1 |
/* Copyright (c) 1997 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for computing and applying brightness mapping. |
9 |
10 |
11 |
#include "pcond.h" |
12 |
13 |
14 |
#define CVRATIO 0.025 /* fraction of samples allowed > env. */ |
15 |
16 |
#define exp10(x) exp(2.302585093*(x)) |
17 |
18 |
float modhist[HISTRES]; /* modified histogram */ |
19 |
double mhistot; /* modified histogram total */ |
20 |
float cumf[HISTRES+1]; /* cumulative distribution function */ |
21 |
22 |
23 |
getfixations(fp) /* load fixation history list */ |
24 |
FILE *fp; |
25 |
26 |
#define FIXHUNK 128 |
27 |
RESOLU fvres; |
28 |
int pos[2]; |
29 |
register int px, py, i; |
30 |
/* initialize our resolution struct */ |
31 |
if ((fvres.or=inpres.or)&YMAJOR) { |
32 |
fvres.xr = fvxr; |
33 |
fvres.yr = fvyr; |
34 |
} else { |
35 |
fvres.xr = fvyr; |
36 |
fvres.yr = fvxr; |
37 |
38 |
/* read each picture position */ |
39 |
while (fscanf(fp, "%d %d", &pos[0], &pos[1]) == 2) { |
40 |
/* convert to closest index in foveal image */ |
41 |
loc2pix(pos, &fvres, |
42 |
(pos[0]+.5)/inpres.xr, (pos[1]+.5)/inpres.yr); |
43 |
/* include nine neighborhood samples */ |
44 |
for (px = pos[0]-1; px <= pos[0]+1; px++) { |
45 |
if (px < 0 || px >= fvxr) |
46 |
continue; |
47 |
for (py = pos[1]-1; py <= pos[1]+1; py++) { |
48 |
if (py < 0 || py >= fvyr) |
49 |
continue; |
50 |
for (i = nfixations; i-- > 0; ) |
51 |
if (fixlst[i][0] == px && |
52 |
fixlst[i][1] == py) |
53 |
break; |
54 |
if (i >= 0) |
55 |
continue; /* already there */ |
56 |
if (nfixations % FIXHUNK == 0) { |
57 |
if (nfixations) |
58 |
fixlst = (short (*)[2]) |
59 |
realloc((char *)fixlst, |
60 |
(nfixations+FIXHUNK)* |
61 |
2*sizeof(short)); |
62 |
else |
63 |
fixlst = (short (*)[2])malloc( |
64 |
FIXHUNK*2*sizeof(short) |
65 |
66 |
if (fixlst == NULL) |
67 |
syserror("malloc"); |
68 |
69 |
fixlst[nfixations][0] = px; |
70 |
fixlst[nfixations][1] = py; |
71 |
nfixations++; |
72 |
73 |
74 |
75 |
if (!feof(fp)) { |
76 |
fprintf(stderr, "%s: format error reading fixation data\n", |
77 |
progname); |
78 |
exit(1); |
79 |
80 |
#undef FIXHUNK |
81 |
82 |
83 |
84 |
double |
85 |
centprob(x, y) /* center-weighting probability function */ |
86 |
int x, y; |
87 |
88 |
double xr, yr, p; |
89 |
/* paraboloid, 0 at 90 degrees from center */ |
90 |
xr = (x - .5*(fvxr-1))/90.; /* 180 degree fisheye has fv?r == 90 */ |
91 |
yr = (y - .5*(fvyr-1))/90.; |
92 |
p = 1. - xr*xr - yr*yr; |
93 |
return(p < 0. ? 0. : p); |
94 |
95 |
96 |
97 |
comphist() /* create foveal sampling histogram */ |
98 |
99 |
double l, b, w, lwmin, lwmax; |
100 |
register int x, y; |
101 |
102 |
lwmin = 1e10; /* find extrema */ |
103 |
lwmax = 0.; |
104 |
for (y = 0; y < fvyr; y++) |
105 |
for (x = 0; x < fvxr; x++) { |
106 |
l = plum(fovscan(y)[x]); |
107 |
if (l < lwmin) lwmin = l; |
108 |
if (l > lwmax) lwmax = l; |
109 |
110 |
lwmin -= FTINY; |
111 |
