--- ray/src/px/pcond3.c 1996/10/11 10:47:00 3.3 +++ ray/src/px/pcond3.c 1997/01/29 13:22:13 3.8 @@ -1,4 +1,4 @@ -/* Copyright (c) 1996 Regents of the University of California */ +/* Copyright (c) 1997 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -11,23 +11,158 @@ static char SCCSid[] = "$SunId$ LBL"; #include "pcond.h" -#define CVRATIO 0.025 /* fraction of pixels allowed > env. */ +#define CVRATIO 0.025 /* fraction of samples allowed > env. */ #define exp10(x) exp(2.302585093*(x)) -int modhist[HISTRES]; /* modified histogram */ +float modhist[HISTRES]; /* modified histogram */ +double mhistot; /* modified histogram total */ float cumf[HISTRES+1]; /* cumulative distribution function */ +getfixations(fp) /* load fixation history list */ +FILE *fp; +{ +#define FIXHUNK 128 + RESOLU fvres; + int pos[2]; + register int px, py, i; + /* initialize our resolution struct */ + if ((fvres.or=inpres.or)&YMAJOR) { + fvres.xr = fvxr; + fvres.yr = fvyr; + } else { + fvres.xr = fvyr; + fvres.yr = fvxr; + } + /* read each picture position */ + while (fscanf(fp, "%d %d", &pos[0], &pos[1]) == 2) { + /* convert to closest index in foveal image */ + loc2pix(pos, &fvres, + (pos[0]+.5)/inpres.xr, (pos[1]+.5)/inpres.yr); + /* include nine neighborhood samples */ + for (px = pos[0]-1; px <= pos[0]+1; px++) { + if (px < 0 || px >= fvxr) + continue; + for (py = pos[1]-1; py <= pos[1]+1; py++) { + if (py < 0 || py >= fvyr) + continue; + for (i = nfixations; i-- > 0; ) + if (fixlst[i][0] == px && + fixlst[i][1] == py) + break; + if (i >= 0) + continue; /* already there */ + if (nfixations % FIXHUNK == 0) { + if (nfixations) + fixlst = (short (*)[2]) + realloc((char *)fixlst, + (nfixations+FIXHUNK)* + 2*sizeof(short)); + else + fixlst = (short (*)[2])malloc( + FIXHUNK*2*sizeof(short) + ); + if (fixlst == NULL) + syserror("malloc"); + } + fixlst[nfixations][0] = px; + fixlst[nfixations][1] = py; + nfixations++; + } + } + } + if (!feof(fp)) { + fprintf(stderr, "%s: format error reading fixation data\n", + progname); + exit(1); + } +#undef FIXHUNK +} + + +double +centprob(x, y) /* center-weighting probability function */ +int x, y; +{ + double xr, yr, p; + /* paraboloid, 0 at 90 degrees from center */ + xr = (x - .5*(fvxr-1))/90.; /* 180 degree fisheye has fv?r == 90 */ + yr = (y - .5*(fvyr-1))/90.; + p = 1. - xr*xr - yr*yr; + return(p < 0. ? 0. : p); +} + + +comphist() /* create foveal sampling histogram */ +{ + double l, b, w, lwmin, lwmax; + register int x, y; + + lwmin = 1e10; /* find extrema */ + lwmax = 0.; + for (y = 0; y < fvyr; y++) + for (x = 0; x < fvxr; x++) { + l = plum(fovscan(y)[x]); + if (l < lwmin) lwmin = l; + if (l > lwmax) lwmax = l; + } + lwmin -= FTINY; + lwmax += FTINY; + if (lwmin < LMIN) lwmin = LMIN; + if (lwmax > LMAX) lwmax = LMAX; + bwmin = Bl(lwmin); + bwmax = Bl(lwmax); + /* (re)compute histogram */ + bwavg = 0.; + histot = 0.; + for (x = 0; x < HISTRES; x++) + bwhist[x] = 0.; + /* global average */ + if (!(what2do&DO_FIXHIST) || fixfrac < 1.-FTINY) + for (y = 0; y < fvyr; y++) + for (x = 0; x < fvxr; x++) { + l = plum(fovscan(y)[x]); + if (l < lwmin) continue; + if (l > lwmax) continue; + b = Bl(l); + bwavg += b; + w = what2do&DO_CWEIGHT ? centprob(x,y) : 1.; + bwhist[bwhi(b)] += w; + histot += w; + } + /* average fixation points */ + if (what2do&DO_FIXHIST && nfixations > 0) { + if (histot > FTINY) + w = fixfrac/(1.