| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pcond3.c,v 3.14 2003/06/30 14:59:12 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines for computing and applying brightness mapping.
| 6 |
| 7 |
| 8 |
#include <string.h>
| 9 |
| 10 |
#include "pcond.h"
| 11 |
| 12 |
| 13 |
#define CVRATIO 0.025 /* fraction of samples allowed > env. */
| 14 |
| 15 |
#define LN_10 2.30258509299404568402
| 16 |
#define exp10(x) exp(LN_10*(x))
| 17 |
| 18 |
double modhist[HISTRES]; /* modified histogram */
| 19 |
double mhistot; /* modified histogram total */
| 20 |
double cumf[HISTRES+1]; /* cumulative distribution function */
| 21 |
| 22 |
static double centprob(int x, int y);
| 23 |
static void mkcumf(void);
| 24 |
static double cf(double b);
| 25 |
static double BLw(double Lw);
| 26 |
#if ADJ_VEIL
| 27 |
static void mkcrfimage(void);
| 28 |
#endif
| 29 |
| 30 |
| 31 |
| 32 |
extern void
| 33 |
getfixations( /* load fixation history list */
| 34 |
FILE *fp
| 35 |
| 36 |
| 37 |
#define FIXHUNK 128
| 38 |
RESOLU fvres;
| 39 |
int pos[2];
| 40 |
register int px, py, i;
| 41 |
/* initialize our resolution struct */
| 42 |
if ((fvres.rt=inpres.rt)&YMAJOR) {
| 43 |
fvres.xr = fvxr;
| 44 |
fvres.yr = fvyr;
| 45 |
} else {
| 46 |
fvres.xr = fvyr;
| 47 |
fvres.yr = fvxr;
| 48 |
| 49 |
/* read each picture position */
| 50 |
while (fscanf(fp, "%d %d", &pos[0], &pos[1]) == 2) {
| 51 |
/* convert to closest index in foveal image */
| 52 |
loc2pix(pos, &fvres,
| 53 |
(pos[0]+.5)/inpres.xr, (pos[1]+.5)/inpres.yr);
| 54 |
/* include nine neighborhood samples */
| 55 |
for (px = pos[0]-1; px <= pos[0]+1; px++) {
| 56 |
if (px < 0 || px >= fvxr)
| 57 |
continue;
| 58 |
for (py = pos[1]-1; py <= pos[1]+1; py++) {
| 59 |
if (py < 0 || py >= fvyr)
| 60 |
continue;
| 61 |
for (i = nfixations; i-- > 0; )
| 62 |
if (fixlst[i][0] == px &&
| 63 |
fixlst[i][1] == py)
| 64 |
break;
| 65 |
if (i >= 0)
| 66 |
continue; /* already there */
| 67 |
if (nfixations % FIXHUNK == 0) {
| 68 |
if (nfixations)
| 69 |
fixlst = (short (*)[2])
| 70 |
realloc((void *)fixlst,
| 71 |
(nfixations+FIXHUNK)*
| 72 |
2*sizeof(short));
| 73 |
else
| 74 |
fixlst = (short (*)[2])malloc(
| 75 |
FIXHUNK*2*sizeof(short)
| 76 |
| 77 |
if (fixlst == NULL)
| 78 |
syserror("malloc");
| 79 |
| 80 |
fixlst[nfixations][0] = px;
| 81 |
fixlst[nfixations][1] = py;
| 82 |
nfixations++;
| 83 |
| 84 |
| 85 |
| 86 |
if (!feof(fp)) {
| 87 |
fprintf(stderr, "%s: format error reading fixation data\n",
| 88 |
progname);
| 89 |
exit(1);
| 90 |
| 91 |
#undef FIXHUNK
| 92 |
| 93 |
| 94 |
| 95 |
extern void
| 96 |