lwmax += FTINY; |
112 |
if (lwmin < LMIN) lwmin = LMIN; |
113 |
if (lwmax > LMAX) lwmax = LMAX; |
114 |
bwmin = Bl(lwmin); |
115 |
bwmax = Bl(lwmax); |
116 |
/* (re)compute histogram */ |
117 |
bwavg = 0.; |
118 |
histot = 0.; |
119 |
for (x = 0; x < HISTRES; x++) |
120 |
bwhist[x] = 0.; |
121 |
/* global average */ |
122 |
if (!(what2do&DO_FIXHIST) || fixfrac < 1.-FTINY) |
123 |
124 |
125 |
126 |
if (l < lwmin) continue; |
127 |
if (l > lwmax) continue; |
128 |
b = Bl(l); |
129 |
bwavg += b; |
130 |
w = what2do&DO_CWEIGHT ? centprob(x,y) : 1.; |
131 |
bwhist[bwhi(b)] += w; |
132 |
histot += w; |
133 |
134 |
/* average fixation points */ |
135 |
if (what2do&DO_FIXHIST && nfixations > 0) { |
136 |
if (histot > FTINY) |
137 |
w = fixfrac/(1.-fixfrac)*histot/nfixations; |
138 |
else |
139 |
w = 1.; |
140 |
for (x = 0; x < nfixations; x++) { |
141 |
l = plum(fovscan(fixlst[x][1])[fixlst[x][0]]); |
142 |
143 |
144 |
b = Bl(l); |
145 |
bwavg += b; |
146 |
147 |
histot += w; |
148 |
149 |
150 |
bwavg /= histot; |
151 |
152 |
153 |
154 |
mkcumf() /* make cumulative distribution function */ |
155 |
156 |
register int i; |
157 |
register double sum; |
158 |
159 |
mhistot = 0.; /* compute modified total */ |
160 |
for (i = 0; i < HISTRES; i++) |
161 |
mhistot += modhist[i]; |
162 |
163 |
sum = 0.; /* compute cumulative function */ |
164 |
for (i = 0; i < HISTRES; i++) { |
165 |
cumf[i] = sum/mhistot; |
166 |
sum += modhist[i]; |
167 |
168 |
cumf[HISTRES] = 1.; |
169 |
170 |
171 |
172 |
double |
173 |
cf(b) /* return cumulative function at b */ |
174 |
double b; |
175 |
176 |
double x; |
177 |
register int i; |
178 |
179 |
i = x = HISTRES*(b - bwmin)/(bwmax - bwmin); |
180 |
x -= (double)i; |
181 |
return(cumf[i]*(1.-x) + cumf[i+1]*x); |
182 |
183 |
184 |
185 |
double |
186 |
BLw(Lw) /* map world luminance to display brightness */ |
187 |
double Lw; |
188 |
189 |
double b; |
190 |
191 |
if (Lw <= LMIN || (b = Bl(Lw)) <= bwmin+FTINY) |
192 |
return(Bldmin); |
193 |
if (b >= bwmax-FTINY) |
194 |
return(Bldmax); |
195 |
return(Bldmin + cf(b)*(Bldmax-Bldmin)); |
196 |
197 |
198 |
199 |
double |
200 |
htcontrs(La) /* human threshold contrast sensitivity, dL(La) */ |
201 |
double La; |
202 |
203 |
double l10La, l10dL; |
204 |
/* formula taken from Ferwerda et al. [SG96] */ |
205 |
if (La < 1.148e-4) |
206 |
return(1.38e-3); |
207 |
l10La = log10(La); |
208 |
if (l10La < -1.44) /* rod response regime */ |
209 |
l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86; |
210 |
else if (l10La < -.0184) |
211 |
l10dL = l10La - .395; |
212 |
else if (l10La < 1.9) /* cone response regime */ |
213 |
l10dL = pow(.249*l10La + .65, 2.7) - .72; |
214 |
else |
215 |
l10dL = l10La - 1.255; |
216 |
217 |
return(exp10(l10dL)); |
218 |
219 |
220 |
221 |
double |
222 |
clampf(Lw) /* derivative clamping function */ |
223 |
double Lw; |
224 |
225 |
double bLw, ratio; |
226 |
227 |
