root/radiance/ray/src/px/pcond4.c
Revision: 3.19
Committed: Sun Nov 14 16:57:18 2004 UTC (20 years, 5 months ago) by greg
CVS Tags: rad4R2P2, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1
Changes since 3.18: +2 -6 lines
# User Rev Content
1 greg 3.1 #ifndef lint
2 greg 3.19 static const char RCSid[] = "$Id: pcond4.c,v 3.18 2004/11/08 15:50:59 greg Exp $";
3 greg 3.1 #endif
4     /*
5     * Routines for veiling glare and loss of acuity.
6     */
7
8     #include "pcond.h"
9
10 greg 3.3 /************** VEILING STUFF *****************/
11 greg 3.1
12     #define VADAPT 0.08 /* fraction of adaptation from veil */
13
14 greg 3.11 static COLOR *veilimg = NULL; /* veiling image */
15 greg 3.1
16     #define veilscan(y) (veilimg+(y)*fvxr)
17
18 greg 3.2 static float (*raydir)[3] = NULL; /* ray direction for each pixel */
19 greg 3.1
20     #define rdirscan(y) (raydir+(y)*fvxr)
21
22 schorsch 3.17 static void compraydir(void);
23     #if ADJ_VEIL
24     static void smoothveil(void);
25     #endif
26 greg 3.1
27 schorsch 3.17
28     static void
29     compraydir(void) /* compute ray directions */
30 greg 3.1 {
31 greg 3.2 FVECT rorg, rdir;
32 greg 3.1 double h, v;
33     register int x, y;
34
35     if (raydir != NULL) /* already done? */
36     return;
37 greg 3.2 raydir = (float (*)[3])malloc(fvxr*fvyr*3*sizeof(float));
38 greg 3.1 if (raydir == NULL)
39     syserror("malloc");
40
41     for (y = 0; y < fvyr; y++) {
42 greg 3.16 switch (inpres.rt) {
43 greg 3.1 case YMAJOR: case YMAJOR|XDECR:
44     v = (y+.5)/fvyr; break;
45     case YMAJOR|YDECR: case YMAJOR|YDECR|XDECR:
46     v = 1. - (y+.5)/fvyr; break;
47     case 0: case YDECR:
48     h = (y+.5)/fvyr; break;
49     case XDECR: case XDECR|YDECR:
50     h = 1. - (y+.5)/fvyr; break;
51     }
52     for (x = 0; x < fvxr; x++) {
53 greg 3.16 switch (inpres.rt) {
54 greg 3.1 case YMAJOR: case YMAJOR|YDECR:
55     h = (x+.5)/fvxr; break;
56     case YMAJOR|XDECR: case YMAJOR|XDECR|YDECR:
57     h = 1. - (x+.5)/fvxr; break;
58     case 0: case XDECR:
59     v = (x+.5)/fvxr; break;
60     case YDECR: case YDECR|XDECR:
61     v = 1. - (x+.5)/fvxr; break;
62     }
63 greg 3.2 if (viewray(rorg, rdir, &ourview, h, v)
64     >= -FTINY) {
65     rdirscan(y)[x][0] = rdir[0];
66     rdirscan(y)[x][1] = rdir[1];
67     rdirscan(y)[x][2] = rdir[2];
68     } else {
69 greg 3.1 rdirscan(y)[x][0] =
70     rdirscan(y)[x][1] =
71     rdirscan(y)[x][2] = 0.0;
72     }
73     }
74     }
75     }
76
77
78 schorsch 3.17 extern void
79     compveil(void) /* compute veiling image */
80 greg 3.1 {
81     double t2, t2sum;
82     COLOR ctmp, vsum;
83     int px, py;
84     register int x, y;
85 greg 3.11
86     if (veilimg != NULL) /* already done? */
87     return;
88 greg 3.1 /* compute ray directions */
89     compraydir();
90     /* compute veil image */
91     veilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR));
92     if (veilimg == NULL)
93     syserror("malloc");
