feat(pcond,pvalue): Added hyperspectral input handling
perf(pcond): more aggressive trim criterion for tone curve
perf(pcond): added random point sampling to histogram for more robust mapping
Fixed issue with missing veil from very bright sources like the sun
Fixed issue with undersampled histogram in phisto
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -I option for precomputed histogram
added an extra histogram bin at lower limit to avoid clipping
added -i option to take fixation points on standard input
fixed writing of linear ramp with -m option
removed shiftdir() function, which is no longer needed
changed to histogram truncation made veiling reflection modify FOV sample image
added -m option to print out mapping function
corrected tests in check2do()
fixed bugs in color scaling
