root/radiance/ray/src/px/pcond4.c
Revision: 3.16
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.15: +132 -7 lines
# User Rev Content
1 greg 3.1 #ifndef lint
2 greg 3.16 static const char RCSid[] = "$Id$";
3 greg 3.1 #endif
4     /*
5     * Routines for veiling glare and loss of acuity.
6     */
7
8     #include "pcond.h"
9
10 greg 3.3 /************** VEILING STUFF *****************/
11 greg 3.1
12     #define VADAPT 0.08 /* fraction of adaptation from veil */
13
14 greg 3.11 static COLOR *veilimg = NULL; /* veiling image */
15 greg 3.1
16     #define veilscan(y) (veilimg+(y)*fvxr)
17
18 greg 3.2 static float (*raydir)[3] = NULL; /* ray direction for each pixel */
19 greg 3.1
20     #define rdirscan(y) (raydir+(y)*fvxr)
21
22
23     compraydir() /* compute ray directions */
24     {
25 greg 3.2 FVECT rorg, rdir;
26 greg 3.1 double h, v;
27     register int x, y;
28
29     if (raydir != NULL) /* already done? */
30     return;
31 greg 3.2 raydir = (float (*)[3])malloc(fvxr*fvyr*3*sizeof(float));
32 greg 3.1 if (raydir == NULL)
33     syserror("malloc");
34
35     for (y = 0; y < fvyr; y++) {
36 greg 3.16 switch (inpres.rt) {
37 greg 3.1 case YMAJOR: case YMAJOR|XDECR:
38     v = (y+.5)/fvyr; break;
39     case YMAJOR|YDECR: case YMAJOR|YDECR|XDECR:
40     v = 1. - (y+.5)/fvyr; break;
41     case 0: case YDECR:
42     h = (y+.5)/fvyr; break;
43     case XDECR: case XDECR|YDECR:
44     h = 1. - (y+.5)/fvyr; break;
45     }
46     for (x = 0; x < fvxr; x++) {
47 greg 3.16 switch (inpres.rt) {
48 greg 3.1 case YMAJOR: case YMAJOR|YDECR:
49     h = (x+.5)/fvxr; break;
50     case YMAJOR|XDECR: case YMAJOR|XDECR|YDECR:
51     h = 1. - (x+.5)/fvxr; break;
52     case 0: case XDECR:
53     v = (x+.5)/fvxr; break;
54     case YDECR: case YDECR|XDECR:
55     v = 1. - (x+.5)/fvxr; break;
56     }
57 greg 3.2 if (viewray(rorg, rdir, &ourview, h, v)
58     >= -FTINY) {
59     rdirscan(y)[x][0] = rdir[0];
60     rdirscan(y)[x][1] = rdir[1];
61     rdirscan(y)[x][2] = rdir[2];
62     } else {
63 greg 3.1 rdirscan(y)[x][0] =
64     rdirscan(y)[x][1] =
65     rdirscan(y)[x][2] = 0.0;
66     }
67     }
68     }
69     }
70
71
72     compveil() /* compute veiling image */
73     {
74     double t2, t2sum;
75     COLOR ctmp, vsum;
76     int px, py;
77     register int x, y;
78 greg 3.11
79     if (veilimg != NULL) /* already done? */
80     return;
81 greg 3.1 /* compute ray directions */
82     compraydir();
83     /* compute veil image */
84     veilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR));
85     if (veilimg == NULL)
86     syserror("malloc");
87     for (py = 0; py < fvyr; py++)
88     for (px = 0; px < fvxr; px++) {
89     t2sum = 0.;
90     setcolor(vsum, 0., 0., 0.);
91     for (y = 0; y < fvyr; y++)
92     for (x = 0; x < fvxr; x++) {
93     if (x == px && y == py) continue;
94     t2 = DOT(rdirscan(py)[px],
95     rdirscan(y)[x]);
96     if (t2 <= FTINY) continue;
97 greg 3.4 /* use approximation instead
98 greg 3.12 t3 = acos(t2);
99     t2 = t2/(t3*t3);
100 greg 3.4 */
101 greg 3.12 t2 *= .5 / (1. - t2);
102 greg 3.1 copycolor(ctmp, fovscan(y)[x]);
103     scalecolor(ctmp, t2);
104     addcolor(vsum, ctmp);
105     t2sum += t2;
106     }
107     /* VADAPT of original is subtracted in addveil() */
108 gregl 3.15 if (t2sum > FTINY)
109     scalecolor(vsum, VADAPT/t2sum);
110 greg 3.1 copycolor(veilscan(py)[px], vsum);
111     }
112 greg 3.11 /* modify FOV sample image */
113     for (y = 0; y < fvyr; y++)
114     for (x = 0; x < fvxr; x++) {
115     scalecolor(fovscan(y)[x], 1.-VADAPT);
116     addcolor(fovscan(y)[x], veilscan(y)[x]);
117     }
118     comphist(); /* recompute histogram */
119 greg 3.1 }
120
121
122 greg 3.16 #if ADJ_VEIL
123     /*
124     * The following veil adjustment was added to compensate for
125     * the fact that contrast reduction gets confused with veil
126     * in the human visual system. Therefore, we reduce the
127     * veil in portions of the image where our mapping has
128     * already reduced contrast below the target value.
