root/radiance/ray/src/px/pcond4.c
Revision: 3.6
Committed: Sat Oct 5 08:05:27 1996 UTC (27 years, 7 months ago) by greg
Changes since 3.5: +15 -5 lines
fixed potential bug in getascan()
made ascanval() more efficient
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines for veiling glare and loss of acuity.
9 */
10
11 #include "pcond.h"
12
13 /************** VEILING STUFF *****************/
14
15 #define VADAPT 0.08 /* fraction of adaptation from veil */
16
17 extern COLOR *fovimg; /* foveal (1 degree) averaged image */
18 extern short fvxr, fvyr; /* foveal image resolution */
19
20 #define fovscan(y) (fovimg+(y)*fvxr)
21
22 static COLOR *veilimg; /* veiling image */
23
24 #define veilscan(y) (veilimg+(y)*fvxr)
25
26 static float (*raydir)[3] = NULL; /* ray direction for each pixel */
27
28 #define rdirscan(y) (raydir+(y)*fvxr)
29
30
31 compraydir() /* compute ray directions */
32 {
33 FVECT rorg, rdir;
34 double h, v;
35 register int x, y;
36
37 if (raydir != NULL) /* already done? */
38 return;
39 raydir = (float (*)[3])malloc(fvxr*fvyr*3*sizeof(float));
40 if (raydir == NULL)
41 syserror("malloc");
42
43 for (y = 0; y < fvyr; y++) {
44 switch (inpres.or) {
45 case YMAJOR: case YMAJOR|XDECR:
46 v = (y+.5)/fvyr; break;
47 case YMAJOR|YDECR: case YMAJOR|YDECR|XDECR:
48 v = 1. - (y+.5)/fvyr; break;
49 case 0: case YDECR:
50 h = (y+.5)/fvyr; break;
51 case XDECR: case XDECR|YDECR:
52 h = 1. - (y+.5)/fvyr; break;
53 }
54 for (x = 0; x < fvxr; x++) {
55 switch (inpres.or) {
56 case YMAJOR: case YMAJOR|YDECR:
57 h = (x+.5)/fvxr; break;
58 case YMAJOR|XDECR: case YMAJOR|XDECR|YDECR:
59 h = 1. - (x+.5)/fvxr; break;
60 case 0: case XDECR:
61 v = (x+.5)/fvxr; break;
62 case YDECR: case YDECR|XDECR:
63 v = 1. - (x+.5)/fvxr; break;
64 }
65 if (viewray(rorg, rdir, &ourview, h, v)
66 >= -FTINY) {
67 rdirscan(y)[x][0] = rdir[0];
68 rdirscan(y)[x][1] = rdir[1];
69 rdirscan(y)[x][2] = rdir[2];
70 } else {
71 rdirscan(y)[x][0] =
72 rdirscan(y)[x][1] =
73 rdirscan(y)[x][2] = 0.0;
74 }
75 }
76 }
77 }
78
79
80 compveil() /* compute veiling image */
81 {
82 double t2, t2sum;
83 COLOR ctmp, vsum;
84 int px, py;
85 register int x, y;
86 /* compute ray directions */
87 compraydir();
88 /* compute veil image */
89 veilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR));
90 if (veilimg == NULL)
91 syserror("malloc");
92 for (py = 0; py < fvyr; py++)
93 for (px = 0; px < fvxr; px++) {
94 t2sum = 0.;
95 setcolor(vsum, 0., 0., 0.);
96 for (y = 0; y < fvyr; y++)
97 for (x = 0; x < fvxr; x++) {
98 if (x == px && y == py) continue;
99 t2 = DOT(rdirscan(py)[px],
100 rdirscan(y)[x]);
101 if (t2 <= FTINY) continue;
102 /* use approximation instead
103 t2 = acos(t2);
104 t2 = 1./(t2*t2);
105 */
106 t2 = .5 / (1. - t2);
107 copycolor(ctmp, fovscan(y)[x]);
108 scalecolor(ctmp, t2);
109 addcolor(vsum, ctmp);
110 t2sum += t2;
111 }
112 /* VADAPT of original is subtracted in addveil() */
113 scalecolor(vsum, VADAPT/t2sum);
114 copycolor(veilscan(py)[px], vsum);
115 }
116 }
117
118
119 addveil(sl, y) /* add veil to scanline */
120 COLOR *sl;
121 int y;
122 {
123 int vx, vy;
124 double dx, dy;
125 double lv, uv;
126 register int x, i;
127
128 vy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
129 if (vy >= fvyr-1) vy--;
130 dy -= (double)vy;
131 for (x = 0; x < scanlen(&inpres); x++) {
132 vx = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
133 if (vx >= fvxr-1) vx--;
134 dx -= (double)vx;
135 for (i = 0; i < 3; i++) {
136 lv = (1.-dy)*colval(veilscan(vy)[vx],i) +