94     for (py = 0; py < fvyr; py++)
95     for (px = 0; px < fvxr; px++) {
96     t2sum = 0.;
97     setcolor(vsum, 0., 0., 0.);
98     for (y = 0; y < fvyr; y++)
99     for (x = 0; x < fvxr; x++) {
100     if (x == px && y == py) continue;
101     t2 = DOT(rdirscan(py)[px],
102     rdirscan(y)[x]);
103     if (t2 <= FTINY) continue;
104 greg 3.4 /* use approximation instead
105 greg 3.12 t3 = acos(t2);
106     t2 = t2/(t3*t3);
107 greg 3.4 */
108 greg 3.12 t2 *= .5 / (1. - t2);
109 greg 3.1 copycolor(ctmp, fovscan(y)[x]);
110     scalecolor(ctmp, t2);
111     addcolor(vsum, ctmp);
112     t2sum += t2;
113     }
114     /* VADAPT of original is subtracted in addveil() */
115 gregl 3.15 if (t2sum > FTINY)
116     scalecolor(vsum, VADAPT/t2sum);
117 greg 3.1 copycolor(veilscan(py)[px], vsum);
118     }
119 greg 3.11 /* modify FOV sample image */
120     for (y = 0; y < fvyr; y++)
121     for (x = 0; x < fvxr; x++) {
122     scalecolor(fovscan(y)[x], 1.-VADAPT);
123     addcolor(fovscan(y)[x], veilscan(y)[x]);
124     }
125     comphist(); /* recompute histogram */
126 greg 3.1 }
127
128
129 greg 3.16 #if ADJ_VEIL
130     /*
131     * The following veil adjustment was added to compensate for
132     * the fact that contrast reduction gets confused with veil
133     * in the human visual system. Therefore, we reduce the
134     * veil in portions of the image where our mapping has
135     * already reduced contrast below the target value.
136     * This gets called after the intial veil has been computed
137     * and added to the foveal image, and the mapping has been
138     * determined.
139     */
140 schorsch 3.17 extern void
141     adjveil(void) /* adjust veil image */
142 greg 3.16 {
143     float *crfptr = crfimg;
144     COLOR *fovptr = fovimg;
145     COLOR *veilptr = veilimg;
146     double s2nits = 1./inpexp;
147     double vl, vl2, fovl, vlsum;
148     double deltavc[3];
149     int i, j;
150
151     if (lumf == rgblum)
152     s2nits *= WHTEFFICACY;
153
154     for (i = fvxr*fvyr; i--; crfptr++, fovptr++, veilptr++) {
155     if (crfptr[0] >= 0.95)
156     continue;
157     vl = plum(veilptr[0]);
158     fovl = (plum(fovptr[0]) - vl) * (1./(1.-VADAPT));
159     if (vl <= 0.05*fovl)
160     continue;
161     vlsum = vl;
162     for (j = 2; j < 11; j++) {
163     vlsum += crfptr[0]*vl - (1.0 - crfptr[0])*fovl;
164     vl2 = vlsum / (double)j;
165     if (vl2 < 0.0)
166     vl2 = 0.0;
167     crfptr[0] = crfactor(fovl + vl2);
168     }
169     /* desaturation code causes color fringes at this level */
170     for (j = 3; j--; ) {
171     double vc = colval(veilptr[0],j);
172     double fovc = (colval(fovptr[0],j) - vc) *
173     (1./(1.-VADAPT));
174     deltavc[j] = (1.-crfptr[0])*(fovl/s2nits - fovc);
175     if (vc + deltavc[j] < 0.0)
176     break;
177     }
178     if (j < 0)
179     addcolor(veilptr[0], deltavc);
180     else
181     scalecolor(veilptr[0], vl2/vl);
182     }
