--- ray/src/px/pcond3.c 2017/11/30 18:43:05 3.17 +++ ray/src/px/pcond3.c 2024/09/11 18:56:12 3.20 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pcond3.c,v 3.17 2017/11/30 18:43:05 greg Exp $"; +static const char RCSid[] = "$Id: pcond3.c,v 3.20 2024/09/11 18:56:12 greg Exp $"; #endif /* * Routines for computing and applying brightness mapping. @@ -8,6 +8,7 @@ static const char RCSid[] = "$Id: pcond3.c,v 3.17 2017 #include #include "pcond.h" +#include "random.h" #define CVRATIO 0.025 /* fraction of samples allowed > env. */ @@ -19,10 +20,11 @@ double modhist[HISTRES]; /* modified histogram */ double mhistot; /* modified histogram total */ double cumf[HISTRES+1]; /* cumulative distribution function */ -static double centprob(int x, int y); +static double centprob(int x, int y); static void mkcumf(void); -static double cf(double b); -static double BLw(double Lw); +static double cf(double b); +static double BLw(double Lw); +static float *getlumsamp(int n); #if ADJ_VEIL static void mkcrfimage(void); #endif @@ -177,10 +179,55 @@ centprob( /* center-weighting probability function * } +static float * +getlumsamp(int n) /* get set of random point sample luminances */ +{ + float *ls = (float *)malloc(n*sizeof(float)); + COLR *cscan = (COLR *)malloc(scanlen(&inpres)*sizeof(COLR)); + long startpos = ftell(infp); + long npleft = (long)inpres.xr*inpres.yr; + int x; + + if ((ls == NULL) | (cscan == NULL)) + syserror("malloc"); + x = 0; /* read/convert samples */ + while (n > 0) { + COLOR col; + int sv = 0; + double rval, cumprob = 0; + + if (x <= 0 && fread2colrs(cscan, x=scanlen(&inpres), infp, + NCSAMP, WLPART) < 0) { + fprintf(stderr, "%s: %s: scanline read error\n", + progname, infn); + exit(1); + } + rval = frandom(); /* random distance to next sample */ + while ((cumprob += (1.-cumprob)*n/(npleft-sv)) < rval) + sv++; + if (x < ++sv) { /* out of pixels in this scanline */ + npleft -= x; + x = 0; + continue; + } + x -= sv; + colr_color(col, cscan[x]); + ls[--n] = plum(col); + npleft -= sv; + } + free(cscan); /* clean up and reset file pointer */ + if (fseek(infp, startpos, SEEK_SET) < 0) + syserror("fseek"); + return(ls); +} + + void comphist(void) /* create foveal sampling histogram */ { double l, b, w, lwmin, lwmax; + float *lumsamp; + int nlumsamp; int x, y; /* check for precalculated histogram */ if (what2do&DO_PREHIST) @@ -193,6 +240,16 @@ comphist(void) /* create foveal sampling histogram * if (l < lwmin) lwmin = l; if (l > lwmax) lwmax = l; } + /* sample luminance pixels */ + nlumsamp = fvxr*fvyr*16; + if (nlumsamp > inpres.xr*inpres.yr) + nlumsamp = inpres.xr*inpres.yr; + lumsamp = getlumsamp(nlumsamp); + for (x = nlumsamp; x--; ) { + l = lumsamp[x]; + if (l < lwmin) lwmin = l; + if (l > lwmax) lwmax = l; + } lwmax *= 1.01; if (lwmax > LMAX) lwmax = LMAX; @@ -207,10 +264,9 @@ comphist(void) /* create foveal sampling histogram * /* (re)compute histogram */ bwavg = 0.; histot = 0.; - for (x = 0; x < HISTRES; x++) - bwhist[x] = 0.; + memset(bwhist, 0, sizeof(bwhist)); /* global average */ - if (!(what2do&DO_FIXHIST) || fixfrac < 1.-FTINY) + if (!(what2do&DO_FIXHIST) || fixfrac < 1.-FTINY) { for (y = 0; y < fvyr; y++) for (x = 0; x < fvxr; x++) { l = plum(fovscan(y)[x]); @@ -222,6 +278,18 @@ comphist(void) /* create foveal sampling histogram * bwhist[bwhi(b)] += w; histot += w; } + /* weight for point luminances */ + w = 1. * histot / nlumsamp; + for (x = nlumsamp; x--; ) { + l = lumsamp[x]; + if (l < lwmin+FTINY) continue; + if (l >= lwmax-FTINY) continue; + b = Bl(l); + bwavg += w*b; + bwhist[bwhi(b)] += w; + histot += w; + } + } /* average fixation points */ if (what2do&DO_FIXHIST && nfixations > 0) { if (histot > FTINY) @@ -243,6 +311,7 @@ comphist(void) /* create foveal sampling histogram * bwhist[1] *= 0.5; bwhist[0] += bwhist[1]; } + free(lumsamp); } @@ -391,7 +460,7 @@ mkbrmap(void) /* make dynamic range map */ modhist[i] = ceiling; } } - } while (trimmings > histot*CVRATIO); + } while (trimmings > mhistot*CVRATIO); #if ADJ_VEIL mkcrfimage(); /* contrast reduction image */
