root/radiance/ray/src/px/pcond4.c
Sun Nov 14 16:57:18 2004 UTC (19 years, 6 months ago) by greg
CVS Tags: rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Changes since 3.18: +2 -6 lines
Diff to previous 3.18 , to selected 3.3
Mon Nov 8 15:50:59 2004 UTC (19 years, 7 months ago) by greg
Changes since 3.17: +10 -3 lines
Diff to previous 3.17 , to selected 3.3
Changes since 3.16: +60 -33 lines
Diff to previous 3.16 , to selected 3.3
Changes since 3.15: +132 -7 lines
Diff to previous 3.15 , to selected 3.3
Wed Aug 13 11:24:48 1997 UTC (26 years, 9 months ago) by gregl
Changes since 3.14: +2 -1 lines
Diff to previous 3.14 , to selected 3.3
fixed bug in veil computation for fisheye views (divide by zero)
Tue Jan 28 16:31:17 1997 UTC (27 years, 4 months ago) by greg
Changes since 3.13: +2 -5 lines
Diff to previous 3.13 , to selected 3.3
removed unnecessary debugging statements
Sat Jan 11 19:34:22 1997 UTC (27 years, 4 months ago) by greg
Changes since 3.12: +4 -27 lines
Diff to previous 3.12 , to selected 3.3
changed from interpolation of Shaler's data to atan() fit in hacuity()
Fri Jan 10 13:06:54 1997 UTC (27 years, 5 months ago) by greg
Changes since 3.11: +3 -3 lines
Diff to previous 3.11 , to selected 3.3
added cosine correction to veiling glare computation
Thu Jan 9 13:56:32 1997 UTC (27 years, 5 months ago) by greg
Changes since 3.10: +11 -6 lines
Diff to previous 3.10 , to selected 3.3
Fri Oct 11 10:23:59 1996 UTC (27 years, 8 months ago) by greg
Diff to previous 3.9 , to selected 3.3
changed lower limit for pixel solid angle test in initacuity()
Thu Oct 10 16:36:39 1996 UTC (27 years, 8 months ago) by greg
Changes since 3.8: +18 -13 lines
Diff to previous 3.8 , to selected 3.3
bug fix in computation of tsampr array
Tue Oct 8 12:48:00 1996 UTC (27 years, 8 months ago) by greg
Changes since 3.7: +30 -27 lines
Diff to previous 3.7 , to selected 3.3
Changed definition of SCANBAR to make code slightly more logical.
Sat Oct 5 11:17:10 1996 UTC (27 years, 8 months ago) by greg
Diff to previous 3.6 , to selected 3.3
bug fix in acuscan()
Sat Oct 5 08:05:27 1996 UTC (27 years, 8 months ago) by greg
Changes since 3.5: +15 -5 lines
Diff to previous 3.5 , to selected 3.3
fixed potential bug in getascan()
made ascanval() more efficient
Fri Oct 4 18:11:52 1996 UTC (27 years, 8 months ago) by greg
Changes since 3.4: +6 -1 lines
Diff to previous 3.4 , to selected 3.3
added limit check to hacuity()
Fri Oct 4 17:51:41 1996 UTC (27 years, 8 months ago) by greg
Changes since 3.3: +7 -3 lines
Diff to previous 3.3
fixed problem with fisheye views
made veil computation faster with approximation to acos()
Revision 3.3 - (view) (download) (annotate) - [selected]
Fri Oct 4 16:10:43 1996 UTC (27 years, 8 months ago) by greg
Changes since 3.2: +234 -0 lines
Diff to previous 3.2
Thu Oct 3 20:14:20 1996 UTC (27 years, 8 months ago) by greg
Changes since 3.1: +9 -5 lines
Diff to previous 3.1 , to selected 3.3
decreased size of raydir array by changing from FVECT to float
Thu Oct 3 16:52:51 1996 UTC (27 years, 8 months ago) by greg
Diff to selected 3.3
