root/radiance/ray/src/px/pcond4.c
Revision: 3.11
Committed: Thu Jan 9 13:56:32 1997 UTC (27 years, 3 months ago) by greg
Changes since 3.10: +11 -6 lines
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines for veiling glare and loss of acuity.
9 */
10
11 #include "pcond.h"
12
13 /************** VEILING STUFF *****************/
14
15 #define VADAPT 0.08 /* fraction of adaptation from veil */
16
17 static COLOR *veilimg = NULL; /* veiling image */
18
19 #define veilscan(y) (veilimg+(y)*fvxr)
20
21 static float (*raydir)[3] = NULL; /* ray direction for each pixel */
22
23 #define rdirscan(y) (raydir+(y)*fvxr)
24
25
26 compraydir() /* compute ray directions */
27 {
28 FVECT rorg, rdir;
29 double h, v;
30 register int x, y;
31
32 if (raydir != NULL) /* already done? */
33 return;
34 raydir = (float (*)[3])malloc(fvxr*fvyr*3*sizeof(float));
35 if (raydir == NULL)
36 syserror("malloc");
37
38 for (y = 0; y < fvyr; y++) {
39 switch (inpres.or) {
40 case YMAJOR: case YMAJOR|XDECR:
41 v = (y+.5)/fvyr; break;
42 case YMAJOR|YDECR: case YMAJOR|YDECR|XDECR:
43 v = 1. - (y+.5)/fvyr; break;
44 case 0: case YDECR:
45 h = (y+.5)/fvyr; break;
46 case XDECR: case XDECR|YDECR:
47 h = 1. - (y+.5)/fvyr; break;
48 }
49 for (x = 0; x < fvxr; x++) {
50 switch (inpres.or) {
51 case YMAJOR: case YMAJOR|YDECR:
52 h = (x+.5)/fvxr; break;
53 case YMAJOR|XDECR: case YMAJOR|XDECR|YDECR:
54 h = 1. - (x+.5)/fvxr; break;
55 case 0: case XDECR:
56 v = (x+.5)/fvxr; break;
57 case YDECR: case YDECR|XDECR:
58 v = 1. - (x+.5)/fvxr; break;
59 }
60 if (viewray(rorg, rdir, &ourview, h, v)
61 >= -FTINY) {
62 rdirscan(y)[x][0] = rdir[0];
63 rdirscan(y)[x][1] = rdir[1];
64 rdirscan(y)[x][2] = rdir[2];
65 } else {
66 rdirscan(y)[x][0] =
67 rdirscan(y)[x][1] =
68 rdirscan(y)[x][2] = 0.0;
69 }
70 }
71 }
72 }
73
74
75 compveil() /* compute veiling image */
76 {
77 double t2, t2sum;
78 COLOR ctmp, vsum;
79 int px, py;
80 register int x, y;
81
82 if (veilimg != NULL) /* already done? */
83 return;
84 /* compute ray directions */
85 compraydir();
86 /* compute veil image */
87 veilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR));
88 if (veilimg == NULL)
89 syserror("malloc");
90 for (py = 0; py < fvyr; py++)
91 for (px = 0; px < fvxr; px++) {
92 t2sum = 0.;
93 setcolor(vsum, 0., 0., 0.);
94 for (y = 0; y < fvyr; y++)
95 for (x = 0; x < fvxr; x++) {
96 if (x == px && y == py) continue;
97 t2 = DOT(rdirscan(py)[px],
98 rdirscan(y)[x]);
99 if (t2 <= FTINY) continue;
100 /* use approximation instead
101 t2 = acos(t2);
102 t2 = 1./(t2*t2);
103 */
104 t2 = .5 / (1. - t2);
105 copycolor(ctmp, fovscan(y)[x]);
106 scalecolor(ctmp, t2);
107 addcolor(vsum, ctmp);
108 t2sum += t2;
109 }
110 /* VADAPT of original is subtracted in addveil() */
111 scalecolor(vsum, VADAPT/t2sum);
112 copycolor(veilscan(py)[px], vsum);
113 }
114 /* modify FOV sample image */
115 for (y = 0; y < fvyr; y++)
116 for (x = 0; x < fvxr; x++) {
117 scalecolor(fovscan(y)[x], 1.-VADAPT);
118 addcolor(fovscan(y)[x], veilscan(y)[x]);
119 }
120 comphist(); /* recompute histogram */
121 }
122
123
124 addveil(sl, y) /* add veil to scanline */
125 COLOR *sl;
126 int y;
127 {
128 int vx, vy;
129 double dx, dy;
130 double lv, uv;
131 register int x, i;
132
133 vy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
134 while (vy >= fvyr-1) vy--;
135 dy -= (double)vy;
136 for (x = 0; x < scanlen(&inpres); x++) {
137 vx = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
138 while (vx >= fvxr-1) vx--;
139 dx -= (double)vx;
140 for (i = 0; i < 3; i++) {
141 lv = (1.-dy)*colval(veilscan(vy)[vx],i) +
142 dy*colval(veilscan(vy+1)[vx],i);