-fixfrac)*histot/nfixations; + else + w = 1.; + for (x = 0; x < nfixations; x++) { + l = plum(fovscan(fixlst[x][1])[fixlst[x][0]]); + if (l < lwmin) continue; + if (l > lwmax) continue; + b = Bl(l); + bwavg += b; + bwhist[bwhi(b)] += w; + histot += w; + } + } + bwavg /= histot; +} + + mkcumf() /* make cumulative distribution function */ { register int i; - register long sum; + register double sum; - cumf[0] = 0.; - sum = modhist[0]; - for (i = 1; i < HISTRES; i++) { - cumf[i] = (double)sum/histot; + mhistot = 0.; /* compute modified total */ + for (i = 0; i < HISTRES; i++) + mhistot += modhist[i]; + + sum = 0.; /* compute cumulative function */ + for (i = 0; i < HISTRES; i++) { + cumf[i] = sum/mhistot; sum += modhist[i]; } cumf[HISTRES] = 1.; @@ -57,7 +192,7 @@ double Lw; return(Bldmin); if (b >= bwmax-FTINY) return(Bldmax); - return(Bldmin + cf(Bl(Lw))*(Bldmax-Bldmin)); + return(Bldmin + cf(b)*(Bldmax-Bldmin)); } @@ -96,66 +231,31 @@ double Lw; int -shiftdir(bw) /* compute shift direction for histogram */ -double bw; -{ - if (what2do&DO_HSENS && cf(bw) - (bw - bwmin)/(Bldmax - bwmin)) - return(1); - return(-1); -} - - -int mkbrmap() /* make dynamic range map */ { - int hdiffs[HISTRES], above, below; double T, b, s; - int maxd, maxi, sd; + double ceiling, trimmings; register int i; /* copy initial histogram */ - for (i = 0; i < HISTRES; i++) - modhist[i] = bwhist[i]; - T = histot * (bwmax - bwmin) / HISTRES; + bcopy((char *)bwhist, (char *)modhist, sizeof(modhist)); s = (bwmax - bwmin)/HISTRES; /* loop until satisfactory */ - for ( ; ; ) { - mkcumf(); /* sync brightness mapping */ - above = below = 0; /* compute visibility overflow */ + do { + mkcumf(); /* sync brightness mapping */ + if (mhistot <= histot*CVRATIO) + return(-1); /* no compression needed! */ + T = mhistot * (bwmax - bwmin) / HISTRES; + trimmings = 0.; /* clip to envelope */ for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { - hdiffs[i] = modhist[i] - (int)(T*clampf(Lb(b)) + .5); - if (hdiffs[i] > 0) above += hdiffs[i]; - else below -= hdiffs[i]; + ceiling = T*clampf(Lb(b)); + if (modhist[i] > ceiling) { + trimmings += modhist[i] - ceiling; + modhist[i] = ceiling; + } } - if (above <= histot*CVRATIO) - break; /* close enough */ - if (above-below >= 0) - return(-1); /* Houston, we have a problem.... */ - /* original looped here as well (BEGIN_L2) */ - maxd = 0; /* find largest overvis */ - for (i = 0; i < HISTRES; i++) - if (hdiffs[i] > maxd) - maxd = hdiffs[maxi=i]; - /* broke loop here when (maxd == 0) (BREAK_L2) */ - for (sd = shiftdir((maxi+.5)/HISTRES*(bwmax-bwmin)+bwmin); - hdiffs[maxi] == maxd; sd = -sd) - for (i = maxi+sd; i >= 0 & i < HISTRES; i += sd) - if (hdiffs[i] < 0) { - if (hdiffs[i] <= -maxd) { - modhist[i] += maxd; - modhist[maxi] -= maxd; - hdiffs[i] += maxd; - hdiffs[maxi] = 0; - } else { - modhist[maxi] += hdiffs[i]; - modhist[i] -= hdiffs[i]; - hdiffs[maxi] += hdiffs[i]; - hdiffs[i] = 0; - } - break; - } - /* (END_L2) */ - } - return(0); + } while (trimmings > histot*CVRATIO); + + return(0); /* we got it */ } @@ -211,37 +311,24 @@ int xres; } -#ifdef DEBUG -doplots() /* generate debugging plots */ +putmapping(fp) /* put out mapping function */ +FILE *fp; { - double T, b, s; - FILE *fp; - char fname[128]; + double b, s; register int i; + double wlum, sf, dlum; - T = histot * (bwmax - bwmin) / HISTRES; + sf = scalef*inpexp; + if (lumf == cielum) sf *= WHTEFFICACY; s = (bwmax - bwmin)/HISTRES; - - sprintf(fname, "%s_hist.plt", infn); - if ((fp = fopen(fname, "w")) == NULL) - syserror(fname); - fputs("include=curve.plt\n", fp); - fputs("title=\"Brightness Frequency Distribution\"\n", fp); - fprintf(fp, "subtitle=%s\n", infn); - fputs("ymin=0\n", fp); - fputs("xlabel=\"Perceptual Brightness B(Lw)\"\n", fp); - fputs("ylabel=\"Frequency Count\"\n", fp); - fputs("Alabel=\"Histogram\"\n", fp); - fputs("Alintype=0\n", fp); - fputs("Blabel=\"Envelope\"\n", fp); - fputs("Bsymsize=0\n", fp); - fputs("Adata=\n", fp); - for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) - fprintf(fp, "\t%f %d\n", b, modhist[i]); - fputs(";\nBdata=\n", fp); - for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) - fprintf(fp, "\t%f %f\n", b, T*clampf(Lb(b))); - fputs(";\n", fp); - fclose(fp); + for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { + wlum = Lb(b); + if (what2do&DO_LINEAR) { + dlum = sf*wlum; + if (dlum > ldmax) dlum = ldmax; + else if (dlum < ldmin) dlum = ldmin; + fprintf(fp, "%e %e\n", wlum, dlum); + } else + fprintf(fp, "%e %e\n", wlum, Lb(BLw(wlum))); + } } -#endif
