Fixed issue with undersampled histogram in phisto
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed bug in veil computation for fisheye views (divide by zero)
removed unnecessary debugging statements
changed from interpolation of Shaler's data to atan() fit in hacuity()
added cosine correction to veiling glare computation
changed to histogram truncation made veiling reflection modify FOV sample image
changed lower limit for pixel solid angle test in initacuity()
bug fix in computation of tsampr array
Changed definition of SCANBAR to make code slightly more logical.
bug fix in acuscan()
fixed potential bug in getascan() made ascanval() more efficient
added limit check to hacuity()
fixed problem with fisheye views made veil computation faster with approximation to acos()
decreased size of raydir array by changing from FVECT to float
