--- ray/src/px/pcond3.c 1997/01/29 13:22:13 3.8 +++ ray/src/px/pcond3.c 2003/05/13 17:58:33 3.13 @@ -1,9 +1,6 @@ -/* Copyright (c) 1997 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pcond3.c,v 3.13 2003/05/13 17:58:33 greg Exp $"; #endif - /* * Routines for computing and applying brightness mapping. */ @@ -13,11 +10,12 @@ static char SCCSid[] = "$SunId$ LBL"; #define CVRATIO 0.025 /* fraction of samples allowed > env. */ -#define exp10(x) exp(2.302585093*(x)) +#define LN_10 2.30258509299404568402 +#define exp10(x) exp(LN_10*(x)) -float modhist[HISTRES]; /* modified histogram */ +double modhist[HISTRES]; /* modified histogram */ double mhistot; /* modified histogram total */ -float cumf[HISTRES+1]; /* cumulative distribution function */ +double cumf[HISTRES+1]; /* cumulative distribution function */ getfixations(fp) /* load fixation history list */ @@ -28,7 +26,7 @@ FILE *fp; int pos[2]; register int px, py, i; /* initialize our resolution struct */ - if ((fvres.or=inpres.or)&YMAJOR) { + if ((fvres.rt=inpres.rt)&YMAJOR) { fvres.xr = fvxr; fvres.yr = fvyr; } else { @@ -56,7 +54,7 @@ FILE *fp; if (nfixations % FIXHUNK == 0) { if (nfixations) fixlst = (short (*)[2]) - realloc((char *)fixlst, + realloc((void *)fixlst, (nfixations+FIXHUNK)* 2*sizeof(short)); else @@ -81,6 +79,74 @@ FILE *fp; } +gethisto(fp) /* load precomputed luminance histogram */ +FILE *fp; +{ + double histo[MAXPREHIST]; + double histart, histep; + double l, b, lastb, w; + int n; + register int i; + /* load data */ + for (i = 0; i < MAXPREHIST && + fscanf(fp, "%lf %lf", &b, &histo[i]) == 2; i++) { + if (i > 1 && fabs(b - lastb - histep) > .001) { + fprintf(stderr, + "%s: uneven step size in histogram data\n", + progname); + exit(1); + } + if (i == 1) + if ((histep = b - (histart = lastb)) <= FTINY) { + fprintf(stderr, + "%s: illegal step in histogram data\n", + progname); + exit(1); + } + lastb = b; + } + if (i < 2 || !feof(fp)) { + fprintf(stderr, + "%s: format/length error loading histogram (log10L %f at %d)\n", + progname, b, i); + exit(1); + } + n = i; + histart *= LN_10; + histep *= LN_10; + /* find extrema */ + for (i = 0; i < n && histo[i] <= FTINY; i++) + ; + bwmin = histart + (i-.001)*histep; + for (i = n; i-- && histo[i] <= FTINY; ) + ; + bwmax = histart + (i+1.001)*histep; + if (bwmax > Bl(LMAX)) + bwmax = Bl(LMAX); + if (bwmin < Bl(LMIN)) + bwmin = Bl(LMIN); + else /* duplicate bottom bin */ + bwmin = bwmax - (bwmax-bwmin)*HISTRES/(HISTRES-1); + /* convert histogram */ + bwavg = 0.; histot = 0.; + for (i = 0; i < HISTRES; i++) + bwhist[i] = 0.; + for (i = 0, b = histart; i < n; i++, b += histep) { + if (b < bwmin+FTINY) continue; + if (b >= bwmax-FTINY) break; + w = histo[i]; + bwavg += w*b; + bwhist[bwhi(b)] += w; + histot += w; + } + bwavg /= histot; + if (bwmin > Bl(LMIN)+FTINY) { /* add false samples at bottom */ + bwhist[1] *= 0.5; + bwhist[0] += bwhist[1]; + } +} + + double centprob(x, y) /* center-weighting probability function */ int x, y; @@ -98,7 +164,9 @@ comphist() /* create foveal sampling histogram */ { double l, b, w, lwmin, lwmax; register int x, y; - + /* check for precalculated histogram */ + if (what2do&DO_PREHIST) + return; lwmin = 1e10; /* find extrema */ lwmax = 0.; for (y = 0; y < fvyr; y++) @@ -107,12 +175,17 @@ comphist() /* create foveal sampling histogram */ if (l < lwmin) lwmin = l; if (l > lwmax) lwmax = l; } - lwmin -= FTINY; - lwmax += FTINY; - if (lwmin < LMIN) lwmin = LMIN; - if (lwmax > LMAX) lwmax = LMAX; - bwmin = Bl(lwmin); + lwmax *= 1.01; + if (lwmax > LMAX) + lwmax = LMAX; bwmax = Bl(lwmax); + if (lwmin < LMIN) { + lwmin = LMIN; + bwmin = Bl(LMIN); + } else { /* duplicate bottom bin */ + bwmin = bwmax - (bwmax-Bl(lwmin))*HISTRES/(HISTRES-1); + lwmin = Lb(bwmin); + } /* (re)compute histogram */ bwavg = 0.; histot = 0.; @@ -123,11 +196,11 @@ comphist() /* create foveal sampling histogram */ for (y = 0; y < fvyr; y++) for (x = 0; x < fvxr; x++) { l = plum(fovscan(y)[x]); - if (l < lwmin) continue; - if (l > lwmax) continue; + if (l < lwmin+FTINY) continue; + if (l >= lwmax-FTINY) continue; b = Bl(l); - bwavg += b; w = what2do&DO_CWEIGHT ? centprob(x,y) : 1.; + bwavg += w*b; bwhist[bwhi(b)] += w; histot += w; } @@ -139,15 +212,19 @@ comphist() /* create foveal sampling histogram */ w = 1.; for (x = 0; x < nfixations; x++) { l = plum(fovscan(fixlst[x][1])[fixlst[x][0]]); - if (l < lwmin) continue; - if (l > lwmax) continue; + if (l < lwmin+FTINY) continue; + if (l >= lwmax-FTINY) continue; b = Bl(l); - bwavg += b; + bwavg += w*b; bwhist[bwhi(b)] += w; histot += w; } } bwavg /= histot; + if (lwmin > LMIN+FTINY) { /* add false samples at bottom */ + bwhist[1] *= 0.5; + bwhist[0] += bwhist[1]; + } } @@ -219,7 +296,7 @@ double La; double -clampf(Lw) /* derivative clamping function */ +clampf(Lw) /* histogram clamping function */ double Lw; { double bLw, ratio; @@ -229,25 +306,61 @@ double Lw; return(ratio/(Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw))); } +double +crfactor(Lw) /* contrast reduction factor */ +double Lw; +{ + int i = HISTRES*(Bl(Lw) - bwmin)/(bwmax - bwmin); + double bLw, ratio, Tdb; + if (i <= 0) + return(1.0); + if (i >= HISTRES) + return(1.0); + bLw = BLw(Lw); + ratio = what2do&DO_HSENS ? htcontrs(Lb(bLw))/htcontrs(Lw) : Lb(bLw)/Lw; + Tdb = mhistot * (bwmax - bwmin) / HISTRES; + return(modhist[i]*Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw)/(Tdb*ratio)); +} + + +#if ADJ_VEIL +mkcrfimage() /* compute contrast reduction factor image */ +{ + int i; + float *crfptr; + COLOR *fovptr; + + if (crfimg == NULL) + crfimg = (float *)malloc(fvxr*fvyr*sizeof(float)); + if (crfimg == NULL) + syserror("malloc"); + crfptr = crfimg; + fovptr = fovimg; + for (i = fvxr*fvyr; i--; crfptr++, fovptr++) + crfptr[0] = crfactor(plum(fovptr[0])); +} +#endif + + int mkbrmap() /* make dynamic range map */ { - double T, b, s; + double Tdb, b, s; double ceiling, trimmings; register int i; /* copy initial histogram */ - bcopy((char *)bwhist, (char *)modhist, sizeof(modhist)); - s = (bwmax - bwmin)/HISTRES; + bcopy((void *)bwhist, (void *)modhist, sizeof(modhist)); + s = (bwmax - bwmin)/HISTRES; /* s is delta b */ /* loop until satisfactory */ do { mkcumf(); /* sync brightness mapping */ if (mhistot <= histot*CVRATIO) return(-1); /* no compression needed! */ - T = mhistot * (bwmax - bwmin) / HISTRES; + Tdb = mhistot * s; trimmings = 0.; /* clip to envelope */ for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { - ceiling = T*clampf(Lb(b)); + ceiling = Tdb*clampf(Lb(b)); if (modhist[i] > ceiling) { trimmings += modhist[i] - ceiling; modhist[i] = ceiling; @@ -255,6 +368,10 @@ mkbrmap() /* make dynamic range map */ } } while (trimmings > histot*CVRATIO); +#if ADJ_VEIL + mkcrfimage(); /* contrast reduction image */ +#endif + return(0); /* we got it */ } @@ -295,18 +412,18 @@ COLOR *scan; int xres; { double mult, Lw, b; - register int i; + register int x; - for (i = 0; i < xres; i++) { - Lw = plum(scan[i]); + for (x = 0; x < xres; x++) { + Lw = plum(scan[x]); if (Lw < LMIN) { - setcolor(scan[i], 0., 0., 0.); + setcolor(scan[x], 0., 0., 0.); continue; } - b = BLw(Lw); - mult = (Lb(b) - ldmin)/(ldmax - ldmin) / (Lw*inpexp); + b = BLw(Lw); /* apply brightness mapping */ + mult = (Lb(b) - ldmin)/(ldmax - ldmin)/(Lw*inpexp); if (lumf == rgblum) mult *= WHTEFFICACY; - scalecolor(scan[i], mult); + scalecolor(scan[x], mult); } }
