| 1 |
/* Copyright (c) 1996 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Routines for veiling glare and loss of acuity.
| 9 |
| 10 |
| 11 |
#include "pcond.h"
| 12 |
| 13 |
/************** VEILING STUFF *****************/
| 14 |
| 15 |
#define VADAPT 0.08 /* fraction of adaptation from veil */
| 16 |
| 17 |
extern COLOR *fovimg; /* foveal (1 degree) averaged image */
| 18 |
extern short fvxr, fvyr; /* foveal image resolution */
| 19 |
| 20 |
#define fovscan(y) (fovimg+(y)*fvxr)
| 21 |
| 22 |
static COLOR *veilimg; /* veiling image */
| 23 |
| 24 |
#define veilscan(y) (veilimg+(y)*fvxr)
| 25 |
| 26 |
static float (*raydir)[3] = NULL; /* ray direction for each pixel */
| 27 |
| 28 |
#define rdirscan(y) (raydir+(y)*fvxr)
| 29 |
| 30 |
| 31 |
compraydir() /* compute ray directions */
| 32 |
| 33 |
FVECT rorg, rdir;
| 34 |
double h, v;
| 35 |
register int x, y;
| 36 |
| 37 |
if (raydir != NULL) /* already done? */
| 38 |
return;
| 39 |
raydir = (float (*)[3])malloc(fvxr*fvyr*3*sizeof(float));
| 40 |
if (raydir == NULL)
| 41 |
syserror("malloc");
| 42 |
| 43 |
for (y = 0; y < fvyr; y++) {
| 44 |
switch (inpres.or) {
| 45 |
case YMAJOR: case YMAJOR|XDECR:
| 46 |
v = (y+.5)/fvyr; break;
| 47 |
case YMAJOR|YDECR: case YMAJOR|YDECR|XDECR:
| 48 |
v = 1. - (y+.5)/fvyr; break;
| 49 |
case 0: case YDECR:
| 50 |
h = (y+.5)/fvyr; break;
| 51 |
case XDECR: case XDECR|YDECR:
| 52 |
h = 1. - (y+.5)/fvyr; break;
| 53 |
| 54 |
for (x = 0; x < fvxr; x++) {
| 55 |
| 56 |
case YMAJOR: case YMAJOR|YDECR:
| 57 |
h = (x+.5)/fvxr; break;
| 58 |
case YMAJOR|XDECR: case YMAJOR|XDECR|YDECR:
| 59 |
h = 1. - (x+.5)/fvxr; break;
| 60 |
case 0: case XDECR:
| 61 |
v = (x+.5)/fvxr; break;
| 62 |
case YDECR: case YDECR|XDECR:
| 63 |
v = 1. - (x+.5)/fvxr; break;
| 64 |
| 65 |
if (viewray(rorg, rdir, &ourview, h, v)
| 66 |
>= -FTINY) {
| 67 |
rdirscan(y)[x][0] = rdir[0];
| 68 |
rdirscan(y)[x][1] = rdir[1];
| 69 |
rdirscan(y)[x][2] = rdir[2];
| 70 |
} else {
| 71 |
rdirscan(y)[x][0] =
| 72 |
rdirscan(y)[x][1] =
| 73 |
rdirscan(y)[x][2] = 0.0;
| 74 |
| 75 |
| 76 |
| 77 |
| 78 |
| 79 |
| 80 |
compveil() /* compute veiling image */
| 81 |
| 82 |
double t2, t2sum;
| 83 |
COLOR ctmp, vsum;
| 84 |
int px, py;
| 85 |
register int x, y;
| 86 |
| 87 |
compraydir();
| 88 |
/* compute veil image */
| 89 |
veilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR));
| 90 |
if (veilimg == NULL)
| 91 |
syserror("malloc");
| 92 |
for (py = 0; py < fvyr; py++)
| 93 |
for (px = 0; px < fvxr; px++) {
| 94 |
t2sum = 0.;
| 95 |
setcolor(vsum, 0., 0., 0.);
| 96 |
| 97 |
| 98 |
if (x == px && y == py) continue;
| 99 |
t2 = DOT(rdirscan(py)[px],
| 100 |
rdirscan(y)[x]);
| 101 |
if (t2 <= FTINY) continue;
| 102 |
/* use approximation instead
| 103 |
t2 = acos(t2);
| 104 |
t2 = 1./(t2*t2);
| 105 |
| 106 |
t2 = .5 / (1. - t2);
| 107 |
copycolor(ctmp, fovscan(y)[x]);
| 108 |
scalecolor(ctmp, t2);