129     * This gets called after the intial veil has been computed
130     * and added to the foveal image, and the mapping has been
131     * determined.
132     */
133     adjveil() /* adjust veil image */
134     {
135     float *crfptr = crfimg;
136     COLOR *fovptr = fovimg;
137     COLOR *veilptr = veilimg;
138     double s2nits = 1./inpexp;
139     double vl, vl2, fovl, vlsum;
140     double deltavc[3];
141     int i, j;
142
143     if (lumf == rgblum)
144     s2nits *= WHTEFFICACY;
145
146     for (i = fvxr*fvyr; i--; crfptr++, fovptr++, veilptr++) {
147     if (crfptr[0] >= 0.95)
148     continue;
149     vl = plum(veilptr[0]);
150     fovl = (plum(fovptr[0]) - vl) * (1./(1.-VADAPT));
151     if (vl <= 0.05*fovl)
152     continue;
153     vlsum = vl;
154     for (j = 2; j < 11; j++) {
155     vlsum += crfptr[0]*vl - (1.0 - crfptr[0])*fovl;
156     vl2 = vlsum / (double)j;
157     if (vl2 < 0.0)
158     vl2 = 0.0;
159     crfptr[0] = crfactor(fovl + vl2);
160     }
161     /* desaturation code causes color fringes at this level */
162     for (j = 3; j--; ) {
163     double vc = colval(veilptr[0],j);
164     double fovc = (colval(fovptr[0],j) - vc) *
165     (1./(1.-VADAPT));
166     deltavc[j] = (1.-crfptr[0])*(fovl/s2nits - fovc);
167     if (vc + deltavc[j] < 0.0)
168     break;
169     }
170     if (j < 0)
171     addcolor(veilptr[0], deltavc);
172     else
173     scalecolor(veilptr[0], vl2/vl);
174     }
175     smoothveil(); /* smooth our result */
176     }
177
178
179     smoothveil() /* smooth veil image */
180     {
181     COLOR *nveilimg;
182     COLOR *ovptr, *nvptr;
183     int x, y, i;
184
185     nveilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR));
186     if (nveilimg == NULL)
187     return;
188     for (y = 1; y < fvyr-1; y++) {
189     ovptr = veilimg + y*fvxr + 1;
190     nvptr = nveilimg + y*fvxr + 1;
191     for (x = 1; x < fvxr-1; x++, ovptr++, nvptr++)
192     for (i = 3; i--; )
193     nvptr[0][i] = 0.5 * ovptr[0][i]
194     + (1./12.) *
195     (ovptr[-1][i] + ovptr[-fvxr][i] +
196     ovptr[1][i] + ovptr[fvxr][i])
197     + (1./24.) *
198     (ovptr[-fvxr-1][i] + ovptr[-fvxr+1][i] +
199     ovptr[fvxr-1][i] + ovptr[fvxr+1][i]);
200     }
201     ovptr = veilimg + 1;
202     nvptr = nveilimg + 1;
203     for (x = 1; x < fvxr-1; x++, ovptr++, nvptr++)
204     for (i = 3; i--; )
205     nvptr[0][i] = 0.5 * ovptr[0][i]
206     + (1./9.) *
207     (ovptr[-1][i] + ovptr[1][i] + ovptr[fvxr][i])
208     + (1./12.) *
209     (ovptr[fvxr-1][i] + ovptr[fvxr+1][i]);
210     ovptr = veilimg + (fvyr-1)*fvxr + 1;
211     nvptr = nveilimg + (fvyr-1)*fvxr + 1;
212     for (x = 1; x < fvxr-1; x++, ovptr++, nvptr++)
213     for (i = 3; i--; )
214     nvptr[0][i] = 0.5 * ovptr[0][i]
215     + (1./9.) *
216     (ovptr[-1][i] + ovptr[1][i] + ovptr[-fvxr][i])
217     + (1./12.) *
218     (ovptr[-fvxr-1][i] + ovptr[-fvxr+1][i]);
219     ovptr = veilimg + fvxr;
220     nvptr = nveilimg + fvxr;
221     for (y = 1; y < fvyr-1; y++, ovptr += fvxr, nvptr += fvxr)
222     for (i = 3; i--; )
223     nvptr[0][i] = 0.5 * ovptr[0][i]
224     + (1./9.) *
225     (ovptr[-fvxr][i] + ovptr[1][i] + ovptr[fvxr][i])
226     + (1./12.) *
227     (ovptr[-fvxr+1][i] + ovptr[fvxr+1][i]);