183     smoothveil(); /* smooth our result */
184     }
185
186
187 schorsch 3.17 static void
188     smoothveil(void) /* smooth veil image */
189 greg 3.16 {
190     COLOR *nveilimg;
191     COLOR *ovptr, *nvptr;
192     int x, y, i;
193
194     nveilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR));
195     if (nveilimg == NULL)
196     return;
197     for (y = 1; y < fvyr-1; y++) {
198     ovptr = veilimg + y*fvxr + 1;
199     nvptr = nveilimg + y*fvxr + 1;
200     for (x = 1; x < fvxr-1; x++, ovptr++, nvptr++)
201     for (i = 3; i--; )
202     nvptr[0][i] = 0.5 * ovptr[0][i]
203     + (1./12.) *
204     (ovptr[-1][i] + ovptr[-fvxr][i] +
205     ovptr[1][i] + ovptr[fvxr][i])
206     + (1./24.) *
207     (ovptr[-fvxr-1][i] + ovptr[-fvxr+1][i] +
208     ovptr[fvxr-1][i] + ovptr[fvxr+1][i]);
209     }
210     ovptr = veilimg + 1;
211     nvptr = nveilimg + 1;
212     for (x = 1; x < fvxr-1; x++, ovptr++, nvptr++)
213     for (i = 3; i--; )
214     nvptr[0][i] = 0.5 * ovptr[0][i]
215     + (1./9.) *
216     (ovptr[-1][i] + ovptr[1][i] + ovptr[fvxr][i])
217     + (1./12.) *
218     (ovptr[fvxr-1][i] + ovptr[fvxr+1][i]);
219     ovptr = veilimg + (fvyr-1)*fvxr + 1;
220     nvptr = nveilimg + (fvyr-1)*fvxr + 1;
221     for (x = 1; x < fvxr-1; x++, ovptr++, nvptr++)
222     for (i = 3; i--; )
223     nvptr[0][i] = 0.5 * ovptr[0][i]
224     + (1./9.) *
225     (ovptr[-1][i] + ovptr[1][i] + ovptr[-fvxr][i])
226     + (1./12.) *
227     (ovptr[-fvxr-1][i] + ovptr[-fvxr+1][i]);
228     ovptr = veilimg + fvxr;
229     nvptr = nveilimg + fvxr;
230     for (y = 1; y < fvyr-1; y++, ovptr += fvxr, nvptr += fvxr)
231     for (i = 3; i--; )
232     nvptr[0][i] = 0.5 * ovptr[0][i]
233     + (1./9.) *
234     (ovptr[-fvxr][i] + ovptr[1][i] + ovptr[fvxr][i])
235     + (1./12.) *
236     (ovptr[-fvxr+1][i] + ovptr[fvxr+1][i]);
237     ovptr = veilimg + fvxr - 1;
238     nvptr = nveilimg + fvxr - 1;
239     for (y = 1; y < fvyr-1; y++, ovptr += fvxr, nvptr += fvxr)
240     for (i = 3; i--; )
241     nvptr[0][i] = 0.5 * ovptr[0][i]
242     + (1./9.) *
243     (ovptr[-fvxr][i] + ovptr[-1][i] + ovptr[fvxr][i])
244     + (1./12.) *
245     (ovptr[-fvxr-1][i] + ovptr[fvxr-1][i]);
246     for (i = 3; i--; ) {
247     nveilimg[0][i] = veilimg[0][i];
248     nveilimg[fvxr-1][i] = veilimg[fvxr-1][i];
249     nveilimg[(fvyr-1)*fvxr][i] = veilimg[(fvyr-1)*fvxr][i];
250     nveilimg[fvyr*fvxr-1][i] = veilimg[fvyr*fvxr-1][i];
251     }
252     free((void *)veilimg);
253     veilimg = nveilimg;
254     }
255     #endif
256
257 schorsch 3.17 extern void
258     addveil( /* add veil to scanline */
259     COLOR *sl,
260     int y
261     )
262 greg 3.1 {
263     int vx, vy;
264     double dx, dy;
265     double lv, uv;
266     register int x, i;
267
268     vy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
269 greg 3.7 while (vy >= fvyr-1) vy--;
270 greg 3.1 dy -= (double)vy;
271     for (x = 0; x < scanlen(&inpres); x++) {