gethisto( /* load precomputed luminance histogram */
| 97 |
FILE *fp
| 98 |
| 99 |
| 100 |
double histo[MAXPREHIST];
| 101 |
double histart, histep;
| 102 |
double b, lastb, w;
| 103 |
int n;
| 104 |
register int i;
| 105 |
/* load data */
| 106 |
for (i = 0; i < MAXPREHIST &&
| 107 |
fscanf(fp, "%lf %lf", &b, &histo[i]) == 2; i++) {
| 108 |
if (i > 1 && fabs(b - lastb - histep) > .001) {
| 109 |
fprintf(stderr,
| 110 |
"%s: uneven step size in histogram data\n",
| 111 |
progname);
| 112 |
exit(1);
| 113 |
| 114 |
if (i == 1)
| 115 |
if ((histep = b - (histart = lastb)) <= FTINY) {
| 116 |
fprintf(stderr,
| 117 |
"%s: illegal step in histogram data\n",
| 118 |
progname);
| 119 |
exit(1);
| 120 |
| 121 |
lastb = b;
| 122 |
| 123 |
if (i < 2 || !feof(fp)) {
| 124 |
fprintf(stderr,
| 125 |
"%s: format/length error loading histogram (log10L %f at %d)\n",
| 126 |
progname, b, i);
| 127 |
exit(1);
| 128 |
| 129 |
n = i;
| 130 |
histart *= LN_10;
| 131 |
histep *= LN_10;
| 132 |
/* find extrema */
| 133 |
for (i = 0; i < n && histo[i] <= FTINY; i++)
| 134 |
| 135 |
bwmin = histart + (i-.001)*histep;
| 136 |
for (i = n; i-- && histo[i] <= FTINY; )
| 137 |
| 138 |
bwmax = histart + (i+1.001)*histep;
| 139 |
if (bwmax > Bl(LMAX))
| 140 |
bwmax = Bl(LMAX);
| 141 |
if (bwmin < Bl(LMIN))
| 142 |
bwmin = Bl(LMIN);
| 143 |
else /* duplicate bottom bin */
| 144 |
bwmin = bwmax - (bwmax-bwmin)*HISTRES/(HISTRES-1);
| 145 |
/* convert histogram */
| 146 |
bwavg = 0.; histot = 0.;
| 147 |
for (i = 0; i < HISTRES; i++)
| 148 |
bwhist[i] = 0.;
| 149 |
for (i = 0, b = histart; i < n; i++, b += histep) {
| 150 |
if (b < bwmin+FTINY) continue;
| 151 |
if (b >= bwmax-FTINY) break;
| 152 |
w = histo[i];
| 153 |
bwavg += w*b;
| 154 |
bwhist[bwhi(b)] += w;
| 155 |
histot += w;
| 156 |
| 157 |
bwavg /= histot;
| 158 |
if (bwmin > Bl(LMIN)+FTINY) { /* add false samples at bottom */
| 159 |
bwhist[1] *= 0.5;
| 160 |
bwhist[0] += bwhist[1];
| 161 |
| 162 |
| 163 |
| 164 |
| 165 |
static double
| 166 |
centprob( /* center-weighting probability function */
| 167 |
int x,
| 168 |
int y
| 169 |
| 170 |
| 171 |
double xr, yr, p;
| 172 |
/* paraboloid, 0 at 90 degrees from center */
| 173 |
xr = (x - .5*(fvxr-1))/90.; /* 180 degree fisheye has fv?r == 90 */
| 174 |
yr = (y - .5*(fvyr-1))/90.;
| 175 |
p = 1. - xr*xr - yr*yr;
| 176 |
return(p < 0. ? 0. : p);
| 177 |
| 178 |
| 179 |
| 180 |
extern void
| 181 |
comphist(void) /* create foveal sampling histogram */
| 182 |
| 183 |
double l, b, w, lwmin, lwmax;
| 184 |
register int x, y;
| 185 |
/* check for precalculated histogram */
| 186 |