bLw = BLw(Lw); /* apply current brightness map */ |
228 |
ratio = what2do&DO_HSENS ? htcontrs(Lb(bLw))/htcontrs(Lw) : Lb(bLw)/Lw; |
229 |
return(ratio/(Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw))); |
230 |
231 |
232 |
233 |
int |
234 |
mkbrmap() /* make dynamic range map */ |
235 |
236 |
double T, b, s; |
237 |
double ceiling, trimmings; |
238 |
register int i; |
239 |
/* copy initial histogram */ |
240 |
bcopy((char *)bwhist, (char *)modhist, sizeof(modhist)); |
241 |
s = (bwmax - bwmin)/HISTRES; |
242 |
/* loop until satisfactory */ |
243 |
do { |
244 |
mkcumf(); /* sync brightness mapping */ |
245 |
if (mhistot <= histot*CVRATIO) |
246 |
return(-1); /* no compression needed! */ |
247 |
T = mhistot * (bwmax - bwmin) / HISTRES; |
248 |
trimmings = 0.; /* clip to envelope */ |
249 |
for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { |
250 |
ceiling = T*clampf(Lb(b)); |
251 |
if (modhist[i] > ceiling) { |
252 |
trimmings += modhist[i] - ceiling; |
253 |
modhist[i] = ceiling; |
254 |
255 |
256 |
} while (trimmings > histot*CVRATIO); |
257 |
258 |
return(0); /* we got it */ |
259 |
260 |
261 |
262 |
scotscan(scan, xres) /* apply scotopic color sensitivity loss */ |
263 |
COLOR *scan; |
264 |
int xres; |
265 |
266 |
COLOR ctmp; |
267 |
double incolor, b, Lw; |
268 |
register int i; |
269 |
270 |
for (i = 0; i < xres; i++) { |
271 |
Lw = plum(scan[i]); |
272 |
if (Lw >= TopMesopic) |
273 |
incolor = 1.; |
274 |
else if (Lw <= BotMesopic) |
275 |
incolor = 0.; |
276 |
else |
277 |
incolor = (Lw - BotMesopic) / |
278 |
(TopMesopic - BotMesopic); |
279 |
if (incolor < 1.-FTINY) { |
280 |
b = (1.-incolor)*slum(scan[i])*inpexp/SWNORM; |
281 |
if (lumf == rgblum) b /= WHTEFFICACY; |
282 |
setcolor(ctmp, b, b, b); |
283 |
if (incolor <= FTINY) |
284 |
setcolor(scan[i], 0., 0., 0.); |
285 |
else |
286 |
scalecolor(scan[i], incolor); |
287 |
addcolor(scan[i], ctmp); |
288 |
289 |
290 |
291 |
292 |
293 |
mapscan(scan, xres) /* apply tone mapping operator to scanline */ |
294 |
COLOR *scan; |
295 |
int xres; |
296 |
297 |
double mult, Lw, b; |
298 |
register int i; |
299 |
300 |
301 |
302 |
if (Lw < LMIN) { |
303 |
304 |
continue; |
305 |
306 |
b = BLw(Lw); |
307 |
mult = (Lb(b) - ldmin)/(ldmax - ldmin) / (Lw*inpexp); |
308 |
if (lumf == rgblum) mult *= WHTEFFICACY; |
309 |
scalecolor(scan[i], mult); |
310 |
311 |
312 |
313 |
314 |
putmapping(fp) /* put out mapping function */ |
315 |
FILE *fp; |
316 |
317 |
double b, s; |
318 |
register int i; |
319 |
double wlum, sf, dlum; |
320 |
321 |
sf = scalef*inpexp; |
322 |
if (lumf == cielum) sf *= WHTEFFICACY; |
323 |
324 |
325 |
wlum = Lb(b); |
326 |
if (what2do&DO_LINEAR) { |
327 |
dlum = sf*wlum; |
328 |
if (dlum > ldmax) dlum = ldmax; |
329 |
else if (dlum < ldmin) dlum = ldmin; |
330 |
fprintf(fp, "%e %e\n", wlum, dlum); |
331 |
} else |
332 |
fprintf(fp, "%e %e\n", wlum, Lb(BLw(wlum))); |
333 |
334 |