272     vx = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
273 greg 3.7 while (vx >= fvxr-1) vx--;
274 greg 3.1 dx -= (double)vx;
275     for (i = 0; i < 3; i++) {
276     lv = (1.-dy)*colval(veilscan(vy)[vx],i) +
277     dy*colval(veilscan(vy+1)[vx],i);
278     uv = (1.-dy)*colval(veilscan(vy)[vx+1],i) +
279     dy*colval(veilscan(vy+1)[vx+1],i);
280     colval(sl[x],i) = (1.-VADAPT)*colval(sl[x],i) +
281     (1.-dx)*lv + dx*uv;
282     }
283     }
284 greg 3.3 }
285
286
287     /****************** ACUITY STUFF *******************/
288
289 greg 3.8 typedef struct {
290     short sampe; /* sample area size (exponent of 2) */
291 greg 3.3 short nscans; /* number of scanlines in this bar */
292     int len; /* individual scanline length */
293     int nread; /* number of scanlines loaded */
294 greg 3.8 COLOR *sdata; /* scanbar data */
295 greg 3.3 } SCANBAR;
296
297 greg 3.8 #define bscan(sb,y) ((COLOR *)(sb)->sdata+((y)%(sb)->nscans)*(sb)->len)
298 greg 3.3
299     SCANBAR *rootbar; /* root scan bar (lowest resolution) */
300
301 greg 3.18 float *inpacuD = NULL; /* input acuity data (cycles/degree) */
302 greg 3.3
303     #define tsampr(x,y) inpacuD[(y)*fvxr+(x)]
304
305 schorsch 3.17 static COLOR * getascan(SCANBAR *sb, int y);
306     static void acusample(COLOR col, int x, int y, double sr);
307     static void ascanval(COLOR col, int x, int y, SCANBAR *sb);
308     static SCANBAR *sballoc(int se, int ns, int sl);
309
310     extern double
311     hacuity( /* return visual acuity in cycles/degree */
312     double La
313     )
314 greg 3.13 {
315     /* functional fit */
316     return(17.25*atan(1.4*log10(La) + 0.35) + 25.72);
317 greg 3.3 }
318
319
320 schorsch 3.17 static COLOR *
321     getascan( /* find/read scanline y for scanbar sb */
322     register SCANBAR *sb,
323     int y
324     )
325 greg 3.3 {
326     register COLOR *sl0, *sl1, *mysl;
327     register int i;
328
329 greg 3.6 if (y < sb->nread - sb->nscans) /* too far back? */
330     return(NULL);
331 greg 3.3 for ( ; y >= sb->nread; sb->nread++) { /* read as necessary */
332     mysl = bscan(sb, sb->nread);
333 greg 3.8 if (sb->sampe == 0) {
334 greg 3.3 if (freadscan(mysl, sb->len, infp) < 0) {
335     fprintf(stderr, "%s: %s: scanline read error\n",
336     progname, infn);
337     exit(1);
338     }
339     } else {
340 greg 3.8 sl0 = getascan(sb+1, 2*y);
341 greg 3.6 if (sl0 == NULL)
342     return(NULL);
343 greg 3.8 sl1 = getascan(sb+1, 2*y+1);
344 greg 3.3 for (i = 0; i < sb->len; i++) {
345     copycolor(mysl[i], sl0[2*i]);
346     addcolor(mysl[i], sl0[2*i+1]);
347     addcolor(mysl[i], sl1[2*i]);
348     addcolor(mysl[i], sl1[2*i+1]);
349     scalecolor(mysl[i], 0.25);
350     }
351     }
352     }
353     return(bscan(sb, y));
354     }
355
356
357 schorsch 3.17 extern void
358     acuscan( /* get acuity-sampled scanline */
359     COLOR *scln,
360     int y
361     )
362 greg 3.3 {
363     double sr;
364     double dx, dy;
