--- ray/src/px/pcond3.c 1997/01/09 13:56:30 3.5 +++ ray/src/px/pcond3.c 2004/03/28 20:33:14 3.15 @@ -1,28 +1,255 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pcond3.c,v 3.15 2004/03/28 20:33:14 schorsch Exp $"; #endif - /* * Routines for computing and applying brightness mapping. */ +#include + #include "pcond.h" #define CVRATIO 0.025 /* fraction of samples allowed > env. */ -#define exp10(x) exp(2.302585093*(x)) +#define LN_10 2.30258509299404568402 +#define exp10(x) exp(LN_10*(x)) -float modhist[HISTRES]; /* modified histogram */ +double modhist[HISTRES]; /* modified histogram */ double mhistot; /* modified histogram total */ -float cumf[HISTRES+1]; /* cumulative distribution function */ +double cumf[HISTRES+1]; /* cumulative distribution function */ +static double centprob(int x, int y); +static void mkcumf(void); +static double cf(double b); +static double BLw(double Lw); +#if ADJ_VEIL +static void mkcrfimage(void); +#endif -mkcumf() /* make cumulative distribution function */ + + +extern void +getfixations( /* load fixation history list */ +FILE *fp +) { +#define FIXHUNK 128 + RESOLU fvres; + int pos[2]; + register int px, py, i; + /* initialize our resolution struct */ + if ((fvres.rt=inpres.rt)&YMAJOR) { + fvres.xr = fvxr; + fvres.yr = fvyr; + } else { + fvres.xr = fvyr; + fvres.yr = fvxr; + } + /* read each picture position */ + while (fscanf(fp, "%d %d", &pos[0], &pos[1]) == 2) { + /* convert to closest index in foveal image */ + loc2pix(pos, &fvres, + (pos[0]+.5)/inpres.xr, (pos[1]+.5)/inpres.yr); + /* include nine neighborhood samples */ + for (px = pos[0]-1; px <= pos[0]+1; px++) { + if (px < 0 || px >= fvxr) + continue; + for (py = pos[1]-1; py <= pos[1]+1; py++) { + if (py < 0 || py >= fvyr) + continue; + for (i = nfixations; i-- > 0; ) + if (fixlst[i][0] == px && + fixlst[i][1] == py) + break; + if (i >= 0) + continue; /* already there */ + if (nfixations % FIXHUNK == 0) { + if (nfixations) + fixlst = (short (*)[2]) + realloc((void *)fixlst, + (nfixations+FIXHUNK)* + 2*sizeof(short)); + else + fixlst = (short (*)[2])malloc( + FIXHUNK*2*sizeof(short) + ); + if (fixlst == NULL) + syserror("malloc"); + } + fixlst[nfixations][0] = px; + fixlst[nfixations][1] = py; + nfixations++; + } + } + } + if (!feof(fp)) { + fprintf(stderr, "%s: format error reading fixation data\n", + progname); + exit(1); + } +#undef FIXHUNK +} + + +extern void +gethisto( /* load precomputed luminance histogram */ + FILE *fp +) +{ + double histo[MAXPREHIST]; + double histart, histep; + double b, lastb, w; + int n; register int i; + /* load data */ + for (i = 0; i < MAXPREHIST && + fscanf(fp, "%lf %lf", &b, &histo[i]) == 2; i++) { + if (i > 1 && fabs(b - lastb - histep) > .001) { + fprintf(stderr, + "%s: uneven step size in histogram data\n", + progname); + exit(1); + } + if (i == 1) + if ((histep = b - (histart = lastb)) <= FTINY) { + fprintf(stderr, + "%s: illegal step in histogram data\n", + progname); + exit(1); + } + lastb = b; + } + if (i < 2 || !feof(fp)) { + fprintf(stderr, + "%s: format/length error loading histogram (log10L %f at %d)\n", + progname, b, i); + exit(1); + } + n = i; + histart *= LN_10; + histep *= LN_10; + /* find extrema */ + for (i = 0; i < n && histo[i] <= FTINY; i++) + ; + bwmin = histart + (i-.001)*histep; + for (i = n; i-- && histo[i] <= FTINY; ) + ; + bwmax = histart + (i+1.001)*histep; + if (bwmax > Bl(LMAX)) + bwmax = Bl(LMAX); + if (bwmin < Bl(LMIN)) + bwmin = Bl(LMIN); + else /* duplicate bottom bin */ + bwmin = bwmax - (bwmax-bwmin)*HISTRES/(HISTRES-1); + /* convert histogram */ + bwavg = 0.; histot = 0.; + for (i = 0; i < HISTRES; i++) + bwhist[i] = 0.; + for (i = 0, b = histart; i < n; i++, b += histep) { + if (b < bwmin+FTINY) continue; + if (b >= bwmax-FTINY) break; + w = histo[i]; + bwavg += w*b; + bwhist[bwhi(b)] += w; + histot += w; + } + bwavg /= histot; + if (bwmin > Bl(LMIN)+FTINY) { /* add false samples at bottom */ + bwhist[1] *= 0.5; + bwhist[0] += bwhist[1]; + } +} + + +static double +centprob( /* center-weighting probability function */ + int x, + int y +) +{ + double xr, yr, p; + /* paraboloid, 0 at 90 degrees from center */ + xr = (x - .5*(fvxr-1))/90.; /* 180 degree fisheye has fv?r == 90 */ + yr = (y - .5*(fvyr-1))/90.; + p = 1. - xr*xr - yr*yr; + return(p < 0. ? 0. : p); +} + + +extern void +comphist(void) /* create foveal sampling histogram */ +{ + double l, b, w, lwmin, lwmax; + register int x, y; + /* check for precalculated histogram */ + if (what2do&DO_PREHIST) + return; + lwmin = 1e10; /* find extrema */ + lwmax = 0.; + for (y = 0; y < fvyr; y++) + for (x = 0; x < fvxr; x++) { + l = plum(fovscan(y)[x]); + if (l < lwmin) lwmin = l; + if (l > lwmax) lwmax = l; + } + lwmax *= 1.01; + if (lwmax > LMAX) + lwmax = LMAX; + bwmax = Bl(lwmax); + if (lwmin < LMIN) { + lwmin = LMIN; + bwmin = Bl(LMIN); + } else { /* duplicate bottom bin */ + bwmin = bwmax - (bwmax-Bl(lwmin))*HISTRES/(HISTRES-1); + lwmin = Lb(bwmin); + } + /* (re)compute histogram */ + bwavg = 0.; + histot = 0.; + for (x = 0; x < HISTRES; x++) + bwhist[x] = 0.; + /* global average */ + if (!(what2do&DO_FIXHIST) || fixfrac < 1.-FTINY) + for (y = 0; y < fvyr; y++) + for (x = 0; x < fvxr; x++) { + l = plum(fovscan(y)[x]); + if (l < lwmin+FTINY) continue; + if (l >= lwmax-FTINY) continue; + b = Bl(l); + w = what2do&DO_CWEIGHT ? centprob(x,y) : 1.; + bwavg += w*b; + bwhist[bwhi(b)] += w; + histot += w; + } + /* average fixation points */ + if (what2do&DO_FIXHIST && nfixations > 0) { + if (histot > FTINY) + w = fixfrac/(1.-fixfrac)*histot/nfixations; + else + w = 1.; + for (x = 0; x < nfixations; x++) { + l = plum(fovscan(fixlst[x][1])[fixlst[x][0]]); + if (l < lwmin+FTINY) continue; + if (l >= lwmax-FTINY) continue; + b = Bl(l); + bwavg += w*b; + bwhist[bwhi(b)] += w; + histot += w; + } + } + bwavg /= histot; + if (lwmin > LMIN+FTINY) { /* add false samples at bottom */ + bwhist[1] *= 0.5; + bwhist[0] += bwhist[1]; + } +} + + +static void +mkcumf(void) /* make cumulative distribution function */ +{ + register int i; register double sum; mhistot = 0.; /* compute modified total */ @@ -38,9 +265,10 @@ mkcumf() /* make cumulative distribution function */ } -double -cf(b) /* return cumulative function at b */ -double b; +static double +cf( /* return cumulative function at b */ + double b +) { double x; register int i; @@ -51,9 +279,10 @@ double b; } -double -BLw(Lw) /* map world luminance to display brightness */ -double Lw; +static double +BLw( /* map world luminance to display brightness */ + double Lw +) { double b; @@ -65,9 +294,10 @@ double Lw; } -double -htcontrs(La) /* human threshold contrast sensitivity, dL(La) */ -double La; +extern double +htcontrs( /* human threshold contrast sensitivity, dL(La) */ + double La +) { double l10La, l10dL; /* formula taken from Ferwerda et al. [SG96] */ @@ -87,9 +317,10 @@ double La; } -double -clampf(Lw) /* derivative clamping function */ -double Lw; +extern double +clampf( /* histogram clamping function */ + double Lw +) { double bLw, ratio; @@ -98,35 +329,63 @@ double Lw; return(ratio/(Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw))); } +extern double +crfactor( /* contrast reduction factor */ + double Lw +) +{ + int i = HISTRES*(Bl(Lw) - bwmin)/(bwmax - bwmin); + double bLw, ratio, Tdb; -int -shiftdir(bw) /* compute shift direction for histogram */ -double bw; + if (i <= 0) + return(1.0); + if (i >= HISTRES) + return(1.0); + bLw = BLw(Lw); + ratio = what2do&DO_HSENS ? htcontrs(Lb(bLw))/htcontrs(Lw) : Lb(bLw)/Lw; + Tdb = mhistot * (bwmax - bwmin) / HISTRES; + return(modhist[i]*Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw)/(Tdb*ratio)); +} + + +#if ADJ_VEIL +static void +mkcrfimage(void) /* compute contrast reduction factor image */ { - if (what2do&DO_HSENS && cf(bw) - (bw - bwmin)/(Bldmax - bwmin)) - return(1); - return(-1); + int i; + float *crfptr; + COLOR *fovptr; + + if (crfimg == NULL) + crfimg = (float *)malloc(fvxr*fvyr*sizeof(float)); + if (crfimg == NULL) + syserror("malloc"); + crfptr = crfimg; + fovptr = fovimg; + for (i = fvxr*fvyr; i--; crfptr++, fovptr++) + crfptr[0] = crfactor(plum(fovptr[0])); } +#endif -int -mkbrmap() /* make dynamic range map */ +extern int +mkbrmap(void) /* make dynamic range map */ { - double T, b, s; + double Tdb, b, s; double ceiling, trimmings; register int i; /* copy initial histogram */ - bcopy((char *)bwhist, (char *)modhist, sizeof(modhist)); - s = (bwmax - bwmin)/HISTRES; + memcpy((void *)modhist, (void *)bwhist, sizeof(modhist)); + s = (bwmax - bwmin)/HISTRES; /* s is delta b */ /* loop until satisfactory */ do { mkcumf(); /* sync brightness mapping */ if (mhistot <= histot*CVRATIO) return(-1); /* no compression needed! */ - T = mhistot * (bwmax - bwmin) / HISTRES; + Tdb = mhistot * s; trimmings = 0.; /* clip to envelope */ for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { - ceiling = T*clampf(Lb(b)); + ceiling = Tdb*clampf(Lb(b)); if (modhist[i] > ceiling) { trimmings += modhist[i] - ceiling; modhist[i] = ceiling; @@ -134,13 +393,19 @@ mkbrmap() /* make dynamic range map */ } } while (trimmings > histot*CVRATIO); +#if ADJ_VEIL + mkcrfimage(); /* contrast reduction image */ +#endif + return(0); /* we got it */ } -scotscan(scan, xres) /* apply scotopic color sensitivity loss */ -COLOR *scan; -int xres; +extern void +scotscan( /* apply scotopic color sensitivity loss */ + COLOR *scan, + int xres +) { COLOR ctmp; double incolor, b, Lw; @@ -169,42 +434,49 @@ int xres; } -mapscan(scan, xres) /* apply tone mapping operator to scanline */ -COLOR *scan; -int xres; +extern void +mapscan( /* apply tone mapping operator to scanline */ + COLOR *scan, + int xres +) { double mult, Lw, b; - register int i; + register int x; - for (i = 0; i < xres; i++) { - Lw = plum(scan[i]); + for (x = 0; x < xres; x++) { + Lw = plum(scan[x]); if (Lw < LMIN) { - setcolor(scan[i], 0., 0., 0.); + setcolor(scan[x], 0., 0., 0.); continue; } - b = BLw(Lw); - mult = (Lb(b) - ldmin)/(ldmax - ldmin) / (Lw*inpexp); + b = BLw(Lw); /* apply brightness mapping */ + mult = (Lb(b) - ldmin)/(ldmax - ldmin)/(Lw*inpexp); if (lumf == rgblum) mult *= WHTEFFICACY; - scalecolor(scan[i], mult); + scalecolor(scan[x], mult); } } -putmapping(fp) /* put out mapping function */ -FILE *fp; +extern void +putmapping( /* put out mapping function */ + FILE *fp +) { double b, s; register int i; - double wlum, sf; + double wlum, sf, dlum; sf = scalef*inpexp; if (lumf == cielum) sf *= WHTEFFICACY; s = (bwmax - bwmin)/HISTRES; for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { wlum = Lb(b); - if (what2do&DO_LINEAR) - fprintf(fp, "%e %e\n", wlum, sf*wlum); - else + if (what2do&DO_LINEAR) { + dlum = sf*wlum; + if (dlum > ldmax) dlum = ldmax; + else if (dlum < ldmin) dlum = ldmin; + fprintf(fp, "%e %e\n", wlum, dlum); + } else fprintf(fp, "%e %e\n", wlum, Lb(BLw(wlum))); } }
