--- ray/src/px/pcond3.c 1996/10/11 10:47:00 3.3 +++ ray/src/px/pcond3.c 2021/04/13 02:56:42 3.19 @@ -1,45 +1,345 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pcond3.c,v 3.19 2021/04/13 02:56:42 greg Exp $"; #endif - /* * Routines for computing and applying brightness mapping. */ +#include + #include "pcond.h" +#include "random.h" -#define CVRATIO 0.025 /* fraction of pixels allowed > env. */ +#define CVRATIO 0.025 /* fraction of samples allowed > env. */ -#define exp10(x) exp(2.302585093*(x)) +#define LN_10 2.30258509299404568402 +#define exp10(x) exp(LN_10*(x)) -int modhist[HISTRES]; /* modified histogram */ -float cumf[HISTRES+1]; /* cumulative distribution function */ +double modhist[HISTRES]; /* modified histogram */ +double mhistot; /* modified histogram total */ +double cumf[HISTRES+1]; /* cumulative distribution function */ +static double centprob(int x, int y); +static void mkcumf(void); +static double cf(double b); +static double BLw(double Lw); +static float *getlumsamp(int n); +#if ADJ_VEIL +static void mkcrfimage(void); +#endif -mkcumf() /* make cumulative distribution function */ + + +void +getfixations( /* load fixation history list */ +FILE *fp +) { - register int i; - register long sum; +#define FIXHUNK 128 + RESOLU fvres; + int pos[2]; + int px, py, i; + /* initialize our resolution struct */ + if ((fvres.rt=inpres.rt)&YMAJOR) { + fvres.xr = fvxr; + fvres.yr = fvyr; + } else { + fvres.xr = fvyr; + fvres.yr = fvxr; + } + /* read each picture position */ + while (fscanf(fp, "%d %d", &pos[0], &pos[1]) == 2) { + /* convert to closest index in foveal image */ + loc2pix(pos, &fvres, + (pos[0]+.5)/inpres.xr, (pos[1]+.5)/inpres.yr); + /* include nine neighborhood samples */ + for (px = pos[0]-1; px <= pos[0]+1; px++) { + if (px < 0 || px >= fvxr) + continue; + for (py = pos[1]-1; py <= pos[1]+1; py++) { + if (py < 0 || py >= fvyr) + continue; + for (i = nfixations; i-- > 0; ) + if (fixlst[i][0] == px && + fixlst[i][1] == py) + break; + if (i >= 0) + continue; /* already there */ + if (nfixations % FIXHUNK == 0) { + if (nfixations) + fixlst = (short (*)[2]) + realloc((void *)fixlst, + (nfixations+FIXHUNK)* + 2*sizeof(short)); + else + fixlst = (short (*)[2])malloc( + FIXHUNK*2*sizeof(short) + ); + if (fixlst == NULL) + syserror("malloc"); + } + fixlst[nfixations][0] = px; + fixlst[nfixations][1] = py; + nfixations++; + } + } + } + if (!feof(fp)) { + fprintf(stderr, "%s: format error reading fixation data\n", + progname); + exit(1); + } +#undef FIXHUNK +} - cumf[0] = 0.; - sum = modhist[0]; - for (i = 1; i < HISTRES; i++) { - cumf[i] = (double)sum/histot; + +void +gethisto( /* load precomputed luminance histogram */ + FILE *fp +) +{ + double histo[MAXPREHIST]; + double histart, histep; + double b, lastb, w; + int n; + int i; + /* load data */ + for (i = 0; i < MAXPREHIST && + fscanf(fp, "%lf %lf", &b, &histo[i]) == 2; i++) { + if (i > 1 && fabs(b - lastb - histep) > .001) { + fprintf(stderr, + "%s: uneven