if (what2do&DO_PREHIST)
| 187 |
return;
| 188 |
lwmin = 1e10; /* find extrema */
| 189 |
lwmax = 0.;
| 190 |
for (y = 0; y < fvyr; y++)
| 191 |
for (x = 0; x < fvxr; x++) {
| 192 |
l = plum(fovscan(y)[x]);
| 193 |
if (l < lwmin) lwmin = l;
| 194 |
if (l > lwmax) lwmax = l;
| 195 |
| 196 |
lwmax *= 1.01;
| 197 |
if (lwmax > LMAX)
| 198 |
lwmax = LMAX;
| 199 |
bwmax = Bl(lwmax);
| 200 |
if (lwmin < LMIN) {
| 201 |
lwmin = LMIN;
| 202 |
bwmin = Bl(LMIN);
| 203 |
} else { /* duplicate bottom bin */
| 204 |
bwmin = bwmax - (bwmax-Bl(lwmin))*HISTRES/(HISTRES-1);
| 205 |
lwmin = Lb(bwmin);
| 206 |
| 207 |
/* (re)compute histogram */
| 208 |
bwavg = 0.;
| 209 |
histot = 0.;
| 210 |
for (x = 0; x < HISTRES; x++)
| 211 |
bwhist[x] = 0.;
| 212 |
/* global average */
| 213 |
if (!(what2do&DO_FIXHIST) || fixfrac < 1.-FTINY)
| 214 |
| 215 |
| 216 |
| 217 |
if (l < lwmin+FTINY) continue;
| 218 |
if (l >= lwmax-FTINY) continue;
| 219 |
b = Bl(l);
| 220 |
w = what2do&DO_CWEIGHT ? centprob(x,y) : 1.;
| 221 |
bwavg += w*b;
| 222 |
| 223 |
histot += w;
| 224 |
| 225 |
/* average fixation points */
| 226 |
if (what2do&DO_FIXHIST && nfixations > 0) {
| 227 |
if (histot > FTINY)
| 228 |
w = fixfrac/(1.-fixfrac)*histot/nfixations;
| 229 |
else
| 230 |
w = 1.;
| 231 |
for (x = 0; x < nfixations; x++) {
| 232 |
l = plum(fovscan(fixlst[x][1])[fixlst[x][0]]);
| 233 |
| 234 |
| 235 |
b = Bl(l);
| 236 |
bwavg += w*b;
| 237 |
| 238 |
histot += w;
| 239 |
| 240 |
| 241 |
bwavg /= histot;
| 242 |
if (lwmin > LMIN+FTINY) { /* add false samples at bottom */
| 243 |
bwhist[1] *= 0.5;
| 244 |
| 245 |
| 246 |
| 247 |
| 248 |
| 249 |
static void
| 250 |
mkcumf(void) /* make cumulative distribution function */
| 251 |
| 252 |
register int i;
| 253 |
register double sum;
| 254 |
| 255 |
mhistot = 0.; /* compute modified total */
| 256 |
| 257 |
mhistot += modhist[i];
| 258 |
| 259 |
sum = 0.; /* compute cumulative function */
| 260 |
for (i = 0; i < HISTRES; i++) {
| 261 |
cumf[i] = sum/mhistot;
| 262 |
sum += modhist[i];
| 263 |
| 264 |
cumf[HISTRES] = 1.;
| 265 |
| 266 |
| 267 |
| 268 |
static double
| 269 |
cf( /* return cumulative function at b */
| 270 |
double b
| 271 |
| 272 |
| 273 |
double x;
| 274 |
register int i;
| 275 |
| 276 |
i = x = HISTRES*(b - bwmin)/(bwmax - bwmin);
| 277 |
x -= (double)i;
| 278 |
return(cumf[i]*(1.-x) + cumf[i+1]*x);
| 279 |
| 280 |
| 281 |
| 282 |
static double
| 283 |
BLw( /* map world luminance to display brightness */
| 284 |
double Lw
| 285 |
| 286 |
| 287 |
double b;
| 288 |
| 289 |
if (Lw <= LMIN || (b = Bl(Lw)) <= bwmin+FTINY)
| 290 |
return(Bldmin);