| 109 |
addcolor(vsum, ctmp);
| 110 |
t2sum += t2;
| 111 |
| 112 |
/* VADAPT of original is subtracted in addveil() */
| 113 |
scalecolor(vsum, VADAPT/t2sum);
| 114 |
copycolor(veilscan(py)[px], vsum);
| 115 |
| 116 |
| 117 |
| 118 |
| 119 |
addveil(sl, y) /* add veil to scanline */
| 120 |
COLOR *sl;
| 121 |
int y;
| 122 |
| 123 |
int vx, vy;
| 124 |
double dx, dy;
| 125 |
double lv, uv;
| 126 |
register int x, i;
| 127 |
| 128 |
vy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
| 129 |
while (vy >= fvyr-1) vy--;
| 130 |
dy -= (double)vy;
| 131 |
for (x = 0; x < scanlen(&inpres); x++) {
| 132 |
vx = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
| 133 |
while (vx >= fvxr-1) vx--;
| 134 |
dx -= (double)vx;
| 135 |
for (i = 0; i < 3; i++) {
| 136 |
lv = (1.-dy)*colval(veilscan(vy)[vx],i) +
| 137 |
dy*colval(veilscan(vy+1)[vx],i);
| 138 |
uv = (1.-dy)*colval(veilscan(vy)[vx+1],i) +
| 139 |
dy*colval(veilscan(vy+1)[vx+1],i);
| 140 |
colval(sl[x],i) = (1.-VADAPT)*colval(sl[x],i) +
| 141 |
(1.-dx)*lv + dx*uv;
| 142 |
| 143 |
| 144 |
| 145 |
| 146 |
| 147 |
/****************** ACUITY STUFF *******************/
| 148 |
| 149 |
typedef struct scanbar {
| 150 |
short sampr; /* sample area size (power of 2) */
| 151 |
short nscans; /* number of scanlines in this bar */
| 152 |
int len; /* individual scanline length */
| 153 |
struct scanbar *next; /* next higher resolution scanbar */
| 154 |
int nread; /* number of scanlines loaded */
| 155 |
/* followed by the scanline data */
| 156 |
} SCANBAR;
| 157 |
| 158 |
#define bscan(sb,y) ((COLOR *)((sb)+1)+((y)%(sb)->nscans)*(sb)->len)
| 159 |
| 160 |
SCANBAR *rootbar; /* root scan bar (lowest resolution) */
| 161 |
| 162 |
float *inpacuD; /* input acuity data (cycles/degree) */
| 163 |
| 164 |
#define tsampr(x,y) inpacuD[(y)*fvxr+(x)]
| 165 |
| 166 |
| 167 |
double
| 168 |
hacuity(La) /* return visual acuity in cycles/degree */
| 169 |
double La;
| 170 |
{ /* data due to S. Shaler (we should fit it!) */
| 171 |
#define NPOINTS 20
| 172 |
static float l10lum[NPOINTS] = {
| 173 |
-3.10503,-2.66403,-2.37703,-2.09303,-1.64403,-1.35803,
| 174 |
-1.07403,-0.67203,-0.38503,-0.10103,0.29397,0.58097,0.86497,
| 175 |
1.25697,1.54397,1.82797,2.27597,2.56297,2.84697,3.24897
| 176 |
| 177 |
static float resfreq[NPOINTS] = {
| 178 |
2.09,3.28,3.79,4.39,6.11,8.83,10.94,18.66,23.88,31.05,37.42,
| 179 |
37.68,41.60,43.16,45.30,47.00,48.43,48.32,51.06,51.09
| 180 |
| 181 |
double l10La;
| 182 |
register int i;
| 183 |
/* check limits */
| 184 |
if (La <= 7.85e-4)
| 185 |
return(resfreq[0]);
| 186 |
if (La >= 1.78e3)
| 187 |
return(resfreq[NPOINTS-1]);
| 188 |
/* interpolate data */
| 189 |
l10La = log10(La);
| 190 |
for (i = 0; i < NPOINTS-2 && l10lum[i+1] <= l10La; i++)
| 191 |
| 192 |
return( ( (l10lum[i+1] - l10La)*resfreq[i] +
| 193 |
(l10La - l10lum[i])*resfreq[i+1] ) /
| 194 |
(l10lum[i+1] - l10lum[i]) );