step size in histogram data\n", + progname); + exit(1); + } + if (i == 1) + if ((histep = b - (histart = lastb)) <= FTINY) { + fprintf(stderr, + "%s: illegal step in histogram data\n", + progname); + exit(1); + } + lastb = b; + } + if (i < 2 || !feof(fp)) { + fprintf(stderr, + "%s: format/length error loading histogram (log10L %f at %d)\n", + progname, b, i); + exit(1); + } + n = i; + histart *= LN_10; + histep *= LN_10; + /* find extrema */ + for (i = 0; i < n && histo[i] <= FTINY; i++) + ; + bwmin = histart + (i-.001)*histep; + for (i = n; i-- && histo[i] <= FTINY; ) + ; + bwmax = histart + (i+1.001)*histep; + if (bwmax > Bl(LMAX)) + bwmax = Bl(LMAX); + if (bwmin < Bl(LMIN)) + bwmin = Bl(LMIN); + else /* duplicate bottom bin */ + bwmin = bwmax - (bwmax-bwmin)*HISTRES/(HISTRES-1); + /* convert histogram */ + bwavg = 0.; histot = 0.; + for (i = 0; i < HISTRES; i++) + bwhist[i] = 0.; + for (i = 0, b = histart; i < n; i++, b += histep) { + if (b < bwmin+FTINY) continue; + if (b >= bwmax-FTINY) break; + w = histo[i]; + bwavg += w*b; + bwhist[bwhi(b)] += w; + histot += w; + } + bwavg /= histot; + if (bwmin > Bl(LMIN)+FTINY) { /* add false samples at bottom */ + bwhist[1] *= 0.5; + bwhist[0] += bwhist[1]; + } +} + + +static double +centprob( /* center-weighting probability function */ + int x, + int y +) +{ + double xr, yr, p; + /* paraboloid, 0 at 90 degrees from center */ + xr = (x - .5*(fvxr-1))/90.; /* 180 degree fisheye has fv?r == 90 */ + yr = (y - .5*(fvyr-1))/90.; + p = 1. - xr*xr - yr*yr; + return(p < 0. ? 0. : p); +} + + +static float * +getlumsamp(int n) /* get set of random point sample luminances */ +{ + float *ls = (float *)malloc(n*sizeof(float)); + COLR *cscan = (COLR *)malloc(scanlen(&inpres)*sizeof(COLR)); + long startpos = ftell(infp); + long npleft = (long)inpres.xr*inpres.yr; + int x; + + if ((ls == NULL) | (cscan == NULL)) + syserror("malloc"); + x = 0; /* read/convert samples */ + while (n > 0) { + COLOR col; + int sv = 0; + double rval, cumprob = 0; + + if (x <= 0 && freadcolrs(cscan, x=scanlen(&inpres), infp) < 0) { + fprintf(stderr, "%s: %s: scanline read error\n", + progname, infn); + exit(1); + } + rval = frandom(); /* random distance to next sample */ + while ((cumprob += (1.-cumprob)*n/(npleft-sv)) < rval) + sv++; + if (x < ++sv) { /* out of pixels in this scanline */ + npleft -= x; + x = 0; + continue; + } + x -= sv; + colr_color(col, cscan[x]); + ls[--n] = plum(col); + npleft -= sv; + } + free(cscan); /* clean up and reset file pointer */ + if (fseek(infp, startpos, SEEK_SET) < 0) + syserror("fseek"); + return(ls); +} + + +void +comphist(void) /* create foveal sampling histogram */ +{ + double l, b, w, lwmin, lwmax; + float *lumsamp; + int nlumsamp; + int x, y; + /* check for precalculated histogram */ + if (what2do&DO_PREHIST) + return; + lwmin = 1e10; /* find extrema */ + lwmax = 0.; + for (y = 0; y < fvyr; y++) + for (x = 0; x < fvxr; x++) { + l = plum(fovscan(y)[x]); + if (l < lwmin) lwmin = l; + if (l > lwmax) lwmax = l; + } + /* sample luminance pixels */ + nlumsamp = fvxr*fvyr*16; + if (nlumsamp > inpres.xr*inpres.yr) + nlumsamp = inpres.xr*inpres.yr; + lumsamp = getlumsamp(nlumsamp); + for (x = nlumsamp; x--; ) { + l = lumsamp[x]; + if (l < lwmin) lwmin = l; + if (l > lwmax) lwmax = l; + } + lwmax *= 1.01; + if (lwmax > LMAX) + lwmax = LMAX; + bwmax = Bl(lwmax); + if (lwmin < LMIN) { + lwmin = LMIN; + bwmin = Bl(LMIN); + } else { /* duplicate bottom bin */ + bwmin = bwmax - (bwmax-Bl(lwmin))*HISTRES/(HISTRES-1); + lwmin = Lb(bwmin); + } + /* (re)compute histogram */ + bwavg = 0.; + histot = 0.; + memset(bwhist, 0, sizeof(bwhist)); + /* global average */ + if (!(what2do&DO_FIXHIST) || fixfrac < 1.-FTINY) { + for (y = 0; y < fvyr; y++) + for (x = 0; x < fvxr; x++) { + l = plum(fovscan(y)[x]); + if (l < lwmin+FTINY) continue; + if (l >= lwmax-FTINY) continue; + b = Bl(l); + w = what2do&DO_CWEIGHT ? centprob(x,y) : 1.; + bwavg += w*b; + bwhist[bwhi(b)] += w; + histot += w; + } + /* weight for point luminances */ + w = 1. * histot / nlumsamp; + for (x = nlumsamp; x--; ) { + l = lumsamp[x]; + if (l < lwmin+FTINY) continue; + if (l >= lwmax-FTINY) continue; + b = Bl(l); + bwavg += w*b; + bwhist[bwhi(b)] += w; + histot += w; + } + } + /* average fixation points */ + if (what2do&DO_FIXHIST && nfixations > 0) { + if (histot > FTINY) + w = fixfrac/(1.-fixfrac)*histot/nfixations; + else + w = 1.; + for (x = 0; x < nfixations; x++) { + l = plum(fovscan(fixlst[x][1])[fixlst[x][0]]); + if (l < lwmin+FTINY) continue; + if (l >= lwmax-FTINY) continue; + b = Bl(l); + bwavg += w*b; + bwhist[bwhi(b)] += w; + histot += w; + } + } + bwavg /= histot; + if (lwmin > LMIN+FTINY) { /* add false samples at bottom */ + bwhist[1] *= 0.5; + bwhist[0] += bwhist[1]; + } + free(lumsamp); +} + + +static void +mkcumf(void) /* make cumulative distribution function */ +{ + int i; + double sum; + + mhistot = 0.; /* compute modified total */ + for (i = 0; i < HISTRES; i++) + mhistot += modhist[i]; + + sum = 0.; /* compute cumulative function */ + for (i = 0; i < HISTRES; i++) { + cumf[i] = sum/mhistot; sum += modhist[i]; } cumf[HISTRES] = 1.; } -double -cf(b) /* return cumulative function at b */ -double b; +static double +cf( /* return cumulative function at b */ + double b +) { double x; - register int i; + int i; i = x = HISTRES*(b - bwmin)/(bwmax - bwmin); x -= (double)i; @@ -47,9 +347,10 @@ double b; } -double -BLw(Lw) /* map world luminance to display brightness */ -double Lw; +static double +BLw( /* map world luminance to display brightness */ + double Lw +) { double b; @@ -57,13 +358,14 @@ double Lw; return(Bldmin); if (b >= bwmax-FTINY) return(Bldmax); - return(Bldmin + cf(Bl(Lw))*(Bldmax-Bldmin)); + return(Bldmin + cf(b)*(Bldmax-Bldmin)); } double -htcontrs(La) /* human threshold contrast sensitivity, dL(La) */ -double La; +htcontrs( /* human threshold contrast sensitivity, dL(La) */ + double La +) { double l10La, l10dL; /* formula