root/Development/ray/src/px/pcond4.c
Revision: 3.8
Committed: Tue Oct 8 12:48:00 1996 UTC (29 years, 1 month ago) by greg
Changes since 3.7: +30 -27 lines
Changed definition of SCANBAR to make code slightly more logical.
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines for veiling glare and loss of acuity.
9 */
10
11 #include "pcond.h"
12
13 /************** VEILING STUFF *****************/
14
15 #define VADAPT 0.08 /* fraction of adaptation from veil */
16
17 extern COLOR *fovimg; /* foveal (1 degree) averaged image */
18 extern short fvxr, fvyr; /* foveal image resolution */
19
20 #define fovscan(y) (fovimg+(y)*fvxr)
21
22 static COLOR *veilimg; /* veiling image */
23
24 #define veilscan(y) (veilimg+(y)*fvxr)
25
26 static float (*raydir)[3] = NULL; /* ray direction for each pixel */
27
28 #define rdirscan(y) (raydir+(y)*fvxr)
29
30
31 compraydir() /* compute ray directions */
32 {
33 FVECT rorg, rdir;
34 double h, v;
35 register int x, y;
36
37 if (raydir != NULL) /* already done? */
38 return;
39 raydir = (float (*)[3])malloc(fvxr*fvyr*3*sizeof(float));
40 if (raydir == NULL)
41 syserror("malloc");
42
43 for (y = 0; y < fvyr; y++) {
44 switch (inpres.or) {
45 case YMAJOR: case YMAJOR|XDECR:
46 v = (y+.5)/fvyr; break;
47 case YMAJOR|YDECR: case YMAJOR|YDECR|XDECR:
48 v = 1. - (y+.5)/fvyr; break;
49 case 0: case YDECR:
50 h = (y+.5)/fvyr; break;
51 case XDECR: case XDECR|YDECR:
52 h = 1. - (y+.5)/fvyr; break;
53 }
54 for (x = 0; x < fvxr; x++) {
55 switch (inpres.or) {
56 case YMAJOR: case YMAJOR|YDECR:
57 h = (x+.5)/fvxr; break;
58 case YMAJOR|XDECR: case YMAJOR|XDECR|YDECR:
59 h = 1. - (x+.5)/fvxr; break;
60 case 0: case XDECR:
61 v = (x+.5)/fvxr; break;
62 case YDECR: case YDECR|XDECR:
63 v = 1. - (x+.5)/fvxr; break;
64 }
65 if (viewray(rorg, rdir, &ourview, h, v)
66 >= -FTINY) {
67 rdirscan(y)[x][0] = rdir[0];
68 rdirscan(y)[x][1] = rdir[1];
69 rdirscan(y)[x][2] = rdir[2];
70 } else {
71 rdirscan(y)[x][0] =
72 rdirscan(y)[x][1] =
73 rdirscan(y)[x][2] = 0.0;
74 }
75 }
76 }
77 }
78
79
80 compveil() /* compute veiling image */
81 {
82 double t2, t2sum;
83 COLOR ctmp, vsum;
84 int px, py;
85 register int x, y;
86 /* compute ray directions */
87 compraydir();
88 /* compute veil image */
89 veilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR));
90 if (veilimg == NULL)
91 syserror("malloc");
92 for (py = 0; py < fvyr; py++)
93 for (px = 0; px < fvxr; px++) {
94 t2sum = 0.;
95 setcolor(vsum, 0., 0., 0.);
96 for (y = 0; y < fvyr; y++)
97 for (x = 0; x < fvxr; x++) {
98 if (x == px && y == py) continue;
99 t2 = DOT(rdirscan(py)[px],
100 rdirscan(y)[x]);
101 if (t2 <= FTINY) continue;
102 /* use approximation instead
103 t2 = acos(t2);
104 t2 = 1./(t2*t2);
105 */
106 t2 = .5 / (1. - t2);
107 copycolor(ctmp, fovscan(y)[x]);
108 scalecolor(ctmp, t2);
109 addcolor(vsum, ctmp);
110 t2sum += t2;
111 }
112 /* VADAPT of original is subtracted in addveil() */
113 scalecolor(vsum, VADAPT/t2sum);
114 copycolor(veilscan(py)[px], vsum);
115 }
116 }
117
118
119 addveil(sl, y) /* add veil to scanline */
120 COLOR *sl;
121 int y;
122 {
123 int vx, vy;
124 double dx, dy;
125 double lv, uv;
126 register int x, i;
127
128 vy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
129 while (vy >= fvyr-1) vy--;
130 dy -= (double)vy;
131 for (x = 0; x < scanlen(&inpres); x++) {
132 vx = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
133 while (vx >= fvxr-1) vx--;
134 dx -= (double)vx;
135 for (i = 0; i < 3; i++) {
136 lv = (1.-dy)*colval(veilscan(vy)[vx],i) +