365     int ix, iy;
366     register int x;
367 greg 3.18
368     if (inpacuD == NULL)
369     return;
370 greg 3.3 /* compute foveal y position */
371     iy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
372 greg 3.9 while (iy >= fvyr-1) iy--;
373 greg 3.3 dy -= (double)iy;
374     for (x = 0; x < scanlen(&inpres); x++) {
375     /* compute foveal x position */
376     ix = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
377 greg 3.9 while (ix >= fvxr-1) ix--;
378 greg 3.3 dx -= (double)ix;
379     /* interpolate sample rate */
380     sr = (1.-dy)*((1.-dx)*tsampr(ix,iy) + dx*tsampr(ix+1,iy)) +
381     dy*((1.-dx)*tsampr(ix,iy+1) + dx*tsampr(ix+1,iy+1));
382
383     acusample(scln[x], x, y, sr); /* compute sample */
384     }
385     }
386
387
388 schorsch 3.17 static void
389     acusample( /* interpolate sample at (x,y) using rate sr */
390     COLOR col,
391     int x,
392     int y,
393     double sr
394     )
395 greg 3.3 {
396     COLOR c1;
397     double d;
398     register SCANBAR *sb0;
399
400 greg 3.8 for (sb0 = rootbar; sb0->sampe != 0 && 1<<sb0[1].sampe > sr; sb0++)
401 greg 3.3 ;
402     ascanval(col, x, y, sb0);
403 greg 3.8 if (sb0->sampe == 0) /* don't extrapolate highest */
404 greg 3.3 return;
405 greg 3.8 ascanval(c1, x, y, sb0+1);
406     d = ((1<<sb0->sampe) - sr)/(1<<sb0[1].sampe);
407 greg 3.3 scalecolor(col, 1.-d);
408     scalecolor(c1, d);
409     addcolor(col, c1);
410     }
411
412
413 schorsch 3.17 static void
414     ascanval( /* interpolate scanbar at orig. coords (x,y) */
415     COLOR col,
416     int x,
417     int y,
418     SCANBAR *sb
419     )
420 greg 3.3 {
421     COLOR *sl0, *sl1, c1, c1y;
422     double dx, dy;
423     int ix, iy;
424
425 greg 3.8 if (sb->sampe == 0) { /* no need to interpolate */
426 greg 3.6 sl0 = getascan(sb, y);
427     copycolor(col, sl0[x]);
428     return;
429     }
430     /* compute coordinates for sb */
431 greg 3.8 ix = dx = (x+.5)/(1<<sb->sampe) - .5;
432 greg 3.7 while (ix >= sb->len-1) ix--;
433 greg 3.3 dx -= (double)ix;
434 greg 3.8 iy = dy = (y+.5)/(1<<sb->sampe) - .5;
435     while (iy >= (numscans(&inpres)>>sb->sampe)-1) iy--;
436 greg 3.3 dy -= (double)iy;
437     /* get scanlines */
438     sl0 = getascan(sb, iy);
439 greg 3.9 #ifdef DEBUG
440 greg 3.14 if (sl0 == NULL)
441     error(INTERNAL, "cannot backspace in ascanval");
442 greg 3.9 #endif
443 greg 3.3 sl1 = getascan(sb, iy+1);
444     /* 2D linear interpolation */
445     copycolor(col, sl0[ix]);
446     scalecolor(col, 1.-dx);
447     copycolor(c1, sl0[ix+1]);
448     scalecolor(c1, dx);
449     addcolor(col, c1);
450     copycolor(c1y, sl1[ix]);
451     scalecolor(c1y, 1.-dx);
452     copycolor(c1, sl1[ix+1]);
453     scalecolor(c1, dx);
454     addcolor(c1y, c1);
455     scalecolor(col, 1.-dy);
456     scalecolor(c1y, dy);
457     addcolor(col, c1y);
458 greg 3.9 for (ix = 0; ix < 3; ix++) /* make sure no negative */
459     if (colval(col,ix) < 0.)