taken from Ferwerda et al. [SG96] */ @@ -84,8 +386,9 @@ double La; double -clampf(Lw) /* derivative clamping function */ -double Lw; +clampf( /* histogram clamping function */ + double Lw +) { double bLw, ratio; @@ -94,78 +397,87 @@ double Lw; return(ratio/(Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw))); } +double +crfactor( /* contrast reduction factor */ + double Lw +) +{ + int i = HISTRES*(Bl(Lw) - bwmin)/(bwmax - bwmin); + double bLw, ratio, Tdb; -int -shiftdir(bw) /* compute shift direction for histogram */ -double bw; + if (i <= 0) + return(1.0); + if (i >= HISTRES) + return(1.0); + bLw = BLw(Lw); + ratio = what2do&DO_HSENS ? htcontrs(Lb(bLw))/htcontrs(Lw) : Lb(bLw)/Lw; + Tdb = mhistot * (bwmax - bwmin) / HISTRES; + return(modhist[i]*Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw)/(Tdb*ratio)); +} + + +#if ADJ_VEIL +static void +mkcrfimage(void) /* compute contrast reduction factor image */ { - if (what2do&DO_HSENS && cf(bw) - (bw - bwmin)/(Bldmax - bwmin)) - return(1); - return(-1); + int i; + float *crfptr; + COLOR *fovptr; + + if (crfimg == NULL) + crfimg = (float *)malloc(fvxr*fvyr*sizeof(float)); + if (crfimg == NULL) + syserror("malloc"); + crfptr = crfimg; + fovptr = fovimg; + for (i = fvxr*fvyr; i--; crfptr++, fovptr++) + crfptr[0] = crfactor(plum(fovptr[0])); } +#endif int -mkbrmap() /* make dynamic range map */ +mkbrmap(void) /* make dynamic range map */ { - int hdiffs[HISTRES], above, below; - double T, b, s; - int maxd, maxi, sd; - register int i; + double Tdb, b, s; + double ceiling, trimmings; + int i; /* copy initial histogram */ - for (i = 0; i < HISTRES; i++) - modhist[i] = bwhist[i]; - T = histot * (bwmax - bwmin) / HISTRES; - s = (bwmax - bwmin)/HISTRES; + memcpy((void *)modhist, (void *)bwhist, sizeof(modhist)); + s = (bwmax - bwmin)/HISTRES; /* s is delta b */ /* loop until satisfactory */ - for ( ; ; ) { - mkcumf(); /* sync brightness mapping */ - above = below = 0; /* compute visibility overflow */ + do { + mkcumf(); /* sync brightness mapping */ + if (mhistot <= histot*CVRATIO) + return(-1); /* no compression needed! */ + Tdb = mhistot * s; + trimmings = 0.; /* clip to envelope */ for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { - hdiffs[i] = modhist[i] - (int)(T*clampf(Lb(b)) + .5); - if (hdiffs[i] > 0) above += hdiffs[i]; - else below -= hdiffs[i]; + ceiling = Tdb*clampf(Lb(b)); + if (modhist[i] > ceiling) { + trimmings += modhist[i] - ceiling; + modhist[i] = ceiling; + } } - if (above <= histot*CVRATIO) - break; /* close enough */ - if (above-below >= 0) - return(-1); /* Houston, we have a problem.... */ - /* original looped here as well (BEGIN_L2) */ - maxd = 0; /* find largest overvis */ - for (i = 0; i < HISTRES; i++) - if (hdiffs[i] > maxd) - maxd = hdiffs[maxi=i]; - /* broke loop here when (maxd == 0) (BREAK_L2) */ - for (sd = shiftdir((maxi+.5)/HISTRES*(bwmax-bwmin)+bwmin); - hdiffs[maxi] == maxd; sd = -sd) - for (i = maxi+sd; i >= 0 & i < HISTRES; i += sd) - if (hdiffs[i] < 0) { - if (hdiffs[i] <= -maxd) { - modhist[i] += maxd; - modhist[maxi] -= maxd; - hdiffs[i] += maxd; - hdiffs[maxi] = 0; - } else { - modhist[maxi] += hdiffs[i]; - modhist[i] -= hdiffs[i]; - hdiffs[maxi] += hdiffs[i]; - hdiffs[i] = 0; - } - break; - } - /* (END_L2) */ - } - return(0); + } while (trimmings > mhistot*CVRATIO); + +#if ADJ_VEIL + mkcrfimage(); /* contrast reduction image */ +#endif + + return(0); /* we got it */ } -scotscan(scan, xres) /* apply scotopic color sensitivity loss */ -COLOR *scan; -int xres; +void +scotscan( /* apply scotopic color sensitivity loss */ + COLOR *scan, + int xres +) { COLOR ctmp; double incolor, b, Lw; - register int i; + int i; for (i = 0; i < xres; i++) { Lw = plum(scan[i]); @@ -190,58 +502,49 @@ int xres; } -mapscan(scan, xres) /* apply tone mapping operator to scanline */ -COLOR *scan; -int xres; +void +mapscan( /* apply tone mapping operator to scanline */ + COLOR *scan, + int xres +) { double mult, Lw, b; - register int i; + int x; - for (i = 0; i < xres; i++) { - Lw = plum(scan[i]); + for (x = 0; x < xres; x++) { + Lw = plum(scan[x]); if (Lw < LMIN) { - setcolor(scan[i], 0., 0., 0.); + setcolor(scan[x], 0., 0., 0.); continue; } - b = BLw(Lw); - mult = (Lb(b) - ldmin)/(ldmax - ldmin) / (Lw*inpexp); + b = BLw(Lw); /* apply brightness mapping */ + mult = (Lb(b) - ldmin)/(ldmax - ldmin)/(Lw*inpexp); if (lumf == rgblum) mult *= WHTEFFICACY; - scalecolor(scan[i], mult); + scalecolor(scan[x], mult); } } -#ifdef DEBUG -doplots() /* generate debugging plots */ +void +putmapping( /* put out mapping function */ + FILE *fp +) { - double T, b, s; - FILE *fp; - char fname[128]; - register int i; + double b, s; + int i; + double wlum, sf, dlum; - T = histot * (bwmax - bwmin) / HISTRES; + sf = scalef*inpexp; + if (lumf == cielum) sf *= WHTEFFICACY; s = (bwmax - bwmin)/HISTRES; - - sprintf(fname, "%s_hist.plt", infn); - if ((fp = fopen(fname, "w")) == NULL) - syserror(fname); - fputs("include=curve.plt\n", fp); - fputs("title=\"Brightness Frequency Distribution\"\n", fp); - fprintf(fp, "subtitle=%s\n", infn); - fputs("ymin=0\n", fp); - fputs("xlabel=\"Perceptual Brightness B(Lw)\"\n", fp); - fputs("ylabel=\"Frequency Count\"\n", fp); - fputs("Alabel=\"Histogram\"\n", fp); - fputs("Alintype=0\n", fp); - fputs("Blabel=\"Envelope\"\n", fp); - fputs("Bsymsize=0\n", fp); - fputs("Adata=\n", fp); - for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) - fprintf(fp, "\t%f %d\n", b, modhist[i]); - fputs(";\nBdata=\n", fp); - for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) - fprintf(fp, "\t%f %f\n", b, T*clampf(Lb(b))); - fputs(";\n", fp); - fclose(fp); + for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { + wlum = Lb(b); + if (what2do&DO_LINEAR) { + dlum = sf*wlum; + if (dlum > ldmax) dlum = ldmax; + else if (dlum < ldmin) dlum = ldmin; + fprintf(fp, "%e %e\n", wlum, dlum); + } else + fprintf(fp, "%e %e\n", wlum, Lb(BLw(wlum))); + } } -#endif