| 195 |
#undef NPOINTS
| 196 |
| 197 |
| 198 |
| 199 |
COLOR *
| 200 |
getascan(sb, y) /* find/read scanline y for scanbar sb */
| 201 |
register SCANBAR *sb;
| 202 |
int y;
| 203 |
| 204 |
register COLOR *sl0, *sl1, *mysl;
| 205 |
register int i;
| 206 |
| 207 |
if (y < sb->nread - sb->nscans) /* too far back? */
| 208 |
return(NULL);
| 209 |
for ( ; y >= sb->nread; sb->nread++) { /* read as necessary */
| 210 |
mysl = bscan(sb, sb->nread);
| 211 |
if (sb->sampr == 1) {
| 212 |
if (freadscan(mysl, sb->len, infp) < 0) {
| 213 |
fprintf(stderr, "%s: %s: scanline read error\n",
| 214 |
progname, infn);
| 215 |
exit(1);
| 216 |
| 217 |
} else {
| 218 |
sl0 = getascan(sb->next, 2*y);
| 219 |
if (sl0 == NULL)
| 220 |
return(NULL);
| 221 |
sl1 = getascan(sb->next, 2*y+1);
| 222 |
for (i = 0; i < sb->len; i++) {
| 223 |
copycolor(mysl[i], sl0[2*i]);
| 224 |
addcolor(mysl[i], sl0[2*i+1]);
| 225 |
addcolor(mysl[i], sl1[2*i]);
| 226 |
addcolor(mysl[i], sl1[2*i+1]);
| 227 |
scalecolor(mysl[i], 0.25);
| 228 |
| 229 |
| 230 |
| 231 |
return(bscan(sb, y));
| 232 |
| 233 |
| 234 |
| 235 |
acuscan(scln, y) /* get acuity-sampled scanline */
| 236 |
COLOR *scln;
| 237 |
int y;
| 238 |
| 239 |
double sr;
| 240 |
double dx, dy;
| 241 |
int ix, iy;
| 242 |
register int x;
| 243 |
/* compute foveal y position */
| 244 |
iy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
| 245 |
if (iy >= fvyr-1) iy--;
| 246 |
dy -= (double)iy;
| 247 |
| 248 |
/* compute foveal x position */
| 249 |
ix = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
| 250 |
if (ix >= fvxr-1) ix--;
| 251 |
dx -= (double)ix;
| 252 |
/* interpolate sample rate */
| 253 |
sr = (1.-dy)*((1.-dx)*tsampr(ix,iy) + dx*tsampr(ix+1,iy)) +
| 254 |
dy*((1.-dx)*tsampr(ix,iy+1) + dx*tsampr(ix+1,iy+1));
| 255 |
| 256 |
acusample(scln[x], x, y, sr); /* compute sample */
| 257 |
| 258 |
| 259 |
| 260 |
| 261 |
acusample(col, x, y, sr) /* interpolate sample at (x,y) using rate sr */
| 262 |
COLOR col;
| 263 |
int x, y;
| 264 |
double sr;
| 265 |
| 266 |
COLOR c1;
| 267 |
double d;
| 268 |
register SCANBAR *sb0;
| 269 |
| 270 |
for (sb0 = rootbar; sb0->next != NULL && sb0->next->sampr > sr;
| 271 |
sb0 = sb0->next)
| 272 |
| 273 |
ascanval(col, x, y, sb0);
| 274 |
if (sb0->next == NULL) /* don't extrapolate highest */
| 275 |
return;
| 276 |
ascanval(c1, x, y, sb0->next);
| 277 |
d = (sb0->sampr - sr)/(sb0->sampr - sb0->next->sampr);
| 278 |
scalecolor(col, 1.-d);
| 279 |
scalecolor(c1, d);
| 280 |
addcolor(col, c1);
| 281 |
| 282 |
| 283 |
| 284 |
ascanval(col, x, y, sb) /* interpolate scanbar at orig. coords (x,y) */
| 285 |
COLOR col;
| 286 |
int x, y;
| 287 |
SCANBAR *sb;
| 288 |
| 289 |
COLOR *sl0, *sl1, c1, c1y;
| 290 |
double dx, dy;
| 291 |
int ix, iy;
| 292 |
| 293 |
if (sb->sampr == 1) { /* no need to interpolate */
| 294 |
sl0 = getascan(sb, y);
| 295 |
copycolor(col, sl0[x]);
| 296 |
return;