143 uv = (1.-dy)*colval(veilscan(vy)[vx+1],i) +
144 dy*colval(veilscan(vy+1)[vx+1],i);
145 colval(sl[x],i) = (1.-VADAPT)*colval(sl[x],i) +
146 (1.-dx)*lv + dx*uv;
147 }
148 }
149 }
150
151
152 /****************** ACUITY STUFF *******************/
153
154 typedef struct {
155 short sampe; /* sample area size (exponent of 2) */
156 short nscans; /* number of scanlines in this bar */
157 int len; /* individual scanline length */
158 int nread; /* number of scanlines loaded */
159 COLOR *sdata; /* scanbar data */
160 } SCANBAR;
161
162 #define bscan(sb,y) ((COLOR *)(sb)->sdata+((y)%(sb)->nscans)*(sb)->len)
163
164 SCANBAR *rootbar; /* root scan bar (lowest resolution) */
165
166 float *inpacuD; /* input acuity data (cycles/degree) */
167
168 #define tsampr(x,y) inpacuD[(y)*fvxr+(x)]
169
170
171 double
172 hacuity(La) /* return visual acuity in cycles/degree */
173 double La;
174 { /* data due to S. Shaler (we should fit it!) */
175 #define NPOINTS 20
176 static float l10lum[NPOINTS] = {
177 -3.10503,-2.66403,-2.37703,-2.09303,-1.64403,-1.35803,
178 -1.07403,-0.67203,-0.38503,-0.10103,0.29397,0.58097,0.86497,
179 1.25697,1.54397,1.82797,2.27597,2.56297,2.84697,3.24897
180 };
181 static float resfreq[NPOINTS] = {
182 2.09,3.28,3.79,4.39,6.11,8.83,10.94,18.66,23.88,31.05,37.42,
183 37.68,41.60,43.16,45.30,47.00,48.43,48.32,51.06,51.09
184 };
185 double l10La;
186 register int i;
187 /* check limits */
188 if (La <= 7.85e-4)
189 return(resfreq[0]);
190 if (La >= 1.78e3)
191 return(resfreq[NPOINTS-1]);
192 /* interpolate data */
193 l10La = log10(La);
194 for (i = 0; i < NPOINTS-2 && l10lum[i+1] <= l10La; i++)
195 ;
196 return( ( (l10lum[i+1] - l10La)*resfreq[i] +
197 (l10La - l10lum[i])*resfreq[i+1] ) /
198 (l10lum[i+1] - l10lum[i]) );
199 #undef NPOINTS
200 }
201
202
203 COLOR *
204 getascan(sb, y) /* find/read scanline y for scanbar sb */
205 register SCANBAR *sb;
206 int y;
207 {
208 register COLOR *sl0, *sl1, *mysl;
209 register int i;
210
211 if (y < sb->nread - sb->nscans) /* too far back? */
212 return(NULL);
213 for ( ; y >= sb->nread; sb->nread++) { /* read as necessary */
214 mysl = bscan(sb, sb->nread);
215 if (sb->sampe == 0) {
216 if (freadscan(mysl, sb->len, infp) < 0) {
217 fprintf(stderr, "%s: %s: scanline read error\n",
218 progname, infn);
219 exit(1);
220 }
221 } else {
222 sl0 = getascan(sb+1, 2*y);
223 if (sl0 == NULL)
224 return(NULL);
225 sl1 = getascan(sb+1, 2*y+1);
226 for (i = 0; i < sb->len; i++) {
227 copycolor(mysl[i], sl0[2*i]);
228 addcolor(mysl[i], sl0[2*i+1]);
229 addcolor(mysl[i], sl1[2*i]);
230 addcolor(mysl[i], sl1[2*i+1]);
231 scalecolor(mysl[i], 0.25);
232 }
233 }
234 }
235 return(bscan(sb, y));
236 }
237
238
239 acuscan(scln, y) /* get acuity-sampled scanline */
240 COLOR *scln;
241 int y;
242 {
243 double sr;
244 double dx, dy;
245 int ix, iy;
246 register int x;
247 /* compute foveal y position */
248 iy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
249 while (iy >= fvyr-1) iy--;
250 dy -= (double)iy;
251 for (x = 0; x < scanlen(&inpres); x++) {
252 /* compute foveal x position */
253 ix = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
254 while (ix >= fvxr-1) ix--;
255 dx -= (double)ix;
256 /* interpolate sample rate */
257 sr = (1.-dy)*((1.-dx)*tsampr(ix,iy) + dx*tsampr(ix+1,iy)) +
258 dy*((1.-dx)*tsampr(ix,iy+1) + dx*tsampr(ix+1,iy+1));
259
260 acusample(scln[x], x, y, sr); /* compute sample */
261 }
262 }
263
264
265 acusample(col, x, y, sr) /* interpolate sample at (x,y) using rate sr */
266 COLOR col;
267 int x, y;
268 double sr;
269 {
270 COLOR c1;
271 double d;