| 291 |
| 292 |
return(Bldmax);
| 293 |
return(Bldmin + cf(b)*(Bldmax-Bldmin));
| 294 |
| 295 |
| 296 |
| 297 |
extern double
| 298 |
htcontrs( /* human threshold contrast sensitivity, dL(La) */
| 299 |
double La
| 300 |
| 301 |
| 302 |
double l10La, l10dL;
| 303 |
/* formula taken from Ferwerda et al. [SG96] */
| 304 |
if (La < 1.148e-4)
| 305 |
return(1.38e-3);
| 306 |
l10La = log10(La);
| 307 |
if (l10La < -1.44) /* rod response regime */
| 308 |
l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
| 309 |
else if (l10La < -.0184)
| 310 |
l10dL = l10La - .395;
| 311 |
else if (l10La < 1.9) /* cone response regime */
| 312 |
l10dL = pow(.249*l10La + .65, 2.7) - .72;
| 313 |
else
| 314 |
l10dL = l10La - 1.255;
| 315 |
| 316 |
return(exp10(l10dL));
| 317 |
| 318 |
| 319 |
| 320 |
extern double
| 321 |
clampf( /* histogram clamping function */
| 322 |
double Lw
| 323 |
| 324 |
| 325 |
double bLw, ratio;
| 326 |
| 327 |
bLw = BLw(Lw); /* apply current brightness map */
| 328 |
ratio = what2do&DO_HSENS ? htcontrs(Lb(bLw))/htcontrs(Lw) : Lb(bLw)/Lw;
| 329 |
return(ratio/(Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw)));
| 330 |
| 331 |
| 332 |
extern double
| 333 |
crfactor( /* contrast reduction factor */
| 334 |
double Lw
| 335 |
| 336 |
| 337 |
int i = HISTRES*(Bl(Lw) - bwmin)/(bwmax - bwmin);
| 338 |
double bLw, ratio, Tdb;
| 339 |
| 340 |
if (i <= 0)
| 341 |
return(1.0);
| 342 |
if (i >= HISTRES)
| 343 |
return(1.0);
| 344 |
bLw = BLw(Lw);
| 345 |
| 346 |
Tdb = mhistot * (bwmax - bwmin) / HISTRES;
| 347 |
return(modhist[i]*Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw)/(Tdb*ratio));
| 348 |
| 349 |
| 350 |
| 351 |
#if ADJ_VEIL
| 352 |
static void
| 353 |
mkcrfimage(void) /* compute contrast reduction factor image */
| 354 |
| 355 |
int i;
| 356 |
float *crfptr;
| 357 |
COLOR *fovptr;
| 358 |
| 359 |
if (crfimg == NULL)
| 360 |
crfimg = (float *)malloc(fvxr*fvyr*sizeof(float));
| 361 |
if (crfimg == NULL)
| 362 |
syserror("malloc");
| 363 |
crfptr = crfimg;
| 364 |
fovptr = fovimg;
| 365 |
for (i = fvxr*fvyr; i--; crfptr++, fovptr++)
| 366 |
crfptr[0] = crfactor(plum(fovptr[0]));
| 367 |
| 368 |
#endif
| 369 |
| 370 |
| 371 |
extern int
| 372 |
mkbrmap(void) /* make dynamic range map */
| 373 |
| 374 |
double Tdb, b, s;
| 375 |
double ceiling, trimmings;
| 376 |
register int i;
| 377 |
/* copy initial histogram */
| 378 |
memcpy((void *)modhist, (void *)bwhist, sizeof(modhist));
| 379 |
s = (bwmax - bwmin)/HISTRES; /* s is delta b */
| 380 |
/* loop until satisfactory */
| 381 |
do {
| 382 |
mkcumf(); /* sync brightness mapping */