137 dy*colval(veilscan(vy+1)[vx],i);
138 uv = (1.-dy)*colval(veilscan(vy)[vx+1],i) +
139 dy*colval(veilscan(vy+1)[vx+1],i);
140 colval(sl[x],i) = (1.-VADAPT)*colval(sl[x],i) +
141 (1.-dx)*lv + dx*uv;
142 }
143 }
144 }
145
146
147 /****************** ACUITY STUFF *******************/
148
149 typedef struct scanbar {
150 short sampr; /* sample area size (power of 2) */
151 short nscans; /* number of scanlines in this bar */
152 int len; /* individual scanline length */
153 struct scanbar *next; /* next higher resolution scanbar */
154 int nread; /* number of scanlines loaded */
155 /* followed by the scanline data */
156 } SCANBAR;
157
158 #define bscan(sb,y) ((COLOR *)((sb)+1)+((y)%(sb)->nscans)*(sb)->len)
159
160 SCANBAR *rootbar; /* root scan bar (lowest resolution) */
161
162 float *inpacuD; /* input acuity data (cycles/degree) */
163
164 #define tsampr(x,y) inpacuD[(y)*fvxr+(x)]
165
166
167 double
168 hacuity(La) /* return visual acuity in cycles/degree */
169 double La;
170 { /* data due to S. Shaler (we should fit it!) */
171 #define NPOINTS 20
172 static float l10lum[NPOINTS] = {
173 -3.10503,-2.66403,-2.37703,-2.09303,-1.64403,-1.35803,
174 -1.07403,-0.67203,-0.38503,-0.10103,0.29397,0.58097,0.86497,
175 1.25697,1.54397,1.82797,2.27597,2.56297,2.84697,3.24897
176 };
177 static float resfreq[NPOINTS] = {
178 2.09,3.28,3.79,4.39,6.11,8.83,10.94,18.66,23.88,31.05,37.42,
179 37.68,41.60,43.16,45.30,47.00,48.43,48.32,51.06,51.09
180 };
181 double l10La;
182 register int i;
183 /* check limits */
184 if (La <= 7.85e-4)
185 return(resfreq[0]);
186 if (La >= 1.78e3)
187 return(resfreq[NPOINTS-1]);
188 /* interpolate data */
189 l10La = log10(La);
190 for (i = 0; i < NPOINTS-2 && l10lum[i+1] <= l10La; i++)
191 ;
192 return( ( (l10lum[i+1] - l10La)*resfreq[i] +
193 (l10La - l10lum[i])*resfreq[i+1] ) /
194 (l10lum[i+1] - l10lum[i]) );
195 #undef NPOINTS
196 }
197
198
199 COLOR *
200 getascan(sb, y) /* find/read scanline y for scanbar sb */
201 register SCANBAR *sb;
202 int y;
203 {
204 register COLOR *sl0, *sl1, *mysl;
205 register int i;
206
207 if (y < sb->nread - sb->nscans) /* too far back? */
208 return(NULL);
209 for ( ; y >= sb->nread; sb->nread++) { /* read as necessary */
210 mysl = bscan(sb, sb->nread);
211 if (sb->sampr == 1) {
212 if (freadscan(mysl, sb->len, infp) < 0) {
213 fprintf(stderr, "%s: %s: scanline read error\n",
214 progname, infn);
215 exit(1);
216 }
217 } else {
218 sl0 = getascan(sb->next, 2*y);
219 if (sl0 == NULL)
220 return(NULL);
221 sl1 = getascan(sb->next, 2*y+1);
222 for (i = 0; i < sb->len; i++) {
223 copycolor(mysl[i], sl0[2*i]);
224 addcolor(mysl[i], sl0[2*i+1]);
225 addcolor(mysl[i], sl1[2*i]);
226 addcolor(mysl[i], sl1[2*i+1]);
227 scalecolor(mysl[i], 0.25);
228 }
229 }
230 }
231 return(bscan(sb, y));
232 }
233
234
235 acuscan(scln, y) /* get acuity-sampled scanline */
236 COLOR *scln;
237 int y;
238 {
239 double sr;
240 double dx, dy;
241 int ix, iy;
242 register int x;
243 /* compute foveal y position */
244 iy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
245 if (iy >= fvyr-1) iy--;
246 dy -= (double)iy;
247 for (x = 0; x < scanlen(&inpres); x++) {
248 /* compute foveal x position */
249 ix = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
250 if (ix >= fvxr-1) ix--;
251 dx -= (double)ix;
252 /* interpolate sample rate */
253 sr = (1.-dy)*((1.-dx)*tsampr(ix,iy) + dx*tsampr(ix+1,iy)) +
254 dy*((1.-dx)*tsampr(ix,iy+1) + dx*tsampr(ix+1,iy+1));
255
256 acusample(scln[x], x, y, sr); /* compute sample */
257 }
258 }
259