272 register SCANBAR *sb0;
273
274 for (sb0 = rootbar; sb0->sampe != 0 && 1<<sb0[1].sampe > sr; sb0++)
275 ;
276 ascanval(col, x, y, sb0);
277 if (sb0->sampe == 0) /* don't extrapolate highest */
278 return;
279 ascanval(c1, x, y, sb0+1);
280 d = ((1<<sb0->sampe) - sr)/(1<<sb0[1].sampe);
281 scalecolor(col, 1.-d);
282 scalecolor(c1, d);
283 addcolor(col, c1);
284 }
285
286
287 ascanval(col, x, y, sb) /* interpolate scanbar at orig. coords (x,y) */
288 COLOR col;
289 int x, y;
290 SCANBAR *sb;
291 {
292 COLOR *sl0, *sl1, c1, c1y;
293 double dx, dy;
294 int ix, iy;
295
296 if (sb->sampe == 0) { /* no need to interpolate */
297 sl0 = getascan(sb, y);
298 copycolor(col, sl0[x]);
299 return;
300 }
301 /* compute coordinates for sb */
302 ix = dx = (x+.5)/(1<<sb->sampe) - .5;
303 while (ix >= sb->len-1) ix--;
304 dx -= (double)ix;
305 iy = dy = (y+.5)/(1<<sb->sampe) - .5;
306 while (iy >= (numscans(&inpres)>>sb->sampe)-1) iy--;
307 dy -= (double)iy;
308 /* get scanlines */
309 sl0 = getascan(sb, iy);
310 #ifdef DEBUG
311 if (sl0 == NULL) {
312 fprintf(stderr, "%s: internal - cannot backspace in ascanval\n",
313 progname);
314 abort();
315 }
316 #endif
317 sl1 = getascan(sb, iy+1);
318 /* 2D linear interpolation */
319 copycolor(col, sl0[ix]);
320 scalecolor(col, 1.-dx);
321 copycolor(c1, sl0[ix+1]);
322 scalecolor(c1, dx);
323 addcolor(col, c1);
324 copycolor(c1y, sl1[ix]);
325 scalecolor(c1y, 1.-dx);
326 copycolor(c1, sl1[ix+1]);
327 scalecolor(c1, dx);
328 addcolor(c1y, c1);
329 scalecolor(col, 1.-dy);
330 scalecolor(c1y, dy);
331 addcolor(col, c1y);
332 for (ix = 0; ix < 3; ix++) /* make sure no negative */
333 if (colval(col,ix) < 0.)
334 colval(col,ix) = 0.;
335 }
336
337
338 SCANBAR *
339 sballoc(se, ns, sl) /* allocate scanbar */
340 int se; /* sampling rate exponent */
341 int ns; /* number of scanlines */
342 int sl; /* original scanline length */
343 {
344 SCANBAR *sbarr;
345 register SCANBAR *sb;
346
347 sbarr = sb = (SCANBAR *)malloc((se+1)*sizeof(SCANBAR));
348 if (sb == NULL)
349 syserror("malloc");
350 do {
351 sb->sampe = se;
352 sb->len = sl>>se;
353 sb->nscans = ns;
354 sb->sdata = (COLOR *)malloc(sb->len*ns*sizeof(COLOR));
355 if (sb->sdata == NULL)
356 syserror("malloc");
357 sb->nread = 0;
358 ns <<= 1;
359 sb++;
360 } while (--se >= 0);
361 return(sbarr);
362 }
363
364
365 initacuity() /* initialize variable acuity sampling */
366 {
367 FVECT diffx, diffy, cp;
368 double omega, maxsr;
369 register int x, y, i;
370
371 compraydir(); /* compute ray directions */
372
373 inpacuD = (float *)malloc(fvxr*fvyr*sizeof(float));
374 if (inpacuD == NULL)
375 syserror("malloc");
376 maxsr = 1.; /* compute internal sample rates */
377 for (y = 1; y < fvyr-1; y++)
378 for (x = 1; x < fvxr-1; x++) {
379 for (i = 0; i < 3; i++) {
380 diffx[i] = 0.5*fvxr/scanlen(&inpres) *
381 (rdirscan(y)[x+1][i] -
382 rdirscan(y)[x-1][i]);
383 diffy[i] = 0.5*fvyr/numscans(&inpres) *
384 (rdirscan(y+1)[x][i] -
385 rdirscan(y-1)[x][i]);
386 }
387 fcross(cp, diffx, diffy);
388 omega = 0.5 * sqrt(DOT(cp,cp));
389 if (omega <= FTINY*FTINY)
390 tsampr(x,y) = 1.;
391 else if ((tsampr(x,y) = PI/180. / sqrt(omega) /
392 hacuity(plum(fovscan(y)[x]))) > maxsr)
393 maxsr = tsampr(x,y);
394 }
395 /* copy perimeter (easier) */
396 for (x = 1; x < fvxr-1; x++) {
397 tsampr(x,0) = tsampr(x,1);
398 tsampr(x,fvyr-1) = tsampr(x,fvyr-2);
399 }
400 for (y = 0; y < fvyr; y++) {
401 tsampr(0,y) = tsampr(1,y);
402 tsampr(fvxr-1,y) = tsampr(fvxr-2,y);
403 }
404 /* initialize with next power of two */
405 rootbar = sballoc((int)(log(maxsr)/log(2.))+1, 2, scanlen(&inpres));
406 }
