamut >= (long)xres*yres/100)
152 fprintf(stderr, "%s: warning - %ld%% of pixels out of gamut\n",
153 progname, 100*ngamut/((long)xres*yres));
154 free((void *)scan);
155 }
