root/radiance/ray/src/px/pcwarp.c
Revision: 3.7
Committed: Fri Jul 19 17:37:56 2019 UTC (4 years, 11 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Changes since 3.6: +2 -3 lines
2 static const char RCSid[] = "$Id: pcwarp.c,v 3.6 2018/08/02 18:33:44 greg Exp $";
5 * Warp colors in Radiance picture to correct for input/output changes.
6 */
7
8 #include "rtio.h"
9 #include "resolu.h"
10 #include "color.h"
11 #include "warp3d.h"
12
13 char *progname; /* global argv[0] */
14
15 FILE *infp = NULL; /* input stream */
16 int xres, yres; /* input picture resolution */
17
18 WARP3D *cwarp; /* our warp map */
19 int iclip = CGAMUT_UPPER; /* input value gamut clipping */
20 int oclip = CGAMUT_LOWER; /* output value gamut clipping */
21
22 static void syserror(char *s);
23 static void picwarp(void);
24
25
26 int
27 main(
28 int argc,
29 char *argv[]
30 )
31 {
32 static char picfmt[MAXFMTLEN] = PICFMT;
33 int cwflags = 0;
34 int rval;
35 int i;
36
37 progname = argv[0];
38 infp = stdin;
39 /* get options */
40 for (i = 1; i < argc && argv[i][0] == '-'; i++)
41 switch (argv[i][1]) {
42 case 'e':
43 cwflags = W3EXACT;
44 break;
45 case 'f':
46 cwflags = W3FAST;
47 break;
48 case 'i':
49 iclip = 0;
50 break;
51 case 'o':
52 oclip = CGAMUT;
53 break;
54 default:
55 goto userr;
56 }
57 /* load warp map */
58 if (i >= argc)
59 goto userr;
60 if ((cwarp = load3dw(argv[i++], NULL)) == NULL)
61 syserror("load3dw");
62 set3dwfl(cwarp, cwflags);
63 /* open input and output pictures */
64 if (i < argc && (infp = fopen(argv[i], "r")) == NULL)
65 syserror(argv[i]);
66 if (i < argc-1 && freopen(argv[i+1], "w", stdout) == NULL)
67 syserror(argv[i+1]);
68 /* transfer header */
69 if ((rval = checkheader(infp, picfmt, stdout)) < 0) {
70 fprintf(stderr, "%s: input not a Radiance picture\n",
71 progname);
72 exit(1);
73 }
74 if (rval)
75 fputformat(picfmt, stdout);
76 /* add new header info. */
77 printargs(i, argv, stdout);
78 putchar('\n');
79 /* get picture size */
80 if ((rval = fgetresolu(&xres, &yres, infp)) < 0) {
81 fprintf(stderr, "%s: bad picture size\n", progname);
82 exit(1);
83 }
84 /* new picture size the same */
85 fputresolu(rval, xres, yres, stdout);
86 /* warp those colors! */
87 picwarp();
88 exit(0);
89 userr:
90 fprintf(stderr,
91 "Usage: %s [-i][-o][-e|-f] map.cwp [input.hdr [output.hdr]]\n",
92 progname);
93 exit(1);
94 }
95
96
97 static void
98 syserror( /* print system error and exit */
99 char *s
100 )
101 {
102 fprintf(stderr, "%s: ", progname);
103 perror(s);
104 exit(2);
105 }
106
107
108 static void
109 picwarp(void) /* warp our picture scanlines */
110 {
111 register COLOR *scan;
112 long ngamut = 0;
113 int rval;
114 int y;
115 register int x;
116
117 scan = (COLOR *)malloc(xres*sizeof(COLOR));
118 if (scan == NULL)
119 syserror("picwarp");
120 for (y = 0; y < yres; y++) {
121 if (freadscan(scan, xres, infp) < 0) {
122 fprintf(stderr, "%s: error reading input picture\n",
123 progname);
124 exit(1);
125 }
126 for (x = 0; x < xres; x++) {
127 if (iclip)
128 clipgamut(scan[x], bright(scan[x]), iclip,
129 cblack, cwhite);
130 rval = warp3d(scan[x], scan[x], cwarp);
131 if (rval & W3ERROR)
132 syserror("warp3d");
133 if (rval & W3BADMAP) {
134 fprintf(stderr, "%s: singular color mapping\n",
135 progname);
136 exit(1);
137 }
138 if (rval & W3GAMUT)
139 ngamut++;
140 if (oclip)
141 clipgamut(scan[x], bright(scan[x]), oclip,
142 cblack, cwhite);
143 }
144 if (fwritescan(scan, xres, stdout) < 0) {
145 fprintf(stderr, "%s: error writing output picture\n",
146 progname);
147 exit(1);
148 }
149 }
150 if (ngamut >= (long)xres*yres/100)
151 fprintf(stderr, "%s: warning - %ld%% of pixels out of gamut\n",
152 progname, 100*ngamut/((long)xres*yres));
153 free((void *)scan);
154 }
