--- ray/src/px/pcond4.c 1997/08/13 11:24:48 3.15 +++ ray/src/px/pcond4.c 2004/11/14 16:57:18 3.19 @@ -1,9 +1,6 @@ -/* Copyright (c) 1997 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pcond4.c,v 3.19 2004/11/14 16:57:18 greg Exp $"; #endif - /* * Routines for veiling glare and loss of acuity. */ @@ -22,8 +19,14 @@ static float (*raydir)[3] = NULL; /* ray direction for #define rdirscan(y) (raydir+(y)*fvxr) +static void compraydir(void); +#if ADJ_VEIL +static void smoothveil(void); +#endif -compraydir() /* compute ray directions */ + +static void +compraydir(void) /* compute ray directions */ { FVECT rorg, rdir; double h, v; @@ -36,7 +39,7 @@ compraydir() /* compute ray directions */ syserror("malloc"); for (y = 0; y < fvyr; y++) { - switch (inpres.or) { + switch (inpres.rt) { case YMAJOR: case YMAJOR|XDECR: v = (y+.5)/fvyr; break; case YMAJOR|YDECR: case YMAJOR|YDECR|XDECR: @@ -47,7 +50,7 @@ compraydir() /* compute ray directions */ h = 1. - (y+.5)/fvyr; break; } for (x = 0; x < fvxr; x++) { - switch (inpres.or) { + switch (inpres.rt) { case YMAJOR: case YMAJOR|YDECR: h = (x+.5)/fvxr; break; case YMAJOR|XDECR: case YMAJOR|XDECR|YDECR: @@ -72,7 +75,8 @@ compraydir() /* compute ray directions */ } -compveil() /* compute veiling image */ +extern void +compveil(void) /* compute veiling image */ { double t2, t2sum; COLOR ctmp, vsum; @@ -122,10 +126,140 @@ compveil() /* compute veiling image */ } -addveil(sl, y) /* add veil to scanline */ -COLOR *sl; -int y; +#if ADJ_VEIL +/* + * The following veil adjustment was added to compensate for + * the fact that contrast reduction gets confused with veil + * in the human visual system. Therefore, we reduce the + * veil in portions of the image where our mapping has + * already reduced contrast below the target value. + * This gets called after the intial veil has been computed + * and added to the foveal image, and the mapping has been + * determined. + */ +extern void +adjveil(void) /* adjust veil image */ { + float *crfptr = crfimg; + COLOR *fovptr = fovimg; + COLOR *veilptr = veilimg; + double s2nits = 1./inpexp; + double vl, vl2, fovl, vlsum; + double deltavc[3]; + int i, j; + + if (lumf == rgblum) + s2nits *= WHTEFFICACY; + + for (i = fvxr*fvyr; i--; crfptr++, fovptr++, veilptr++) { + if (crfptr[0] >= 0.95) + continue; + vl = plum(veilptr[0]); + fovl = (plum(fovptr[0]) - vl) * (1./(1.-VADAPT)); + if (vl <= 0.05*fovl) + continue; + vlsum = vl; + for (j = 2; j < 11; j++) { + vlsum += crfptr[0]*vl - (1.0 - crfptr[0])*fovl; + vl2 = vlsum / (double)j; + if (vl2 < 0.0) + vl2 = 0.0; + crfptr[0] = crfactor(fovl + vl2); + } + /* desaturation code causes color fringes at this level */ + for (j = 3; j--; ) { + double vc = colval(veilptr[0],j); + double fovc = (colval(fovptr[0],j) - vc) * + (1./(1.-VADAPT)); + deltavc[j] = (1.-crfptr[0])*(fovl/s2nits - fovc); + if (vc + deltavc[j] < 0.0) + break; + } + if (j < 0) + addcolor(veilptr[0], deltavc); + else + scalecolor(veilptr[0], vl2/vl); + } + smoothveil(); /* smooth our result */ +} + + +static void +smoothveil(void) /* smooth veil image */ +{ + COLOR *nveilimg; + COLOR *ovptr, *nvptr; + int x, y, i; + + nveilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR)); + if (nveilimg == NULL) + return; + for (y = 1; y < fvyr-1; y++) { + ovptr = veilimg + y*fvxr + 1; + nvptr = nveilimg + y*fvxr + 1; + for (x = 1; x < fvxr-1; x++, ovptr++, nvptr++) + for (i = 3; i--; ) + nvptr[0][i] = 0.5 * ovptr[0][i] + + (1./12.) * + (ovptr[-1][i] + ovptr[-fvxr][i] + + ovptr[1][i] + ovptr[fvxr][i]) + + (1./24.) * + (ovptr[-fvxr-1][i] + ovptr[-fvxr+1][i] + + ovptr[fvxr-1][i] + ovptr[fvxr+1][i]); + } + ovptr = veilimg + 1; + nvptr = nveilimg + 1; + for (x = 1; x < fvxr-1; x++, ovptr++, nvptr++) + for (i = 3; i--; ) + nvptr[0][i] = 0.5 * ovptr[0][i] + + (1./9.) * + (ovptr[-1][i] + ovptr[1][i] + ovptr[fvxr][i]) + + (1./12.) * + (ovptr[fvxr-1][i] + ovptr[fvxr+1][i]); + ovptr = veilimg + (fvyr-1)*fvxr + 1; + nvptr = nveilimg + (fvyr-1)*fvxr + 1; + for (x = 1; x < fvxr-1; x++, ovptr++, nvptr++) + for (i = 3; i--; ) + nvptr[0][i] = 0.5 * ovptr[0][i] + + (1./9.) * + (ovptr[-1][i] + ovptr[1][i] + ovptr[-fvxr][i]) + + (1./12.) * + (ovptr[-fvxr-1][i] + ovptr[-fvxr+1][i]); + ovptr = veilimg + fvxr; + nvptr = nveilimg + fvxr; + for (y = 1; y < fvyr-1; y++, ovptr += fvxr, nvptr += fvxr) + for (i = 3; i--; ) + nvptr[0][i] = 0.5 * ovptr[0][i] + + (1./9.) * + (ovptr[-fvxr][i] + ovptr[1][i] + ovptr[fvxr][i]) + + (1./12.) * + (ovptr[-fvxr+1][i] + ovptr[fvxr+1][i]); + ovptr = veilimg + fvxr - 1; + nvptr = nveilimg + fvxr - 1; + for (y = 1; y < fvyr-1; y++, ovptr += fvxr, nvptr += fvxr) + for (i = 3; i--; ) + nvptr[0][i] = 0.5 * ovptr[0][i] + + (1./9.) * + (ovptr[-fvxr][i] + ovptr[-1][i] + ovptr[fvxr][i]) + + (1./12.) * + (ovptr[-fvxr-1][i] + ovptr[fvxr-1][i]); + for (i = 3; i--; ) { + nveilimg[0][i] = veilimg[0][i]; + nveilimg[fvxr-1][i] = veilimg[fvxr-1][i]; + nveilimg[(fvyr-1)*fvxr][i] = veilimg[(fvyr-1)*fvxr][i]; + nveilimg[fvyr*fvxr-1][i] = veilimg[fvyr*fvxr-1][i]; + } + free((void *)veilimg); + veilimg = nveilimg; +} +#endif + +extern void +addveil( /* add veil to scanline */ + COLOR *sl, + int y +) +{ int vx, vy; double dx, dy; double lv, uv; @@ -164,24 +298,30 @@ typedef struct { SCANBAR *rootbar; /* root scan bar (lowest resolution) */ -float *inpacuD; /* input acuity data (cycles/degree) */ +float *inpacuD = NULL; /* input acuity data (cycles/degree) */ #define tsampr(x,y) inpacuD[(y)*fvxr+(x)] +static COLOR * getascan(SCANBAR *sb, int y); +static void acusample(COLOR col, int x, int y, double sr); +static void ascanval(COLOR col, int x, int y, SCANBAR *sb); +static SCANBAR *sballoc(int se, int ns, int sl); -double -hacuity(La) /* return visual acuity in cycles/degree */ -double La; +extern double +hacuity( /* return visual acuity in cycles/degree */ + double La +) { /* functional fit */ return(17.25*atan(1.4*log10(La) + 0.35) + 25.72); } -COLOR * -getascan(sb, y) /* find/read scanline y for scanbar sb */ -register SCANBAR *sb; -int y; +static COLOR * +getascan( /* find/read scanline y for scanbar sb */ + register SCANBAR *sb, + int y +) { register COLOR *sl0, *sl1, *mysl; register int i; @@ -214,14 +354,19 @@ int y; } -acuscan(scln, y) /* get acuity-sampled scanline */ -COLOR *scln; -int y; +extern void +acuscan( /* get acuity-sampled scanline */ + COLOR *scln, + int y +) { double sr; double dx, dy; int ix, iy; register int x; + + if (inpacuD == NULL) + return; /* compute foveal y position */ iy = dy = (y+.5)/numscans(&inpres)*fvyr - .5; while (iy >= fvyr-1) iy--; @@ -240,10 +385,13 @@ int y; } -acusample(col, x, y, sr) /* interpolate sample at (x,y) using rate sr */ -COLOR col; -int x, y; -double sr; +static void +acusample( /* interpolate sample at (x,y) using rate sr */ + COLOR col, + int x, + int y, + double sr +) { COLOR c1; double d; @@ -262,10 +410,13 @@ double sr; } -ascanval(col, x, y, sb) /* interpolate scanbar at orig. coords (x,y) */ -COLOR col; -int x, y; -SCANBAR *sb; +static void +ascanval( /* interpolate scanbar at orig. coords (x,y) */ + COLOR col, + int x, + int y, + SCANBAR *sb +) { COLOR *sl0, *sl1, c1, c1y; double dx, dy; @@ -310,11 +461,12 @@ SCANBAR *sb; } -SCANBAR * -sballoc(se, ns, sl) /* allocate scanbar */ -int se; /* sampling rate exponent */ -int ns; /* number of scanlines */ -int sl; /* original scanline length */ +static SCANBAR * +sballoc( /* allocate scanbar */ + int se, /* sampling rate exponent */ + int ns, /* number of scanlines */ + int sl /* original scanline length */ +) { SCANBAR *sbarr; register SCANBAR *sb; @@ -323,8 +475,10 @@ int sl; /* original scanline length */ if (sb == NULL) syserror("malloc"); do { - sb->sampe = se; sb->len = sl>>se; + if (sb->len <= 0) + continue; + sb->sampe = se; sb->nscans = ns; sb->sdata = (COLOR *)malloc(sb->len*ns*sizeof(COLOR)); if (sb->sdata == NULL) @@ -337,12 +491,13 @@ int sl; /* original scanline length */ } -initacuity() /* initialize variable acuity sampling */ +extern void +initacuity(void) /* initialize variable acuity sampling */ { FVECT diffx, diffy, cp; double omega, maxsr; register int x, y, i; - + compraydir(); /* compute ray directions */ inpacuD = (float *)malloc(fvxr*fvyr*sizeof(float));
