root/radiance/ray/src/px/pcond4.c
Revision: 3.13
Committed: Sat Jan 11 19:34:22 1997 UTC (28 years, 5 months ago) by greg
Changes since 3.12: +4 -27 lines
changed from interpolation of Shaler's data to atan() fit in hacuity()
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines for veiling glare and loss of acuity.
9 */
10
11 #include "pcond.h"
12
13 /************** VEILING STUFF *****************/
14
15 #define VADAPT 0.08 /* fraction of adaptation from veil */
16
17 static COLOR *veilimg = NULL; /* veiling image */
18
19 #define veilscan(y) (veilimg+(y)*fvxr)
20
21 static float (*raydir)[3] = NULL; /* ray direction for each pixel */
22
23 #define rdirscan(y) (raydir+(y)*fvxr)
24
25
26 compraydir() /* compute ray directions */
27 {
28 FVECT rorg, rdir;
29 double h, v;
30 register int x, y;
31
32 if (raydir != NULL) /* already done? */
33 return;
34 raydir = (float (*)[3])malloc(fvxr*fvyr*3*sizeof(float));
35 if (raydir == NULL)
36 syserror("malloc");
37
38 for (y = 0; y < fvyr; y++) {
39 switch (inpres.or) {
40 case YMAJOR: case YMAJOR|XDECR:
41 v = (y+.5)/fvyr; break;
42 case YMAJOR|YDECR: case YMAJOR|YDECR|XDECR:
43 v = 1. - (y+.5)/fvyr; break;
44 case 0: case YDECR:
45 h = (y+.5)/fvyr; break;
46 case XDECR: case XDECR|YDECR:
47 h = 1. - (y+.5)/fvyr; break;
48 }
49 for (x = 0; x < fvxr; x++) {
50 switch (inpres.or) {
51 case YMAJOR: case YMAJOR|YDECR:
52 h = (x+.5)/fvxr; break;
53 case YMAJOR|XDECR: case YMAJOR|XDECR|YDECR:
54 h = 1. - (x+.5)/fvxr; break;
55 case 0: case XDECR:
56 v = (x+.5)/fvxr; break;
57 case YDECR: case YDECR|XDECR:
58 v = 1. - (x+.5)/fvxr; break;
59 }
60 if (viewray(rorg, rdir, &ourview, h, v)
61 >= -FTINY) {
62 rdirscan(y)[x][0] = rdir[0];
63 rdirscan(y)[x][1] = rdir[1];
64 rdirscan(y)[x][2] = rdir[2];
65 } else {
66 rdirscan(y)[x][0] =
67 rdirscan(y)[x][1] =
68 rdirscan(y)[x][2] = 0.0;
69 }
70 }
71 }
72 }
73
74
75 compveil() /* compute veiling image */
76 {
77 double t2, t2sum;
78 COLOR ctmp, vsum;
79 int px, py;
80 register int x, y;
81
82 if (veilimg != NULL) /* already done? */
83 return;
84 /* compute ray directions */
85 compraydir();
86 /* compute veil image */
87 veilimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR));
88 if (veilimg == NULL)
89 syserror("malloc");
90 for (py = 0; py < fvyr; py++)
91 for (px = 0; px < fvxr; px++) {
92 t2sum = 0.;
93 setcolor(vsum, 0., 0., 0.);
94 for (y = 0; y < fvyr; y++)
95 for (x = 0; x < fvxr; x++) {
96 if (x == px && y == py) continue;
97 t2 = DOT(rdirscan(py)[px],
98 rdirscan(y)[x]);
99 if (t2 <= FTINY) continue;
100 /* use approximation instead
101 t3 = acos(t2);
102 t2 = t2/(t3*t3);
103 */
104 t2 *= .5 / (1. - t2);
105 copycolor(ctmp, fovscan(y)[x]);
106 scalecolor(ctmp, t2);
107 addcolor(vsum, ctmp);
108 t2sum += t2;
109 }
110 /* VADAPT of original is subtracted in addveil() */
111 scalecolor(vsum, VADAPT/t2sum);
112 copycolor(veilscan(py)[px], vsum);
113 }
114 /* modify FOV sample image */
115 for (y = 0; y < fvyr; y++)
116 for (x = 0; x < fvxr; x++) {
117 scalecolor(fovscan(y)[x], 1.-VADAPT);
118 addcolor(fovscan(y)[x], veilscan(y)[x]);
119 }
120 comphist(); /* recompute histogram */
121 }
122
123
124 addveil(sl, y) /* add veil to scanline */
125 COLOR *sl;
126 int y;
127 {
128 int vx, vy;
129 double dx, dy;
130 double lv, uv;
131 register int x, i;
132
133 vy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