228     ovptr = veilimg + fvxr - 1;
229     nvptr = nveilimg + fvxr - 1;
230     for (y = 1; y < fvyr-1; y++, ovptr += fvxr, nvptr += fvxr)
231     for (i = 3; i--; )
232     nvptr[0][i] = 0.5 * ovptr[0][i]
233     + (1./9.) *
234     (ovptr[-fvxr][i] + ovptr[-1][i] + ovptr[fvxr][i])
235     + (1./12.) *
236     (ovptr[-fvxr-1][i] + ovptr[fvxr-1][i]);
237     for (i = 3; i--; ) {
238     nveilimg[0][i] = veilimg[0][i];
239     nveilimg[fvxr-1][i] = veilimg[fvxr-1][i];
240     nveilimg[(fvyr-1)*fvxr][i] = veilimg[(fvyr-1)*fvxr][i];
241     nveilimg[fvyr*fvxr-1][i] = veilimg[fvyr*fvxr-1][i];
242     }
243     free((void *)veilimg);
244     veilimg = nveilimg;
245     }
246     #endif
247
248 greg 3.1 addveil(sl, y) /* add veil to scanline */
249     COLOR *sl;
250     int y;
251     {
252     int vx, vy;
253     double dx, dy;
254     double lv, uv;
255     register int x, i;
256
257     vy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
258 greg 3.7 while (vy >= fvyr-1) vy--;
259 greg 3.1 dy -= (double)vy;
260     for (x = 0; x < scanlen(&inpres); x++) {
261     vx = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
262 greg 3.7 while (vx >= fvxr-1) vx--;
263 greg 3.1 dx -= (double)vx;
264     for (i = 0; i < 3; i++) {
265     lv = (1.-dy)*colval(veilscan(vy)[vx],i) +
266     dy*colval(veilscan(vy+1)[vx],i);
267     uv = (1.-dy)*colval(veilscan(vy)[vx+1],i) +
268     dy*colval(veilscan(vy+1)[vx+1],i);
269     colval(sl[x],i) = (1.-VADAPT)*colval(sl[x],i) +
270     (1.-dx)*lv + dx*uv;
271     }
272     }
273 greg 3.3 }
274
275
276     /****************** ACUITY STUFF *******************/
277
278 greg 3.8 typedef struct {
279     short sampe; /* sample area size (exponent of 2) */
280 greg 3.3 short nscans; /* number of scanlines in this bar */
281     int len; /* individual scanline length */
282     int nread; /* number of scanlines loaded */
283 greg 3.8 COLOR *sdata; /* scanbar data */
284 greg 3.3 } SCANBAR;
285
286 greg 3.8 #define bscan(sb,y) ((COLOR *)(sb)->sdata+((y)%(sb)->nscans)*(sb)->len)
287 greg 3.3
288     SCANBAR *rootbar; /* root scan bar (lowest resolution) */
289
290     float *inpacuD; /* input acuity data (cycles/degree) */
291
292     #define tsampr(x,y) inpacuD[(y)*fvxr+(x)]
293
294
295     double
296     hacuity(La) /* return visual acuity in cycles/degree */
297     double La;
298 greg 3.13 {
299     /* functional fit */
300     return(17.25*atan(1.4*log10(La) + 0.35) + 25.72);
301 greg 3.3 }
302
303
304     COLOR *
305     getascan(sb, y) /* find/read scanline y for scanbar sb */
306     register SCANBAR *sb;
307     int y;
308     {
309     register COLOR *sl0, *sl1, *mysl;
310     register int i;
311
312 greg 3.6 if (y < sb->nread - sb->nscans) /* too far back? */
313     return(NULL);
314 greg 3.3 for ( ; y >= sb->nread; sb->nread++) { /* read as necessary */
315     mysl = bscan(sb, sb->nread);
316 greg 3.8 if (sb->sampe == 0) {
317 greg 3.3 if (freadscan(mysl, sb->len, infp) < 0) {
318     fprintf(stderr, "%s: %s: scanline read error\n",
319     progname, infn);
320     exit(1);
321     }
322     } else {
323 greg 3.8 sl0 = getascan(sb+1, 2*y);
324 greg 3.6 if (sl0 == NULL)
325     return(NULL);
326 greg 3.8 sl1 = getascan(sb+1, 2*y+1);
