root/radiance/ray/src/px/pcond3.c
CVS Tags: rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Changes since 3.14: +66 -37 lines
Diff to previous 3.14 , to selected 3.1
Changes since 3.13: +4 -2 lines
Diff to previous 3.13 , to selected 3.1
Tue May 13 17:58:33 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.12: +1 -1 lines
Diff to previous 3.12 , to selected 3.1
Changes since 3.11: +1 -1 lines
Diff to previous 3.11 , to selected 3.1
Changes since 3.10: +73 -31 lines
Diff to previous 3.10 , to selected 3.1
Thu Mar 12 15:47:34 1998 UTC (26 years, 1 month ago) by gwlarson
Changes since 3.9: +70 -4 lines
Diff to previous 3.9 , to selected 3.1
added -I option for precomputed histogram
Fri Apr 11 18:34:39 1997 UTC (27 years ago) by greg
Changes since 3.8: +14 -5 lines
Diff to previous 3.8 , to selected 3.1
added an extra histogram bin at lower limit to avoid clipping
Wed Jan 29 13:22:13 1997 UTC (27 years, 3 months ago) by greg
Changes since 3.7: +131 -0 lines
Diff to previous 3.7 , to selected 3.1
added -i option to take fixation points on standard input
Sat Jan 11 10:39:25 1997 UTC (27 years, 3 months ago) by greg
Changes since 3.6: +8 -5 lines
Diff to previous 3.6 , to selected 3.1
fixed writing of linear ramp with -m option
Fri Jan 10 16:48:21 1997 UTC (27 years, 3 months ago) by greg
Changes since 3.5: +0 -10 lines
Diff to previous 3.5 , to selected 3.1
removed shiftdir() function, which is no longer needed
Thu Jan 9 13:56:30 1997 UTC (27 years, 3 months ago) by greg
Changes since 3.4: +27 -84 lines
Diff to previous 3.4 , to selected 3.1
Wed Jan 8 17:57:01 1997 UTC (27 years, 3 months ago) by greg
Changes since 3.3: +21 -1 lines
Diff to previous 3.3 , to selected 3.1
added -m option to print out mapping function
Fri Oct 11 10:47:00 1996 UTC (27 years, 6 months ago) by greg
Changes since 3.2: +0 -3 lines
Diff to previous 3.2 , to selected 3.1
corrected tests in check2do()
Thu Oct 10 17:09:26 1996 UTC (27 years, 6 months ago) by greg
Changes since 3.1: +3 -3 lines
fixed bugs in color scaling
Revision 3.1 - (view) (download) (annotate) - [selected]
Thu Oct 3 16:52:50 1996 UTC (27 years, 7 months ago) by greg