134 while (vy >= fvyr-1) vy--;
135 dy -= (double)vy;
136 for (x = 0; x < scanlen(&inpres); x++) {
137 vx = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
138 while (vx >= fvxr-1) vx--;
139 dx -= (double)vx;
140 for (i = 0; i < 3; i++) {
141 lv = (1.-dy)*colval(veilscan(vy)[vx],i) +
142 dy*colval(veilscan(vy+1)[vx],i);
143 uv = (1.-dy)*colval(veilscan(vy)[vx+1],i) +
144 dy*colval(veilscan(vy+1)[vx+1],i);
145 colval(sl[x],i) = (1.-VADAPT)*colval(sl[x],i) +
146 (1.-dx)*lv + dx*uv;
147 }
148 }
149 }
150
151
152 /****************** ACUITY STUFF *******************/
153
154 typedef struct {
155 short sampe; /* sample area size (exponent of 2) */
156 short nscans; /* number of scanlines in this bar */
157 int len; /* individual scanline length */
158 int nread; /* number of scanlines loaded */
159 COLOR *sdata; /* scanbar data */
160 } SCANBAR;
161
162 #define bscan(sb,y) ((COLOR *)(sb)->sdata+((y)%(sb)->nscans)*(sb)->len)
163
164 SCANBAR *rootbar; /* root scan bar (lowest resolution) */
165
166 float *inpacuD; /* input acuity data (cycles/degree) */
167
168 #define tsampr(x,y) inpacuD[(y)*fvxr+(x)]
169
170
171 double
172 hacuity(La) /* return visual acuity in cycles/degree */
173 double La;
174 {
175 /* functional fit */
176 return(17.25*atan(1.4*log10(La) + 0.35) + 25.72);
177 }
178
179
180 COLOR *
181 getascan(sb, y) /* find/read scanline y for scanbar sb */
182 register SCANBAR *sb;
183 int y;
184 {
185 register COLOR *sl0, *sl1, *mysl;
186 register int i;
187
188 if (y < sb->nread - sb->nscans) /* too far back? */
189 return(NULL);
190 for ( ; y >= sb->nread; sb->nread++) { /* read as necessary */
191 mysl = bscan(sb, sb->nread);
192 if (sb->sampe == 0) {
193 if (freadscan(mysl, sb->len, infp) < 0) {
194 fprintf(stderr, "%s: %s: scanline read error\n",
195 progname, infn);
196 exit(1);
197 }
198 } else {
199 sl0 = getascan(sb+1, 2*y);
200 if (sl0 == NULL)
201 return(NULL);
202 sl1 = getascan(sb+1, 2*y+1);
203 for (i = 0; i < sb->len; i++) {
204 copycolor(mysl[i], sl0[2*i]);
205 addcolor(mysl[i], sl0[2*i+1]);
206 addcolor(mysl[i], sl1[2*i]);
207 addcolor(mysl[i], sl1[2*i+1]);
208 scalecolor(mysl[i], 0.25);
209 }
210 }
211 }
212 return(bscan(sb, y));
213 }
214
215
216 acuscan(scln, y) /* get acuity-sampled scanline */
217 COLOR *scln;
218 int y;
219 {
220 double sr;
221 double dx, dy;
222 int ix, iy;
223 register int x;
224 /* compute foveal y position */
225 iy = dy = (y+.5)/numscans(&inpres)*fvyr - .5;
226 while (iy >= fvyr-1) iy--;
227 dy -= (double)iy;
228 for (x = 0; x < scanlen(&inpres); x++) {
229 /* compute foveal x position */
230 ix = dx = (x+.5)/scanlen(&inpres)*fvxr - .5;
231 while (ix >= fvxr-1) ix--;
232 dx -= (double)ix;
233 /* interpolate sample rate */
234 sr = (1.-dy)*((1.-dx)*tsampr(ix,iy) + dx*tsampr(ix+1,iy)) +
235 dy*((1.-dx)*tsampr(ix,iy+1) + dx*tsampr(ix+1,iy+1));
236
237 acusample(scln[x], x, y, sr); /* compute sample */
238 }
239 }
240
241
242 acusample(col, x, y, sr) /* interpolate sample at (x,y) using rate sr */
243 COLOR col;
244 int x, y;
245 double sr;
246 {
247 COLOR c1;
248 double d;
249 register SCANBAR *sb0;
250
251 for (sb0 = rootbar; sb0->sampe != 0 && 1<<sb0[1].sampe > sr; sb0++)
252 ;
253 ascanval(col, x, y, sb0);
254 if (sb0->sampe == 0) /* don't extrapolate highest */
255 return;
256 ascanval(c1, x, y, sb0+1);
