root/radiance/ray/src/px/pcwarp.c
Revision: 3.8
Committed: Fri Jun 6 19:11:21 2025 UTC (3 weeks, 4 days ago) by greg
Changes since 3.7: +3 -4 lines
refactor: Making use of printargs() more consistent with fixargv0()
2 static const char RCSid[] = "$Id: pcwarp.c,v 3.7 2019/07/19 17:37:56 greg Exp $";
5 * Warp colors in Radiance picture to correct for input/output changes.
6 */
7
8 #include "paths.h"
9 #include "rtio.h"
10 #include "resolu.h"
11 #include "color.h"
12 #include "warp3d.h"
13
14 FILE *infp = NULL; /* input stream */
15 int xres, yres; /* input picture resolution */
16
17 WARP3D *cwarp; /* our warp map */
18 int iclip = CGAMUT_UPPER; /* input value gamut clipping */
19 int oclip = CGAMUT_LOWER; /* output value gamut clipping */
20
21 static void syserror(char *s);
22 static void picwarp(void);
23
24
25 int
26 main(
27 int argc,
28 char *argv[]
29 )
30 {
31 static char picfmt[MAXFMTLEN] = PICFMT;
32 int cwflags = 0;
33 int rval;
34 int i;
35
36 fixargv0(argv[0]);
37 infp = stdin;
38 /* get options */
39 for (i = 1; i < argc && argv[i][0] == '-'; i++)
40 switch (argv[i][1]) {
41 case 'e':
42 cwflags = W3EXACT;
43 break;
44 case 'f':
45 cwflags = W3FAST;
46 break;
47 case 'i':
48 iclip = 0;
49 break;
50 case 'o':
51 oclip = CGAMUT;
52 break;
53 default:
54 goto userr;
55 }
56 /* load warp map */
57 if (i >= argc)
58 goto userr;
59 if ((cwarp = load3dw(argv[i++], NULL)) == NULL)
60 syserror("load3dw");
61 set3dwfl(cwarp, cwflags);
62 /* open input and output pictures */
63 if (i < argc && (infp = fopen(argv[i], "r")) == NULL)
64 syserror(argv[i]);
65 if (i < argc-1 && freopen(argv[i+1], "w", stdout) == NULL)
66 syserror(argv[i+1]);
67 /* transfer header */
68 if ((rval = checkheader(infp, picfmt, stdout)) < 0) {
69 fprintf(stderr, "%s: input not a Radiance picture\n",
70 progname);
71 exit(1);
72 }
73 if (rval)
74 fputformat(picfmt, stdout);
75 /* add new header info. */
76 printargs(i, argv, stdout);
77 putchar('\n');
78 /* get picture size */
79 if ((rval = fgetresolu(&xres, &yres, infp)) < 0) {
80 fprintf(stderr, "%s: bad picture size\n", progname);
81 exit(1);
82 }
83 /* new picture size the same */
84 fputresolu(rval, xres, yres, stdout);
85 /* warp those colors! */
86 picwarp();
87 exit(0);
88 userr:
89 fprintf(stderr,
90 "Usage: %s [-i][-o][-e|-f] map.cwp [input.hdr [output.hdr]]\n",
91 progname);
92 exit(1);
93 }
94
95
96 static void
97 syserror( /* print system error and exit */
98 char *s
99 )
100 {
101 fprintf(stderr, "%s: ", progname);
102 perror(s);
103 exit(2);
104 }
105
106
107 static void
108 picwarp(void) /* warp our picture scanlines */
109 {
110 register COLOR *scan;
111 long ngamut = 0;
112 int rval;
113 int y;
114 register int x;
115
116 scan = (COLOR *)malloc(xres*sizeof(COLOR));
117 if (scan == NULL)
118 syserror("picwarp");
119 for (y = 0; y < yres; y++) {
120 if (freadscan(scan, xres, infp) < 0) {
121 fprintf(stderr, "%s: error reading input picture\n",
122 progname);
123 exit(1);
124 }
125 for (x = 0; x < xres; x++) {
126 if (iclip)
127 clipgamut(scan[x], bright(scan[x]), iclip,
128 cblack, cwhite);
129 rval = warp3d(scan[x], scan[x], cwarp);
130 if (rval & W3ERROR)
131 syserror("warp3d");
132 if (rval & W3BADMAP) {
133 fprintf(stderr, "%s: singular color mapping\n",
134 progname);
135 exit(1);
136 }
137 if (rval & W3GAMUT)
138 ngamut++;
139 if (oclip)
140 clipgamut(scan[x], bright(scan[x]), oclip,
141 cblack, cwhite);
142 }
143 if (fwritescan(scan, xres, stdout) < 0) {
144 fprintf(stderr, "%s: error writing output picture\n",
145 progname);
146 exit(1);
147 }
148 }
149 if (ngamut >= (long)xres*yres/100)
150 fprintf(stderr, "%s: warning - %ld%% of pixels out of gamut\n",
151 progname, 100*ngamut/((long)xres*yres));
152 free((void *)scan);
153 }