327 greg 3.3 for (i = 0; i < sb->len; i++) {
328     copycolor(mysl[i], sl0[2*i]);
329     addcolor(mysl[i], sl0[2*i+1]);
330     addcolor(mysl[i], sl1[2*i]);
331     addcolor(mysl[i], sl1[2*i+1]);
332     scalecolor(mysl[i], 0.25);
333     }
334     }
335     }
336     return(bscan(sb, y));
337     }
338
339
340     acuscan(scln, y) /* get acuity-sampled scanline */
341     COLOR *scln;
342     int y;
343     {
344     double sr;
345     double dx, dy;
346     int ix, iy;
347     register int x;
348     /* compute foveal y position */
349     iy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
350 greg 3.9 while (iy >= fvyr-1) iy--;
351 greg 3.3 dy -= (double)iy;
352     for (x = 0; x < scanlen(&inpres); x++) {
353     /* compute foveal x position */
354     ix = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
355 greg 3.9 while (ix >= fvxr-1) ix--;
356 greg 3.3 dx -= (double)ix;
357     /* interpolate sample rate */
358     sr = (1.-dy)*((1.-dx)*tsampr(ix,iy) + dx*tsampr(ix+1,iy)) +
359     dy*((1.-dx)*tsampr(ix,iy+1) + dx*tsampr(ix+1,iy+1));
360
361     acusample(scln[x], x, y, sr); /* compute sample */
362     }
363     }
364
365
366     acusample(col, x, y, sr) /* interpolate sample at (x,y) using rate sr */
367     COLOR col;
368     int x, y;
369     double sr;
370     {
371     COLOR c1;
372     double d;
373     register SCANBAR *sb0;
374
375 greg 3.8 for (sb0 = rootbar; sb0->sampe != 0 && 1<<sb0[1].sampe > sr; sb0++)
376 greg 3.3 ;
377     ascanval(col, x, y, sb0);
378 greg 3.8 if (sb0->sampe == 0) /* don't extrapolate highest */
379 greg 3.3 return;
380 greg 3.8 ascanval(c1, x, y, sb0+1);
381     d = ((1<<sb0->sampe) - sr)/(1<<sb0[1].sampe);
382 greg 3.3 scalecolor(col, 1.-d);
383     scalecolor(c1, d);
384     addcolor(col, c1);
385     }
386
387
388     ascanval(col, x, y, sb) /* interpolate scanbar at orig. coords (x,y) */
389     COLOR col;
390     int x, y;
391     SCANBAR *sb;
392     {
393     COLOR *sl0, *sl1, c1, c1y;
394     double dx, dy;
395     int ix, iy;
396
397 greg 3.8 if (sb->sampe == 0) { /* no need to interpolate */
398 greg 3.6 sl0 = getascan(sb, y);
399     copycolor(col, sl0[x]);
400     return;
401     }
402     /* compute coordinates for sb */
403 greg 3.8 ix = dx = (x+.5)/(1<<sb->sampe) - .5;
404 greg 3.7 while (ix >= sb->len-1) ix--;
405 greg 3.3 dx -= (double)ix;
406 greg 3.8 iy = dy = (y+.5)/(1<<sb->sampe) - .5;
407     while (iy >= (numscans(&inpres)>>sb->sampe)-1) iy--;
408 greg 3.3 dy -= (double)iy;
409     /* get scanlines */
410     sl0 = getascan(sb, iy);
411 greg 3.9 #ifdef DEBUG
412 greg 3.14 if (sl0 == NULL)
413     error(INTERNAL, "cannot backspace in ascanval");
414 greg 3.9 #endif
415 greg 3.3 sl1 = getascan(sb, iy+1);
416     /* 2D linear interpolation */
417     copycolor(col, sl0[ix]);
418     scalecolor(col, 1.-dx);
419     copycolor(c1, sl0[ix+1]);
420     scalecolor(c1, dx);
421     addcolor(col, c1);
422     copycolor(c1y, sl1[ix]);
423     scalecolor(c1y, 1.-dx);
424     copycolor(c1, sl1[ix+1]);
425     scalecolor(c1, dx);
426     addcolor(c1y, c1);
427     scalecolor(col, 1.-dy);
428     scalecolor(c1y, dy);
429     addcolor(col, c1y);
430 greg 3.9 for (ix = 0; ix < 3; ix++) /* make sure no negative */
431     if (colval(col,ix) < 0.)