257 d = ((1<<sb0->sampe) - sr)/(1<<sb0[1].sampe);
258 scalecolor(col, 1.-d);
259 scalecolor(c1, d);
260 addcolor(col, c1);
261 }
262
263
264 ascanval(col, x, y, sb) /* interpolate scanbar at orig. coords (x,y) */
265 COLOR col;
266 int x, y;
267 SCANBAR *sb;
268 {
269 COLOR *sl0, *sl1, c1, c1y;
270 double dx, dy;
271 int ix, iy;
272
273 if (sb->sampe == 0) { /* no need to interpolate */
274 sl0 = getascan(sb, y);
275 copycolor(col, sl0[x]);
276 return;
277 }
278 /* compute coordinates for sb */
279 ix = dx = (x+.5)/(1<<sb->sampe) - .5;
280 while (ix >= sb->len-1) ix--;
281 dx -= (double)ix;
282 iy = dy = (y+.5)/(1<<sb->sampe) - .5;
283 while (iy >= (numscans(&inpres)>>sb->sampe)-1) iy--;
284 dy -= (double)iy;
285 /* get scanlines */
286 sl0 = getascan(sb, iy);
287 #ifdef DEBUG
288 if (sl0 == NULL) {
289 fprintf(stderr, "%s: internal - cannot backspace in ascanval\n",
290 progname);
291 abort();
292 }
293 #endif
294 sl1 = getascan(sb, iy+1);
295 /* 2D linear interpolation */
296 copycolor(col, sl0[ix]);
297 scalecolor(col, 1.-dx);
298 copycolor(c1, sl0[ix+1]);
299 scalecolor(c1, dx);
300 addcolor(col, c1);
301 copycolor(c1y, sl1[ix]);
302 scalecolor(c1y, 1.-dx);
303 copycolor(c1, sl1[ix+1]);
304 scalecolor(c1, dx);
305 addcolor(c1y, c1);
306 scalecolor(col, 1.-dy);
307 scalecolor(c1y, dy);
308 addcolor(col, c1y);
309 for (ix = 0; ix < 3; ix++) /* make sure no negative */
310 if (colval(col,ix) < 0.)
311 colval(col,ix) = 0.;
312 }
313
314
315 SCANBAR *
316 sballoc(se, ns, sl) /* allocate scanbar */
317 int se; /* sampling rate exponent */
318 int ns; /* number of scanlines */
319 int sl; /* original scanline length */
320 {
321 SCANBAR *sbarr;
322 register SCANBAR *sb;
323
324 sbarr = sb = (SCANBAR *)malloc((se+1)*sizeof(SCANBAR));
325 if (sb == NULL)
326 syserror("malloc");
327 do {
328 sb->sampe = se;
329 sb->len = sl>>se;
330 sb->nscans = ns;
331 sb->sdata = (COLOR *)malloc(sb->len*ns*sizeof(COLOR));
332 if (sb->sdata == NULL)
333 syserror("malloc");
334 sb->nread = 0;
335 ns <<= 1;
336 sb++;
337 } while (--se >= 0);
338 return(sbarr);
339 }
340
341
342 initacuity() /* initialize variable acuity sampling */
343 {
344 FVECT diffx, diffy, cp;
345 double omega, maxsr;
346 register int x, y, i;
347
348 compraydir(); /* compute ray directions */
349
350 inpacuD = (float *)malloc(fvxr*fvyr*sizeof(float));
351 if (inpacuD == NULL)
352 syserror("malloc");
353 maxsr = 1.; /* compute internal sample rates */
354 for (y = 1; y < fvyr-1; y++)
355 for (x = 1; x < fvxr-1; x++) {
356 for (i = 0; i < 3; i++) {
357 diffx[i] = 0.5*fvxr/scanlen(&inpres) *
358 (rdirscan(y)[x+1][i] -
359 rdirscan(y)[x-1][i]);
360 diffy[i] = 0.5*fvyr/numscans(&inpres) *
361 (rdirscan(y+1)[x][i] -
362 rdirscan(y-1)[x][i]);
363 }
364 fcross(cp, diffx, diffy);
365 omega = 0.5 * sqrt(DOT(cp,cp));
366 if (omega <= FTINY*FTINY)
367 tsampr(x,y) = 1.;
368 else if ((tsampr(x,y) = PI/180. / sqrt(omega) /
369 hacuity(plum(fovscan(y)[x]))) > maxsr)
370 maxsr = tsampr(x,y);
371 }
372 /* copy perimeter (easier) */
373 for (x = 1; x < fvxr-1; x++) {
374 tsampr(x,0) = tsampr(x,1);
375 tsampr(x,fvyr-1) = tsampr(x,fvyr-2);
376 }
377 for (y = 0; y < fvyr; y++) {
378 tsampr(0,y) = tsampr(1,y);
379 tsampr(fvxr-1,y) = tsampr(fvxr-2,y);
380 }
381 /* initialize with next power of two */
382 rootbar = sballoc((int)(log(maxsr)/log(2.))+1, 2, scanlen(&inpres));
383 }