137 dy*colval(veilscan(vy+1)[vx],i);
138 uv = (1.-dy)*colval(veilscan(vy)[vx+1],i) +
139 dy*colval(veilscan(vy+1)[vx+1],i);
140 colval(sl[x],i) = (1.-VADAPT)*colval(sl[x],i) +
141 (1.-dx)*lv + dx*uv;
142 }
143 }
144 }
145
146
147 /****************** ACUITY STUFF *******************/
148
149 typedef struct {
150 short sampe; /* sample area size (exponent of 2) */
151 short nscans; /* number of scanlines in this bar */
152 int len; /* individual scanline length */
153 int nread; /* number of scanlines loaded */
154 COLOR *sdata; /* scanbar data */
155 } SCANBAR;
156
157 #define bscan(sb,y) ((COLOR *)(sb)->sdata+((y)%(sb)->nscans)*(sb)->len)
158
159 SCANBAR *rootbar; /* root scan bar (lowest resolution) */
160
161 float *inpacuD; /* input acuity data (cycles/degree) */
162
163 #define tsampr(x,y) inpacuD[(y)*fvxr+(x)]
164
165
166 double
167 hacuity(La) /* return visual acuity in cycles/degree */
168 double La;
169 { /* data due to S. Shaler (we should fit it!) */
170 #define NPOINTS 20
171 static float l10lum[NPOINTS] = {
172 -3.10503,-2.66403,-2.37703,-2.09303,-1.64403,-1.35803,
173 -1.07403,-0.67203,-0.38503,-0.10103,0.29397,0.58097,0.86497,
174 1.25697,1.54397,1.82797,2.27597,2.56297,2.84697,3.24897
175 };
176 static float resfreq[NPOINTS] = {
177 2.09,3.28,3.79,4.39,6.11,8.83,10.94,18.66,23.88,31.05,37.42,
178 37.68,41.60,43.16,45.30,47.00,48.43,48.32,51.06,51.09
179 };
180 double l10La;
181 register int i;
182 /* check limits */
183 if (La <= 7.85e-4)
184 return(resfreq[0]);
185 if (La >= 1.78e3)
186 return(resfreq[NPOINTS-1]);
187 /* interpolate data */
188 l10La = log10(La);
189 for (i = 0; i < NPOINTS-2 && l10lum[i+1] <= l10La; i++)
190 ;
191 return( ( (l10lum[i+1] - l10La)*resfreq[i] +
192 (l10La - l10lum[i])*resfreq[i+1] ) /
193 (l10lum[i+1] - l10lum[i]) );
194 #undef NPOINTS
195 }
196
197
198 COLOR *
199 getascan(sb, y) /* find/read scanline y for scanbar sb */
200 register SCANBAR *sb;
201 int y;
202 {
203 register COLOR *sl0, *sl1, *mysl;
204 register int i;
205
206 if (y < sb->nread - sb->nscans) /* too far back? */
207 return(NULL);
208 for ( ; y >= sb->nread; sb->nread++) { /* read as necessary */
209 mysl = bscan(sb, sb->nread);
210 if (sb->sampe == 0) {
211 if (freadscan(mysl, sb->len, infp) < 0) {
212 fprintf(stderr, "%s: %s: scanline read error\n",
213 progname, infn);
214 exit(1);
215 }
216 } else {
217 sl0 = getascan(sb+1, 2*y);
218 if (sl0 == NULL)
219 return(NULL);
220 sl1 = getascan(sb+1, 2*y+1);
221 for (i = 0; i < sb->len; i++) {
222 copycolor(mysl[i], sl0[2*i]);
223 addcolor(mysl[i], sl0[2*i+1]);
224 addcolor(mysl[i], sl1[2*i]);
225 addcolor(mysl[i], sl1[2*i+1]);
226 scalecolor(mysl[i], 0.25);
227 }
228 }
229 }
230 return(bscan(sb, y));
231 }
232
233
234 acuscan(scln, y) /* get acuity-sampled scanline */
235 COLOR *scln;
236 int y;
237 {
238 double sr;
239 double dx, dy;
240 int ix, iy;
241 register int x;
242 /* compute foveal y position */
243 iy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
244 if (iy >= fvyr-1) iy--;
245 dy -= (double)iy;
246 for (x = 0; x < scanlen(&inpres); x++) {
247 /* compute foveal x position */
248 ix = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
249 if (ix >= fvxr-1) ix--;
250 dx -= (double)ix;
251 /* interpolate sample rate */
252 sr = (1.-dy)*((1.-dx)*tsampr(ix,iy) + dx*tsampr(ix+1,iy)) +
253 dy*((1.-dx)*tsampr(ix,iy+1) + dx*tsampr(ix+1,iy+1));
254
255 acusample(scln[x], x, y, sr); /* compute sample */
256 }
257 }
258
259
260 acusample(col, x, y, sr) /* interpolate sample at (x,y) using rate sr */