432     colval(col,ix) = 0.;
433 greg 3.3 }
434
435
436     SCANBAR *
437 greg 3.9 sballoc(se, ns, sl) /* allocate scanbar */
438     int se; /* sampling rate exponent */
439 greg 3.3 int ns; /* number of scanlines */
440     int sl; /* original scanline length */
441     {
442 greg 3.8 SCANBAR *sbarr;
443 greg 3.3 register SCANBAR *sb;
444
445 greg 3.9 sbarr = sb = (SCANBAR *)malloc((se+1)*sizeof(SCANBAR));
446 greg 3.3 if (sb == NULL)
447     syserror("malloc");
448 greg 3.8 do {
449 greg 3.16 sb->len = sl>>se;
450     if (sb->len <= 0)
451     continue;
452 greg 3.9 sb->sampe = se;
453     sb->nscans = ns;
454     sb->sdata = (COLOR *)malloc(sb->len*ns*sizeof(COLOR));
455 greg 3.8 if (sb->sdata == NULL)
456     syserror("malloc");
457     sb->nread = 0;
458     ns <<= 1;
459     sb++;
460 greg 3.9 } while (--se >= 0);
461 greg 3.8 return(sbarr);
462 greg 3.3 }
463
464
465     initacuity() /* initialize variable acuity sampling */
466     {
467     FVECT diffx, diffy, cp;
468     double omega, maxsr;
469     register int x, y, i;
470
471     compraydir(); /* compute ray directions */
472
473     inpacuD = (float *)malloc(fvxr*fvyr*sizeof(float));
474     if (inpacuD == NULL)
475     syserror("malloc");
476     maxsr = 1.; /* compute internal sample rates */
477     for (y = 1; y < fvyr-1; y++)
478     for (x = 1; x < fvxr-1; x++) {
479     for (i = 0; i < 3; i++) {
480     diffx[i] = 0.5*fvxr/scanlen(&inpres) *
481     (rdirscan(y)[x+1][i] -
482     rdirscan(y)[x-1][i]);
483     diffy[i] = 0.5*fvyr/numscans(&inpres) *
484     (rdirscan(y+1)[x][i] -
485     rdirscan(y-1)[x][i]);
486     }
487     fcross(cp, diffx, diffy);
488     omega = 0.5 * sqrt(DOT(cp,cp));
489 greg 3.10 if (omega <= FTINY*FTINY)
490 greg 3.4 tsampr(x,y) = 1.;
491     else if ((tsampr(x,y) = PI/180. / sqrt(omega) /
492     hacuity(plum(fovscan(y)[x]))) > maxsr)
493 greg 3.3 maxsr = tsampr(x,y);
494     }
495     /* copy perimeter (easier) */
496     for (x = 1; x < fvxr-1; x++) {
497     tsampr(x,0) = tsampr(x,1);
498     tsampr(x,fvyr-1) = tsampr(x,fvyr-2);
499     }
500     for (y = 0; y < fvyr; y++) {
501 greg 3.9 tsampr(0,y) = tsampr(1,y);
502     tsampr(fvxr-1,y) = tsampr(fvxr-2,y);
503 greg 3.3 }
504     /* initialize with next power of two */
505 greg 3.8 rootbar = sballoc((int)(log(maxsr)/log(2.))+1, 2, scanlen(&inpres));
506 greg 3.1 }