260
261 acusample(col, x, y, sr) /* interpolate sample at (x,y) using rate sr */
262 COLOR col;
263 int x, y;
264 double sr;
265 {
266 COLOR c1;
267 double d;
268 register SCANBAR *sb0;
269
270 for (sb0 = rootbar; sb0->next != NULL && sb0->next->sampr > sr;
271 sb0 = sb0->next)
272 ;
273 ascanval(col, x, y, sb0);
274 if (sb0->next == NULL) /* don't extrapolate highest */
275 return;
276 ascanval(c1, x, y, sb0->next);
277 d = (sb0->sampr - sr)/(sb0->sampr - sb0->next->sampr);
278 scalecolor(col, 1.-d);
279 scalecolor(c1, d);
280 addcolor(col, c1);
281 }
282
283
284 ascanval(col, x, y, sb) /* interpolate scanbar at orig. coords (x,y) */
285 COLOR col;
286 int x, y;
287 SCANBAR *sb;
288 {
289 COLOR *sl0, *sl1, c1, c1y;
290 double dx, dy;
291 int ix, iy;
292
293 if (sb->sampr == 1) { /* no need to interpolate */
294 sl0 = getascan(sb, y);
295 copycolor(col, sl0[x]);
296 return;
297 }
298 /* compute coordinates for sb */
299 ix = dx = (x+.5)/sb->sampr - .5;
300 if (ix >= sb->len-1) ix--;
301 dx -= (double)ix;
302 iy = dy = (y+.5)/sb->sampr - .5;
303 if (iy >= numscans(&inpres)/sb->sampr-1) iy--;
304 dy -= (double)iy;
305 /* get scanlines */
306 sl0 = getascan(sb, iy);
307 if (sl0 == NULL) {
308 fprintf(stderr, "%s: internal - cannot backspace in ascanval\n",
309 progname);
310 exit(1);
311 }
312 sl1 = getascan(sb, iy+1);
313 /* 2D linear interpolation */
314 copycolor(col, sl0[ix]);
315 scalecolor(col, 1.-dx);
316 copycolor(c1, sl0[ix+1]);
317 scalecolor(c1, dx);
318 addcolor(col, c1);
319 copycolor(c1y, sl1[ix]);
320 scalecolor(c1y, 1.-dx);
321 copycolor(c1, sl1[ix+1]);
322 scalecolor(c1, dx);
323 addcolor(c1y, c1);
324 scalecolor(col, 1.-dy);
325 scalecolor(c1y, dy);
326 addcolor(col, c1y);
327 }
328
329
330 SCANBAR *
331 sballoc(sr, ns, sl) /* allocate scanbar */
332 int sr; /* sampling rate */
333 int ns; /* number of scanlines */
334 int sl; /* original scanline length */
335 {
336 register SCANBAR *sb;
337
338 sb = (SCANBAR *)malloc(sizeof(SCANBAR)+(sl/sr)*ns*sizeof(COLOR));
339 if (sb == NULL)
340 syserror("malloc");
341 sb->nscans = ns;
342 sb->len = sl/sr;
343 sb->nread = 0;
344 if ((sb->sampr = sr) > 1)
345 sb->next = sballoc(sr/2, ns*2, sl);
346 else
347 sb->next = NULL;
348 return(sb);
349 }
350
351
352 initacuity() /* initialize variable acuity sampling */
353 {
354 FVECT diffx, diffy, cp;
355 double omega, maxsr;
356 register int x, y, i;
357
358 compraydir(); /* compute ray directions */
359
360 inpacuD = (float *)malloc(fvxr*fvyr*sizeof(float));
361 if (inpacuD == NULL)
362 syserror("malloc");
363 maxsr = 1.; /* compute internal sample rates */
364 for (y = 1; y < fvyr-1; y++)
365 for (x = 1; x < fvxr-1; x++) {
366 for (i = 0; i < 3; i++) {
367 diffx[i] = 0.5*fvxr/scanlen(&inpres) *
368 (rdirscan(y)[x+1][i] -
369 rdirscan(y)[x-1][i]);
370 diffy[i] = 0.5*fvyr/numscans(&inpres) *
371 (rdirscan(y+1)[x][i] -
372 rdirscan(y-1)[x][i]);
373 }
374 fcross(cp, diffx, diffy);
375 omega = 0.5 * sqrt(DOT(cp,cp));
376 if (omega <= FTINY)
377 tsampr(x,y) = 1.;
378 else if ((tsampr(x,y) = PI/180. / sqrt(omega) /
379 hacuity(plum(fovscan(y)[x]))) > maxsr)
380 maxsr = tsampr(x,y);
381 }
382 /* copy perimeter (easier) */
383 for (x = 1; x < fvxr-1; x++) {
384 tsampr(x,0) = tsampr(x,1);
385 tsampr(x,fvyr-1) = tsampr(x,fvyr-2);
386 }
387 for (y = 0; y < fvyr; y++) {
388 tsampr(y,0) = tsampr(y,1);
389 tsampr(y,fvxr-1) = tsampr(y,fvxr-2);
390 }
391 /* initialize with next power of two */
392 rootbar = sballoc(2<<(int)(log(maxsr)/log(2.)), 2, scanlen(&inpres));
393 }