| 383 |
if (mhistot <= histot*CVRATIO)
| 384 |
return(-1); /* no compression needed! */
| 385 |
Tdb = mhistot * s;
| 386 |
trimmings = 0.; /* clip to envelope */
| 387 |
for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) {
| 388 |
ceiling = Tdb*clampf(Lb(b));
| 389 |
if (modhist[i] > ceiling) {
| 390 |
trimmings += modhist[i] - ceiling;
| 391 |
modhist[i] = ceiling;
| 392 |
| 393 |
| 394 |
} while (trimmings > histot*CVRATIO);
| 395 |
| 396 |
#if ADJ_VEIL
| 397 |
mkcrfimage(); /* contrast reduction image */
| 398 |
#endif
| 399 |
| 400 |
return(0); /* we got it */
| 401 |
| 402 |
| 403 |
| 404 |
extern void
| 405 |
scotscan( /* apply scotopic color sensitivity loss */
| 406 |
COLOR *scan,
| 407 |
int xres
| 408 |
| 409 |
| 410 |
COLOR ctmp;
| 411 |
double incolor, b, Lw;
| 412 |
register int i;
| 413 |
| 414 |
for (i = 0; i < xres; i++) {
| 415 |
Lw = plum(scan[i]);
| 416 |
if (Lw >= TopMesopic)
| 417 |
incolor = 1.;
| 418 |
else if (Lw <= BotMesopic)
| 419 |
incolor = 0.;
| 420 |
else
| 421 |
incolor = (Lw - BotMesopic) /
| 422 |
(TopMesopic - BotMesopic);
| 423 |
if (incolor < 1.-FTINY) {
| 424 |
b = (1.-incolor)*slum(scan[i])*inpexp/SWNORM;
| 425 |
if (lumf == rgblum) b /= WHTEFFICACY;
| 426 |
setcolor(ctmp, b, b, b);
| 427 |
if (incolor <= FTINY)
| 428 |
setcolor(scan[i], 0., 0., 0.);
| 429 |
else
| 430 |
scalecolor(scan[i], incolor);
| 431 |
addcolor(scan[i], ctmp);
| 432 |
| 433 |
| 434 |
| 435 |
| 436 |
| 437 |
extern void
| 438 |
mapscan( /* apply tone mapping operator to scanline */
| 439 |
COLOR *scan,
| 440 |
int xres
| 441 |
| 442 |
| 443 |
double mult, Lw, b;
| 444 |
register int x;
| 445 |
| 446 |
for (x = 0; x < xres; x++) {
| 447 |
Lw = plum(scan[x]);
| 448 |
if (Lw < LMIN) {
| 449 |
setcolor(scan[x], 0., 0., 0.);
| 450 |
continue;
| 451 |
| 452 |
b = BLw(Lw); /* apply brightness mapping */
| 453 |
mult = (Lb(b) - ldmin)/(ldmax - ldmin)/(Lw*inpexp);
| 454 |
if (lumf == rgblum) mult *= WHTEFFICACY;
| 455 |
scalecolor(scan[x], mult);
| 456 |
| 457 |
| 458 |
| 459 |
| 460 |
extern void
| 461 |
putmapping( /* put out mapping function */
| 462 |
FILE *fp
| 463 |
| 464 |
| 465 |
double b, s;
| 466 |
register int i;
| 467 |
double wlum, sf, dlum;
| 468 |
| 469 |
sf = scalef*inpexp;
| 470 |
if (lumf == cielum) sf *= WHTEFFICACY;
| 471 |
| 472 |
| 473 |
wlum = Lb(b);
| 474 |
if (what2do&DO_LINEAR) {
| 475 |
dlum = sf*wlum;
| 476 |
if (dlum > ldmax) dlum = ldmax;
| 477 |
else if (dlum < ldmin) dlum = ldmin;
| 478 |
fprintf(fp, "%e %e\n", wlum, dlum);
| 479 |
} else
| 480 |
fprintf(fp, "%e %e\n", wlum, Lb(BLw(wlum)));
| 481 |
| 482 |