261 COLOR col;
262 int x, y;
263 double sr;
264 {
265 COLOR c1;
266 double d;
267 register SCANBAR *sb0;
268
269 for (sb0 = rootbar; sb0->sampe != 0 && 1<<sb0[1].sampe > sr; sb0++)
270 ;
271 ascanval(col, x, y, sb0);
272 if (sb0->sampe == 0) /* don't extrapolate highest */
273 return;
274 ascanval(c1, x, y, sb0+1);
275 d = ((1<<sb0->sampe) - sr)/(1<<sb0[1].sampe);
276 scalecolor(col, 1.-d);
277 scalecolor(c1, d);
278 addcolor(col, c1);
279 }
280
281
282 ascanval(col, x, y, sb) /* interpolate scanbar at orig. coords (x,y) */
283 COLOR col;
284 int x, y;
285 SCANBAR *sb;
286 {
287 COLOR *sl0, *sl1, c1, c1y;
288 double dx, dy;
289 int ix, iy;
290
291 if (sb->sampe == 0) { /* no need to interpolate */
292 sl0 = getascan(sb, y);
293 copycolor(col, sl0[x]);
294 return;
295 }
296 /* compute coordinates for sb */
297 ix = dx = (x+.5)/(1<<sb->sampe) - .5;
298 while (ix >= sb->len-1) ix--;
299 dx -= (double)ix;
300 iy = dy = (y+.5)/(1<<sb->sampe) - .5;
301 while (iy >= (numscans(&inpres)>>sb->sampe)-1) iy--;
302 dy -= (double)iy;
303 /* get scanlines */
304 sl0 = getascan(sb, iy);
305 if (sl0 == NULL) {
306 fprintf(stderr, "%s: internal - cannot backspace in ascanval\n",
307 progname);
308 exit(1);
309 }
310 sl1 = getascan(sb, iy+1);
311 /* 2D linear interpolation */
312 copycolor(col, sl0[ix]);
313 scalecolor(col, 1.-dx);
314 copycolor(c1, sl0[ix+1]);
315 scalecolor(c1, dx);
316 addcolor(col, c1);
317 copycolor(c1y, sl1[ix]);
318 scalecolor(c1y, 1.-dx);
319 copycolor(c1, sl1[ix+1]);
320 scalecolor(c1, dx);
321 addcolor(c1y, c1);
322 scalecolor(col, 1.-dy);
323 scalecolor(c1y, dy);
324 addcolor(col, c1y);
325 }
326
327
328 SCANBAR *
329 sballoc(sr, ns, sl) /* allocate scanbar */
330 int sr; /* sampling rate */
331 int ns; /* number of scanlines */
332 int sl; /* original scanline length */
333 {
334 SCANBAR *sbarr;
335 register SCANBAR *sb;
336
337 sbarr = sb = (SCANBAR *)malloc((sr+1)*sizeof(SCANBAR));
338 if (sb == NULL)
339 syserror("malloc");
340 do {
341 sb->sdata = (COLOR *)malloc((sl>>sr)*ns*sizeof(COLOR));
342 if (sb->sdata == NULL)
343 syserror("malloc");
344 sb->sampe = sr;
345 sb->nscans = ns;
346 sb->len = sl>>sr;
347 sb->nread = 0;
348 ns <<= 1;
349 sb++;
350 } while (--sr >= 0);
351 return(sbarr);
352 }
353
354
355 initacuity() /* initialize variable acuity sampling */
356 {
357 FVECT diffx, diffy, cp;
358 double omega, maxsr;
359 register int x, y, i;
360
361 compraydir(); /* compute ray directions */
362
363 inpacuD = (float *)malloc(fvxr*fvyr*sizeof(float));
364 if (inpacuD == NULL)
365 syserror("malloc");
366 maxsr = 1.; /* compute internal sample rates */
367 for (y = 1; y < fvyr-1; y++)
368 for (x = 1; x < fvxr-1; x++) {
369 for (i = 0; i < 3; i++) {
370 diffx[i] = 0.5*fvxr/scanlen(&inpres) *
371 (rdirscan(y)[x+1][i] -
372 rdirscan(y)[x-1][i]);
373 diffy[i] = 0.5*fvyr/numscans(&inpres) *
374 (rdirscan(y+1)[x][i] -
375 rdirscan(y-1)[x][i]);
376 }
377 fcross(cp, diffx, diffy);
378 omega = 0.5 * sqrt(DOT(cp,cp));
379 if (omega <= FTINY)
380 tsampr(x,y) = 1.;
381 else if ((tsampr(x,y) = PI/180. / sqrt(omega) /
382 hacuity(plum(fovscan(y)[x]))) > maxsr)
383 maxsr = tsampr(x,y);
384 }
385 /* copy perimeter (easier) */
386 for (x = 1; x < fvxr-1; x++) {
387 tsampr(x,0) = tsampr(x,1);
388 tsampr(x,fvyr-1) = tsampr(x,fvyr-2);
389 }
390 for (y = 0; y < fvyr; y++) {
391 tsampr(y,0) = tsampr(y,1);
392 tsampr(y,fvxr-1) = tsampr(y,fvxr-2);
393 }
394 /* initialize with next power of two */
395 rootbar = sballoc((int)(log(maxsr)/log(2.))+1, 2, scanlen(&inpres));
396 }