| 297 |
| 298 |
/* compute coordinates for sb */
| 299 |
ix = dx = (x+.5)/sb->sampr - .5;
| 300 |
while (ix >= sb->len-1) ix--;
| 301 |
dx -= (double)ix;
| 302 |
iy = dy = (y+.5)/sb->sampr - .5;
| 303 |
while (iy >= numscans(&inpres)/sb->sampr-1) iy--;
| 304 |
dy -= (double)iy;
| 305 |
/* get scanlines */
| 306 |
sl0 = getascan(sb, iy);
| 307 |
if (sl0 == NULL) {
| 308 |
fprintf(stderr, "%s: internal - cannot backspace in ascanval\n",
| 309 |
progname);
| 310 |
exit(1);
| 311 |
| 312 |
sl1 = getascan(sb, iy+1);
| 313 |
/* 2D linear interpolation */
| 314 |
copycolor(col, sl0[ix]);
| 315 |
scalecolor(col, 1.-dx);
| 316 |
copycolor(c1, sl0[ix+1]);
| 317 |
scalecolor(c1, dx);
| 318 |
addcolor(col, c1);
| 319 |
copycolor(c1y, sl1[ix]);
| 320 |
scalecolor(c1y, 1.-dx);
| 321 |
copycolor(c1, sl1[ix+1]);
| 322 |
scalecolor(c1, dx);
| 323 |
addcolor(c1y, c1);
| 324 |
scalecolor(col, 1.-dy);
| 325 |
scalecolor(c1y, dy);
| 326 |
addcolor(col, c1y);
| 327 |
| 328 |
| 329 |
| 330 |
SCANBAR *
| 331 |
sballoc(sr, ns, sl) /* allocate scanbar */
| 332 |
int sr; /* sampling rate */
| 333 |
int ns; /* number of scanlines */
| 334 |
int sl; /* original scanline length */
| 335 |
| 336 |
| 337 |
| 338 |
sb = (SCANBAR *)malloc(sizeof(SCANBAR)+(sl/sr)*ns*sizeof(COLOR));
| 339 |
if (sb == NULL)
| 340 |
syserror("malloc");
| 341 |
sb->nscans = ns;
| 342 |
sb->len = sl/sr;
| 343 |
sb->nread = 0;
| 344 |
if ((sb->sampr = sr) > 1)
| 345 |
sb->next = sballoc(sr/2, ns*2, sl);
| 346 |
else
| 347 |
sb->next = NULL;
| 348 |
return(sb);
| 349 |
| 350 |
| 351 |
| 352 |
initacuity() /* initialize variable acuity sampling */
| 353 |
| 354 |
FVECT diffx, diffy, cp;
| 355 |
double omega, maxsr;
| 356 |
register int x, y, i;
| 357 |
| 358 |
compraydir(); /* compute ray directions */
| 359 |
| 360 |
inpacuD = (float *)malloc(fvxr*fvyr*sizeof(float));
| 361 |
if (inpacuD == NULL)
| 362 |
syserror("malloc");
| 363 |
maxsr = 1.; /* compute internal sample rates */
| 364 |
for (y = 1; y < fvyr-1; y++)
| 365 |
for (x = 1; x < fvxr-1; x++) {
| 366 |
| 367 |
diffx[i] = 0.5*fvxr/scanlen(&inpres) *
| 368 |
(rdirscan(y)[x+1][i] -
| 369 |
rdirscan(y)[x-1][i]);
| 370 |
diffy[i] = 0.5*fvyr/numscans(&inpres) *
| 371 |
(rdirscan(y+1)[x][i] -
| 372 |
rdirscan(y-1)[x][i]);
| 373 |
| 374 |
fcross(cp, diffx, diffy);
| 375 |
omega = 0.5 * sqrt(DOT(cp,cp));
| 376 |
if (omega <= FTINY)
| 377 |
tsampr(x,y) = 1.;
| 378 |
else if ((tsampr(x,y) = PI/180. / sqrt(omega) /
| 379 |
hacuity(plum(fovscan(y)[x]))) > maxsr)
| 380 |
maxsr = tsampr(x,y);
| 381 |
| 382 |
/* copy perimeter (easier) */
| 383 |
| 384 |
tsampr(x,0) = tsampr(x,1);
| 385 |
tsampr(x,fvyr-1) = tsampr(x,fvyr-2);
| 386 |
| 387 |
| 388 |
tsampr(y,0) = tsampr(y,1);
| 389 |
tsampr(y,fvxr-1) = tsampr(y,fvxr-2);
| 390 |
| 391 |
/* initialize with next power of two */
| 392 |
rootbar = sballoc(2<<(int)(log(maxsr)/log(2.)), 2, scanlen(&inpres));
| 393 |