460     colval(col,ix) = 0.;
461 greg 3.3 }
462
463
464 schorsch 3.17 static SCANBAR *
465     sballoc( /* allocate scanbar */
466     int se, /* sampling rate exponent */
467     int ns, /* number of scanlines */
468     int sl /* original scanline length */
469     )
470 greg 3.3 {
471 greg 3.8 SCANBAR *sbarr;
472 greg 3.3 register SCANBAR *sb;
473
474 greg 3.9 sbarr = sb = (SCANBAR *)malloc((se+1)*sizeof(SCANBAR));
475 greg 3.3 if (sb == NULL)
476     syserror("malloc");
477 greg 3.8 do {
478 greg 3.16 sb->len = sl>>se;
479     if (sb->len <= 0)
480     continue;
481 greg 3.9 sb->sampe = se;
482     sb->nscans = ns;
483     sb->sdata = (COLOR *)malloc(sb->len*ns*sizeof(COLOR));
484 greg 3.8 if (sb->sdata == NULL)
485     syserror("malloc");
486     sb->nread = 0;
487     ns <<= 1;
488     sb++;
489 greg 3.9 } while (--se >= 0);
490 greg 3.8 return(sbarr);
491 greg 3.3 }
492
493
494 greg 3.19 extern void
495 schorsch 3.17 initacuity(void) /* initialize variable acuity sampling */
496 greg 3.3 {
497     FVECT diffx, diffy, cp;
498     double omega, maxsr;
499     register int x, y, i;
500 greg 3.18
501 greg 3.3 compraydir(); /* compute ray directions */
502
503     inpacuD = (float *)malloc(fvxr*fvyr*sizeof(float));
504     if (inpacuD == NULL)
505     syserror("malloc");
506     maxsr = 1.; /* compute internal sample rates */
507     for (y = 1; y < fvyr-1; y++)
508     for (x = 1; x < fvxr-1; x++) {
509     for (i = 0; i < 3; i++) {
510     diffx[i] = 0.5*fvxr/scanlen(&inpres) *
511     (rdirscan(y)[x+1][i] -
512     rdirscan(y)[x-1][i]);
513     diffy[i] = 0.5*fvyr/numscans(&inpres) *
514     (rdirscan(y+1)[x][i] -
515     rdirscan(y-1)[x][i]);
516     }
517     fcross(cp, diffx, diffy);
518     omega = 0.5 * sqrt(DOT(cp,cp));
519 greg 3.10 if (omega <= FTINY*FTINY)
520 greg 3.4 tsampr(x,y) = 1.;
521     else if ((tsampr(x,y) = PI/180. / sqrt(omega) /
522     hacuity(plum(fovscan(y)[x]))) > maxsr)
523 greg 3.3 maxsr = tsampr(x,y);
524     }
525     /* copy perimeter (easier) */
526     for (x = 1; x < fvxr-1; x++) {
527     tsampr(x,0) = tsampr(x,1);
528     tsampr(x,fvyr-1) = tsampr(x,fvyr-2);
529     }
530     for (y = 0; y < fvyr; y++) {
531 greg 3.9 tsampr(0,y) = tsampr(1,y);
532     tsampr(fvxr-1,y) = tsampr(fvxr-2,y);
533 greg 3.3 }
534     /* initialize with next power of two */
535 greg 3.8 rootbar = sballoc((int)(log(maxsr)/log(2.))+1, 2, scanlen(&inpres));
536 greg 3.1 }
