root/radiance/ray/src/px/pcond3.c
Wed Sep 11 18:56:12 2024 UTC (8 months, 1 week ago) by greg
Changes since 3.19: +3 -2 lines
Diff to previous 3.19 , to selected 3.2
feat(pcond,pvalue): Added hyperspectral input handling
Tue Apr 13 02:56:42 2021 UTC (4 years, 1 month ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18 , to selected 3.2
perf(pcond): more aggressive trim criterion for tone curve
Sat Jun 27 03:37:24 2020 UTC (4 years, 10 months ago) by greg
Changes since 3.17: +75 -7 lines
Diff to previous 3.17 , to selected 3.2
perf(pcond): added random point sampling to histogram for more robust mapping
Thu Nov 30 18:43:05 2017 UTC (7 years, 5 months ago) by greg
Changes since 3.16: +3 -3 lines
Diff to previous 3.16 , to selected 3.2
Fixed issue with missing veil from very bright sources like the sun
Fri Aug 21 05:48:28 2015 UTC (9 years, 9 months ago) by greg
CVS Tags: rad5R0, rad5R1
Changes since 3.15: +23 -23 lines
Diff to previous 3.15 , to selected 3.2
Fixed issue with undersampled histogram in phisto
Sun Mar 28 20:33:14 2004 UTC (21 years, 2 months ago) by schorsch
CVS Tags: rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Changes since 3.14: +66 -37 lines
Diff to previous 3.14 , to selected 3.2
Mon Jun 30 14:59:12 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.13: +4 -2 lines
Diff to previous 3.13 , to selected 3.2
Tue May 13 17:58:33 2003 UTC (22 years ago) by greg
Changes since 3.12: +1 -1 lines
Diff to previous 3.12 , to selected 3.2
Wed Apr 23 00:52:34 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.11: +1 -1 lines
Diff to previous 3.11 , to selected 3.2
Sat Feb 22 02:07:27 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.10: +73 -31 lines
Diff to previous 3.10 , to selected 3.2
Thu Mar 12 15:47:34 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.9: +70 -4 lines
Diff to previous 3.9 , to selected 3.2
added -I option for precomputed histogram
Fri Apr 11 18:34:39 1997 UTC (28 years, 1 month ago) by greg
Changes since 3.8: +14 -5 lines
Diff to previous 3.8 , to selected 3.2
added an extra histogram bin at lower limit to avoid clipping
Wed Jan 29 13:22:13 1997 UTC (28 years, 3 months ago) by greg
Changes since 3.7: +131 -0 lines
Diff to previous 3.7 , to selected 3.2
added -i option to take fixation points on standard input
Sat Jan 11 10:39:25 1997 UTC (28 years, 4 months ago) by greg
Changes since 3.6: +8 -5 lines
Diff to previous 3.6 , to selected 3.2
fixed writing of linear ramp with -m option
Fri Jan 10 16:48:21 1997 UTC (28 years, 4 months ago) by greg
Changes since 3.5: +0 -10 lines
Diff to previous 3.5 , to selected 3.2
removed shiftdir() function, which is no longer needed
Thu Jan 9 13:56:30 1997 UTC (28 years, 4 months ago) by greg
Changes since 3.4: +27 -84 lines
Diff to previous 3.4 , to selected 3.2
Wed Jan 8 17:57:01 1997 UTC (28 years, 4 months ago) by greg
Changes since 3.3: +21 -1 lines
Diff to previous 3.3 , to selected 3.2
added -m option to print out mapping function
Fri Oct 11 10:47:00 1996 UTC (28 years, 7 months ago) by greg
Changes since 3.2: +0 -3 lines
Diff to previous 3.2
corrected tests in check2do()
Revision 3.2 - (view) (download) (annotate) - [selected]
Thu Oct 10 17:09:26 1996 UTC (28 years, 7 months ago) by greg
Changes since 3.1: +3 -3 lines
fixed bugs in color scaling
Thu Oct 3 16:52:50 1996 UTC (28 years, 7 months ago) by greg
Diff to selected 3.2
